    4. Test Adapter HeatingControl v2.12.x
    • david83
      david83 last edited by
      heatingcontrol.0
      2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all HolidayPresent false (23)
      heatingcontrol.0
      2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all VacationAbsent false (22)
      heatingcontrol.0
      2022-05-20 07:59:57.192	debug	ChangeStatus called, while already changing, push to list all Present true (21)
      heatingcontrol.0
      2022-05-20 07:59:57.191	debug	ChangeStatus called, while already changing, push to list all HeatingPeriodActive true (20)
      heatingcontrol.0
      2022-05-20 07:59:57.191	debug	MaintenanceActive false
      heatingcontrol.0
      2022-05-20 07:59:57.190	debug	PublicHolidyToday false
      heatingcontrol.0
      2022-05-20 07:59:57.186	debug	UpdateDPs for Waschküche starting
      heatingcontrol.0
      2022-05-20 07:59:57.186	debug	Waschküche ### ChangeStatus HeatingPeriodActive to true in starting
      heatingcontrol.0
      2022-05-20 07:59:57.185	error	exception in UpdateDPs [TypeError: Cannot read property 'status' of undefined]
      heatingcontrol.0
      2022-05-20 07:59:57.185	debug	PartyNow false
      heatingcontrol.0
      2022-05-20 07:59:57.181	debug	GuestsPresent false
      heatingcontrol.0
      2022-05-20 07:59:57.180	debug	HolidayPresent false
      heatingcontrol.0
      2022-05-20 07:59:57.176	debug	VacationAbsent false
      heatingcontrol.0
      2022-05-20 07:59:57.176	debug	Present true
      heatingcontrol.0
      2022-05-20 07:59:57.132	debug	HeatingPeriodActive true
      heatingcontrol.0
      2022-05-20 07:59:57.128	info	checking external states
      heatingcontrol.0
      2022-05-20 07:59:57.127	debug	result for CheckSensors4Room in Waschküche is false since 1653026059367 = never
      heatingcontrol.0
      2022-05-20 07:59:57.127	debug	number: one window closed in Waschküche alias.0.Hauswirtschaftsraum.Seitentür.ACTUAL
      • Rene_HM
        Rene_HM Developer @david83 last edited by
        @david83 Ich sehe den Fehler im Log, verstehe aber die Ursache noch nicht. Es scheint aber funktionell keine Auswirkung zu haben, also können wir das erst mal ignorieren. In der V2.9 baue ich zusätzliche checks dafür ein, dann sehen wir hoffentlich die Ursache...
          deta Most Active last edited by
          Hallo Zusammen,
          ich habe da auch ein Anliegen.
          Meine Heizung über die CCU3 und Heating Controll , ist bereits im Sommermodus, also nicht Heizen. Sie bleibt also auf die definierte Temperatur.
          Jetzt gibts leider ein paar kalte Tage grummel. Nun wollte ich diese jetzt einfach wie gewohnt mit Alexa Wohnzimmer auf X Grad.
          Ja Sie stellt kurz auf X Grad und gleich wieder auf die Sommer nicht Heizungs Temperatur. Mh.
          Wenn ich diese Manuell am Heizkörper ändere, dann bleibt diese auch so.
          Vom Sinn her klar. Sommer kein Heizen. Aber in solchen Fällen, müste es doch Möglich sein, dennoch die Heizung einzuschalten. Vielleicht mit einer Sonderfunktion. Sommernotfall ..
          Cu Deta
          P mkshb 2 Replies Last reply Reply Quote 0
            Pittini Developer @deta last edited by Pittini
            @deta Und warum schaltest nicht einfach die Heizperiode wieder an?
            • mkshb
              mkshb @deta last edited by mkshb
              Moin @deta,
              ist es wirklich sinnvoll in den warmen Monaten die Steuerung anzupassen?
              Ob Ventile geöffnet werden oder nicht entscheidet die Raumtemperatur. Somit hättest Du Deinen Sommernotfall sobald es zu kalt wird.
              Andreios 1 Reply Last reply Reply Quote 0
              • Andreios
                Andreios Forum Testing @mkshb last edited by
                @mkshb sagte in Test Adapter HeatingControl v2.8.x:
                Moin @deta,
                Das steckt in den Leuten so drin, kommt wohl noch aus der Zeit, wo ein Heizungsventil wie ein Wasserhahn funktioniert hat. Selbst vor den elektronisch gesteuerten Ventilen habe ich schon die Einstellung im Sommer nicht verändert, weil, wenn das Ventil auf Stufe 3 20°C macht, öffnet es nur, wenn es kälter im Raum ist und dann will ich ja auch im Sommer, dass es warm bleibt.
