    4. [Neuer Adapter] Life360
    • BananaJoe
      BananaJoe Most Active @Fuxsism last edited by
      @fuxsism ständig oder nur zwischendurch mal? Letzteres ist - leider - normal.
        Fuxsism @BananaJoe last edited by
        @bananajoe
        schwer zu sagen... also weniger oft als ständig aber öfters als zwischendurch 🙂
        So ca. alle halbe stunde...
        BananaJoe MiGoller 2 Replies Last reply Reply Quote 0
        • BananaJoe
          @fuxsism ich meine das sieht bei mir nicht anders aus.
          Ok, ich habe mal nachgesehen:
          2022-03-08 02:33:26.755  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 03:09:26.764  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 03:57:27.231  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 06:01:31.150  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 06:05:41.145  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 09:09:26.993  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 09:37:27.027  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 10:05:27.389  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 11:01:27.080  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 13:17:27.081  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 19:41:27.456  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          2022-03-08 20:25:27.459  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
          Mal öfter hintereinander, mal eine Weile nichts
          • MiGoller
            MiGoller Developer @Fuxsism last edited by
            @fuxsism Ja, teilweise lässt die API es temporär eine Anmeldung bzw. Erneuerung der Anmeldesession nicht zu. Der Adapter versucht schon, Verbindungsfehler abzufangen, aber Anmeldefehler zeigt er als Fehler an. Das könnte ich mal in eine Warnung ändern, bis z.B. die Anmeldung 3x nacheinander, also direkt nacheinander, nicht funktioniert hat.
            Allerdings muss ich auch gestehen, dass es mit der API nicht besser wird. Ich hatte das mal zufällig überprüft: Wenn der Adapter den Fehler wirft, dann kann ich auch in der App praktisch nicht eine andere Person orten oder Standorte aktualisieren.
            Wäre schön, wenn die API etwas stabiler werden würde. Nur da mache ich mir so gar keine Hoffnungen; ich bin schon froh, dass ich als Open-Source Entwickler noch nicht abgemahnt worden bin, da der Adapter auf eine nicht offengelegte API zugreifen muss, um die Aufgabe zu erfüllen.
            • U
              UncleB last edited by
              Mahlzeit zusammen.
              Hat jetz weniger mit dem Adapter zu tun, liegt wohl mehr an der App oder am Handy aber Life360 aktualisiert meinen Standort nicht, hab der App alle Berechtigungen erlaubt. Aber es tut sich nix..
              Kann es sein das ich das einzigste Mitglied bin?
              Hab nur einen Kreis und ich bin das einzigste Mitglied, oder hat jemand sonst noch ne Idee?
              VG
              MiGoller 1 Reply Last reply Reply Quote 0
              • MiGoller
                MiGoller Developer @UncleB last edited by
                @uncleb Hey, sorry, dass ich Dir erst jetzt antworten kann. Nur um einem Missverständnis vorzubeugen: Meinst Du, dass der Life360 (-Adapter) den Standort nicht aktualisiert? In meinen Tests war das auch mit einem einzigen Mitglied in einem Kreis möglich.
                Prüfe mal bitte, dass Du in den Life360-Adaptereinstellungen Deiner Instanz unter "Integration" auch die "Standortverfolgung" aktiviert hast. Nur bei aktivierter Standortverfolgung meldet der Adapter die Geolokation der Mitglieder als Koordinaten; andernfalls werden die Standorte nur in Bezug auf die Kreise ausgewertet, aber nicht als Datenpunkt festgehalten.
                  K_o_bold @MiGoller last edited by
                  Bin ich momentan der einzige mit Problemen ?
                  Adapter ist gelb und schießt im Sekundentakt errors
                  Palm_Maniac 1 Reply Last reply Reply Quote 0
                  • Palm_Maniac
                    Palm_Maniac @K_o_bold last edited by Palm_Maniac
                    @k_o_bold Nein, bei mir seit heute auch so. Hab den Adapter erstmal abgeschaltet, da er mir das Log zuspammt. Los ging es, ich meine es zumindest, erst nach den ganzen Adapter-Updates, unter anderem auf Admin V6.0.1
                    K G 2 Replies Last reply Reply Quote 0
                      K_o_bold @Palm_Maniac last edited by
                      @palm_maniac ,
                      Ok. Ich habe nichts verändert. Scheint wohl ein Problem bei Life360 zu sein
                        guergen @Palm_Maniac last edited by
                        @palm_maniac Ich bin noch nicht bei Admin V6, geht dennoch nicht
                        • Palm_Maniac
                          Ok, dann hat es doch nix mit den Updates zu tun und ich brauche nicht rum zu testen. Danke für die Info. 🙂
                            tomtaz last edited by
                            Nein, bin leider auch betroffen. die Life360 Website selbst ist erreichbar, erhalte allerdings auch Zig Einträge seit etwa 15:40 die folgenden Log-Einträge:
                            2022-06-08 15:40:00.017  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:00.359  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:00.694  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:01.039  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:01.375  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:01.730  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:01.736  - error: life360.0 (21011) Failed to connect or to login for 6 times. Aborting ...
                            2022-06-08 15:40:01.740  - error: life360.0 (21011) Error: Error: Connection established but failed to authenticate. Check your credentials!
