    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      sigi234 Forum Testing Most Active @Guest last edited by
      @ciddi89
      Super, läuft mit HM.
      device-watcher.0
      2022-06-08 07:39:02.759	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      device-watcher.0
      2022-06-08 07:39:02.759	debug	all done, exiting
      device-watcher.0
      2022-06-08 07:39:02.758	debug	Function finished: main
      device-watcher.0
      2022-06-08 07:39:02.758	debug	write the datapoints finished main
      device-watcher.0
      2022-06-08 07:39:02.732	debug	write the datapoints main
      device-watcher.0
      2022-06-08 07:39:02.727	debug	[1,2,3,4,5,6,0]
      device-watcher.0
      2022-06-08 07:39:02.703	debug	{"hm-rpc.0.NEQ0007328.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645388,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714285},"hm-rpc.0.NEQ1662322.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645097,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714039},"hm-rpc.0.NEQ1818500.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645152,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714200},"hm-rpc.0.NEQ1826414.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645527,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714318},"hm-rpc.0.OEQ0473764.0.RSSI_DEVICE":{"val":-60,"ack":true,"ts":1654665645065,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1654492285673},"hm-rpc.0.OEQ0655913.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645266,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714229},"hm-rpc.0.OEQ0670648.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645430,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714305},"hm-rpc.0.OEQ0926852.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665644977,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942713929},"hm-rpc.1.00091A49A082FC.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654666668686,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654666603080},"hm-rpc.1.000A1D8997CC3E.0.RSSI_DEVICE":{"val":-64,"ack":true,"ts":1654665666875,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654665666875},"hm-rpc.1.000E9D898ADC67.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654665645456,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1654662366755},"hm-rpc.1.000EDBE9992D89.0.RSSI_DEVICE":{"val":-60,"ack":true,"ts":1654666695665,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654666654471}}
      device-watcher.0
      2022-06-08 07:39:02.651	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      device-watcher.0
      2022-06-08 07:39:02.641	debug	{}
      device-watcher.0
      2022-06-08 07:39:02.570	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      device-watcher.0
      2022-06-08 07:39:02.561	debug	[{"Selektor":"0_userdata.*.link_quality","theName":"common","adapter":"Test"},{"Selektor":"hm-rpc.*.RSSI_DEVICE","theName":"common","adapter":"Homematic"}]
      device-watcher.0
      2022-06-08 07:39:02.561	info	Homematic Devices wurden ausgewählt. Lade Daten...
      device-watcher.0
      2022-06-08 07:39:02.561	warn	Teststates wurden ausgewählt. Lade Daten...
      device-watcher.0
      2022-06-08 07:39:02.560	warn	No devices selected. Pleased check the instance configuration
      device-watcher.0
      2022-06-08 07:39:02.560	debug	Function started: main
      device-watcher.0
      2022-06-08 07:39:02.558	debug	Adapter Device-Watcher was started
      device-watcher.0
      2022-06-08 07:39:02.551	info	starting. Version 0.0.5 (non-npm: ciddi89/ioBroker.device-watcher#4947cb310f92330967f5d7b2de5dbac300651e74) in C:/Program Files/iobroker/Home/node_modules/iobroker.device-watcher, node: v14.19.3, js-controller: 4.0.23
        A Former User @crunchip last edited by
        @crunchip hatte das eingepflegt was du mir am Anfang gesagt hast. Werde dann aber noch den Datenpunkt wifi Signal mit einpflegen wenn es da zwei Versionen gibt.
          A Former User @David G. last edited by
          @david-g danke. Werde versuchen das einzupflegen was geht und was auch für die Breite Masse Sinn macht. 🙂
          1. Der Adapter durch sucht alle Instanzen vorzugsweise nach Link quality/rssi Datenpunkte. Muss noch gucken wie ich es am besten mache wenn nur battery Datenpunkte da sind. Sollte aber kein Problem sein.
