    4. Test Adapter OpenKNX 0.6.x
      Thomas Braun Most Active @ChrisChros last edited by Thomas Braun
      @chrischros
      iobroker update -i
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      cd /opt/iobroker
      npm ls
        ChrisChros @Thomas Braun last edited by
        @thomas-braun hier mal die ganzen Ausgaben der Befehle:
        pi@raspberrypi:/home/iobroker $ iobroker update -i
        ^[[DUsed repository: Beta (latest)
        Adapter    "admin"        : 6.0.0    , installed 5.4.9  [Updatable]
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "history"      : 2.1.2    , installed 2.1.2
        Adapter    "influxdb"     : 3.1.3    , installed 3.1.3
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Adapter    "modbus"       : 5.0.3    , installed 5.0.3
        Adapter    "myvbus"       : 0.2.2    , installed 0.2.2
        Adapter    "openknx"      : 0.2.4    , installed 0.2.3  [Updatable]
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "smartgarden"  : 1.0.6    , installed 1.0.6
        Adapter    "socketio"     : 6.1.4    , installed 6.1.4
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.1.0    , installed 2.1.0
        pi@raspberrypi:/home/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        pi@raspberrypi:/home/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v17.9.0
        v17.9.0
        8.5.5
        pi
        /home/iobroker
        OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:2 http://archive.raspberrypi.org/debian buster InRelease
        OK:3 https://deb.nodesource.com/node_17.x buster InRelease
        Alle Pakete sind aktuell.
        nodejs:
          Installiert:           17.9.0-deb-1nodesource1
          Installationskandidat: 17.9.0-deb-1nodesource1
          Versionstabelle:
         *** 17.9.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_17.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
        pi@raspberrypi:/home/iobroker $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ npm ls
        iobroker.inst@3.0.0 /opt/iobroker
        ├── @types/caseless@0.12.2 extraneous
        ├── @types/request@2.48.8 extraneous
        ├── @types/tough-cookie@4.0.1 extraneous
        ├── acorn-walk@8.2.0 extraneous
        ├── acorn@8.7.0 extraneous
        ├── coffee-compiler@0.3.2 extraneous
        ├── coffee-script@1.12.7 extraneous
        ├── iobroker.admin@5.4.9
        ├── iobroker.backitup@2.4.9
        ├── iobroker.discovery@3.0.3
        ├── iobroker.history@2.1.2
        ├── iobroker.icons-material-png@0.1.0
        ├── iobroker.icons-mfd-svg@1.1.0
        ├── iobroker.influxdb@3.1.3
        ├── iobroker.info@1.9.19
        ├── iobroker.javascript@5.7.0
        ├── iobroker.js-controller@4.0.23
        ├── iobroker.modbus@5.0.3
        ├── iobroker.myvbus@0.2.2
        ├── iobroker.openknx@0.2.4
        ├── iobroker.simple-api@2.7.0
        ├── iobroker.smartgarden@1.0.6
        ├── iobroker.socketio@6.1.4
        ├── iobroker.vis-hqwidgets@1.2.0
        ├── iobroker.vis-materialdesign@0.5.9
        ├── iobroker.vis-metro@1.2.0
        ├── iobroker.vis-timeandweather@1.1.7
        ├── iobroker.vis@1.4.15
        ├── iobroker.web@4.3.0
        ├── iobroker.ws@2.1.0
        ├── jsonata@1.8.6 extraneous
        ├── node-inspect@2.0.0 extraneous
        ├── picocolors@1.0.0 extraneous
        ├── suncalc2@1.8.1 extraneous
        ├── typescript@4.6.4 extraneous
        ├── uuid@8.3.2
        ├── virtual-tsc@0.6.2 extraneous
        ├── vm2@3.9.9 extraneous
        └── wake_on_lan@1.0.0 extraneous
          @chrischros
          Warum node17?
          Zurück auf 14. Oder 16, das bringt npm8 schon mit.
            @thomas-braun hatte bisher ohne Probleme funktioniert gehabt.
