    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      sigi234 Forum Testing Most Active @Guest last edited by
      @ciddi89 sagte in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
      dieser soll als "log" dienen und das letzte Ereignis aufzeigen. Muss den aber in Zukunft mehr Beachtung schenken und bin am überlegen wie ich den am besten umsetze.
      Der backitup Adapter hat so ein Log
        Habe beide Sachen gefixt und hochgeladen.
        device-watcher.0
        2022-06-08 11:58:02.546	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        device-watcher.0
        2022-06-08 11:58:02.546	debug	all done, exiting
        device-watcher.0
        2022-06-08 11:58:02.545	debug	Function finished: main
        device-watcher.0
        2022-06-08 11:58:02.545	debug	write the datapoints finished main
        device-watcher.0
        2022-06-08 11:58:02.520	debug	write the datapoints main
        device-watcher.0
        2022-06-08 11:58:02.519	debug	[1,2,3,4,5,6,0]
        device-watcher.0
        2022-06-08 11:58:02.484	debug	{"hm-rpc.0.NEQ0007328.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645388,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714285},"hm-rpc.0.NEQ1662322.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645097,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714039},"hm-rpc.0.NEQ1818500.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645152,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714200},"hm-rpc.0.NEQ1826414.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645527,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714318},"hm-rpc.0.OEQ0473764.0.RSSI_DEVICE":{"val":-60,"ack":true,"ts":1654665645065,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1654492285673},"hm-rpc.0.OEQ0655913.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645266,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714229},"hm-rpc.0.OEQ0670648.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665645430,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942714305},"hm-rpc.0.OEQ0926852.0.RSSI_DEVICE":{"val":-255,"ack":true,"ts":1654665644977,"q":0,"from":"system.adapter.hm-rega.0","user":"system.user.admin","lc":1619942713929},"hm-rpc.1.00091A49A082FC.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654682049981,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654682039450},"hm-rpc.1.000A1D8997CC3E.0.RSSI_DEVICE":{"val":-65,"ack":true,"ts":1654679948183,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654679948183},"hm-rpc.1.000E9D898ADC67.0.RSSI_DEVICE":{"val":-51,"ack":true,"ts":1654681076170,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654681076170},"hm-rpc.1.000EDBE9992D89.0.RSSI_DEVICE":{"val":-55,"ack":true,"ts":1654682227340,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1654682210691}}
        device-watcher.0
        2022-06-08 11:58:02.429	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
        device-watcher.0
        2022-06-08 11:58:02.424	debug	[{"Selektor":"hm-rpc.*.RSSI_DEVICE","theName":"common","adapter":"Homematic"}]
        device-watcher.0
        2022-06-08 11:58:02.424	info	Homematic Devices wurden ausgewählt. Lade Daten...
        device-watcher.0
        2022-06-08 11:58:02.423	debug	Function started: main
        device-watcher.0
        2022-06-08 11:58:02.422	debug	Adapter Device-Watcher was started
        device-watcher.0
        2022-06-08 11:58:02.415	info	starting. Version 0.0.5 (non-npm: ciddi89/ioBroker.device-watcher#07dc62fa3915d720bb6b22cb3ce4f05396852ac1) in C:/Program Files/iobroker/Home/node_modules/iobroker.device-watcher, node: v14.19.3, js-controller: 4.0.23
        • da_Woody
          da_Woody @Guest last edited by
          🙄 darum hats bei mir so lange gedauert das insten. wohl gerade bei deinen upload reingekracht...
          in verwendung shelly und tasmota. mal beobachten... 👍
            A Former User @da_Woody last edited by
            @da_woody ja irgendwie gibt es da wohl Probleme wenn man über GitHub installieren will. Das kann bei einigen wohl bis zu 10 Minuten dauern. Ist aber ein allgemeines Problem.
            Ronny Gerndt 1 Reply Last reply Reply Quote 1
            • Ronny Gerndt
              Ronny Gerndt @Guest last edited by
              @ciddi89 Habs mir gerade mal in der Pause installiert. Vergiss die Frage wegen Ble von vorhin. 😉
              Ich warte dann mal auf die deconz Implementierung 🙂
              Wäre es möglich neben pushover auch pushbullet zu integrieren? Sonst sieht das ganze schon schick aus.