                            2022-06-08 15:40:01.742  - warn: life360.0 (21011) No data received from Life360 cloud services!
                            Verändert wurde nichts. Ich werd den Adapter mal abschalten um das Log klein zu halten 🙂
                            • MiGoller
                              MiGoller Developer @tomtaz last edited by
                              Hallo zusammen. Sieht so aus, als würden alle Anmeldung an der Life360 API in der Art und Weise, wie der Adapter diese verarbeitet, fehlschlagen. Ich kann das Verhalten auch mit Kommandozeilen-Tools nachstellen.
                              Ich bitte um Geduld, da ich erst herausfinden muss, was sich an der API geändert hat. Es tut mir leid, aber abhängig von den Änderungen, die Life360 vorgenommen haben könnte, könnte es ein wenig dauern, bis der Adapter wieder funktioniert. Bis dahin müssen wir wohl leider auf die Funktionalität verzichten.
                              Auf Github wird der Fehler als Issue #59 geführt: https://github.com/MiGoller/ioBroker.life360/issues/59
                              theb3nzi created this issue in MiGoller/ioBroker.life360
                              closed Connection established but failed to authenticate. Check your credentials #59
                              MiGoller 1 Reply Last reply Reply Quote 1
                              • MiGoller
                                MiGoller Developer @MiGoller last edited by
                                Jetzt kann ich mich auch in der Mobile App auf meinem Smartphone nicht mehr anmelden: Benutzername oder Kennwort seien falsch; sind sie nicht, aber ok. Der Versuch, das Kennwort zurückzusetzen, scheitert allerdings mit einem Fehler 503 Service unavailable.
                                Habt Ihr das auch, oder habe ich grad meinen Account zerschossen?
                                T C 2 Replies Last reply Reply Quote 0
                                  tomtaz @MiGoller last edited by
                                  @migoller Hatte ich tatsächlich gestern auch. Als ich mir dann ein neues passwort angelegt habe, hat er zwar sehr lange gebraucht mich in der Mobile App anzumelden. Aber nach 2 Minuten war ich dann angemeldet.
                                    chemieka @MiGoller last edited by
                                    @migoller
                                    Hatte auch mal zum Test mein Passwort zurückgesetzt. Im App läuft alles normal. Der Adapter läuft leider nicht. Hoffe du kannst den Fehler finden.
                                    • MiGoller
                                      MiGoller Developer @chemieka last edited by
                                      Ich habe neue Erkenntnisse:
                                      1. Falls sich jemand in der Mobile App nicht mit der E-Mail-Adresse anmelden kann, möge es bitte mit der Handynummer versuchen. Bei mir hat es nachstellbar geklappt, auch wenn ich mehrere Versuche benötigt habe. Anschließend konnte ich mich abmelden und wieder mit der E-Mail-Adresse anmelden.
                                      2. Die Life360 API ist umgezogen; es gibt nicht nur neue Endpunkte, auch müssen min. für den Login anderen Aufrufe getätigt werden.
                                      Ich bin dran, aber das kann noch ein wenig dauern, bis der Adapter wieder funktioniert. Geduldet Euch bitte, ich arbeite dran, wie es meine Zeit zulässt.
                                      T MiGoller 2 Replies Last reply Reply Quote 3
                                        @migoller said in [Neuer Adapter] Life360:
                                        1. Die Life360 API ist umgezogen; es gibt nicht nur neue Endpunkte, auch müssen min. für den Login anderen Aufrufe getätigt werden.
                                        Vielen Dank für deinen Einsatz!
                                        • MiGoller
                                          Hallo zusammen. Die ersten Tests sahen gut aus. Die Daten kann ich nun wieder per Life360 API abfragen. Die notwendigen Änderungen pflege ich in den Adapter ein und stelle Euch den so schnell wie möglich zum TESTEN zur Verfügung.
                                          Sobald der Adapter auf Github zum Testen verfügbar ist, werde ich Euch hier eine kurze Info geben.
                                          MiGoller 1 Reply Last reply Reply Quote 2
                                          • MiGoller
                                            Guten Abend zusammen.
                                            Ihr findet die Version 0.2.18 auf GitHub https://github.com/MiGoller/ioBroker.life360 oder als npm-Paket zur Installation bzw. zum Update. Die Installation bzw. das Update können durchaus ein paar Minuten dauern, also seid bitte geduldig. Das Thema schaue ich mir später noch an. Jetzt geht es mir erst einmal darum, dass Ihr den Adapter wieder nutzen könnt.
                                            Falls noch nicht geschehen, stoppt bitte die Lifer360 Adapter Instanz(en), bevor Ihr die neue Version des Adapters über GitHub oder per npm installiert. Nach der Installation bzw. dem Update des Adapters gebt bitte noch einmal Eure Life360 Anmeldedaten in den Einstellungen der Instanz(en) des Adapters neu ein, auch wenn sich diese nicht geändert haben sollten.
                                            Bei mir läuft der Adapter in der Version 0.2.18 nun auf verschiedenen Installationen mit unterschiedlichen Life360 Accounts.
                                            Viel Glück.
                                            BananaJoe 1 Reply Last reply Reply Quote 4
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            167161