              @chrischros
              Ist nicht die empfohlene Version für dein ioBroker und darüberhinaus als ungerade Version die Developer-Geschichte. Und das EOL hat die Version auch überschritten.
                @thomas-braun bin nun deiner Empfehlung gefolgt und habe ein downgrade auf 14.19.3 gemacht.
                pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.19.3
                v14.19.3
                6.14.17
                pi
                /home/pi
                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                nodejs:
                  Installiert:           14.19.3-deb-1nodesource1
                  Installationskandidat: 14.19.3-deb-1nodesource1
                  Versionstabelle:
                 *** 14.19.3-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                Im anschluss daran ein Reboot und das Update des Adapter angestoßen, läuft soweit auch durch aber angezeigt wird mir immer noch die Version 0.2.3.
                  @chrischros
                  iobroker update
                  iobroker upgrade openknx@0.2.4
                  iobroker upload openknx
                    @thomas-braun bringt leider nicht den gewünschten erfolg.
                    Cache vom Browser habe ich auch mal gelöscht, nicht das da noch was ist.
                    Hier mal die Terminal-Ausgabe:
                    pi@raspberrypi:~ $ iobroker update
                    pi@raspberrypi:~ $ iobroker upgrade openknx@0.2.4
                    This upgrade of "openknx" will at least introduce the following changes:
                    -> 0.2.4:
                    see https://www.npmjs.com/package/iobroker.openknx
                    Would you like to upgrade openknx from @0.2.3 to @0.2.4 now? [(y)es, (n)o]: y
                    Update openknx from @0.2.3 to @0.2.4
                    NPM version: 6.14.17
                    Installing iobroker.openknx@0.2.4... (System call)
                    + iobroker.openknx@0.2.4
                    updated 2 packages in 19.563s
                    54 packages are looking for funding
                      run `npm fund` for details
                    upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
                    upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
                    upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
                    upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
                    upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
                    pi@raspberrypi:~ $ iobroker upload openknx
                      Tontechniker @ChrisChros last edited by Tontechniker
                      @chrischros Habe auf das Problem schon in meinem Beitrag vom 28. Mai hingewiesen. Leider noch keine Reaktion vom Entwickler des Adapters (@killroy2 ).
                        ple last edited by
                        Kurze Frage in die Runde,
                        aktuell ändere ich ja fast täglich was an meine GA´s und Räume dabei auf.
                        Nun kann ich ja die Objekte durch den Adapter komplett neu erzeugen lassen oder halt nur neue hinzufügen.
                        Besteht die Möglichkeit, dass der Adapter die aktuellen zu den neu importierenden vergleicht und nur die löscht, die nicht mehr im neuen Ga Export auftauchen?
                        Hatte es jetzt, dass ich einige Beschriftungen geändert habe, die wurden auch richtig angelegt, aber die alten, die falsch beschrieben waren, waren halt auch noch da.
                        Komplett neu erzeugen könnte ich, aber dann sind die Smarthomegeräte nicht mehr verlinkt sowie die History Daten. Das ist echt viel Aufwand, wenn man mal was ändert.
                        Gruß und Danke und ganz viel Lob für den tollen Adapter.
                        T K 2 Replies Last reply Reply Quote 0
                          Tontechniker @ple last edited by
                          @ple Ist eventuell nicht sinnvoll. Ich habe schon öfter GA-Änderungen eingespielt, anschließend von der vorherigen GA teile der Objektdaten kopiert und in die aktuelle GA eingefügt. Anschließend die alte GA gelöscht.
                          themuck 1 Reply Last reply Reply Quote 0
                          • themuck
                            themuck @Tontechniker last edited by
                            ich hab den Adapter in meiner Testumgebung am laufen. Er zieht sich Werte vom KNX Bus wenn ich einen Taster drücke, nur wie schreibe ich dort Werte? Mit blockly habe ich die Temperatur der Wetter Station in ein KNX Objekt geschrieben, das wird auch unter Objekte aktualisiert aber geht dann nicht auf den KNX Bus. Umgekehrt, schreibe ich auf die Adresse über den Bus Monitor einen Wert, aktualisiert sich der der Wert in Smart Taster, aber im IObroker kommt an der Stelle der Wert nicht an.