                Sparpotential ist da nur an der Heizung selber, wenn das noch eine nicht ganz so moderne Heizung ist. Da läuft dann evtl. auch im Sommer die Umwälzpumpe, auch wenn kein Heizbedarf ist und der Kessel wird evtl. auch auf Temperatur gehalten.
                Ich vermute, moderne Heizungen steuern auch die Pumpe nach der Außentemperatur oder haben zumindest eine Sommereinstellung. (Meine Hzg. ist schon sehr alt, da wird nur die Vorlauftemperatur über den Außenfühler über die eingestellte Kurve geregelt.)
                • Rene_HM
                  Rene_HM Developer last edited by
                  Im github und NPM liegt die 2.9.0 zum Testen bereit.
                  siehe auch github
                  Es gibt folgende Änderungen:
                  • Erweitertes Handling beim Setzen von Datenpunkten (Thermostat-Temperatur und Aktor-Status): Pro Gerät kann angegeben werden, ob das erfolgreiche Setzen geprüft werden soll und ob zusätzlich auch das Ack geprüft werden soll. siehe auch issue 306
                  • Benachrichtigung per email, telegram usw wurde hinzugefügt
                  Feedback ist wie immer willkommen...
                  Übrigens: ich suche support bei der Erstellung bzw. Update der Dokumentation. Bei Interesse bitte melden...
                  Dominik F. 1 Reply Last reply Reply Quote 1
                  • Dominik F.
                    Dominik F. @Rene_HM last edited by
                    @rene_hm
                    Bekomme seit dem Update folgende Fehlermeldung:
                    heatingcontrol.0
                    2022-06-11 14:14:49.024	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                    heatingcontrol.0
                    2022-06-11 14:14:48.930	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                    heatingcontrol.0
                    2022-06-11 14:14:48.859	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                    heatingcontrol.0
                    2022-06-11 14:14:48.784	error	exception in SetRoomTemperature [TypeError: Cannot read property 'log' of undefined]
                    Hast du eine Idee?
                    • Rene_HM
                      Rene_HM Developer @Dominik F. last edited by Rene_HM
                      @dominik-f ja, habe eine Idee... liegt wahrscheinlich an den notifications, da habe ich etwas umgebaut.
                      edit:
                      sollte mit der 2.9.1 erledigt sein...
                      Dominik F. 1 Reply Last reply Reply Quote 0
                      • Dominik F.
                        @rene_hm
                        Gerade die neue Version installiert, melde mich falls das Problem weiterhin besteht
                          Phinix @Dominik F. last edited by
                          ich bin gerade dabei mich in den Adapter einzuarbeiten. Zwei Dinge welche ich nicht ganz verstehe.
                          • im Objektbaum heatingcontrol.0.currentprofile kann ich das aktuelle Profil aktivieren. Gilt dies für alle Thermostate oder kann ich für jedes Thermostat ein anderes Profil aktiv schalten?
                          • Wie kann ich einen manuellen Modus aktiv schalten? Heißt wenn ich nicht nach Profil meine Thermostate steuern möchte sondern auf meiner Visualisierung eine Direkteingabe der Temperatur habe?
                          Danke für eure Hilfe
                          • Dominik F.
                            Dominik F. @Phinix last edited by
                            @phinix
                            Diese Datenpunkte sind vorallem dafür da, wenn du die Vis von Pittini dazu nutzt. Ein Profil ist immer für alle Räume, diese kannst du allerdings individuell einstellen in jedem Profil. Die Einstellungsmöglichkeiten werden dir aber erst richtig klar wenn du die Vis nutzt.
                            Sobald du die Temperatur selbstständig irgendwo veränderst wird der manuelle Modus automatisch aktiviert.
                              Phinix @Dominik F. last edited by Phinix
                              @dominik-f
                              Das mit den Profilen habe ich verstanden.
                              Das mit dem manuellen Modus nicht, möchte ich die Temperatur manuell abändern, zb. über einen Slider auf meiner Visu, welchen Datenpunkt muss ich beschreiben damit die Temperatur übernommen wird?
                              • Dominik F.
                                Dominik F. @Phinix last edited by Dominik F.