          2. das holt er sich auch den Link_quality wann dieser sich zuletzt gemeldet hat. Normalerweise senden die Geräte alle paar Stunden ein Signal. Außer zb Geräte die Batterie Los sind so wie die hue tab Schalter.
          3. sollte kein Problem sein nehme ich mit in die Liste auf.
          4. muss ich mir mal anschauen wie man es am besten implementieren könnte.
          5. Schaltzustände habe ich bis jetzt noch nicht eingeplant.
            kenny384 @Guest last edited by kenny384
            @ciddi89 Ich würde das mit dem Objektbaum mal übernehmen, da Deconz auch für mich hilfreich wäre. Es gibt immer einen Datenpunkt reachable und einen für die battery:
            Und das ist der generelle Aufbau des Baumes unter Deconz:
            ? 2 Replies Last reply Reply Quote 0
              A Former User @kenny384 last edited by
              @kenny384 Super danke, nehme ich mit rein. 🙂 Wird aber denke ich mal erst heut Abend was wenn ich Zeit habe. 🙂
                @ciddi89 Top, danke dir.
                Ronny Gerndt 1 Reply Last reply Reply Quote 0
                • Ronny Gerndt
                  Ronny Gerndt @kenny384 last edited by
                  @kenny384 deConz würde mich auch interessieren.
                  Ich hab noch 2 Temperatur und Feuchte Sensoren über Blutooth im Einsatz, würden die auch erkannt werden?
                    Kochen last edited by
                    mal ne ganz blöde Frage:
                    Was mache ich falsch?
                    Ich habe den Adapter installiert und unter Objekten taucht die Instanz auch auf, aber ohne irgendeinen Inhalt:
                    Stehe ich irgendwie auf dem Schlauch?
                    Viele Grüße
                    ? K 2 Replies Last reply Reply Quote 0
                      A Former User @Kochen last edited by A Former User
                      Was soll mir diese Warnung sagen?:
                      device-watcher.0
                      2022-06-08 10:00:12.655	warn	Teststates wurden ausgewählt. Lade Daten...
                        A Former User @Guest last edited by
                        @brainbug ach Mist habe gestern vergessen das auf false zu stellen. Das sind meine virtuellen Test Geräte. Werde es am Mittag schnell umstellen und neu hochladen.
                          sigi234 Forum Testing Most Active @Guest last edited by sigi234
                          @ciddi89
                          Hallo noch was :
                          device-watcher.0
                          2022-06-08 10:39:01.958	warn	No devices selected. Pleased check the instance configuration
                          HM Devices wurde aber ausgewählt.
                          Was ist dieser DP?
                          device-watcher.0.deviceWatcherLog
                            A Former User @sigi234 last edited by
                            @sigi234 & @Brainbug danke euch beiden. War gestern schon spät. Habe beide Sachen gefixt und hochgeladen.
                            @sigi234 said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                            Was ist dieser DP?