              • DJMarc75
                DJMarc75 last edited by
                Mir gefällt der Adapter.
                Ob wohl Nachfrage bei der Community besteht HUE Leuchtmittel/Devices und deren "reachable" Status mit einzubinden ?
                Müsste dann halt iwie zwischen den beiden HUE-Adaptern unterschieden/ausgewählt werden.
                  Kochen @Kochen last edited by
                  @ciddi89 Kannst du helfen?
                    A Former User @Kochen last edited by
                    @kochen said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                    Ich denke, dadurch das ich gestern den Fehler gemacht habe und die sogenannten "Testates" aktiviert hatte, hat sich der Adapter bei dir aufgehängt, da er versucht Devices abzufragen die nicht existieren. Muss da auf jeden fall was einbauen das er es dann abbricht und den Adapter beendet. Also lange rede kurzer Sinn:
                    Nachdem du eine aktuelle Version drüber installiert hast musst du wohl leider iobroker einmal komplett neu starten, danach sollte es laufen.
                      A Former User @DJMarc75 last edited by A Former User
                      @djmarc75 said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                      Sollte einfach gehen. Muss dann halt zwei Auswahl Boxen erstellen einmal für Hue und einmal für Hue extendet
                      • DJMarc75
                        DJMarc75 @Guest last edited by
                        Hue extendet
                        hue-extended.0.lights.xxx.state.reachable
                          A Former User @Ronny Gerndt last edited by
                          @ronny-gerndt said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
                          Kannte ich bis gerade garnicht. 😄 Werde es mal mit in die Liste schreiben. Mal gucken ob ich die ganzen Dienste Hübsch zusammen packe damit die Notificationsseite nicht zu überladen wirkt.
                          frankthegreat 1 Reply Last reply Reply Quote 1
                            Kochen @Guest last edited by
                            @ciddi89 Besten Dank. Eine Neuinstallation hat geholfen.
                            • frankthegreat
                              frankthegreat @Guest last edited by
                              @ciddi89
                              Hey, cooler Adapter 👏
                              Gerade erst gesehen. Werd ich am WE mal testen.
                              Magst du vielleicht noch DECT Geräte mit aufnehmen?
                              Grüße 🖖
                                @frankthegreat
                                Ich denke DECT hat keinen Datenpunkt um das abzufragen?
                                  A Former User @Guest last edited by
                                  @brainbug ist evtl. der Datenpunkt present dafür da ob das Gerät erreichbar ist oder nicht?
                                  ? frankthegreat 2 Replies Last reply Reply Quote 0
                                    @ciddi89 ja funktioniert, hab die Steckdose raus und nach einigen Minuten wird false angezeigt.
                                      @brainbug super danke. Im Prinzip funktionieren Adaptern die mit "reachable" oder "present" arbeiten schonmal. Muss es jetzt aber ein bisschen umbauen da diese Datenpunkt ja schon sagen ob ein Gerät erreichbar ist oder nicht. Wenn ich es soweit umgebaut habe das es für mich passt gebe ich euch bescheid 🙂
                                      • frankthegreat
                                        Jepp, „present“ ist für die Erreichbarkeit. Steht auch so auf GIthub.
                                          Ich hatte es bisher noch nie das ein DECT Gerät nicht mehr erreichbar war. Und die Frage ist natürlich wie weit du mit den unterstützen Geräten gehen möchtest? Was soll alles mit in die Abfrage. Jetzt nicht ernst gemeint: Chromecast, Fullybrowser usw.
                                          frankthegreat ? 2 Replies Last reply Reply Quote 0
                                          • frankthegreat
                                            @brainbug
                                            Wenn die Batterien vom Thermostat leer sind kommt der DB.
                                            Ok, ich krieg dann eine Pushnachricht von der Fritte.
                                            Aber im Prinzip hast Recht…Erreichbarkeit ist eigentlich sehr stabil.
                                            1510
                                            522690