                                @phinix
                                Ich hoffe ich verstehe dich richtig....Du nimmst dafür keinen Datenpunkt vom Adapter, sondern musst einen Datenpunk von deinem Thermostat nehmen. Der Adapter erkennt dann, dass die Temperatur verändert wurde und dies nicht vom Adapter geschehen ist und schaltet sich dann in den Manu Modus
                                Ich zeig dir mal ein Beispiel von meine Visualisierung:
                                Im Wohnzimmer hat der Adapter alles selbstständig gemacht, in der Diele hab ich gerade die Temperatur manuel über den Slider verändert:
                                In diesem Bild siehst du meine Einstellungen.
                                Ganz rechts siehst du, dass in der Diele die 3. Periode aktiv ist. Wird die vierte erreicht, wird sich der Raum die wieder in den Automodus umstellen.
                                  @dominik-f
                                  Mein Fehler war die fehlende Zeit bei "TemperaturOverrideTime", dadurch wurde meine eingegebene Temperatur nicht übernommen. Nachdem ich eine Zeit eingetragen hatte, wechselte der Status von auto in override. Soweit so gut.
                                  Was ich mir eigentlich gewünscht hätte, wäre ein reiner manueller Modus, so wie es zum Bsp. in der Homematic Zentrale ist. Dort kann ich zwischen Auto und Manu Modus umschalten und das Zeitprofil wird dann nicht mehr beachtet.
                                  • Dominik F.
                                    @phinix
                                    Dann musst du im Adapter unter Thermostateinstellung bei Verwendung von Änderungen beim Thermostat das entsprechende Einstellen oder den Raum gar nicht erst in Heatingcontrol einbinden
                                      @dominik-f
                                      Wie meinst du das genau mit den Einstellungen im Thermostat?
                                      Wenn ich es richtig verstanden habe habe ich vier Möglichkeiten; Änderungen am Thermostat ignorieren, Änderung in Zeitplan übernehmen, Änderung für eine bestimmte Zeit übernehmen, Änderungen bis zum nächsten Zeitpunkt übernehmen ... oder habe ich da was falsch verstanden?
                                      Ich werde jetzt versuchen umzudenken, mir einen Zeitplan zu erstellen und diesen im Winter testen 😄
                                      Eine weitere Frage habe ich aber noch; in den Raumeinstellungen kann ich ja noch weitere Sensoren hinterlegen. Fenstersensor ist mir klar. Fenster auf, Temperatur runter. Aber wie wird ein zusätzlicher Temperatursensor behandelt bzw. was bewirkt dieser im Adapter?
                                      • Dominik F.
                                        @phinix
                                        Habe gerade nochmal in den Einstellungen geschaut. In der Vis gibt es einen Slider, womit du bei einem Raum das Zeitprofil ausschalten kannst. Der Datenpunkt dazu heisst: heatingcontrol.0.vis.isActive
                                        Zu deiner anderen Frage: Welche Raumeinstellungen meinst du genau? Meinst du in den Haupteinstellungen die zusätzliche Temperatursensoreinstellung?
                                          @dominik-f said in Test Adapter HeatingControl v2.9.x:
                                          @phinix
                                          Tatsache, cool, danke dir!
                                          Genau, in den Haupteinstellungen kann ich zusätzliche Thermometer aktivieren und den Grenzwert für den Offset festlegen. Dann unter Geräte füge ich für den Raum zb. "Badezimmer" ein zusätzliches Thermometer hinzu. Wie werden die Temperaturdaten genau verwendet bzw. welcher Wert wird mit dem zusätzlichen Temperaturwert vom Sensor verrechnet oder manipuliert?
                                          • Dominik F.
                                            @phinix
                                            Das habe ich noch nie genutzt. Ich verstehe es so: Du hast auf der einen Seite Thermostate, die die Temperaturen direkt an der Heizung messen. Auf der anderen Seite hast du irgendwo im Raum einen Temperatursensor. Die Temperatur an der Heizung selber ist ja logischerweise höher. Sagen wir mal Temperatursensor 21 Grad, Heizungsthermostat 23 Grad. Solltemperatur 22 Grad. Die Heizung würde jetzt also die Ventile zudrehen, weil sie denkt es sind 23 Grad im Raum. Hier greift dann diese Einstellung, indem dem Heizungsthermostat gesagt wird es sind keine 23 Grad sondern 21 Grad und du musst heizen.
                                            Achtung:
                                            Wenn du HM oder HM IP nutzt kannst du die Heizungsthermostate mit dem Wandthermostat verknüpfen und die Verknüpfung macht genau die oben beschriebene Einstellung.Du brauchst dann diese Einstellung nicht mehr und kannst die Datenpunkte von dem Wandthermostat für die Räume nutzen.
                                            heating
                                            236
                                            3158
                                            1856994