                            dieser soll als "log" dienen und das letzte Ereignis aufzeigen. Muss den aber in Zukunft mehr Beachtung schenken und bin am überlegen wie ich den am besten umsetze. 🙂
                            sigi234 da_Woody 3 Replies Last reply Reply Quote 0
                              @ciddi89 sagte in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                              Der backitup Adapter hat so ein Log
                                device-watcher.0
                                2022-06-08 11:58:02.546	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                device-watcher.0
                                2022-06-08 11:58:02.546	debug	all done, exiting
                                device-watcher.0
                                2022-06-08 11:58:02.545	debug	Function finished: main
                                device-watcher.0
                                2022-06-08 11:58:02.545	debug	write the datapoints finished main
                                device-watcher.0
                                2022-06-08 11:58:02.520	debug	write the datapoints main
                                device-watcher.0
                                2022-06-08 11:58:02.519	debug	[1,2,3,4,5,6,0]
                                device-watcher.0
                                2022-06-08 11:58:02.484	debug	{"hm-rpc.0.NEQ0007328.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645388,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714285},"hm-rpc.0.NEQ1662322.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645097,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714039},"hm-rpc.0.NEQ1818500.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645152,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714200},"hm-rpc.0.NEQ1826414.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645527,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714318},"hm-rpc.0.OEQ0473764.0.RSSI_DEVICE":{"val":-60,"ack":true,"ts":1654665645065,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1654492285673},"hm-rpc.0.OEQ0655913.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645266,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714229},"hm-rpc.0.OEQ0670648.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645430,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714305},"hm-rpc.0.OEQ0926852.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665644977,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942713929},"hm-rpc.1.00091A49A082FC.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654682049981,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654682039450},"hm-rpc.1.000A1D8997CC3E.0.RSSI_DEVICE":{"val":-65,"ack":true,"ts":1654679948183,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654679948183},"hm-rpc.1.000E9D898ADC67.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654681076170,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654681076170},"hm-rpc.1.000EDBE9992D89.0.RSSI_DEVICE":{"val":-55,"ack":true,"ts":1654682227340,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654682210691}}
                                device-watcher.0
                                2022-06-08 11:58:02.429	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                device-watcher.0
                                2022-06-08 11:58:02.424	debug	[{"Selektor":"hm-rpc.*.RSSI_DEVICE","theName":"common","adapter":"Homematic"}]
                                device-watcher.0
                                2022-06-08 11:58:02.424	info	Homematic Devices wurden ausgewählt. Lade Daten...
                                device-watcher.0
                                2022-06-08 11:58:02.423	debug	Function started: main
                                device-watcher.0
                                2022-06-08 11:58:02.422	debug	Adapter Device-Watcher was started
                                device-watcher.0
                                2022-06-08 11:58:02.415	info	starting. Version 0.0.5 (non-npm: ciddi89/ioBroker.device-watcher#07dc62fa3915d720bb6b22cb3ce4f05396852ac1) in C:/Program Files/iobroker/Home/node_modules/iobroker.device-watcher, node: v14.19.3, js-controller: 4.0.23
                                • da_Woody
                                  da_Woody @Guest last edited by
                                  🙄 darum hats bei mir so lange gedauert das insten. wohl gerade bei deinen upload reingekracht...
                                  in verwendung shelly und tasmota. mal beobachten... 👍
                                    A Former User @da_Woody last edited by
                                    @da_woody ja irgendwie gibt es da wohl Probleme wenn man über GitHub installieren will. Das kann bei einigen wohl bis zu 10 Minuten dauern. Ist aber ein allgemeines Problem.
                                    Ronny Gerndt 1 Reply Last reply Reply Quote 1
                                    • Ronny Gerndt
                                      Ronny Gerndt @Guest last edited by
                                      @ciddi89 Habs mir gerade mal in der Pause installiert. Vergiss die Frage wegen Ble von vorhin. 😉
                                      Ich warte dann mal auf die deconz Implementierung 🙂
                                      Wäre es möglich neben pushover auch pushbullet zu integrieren? Sonst sieht das ganze schon schick aus.
                                      • DJMarc75
                                        DJMarc75 last edited by
                                        Mir gefällt der Adapter.
                                        Ob wohl Nachfrage bei der Community besteht HUE Leuchtmittel/Devices und deren "reachable" Status mit einzubinden ?
                                        Müsste dann halt iwie zwischen den beiden HUE-Adaptern unterschieden/ausgewählt werden.
                                          Kochen @Kochen last edited by
                                          @ciddi89 Kannst du helfen?
                                            @kochen said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                                            Ich denke, dadurch das ich gestern den Fehler gemacht habe und die sogenannten "Testates" aktiviert hatte, hat sich der Adapter bei dir aufgehängt, da er versucht Devices abzufragen die nicht existieren. Muss da auf jeden fall was einbauen das er es dann abbricht und den Adapter beendet. Also lange rede kurzer Sinn:
                                            Nachdem du eine aktuelle Version drüber installiert hast musst du wohl leider iobroker einmal komplett neu starten, danach sollte es laufen.
                                            1461
                                            496750