                            Ich vermute ich habe da einen Denkfehler... Vielleicht kann mir da jemand kurz auf die Sprünge helfen?
                              Tontechniker @themuck last edited by Tontechniker
                              @themuck Du kannst Dir die Nodes "KNX Ultimate" in Node Red installieren (von Node Red-Webseite). Anschließend die Node "KNX-Device" in den Flow einfügen und in dieser die Parameter einstellen (Gateway, Gruppenadresse, Datenpunkt, usw). Dann im Flow z.B. mit der Node "IoBroker-In" mit Deiner Variablen verbinden. Wenn Du da nicht weiter kommst, kann ich Dir das in einem Beispiel zeigen (morgen!).
                              • themuck
                                @tontechniker danke für die Info. Also funktioniert der Weg über blockly + den KNX Adapter so nicht? Sowas dachte ich mir... Das mit NodeRed werde ich dann Mal ausprobieren.
                                  @themuck Um auf den KNX-Bus zu schreiben, mußt Du den Wert der Variablen auf die entsprechende Gruppenadresse schreiben. Das geschieht mit der Node "KNX-Device". Die Einstellungen sind etwas kompliziert, deshalb melde Dich bitte und investiere nicht zu viel Zeit für das Ausprobieren. Ich kann Dir gern ein Beispiel schicken.
                                  Hans
                                    tro @killroy2 last edited by
                                    @killroy2 Hast Du hierzu inzwischen schon was gefunden?
                                    • themuck
                                      @tontechniker hat auf anhieb geklappt... die Temperatur von der IP Wetterstation liegt jetzt auf dem Glastaster ;).
                                      • N
                                        netfriend last edited by
                                        ich habe ein akutes Problem:
                                        Hatte den Adapter neu gestartet und nun ein Problem, mit dem ich nichts anzufangen weiß. Diese Konstellation lief nun monatelang, im Log steht folgendes:
                                        host.Raspi4
                                        2022-06-14 18:21:21.139	info	Restart adapter system.adapter.openknx.0 because enabled
                                        host.Raspi4
                                        2022-06-14 18:21:21.139	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: }
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: ]
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                                        host.Raspi4
                                        2022-06-14 18:21:21.138	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js',
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: requireStack: [
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                        host.Raspi4
                                        2022-06-14 18:21:21.137	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js:8:16)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                        host.Raspi4
                                        2022-06-14 18:21:21.136	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/KnxProtocol.js
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: Require stack:
                                        host.Raspi4
                                        2022-06-14 18:21:21.135	error	Caught by controller[0]: Error: Cannot find module 'binary-parser'
                                        host.Raspi4
                                        2022-06-14 18:21:21.134	error	Caught by controller[0]: ^
                                        host.Raspi4
                                        2022-06-14 18:21:21.134	error	Caught by controller[0]: throw err;
                                        host.Raspi4
                                        2022-06-14 18:21:21.134	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
                                        host.Raspi4
                                        2022-06-14 18:21:20.245	info	instance system.adapter.openknx.0 started with pid 30715
                                        Kann mir bitte jemand weiterhelfen. Was soll mir der Fehlereintrag sagen?
                                        • N
                                          Nach längerem Suchen und Probieren habe ich openknx nochmal aktualisiert (wieder auf die selbe Version) und siehe da, es funktioniert wieder alles. Hier scheint es irgendwas zerlegt zu haben.
                                            killroy2 @Tontechniker last edited by
                                            @tontechniker ich habs nicht genauer untersucht, ich bringe demnächst ein Update heraus und hoffe dass es dadurch automatisch behoben ist.
                                            31.7k
                                            79.9k
                                            572
                                            122304
