    4. Test Adapter fronius-solarweb
      Strobelix @JB_Sullivan last edited by
      @jb_sullivan said in Test Adapter fronius-solarweb:
      Hat schon jemand beim GEN24 die neue Firmware 1.19.7-1 eingespielt?
      Ja läuft bei mir.
      Keine Fehler oder Veränderungen erkennbar
      nik82 1 Reply Last reply Reply Quote 0
      • nik82
        nik82 Most Active @Strobelix last edited by nik82
        habe gerade versucht den Adapter zu installieren:
        host.IOBROKERIobroker)
        	2022-05-28 20:05:46.075	info	host.IOBROKER(Iobroker) iobroker exit 0
        	2022-05-28 20:05:44.968	info	host.IOBROKER(Iobroker) iobroker upload [0] fronius-solarweb.admin C:/iobroker/SmartHome/node_modules/iobroker.fronius-solarweb/admin/fronius-solarweb.png fronius-solarweb.png image/png
        	2022-05-28 20:05:44.905	info	host.IOBROKER(Iobroker) iobroker upload [1] fronius-solarweb.admin C:/iobroker/SmartHome/node_modules/iobroker.fronius-solarweb/admin/index_m.html index_m.html text/html
        	2022-05-28 20:05:44.844	info	host.IOBROKER(Iobroker) iobroker upload [2] fronius-solarweb.admin C:/iobroker/SmartHome/node_modules/iobroker.fronius-solarweb/admin/style.css style.css text/css
        	2022-05-28 20:05:44.764	info	host.IOBROKER(Iobroker) iobroker upload [3] fronius-solarweb.admin C:/iobroker/SmartHome/node_modules/iobroker.fronius-solarweb/admin/words.js words.js application/javascript
        	2022-05-28 20:04:52.948	info	host.IOBROKER(Iobroker) iobroker npm install TA2k/ioBroker.fronius-solarweb#bf873fc05ce1eecdff2aff880793b3e9f0a6c417 --loglevel error (System call)
        	2022-05-28 20:04:52.947	info	host.IOBROKER(Iobroker) iobroker NPM version: 6.14.10
        	2022-05-28 20:04:52.274	info	host.IOBROKER(Iobroker) iobroker install TA2k/ioBroker.fronius-solarweb#bf873fc05ce1eecdff2aff880793b3e9f0a6c417
        	2022-05-28 20:04:50.640	info	host.IOBROKER(Iobroker) iobroker url https://github.com/TA2k/ioBroker.fronius-solarweb --host IOBROKER(Iobroker)
        Aber ich sehe den Adapter nicht im Iobroker? Stehe gerade auf dem Schlauch, muss ich da noch was machen?
        EDIT: Hat sich erledigt, hat etwas gedauert bis es unter Adapter drin ist und jetzt kann ich die Instanz installieren 🙂
        Vielen Dank, funktioniert super!
        • JB_Sullivan
          Aktuell noch jemand ohne aktualisierte Daten? Solarweb ist erreichbar, aber die Tabelle (Daten) aktualisiert sich nicht. Auch auf die Zwangsanforderungs Buttons bleiben die Werte beim Tageswechsel stehen.
          Negalein S 2 Replies Last reply Reply Quote 0
          • Negalein
            Negalein Global Moderator @JB_Sullivan last edited by
            @jb_sullivan sagte in Test Adapter fronius-solarweb:
            Ja, ist mir auch gerade aufgefallen.
            das funktioniert bei mir
              @jb_sullivan Schau mal in die Solwarweb App, da ist auch alles leer. Also ein Fehler von Solarweb, da hilft auch kein manuelles Triggern.
              • nik82
                ich habe bei mir das Problem, da sich der histdata ohne Ende füllt und dadurch mein kompletter Iobroker extrem langsam wird.
                Kann man die histdata irgendwie ausschalten?
                Mir würden eigentlich die Total-Werte reichen 🙂
                  tombox @nik82 last edited by
                  @nik82 Ich habe es in der github version mal geändert
                  einfach den ordern löschen
                  via github installieren
                  instanz neustarten
                  und schauen ob das erste element immer das aktuellste ist
                  • nik82
                    nik82 Most Active last edited by nik82
                    @tombox
                    Ich habe jetzt ein echtes Problem, ich habe 114000 Objekte die er gerade löschen will, ich habe geschaut, er löscht 400 Objekte in ca. 2,5 Minuten.
                    Kann man die Objekte irgendwie schneller löschen?
                    Bzw. wie kann ich das jetzt abbrechen, damit ich einfach über Nacht löschen lassen kann?
                    da_Woody nodoe 2 Replies Last reply Reply Quote 0
                    • da_Woody
                      da_Woody @nik82 last edited by
                      @nik82 sagte in Test Adapter fronius-solarweb:
                      habe 114000 Objekte
                      echt jetzt? 😵 da musst du durch. adapter stoppen, löschen, neu anlegen lassen.
                      • nodoe
                        nodoe @nik82 last edited by
                        @tombox
                        Ich hatte ein vergleichbares Problem, allerdings mit ca. je 445.000 Objects und States (Fronius-Solarweb-Adapter lief länger zum Testen munter im Parallelbetrieb zum aktiven Fronius-Adapter mit). Dann gingen kein Backup und kein Admin mehr. Externes Bearbeiten der Redis-DB und Löschen der fronius-solarweb-Einträge hat geholfen.
                          tombox @nodoe last edited by
                          @nodoe Ist es mit der Github version besser?
                          nodoe 1 Reply Last reply Reply Quote 0
                          • nodoe
                            nodoe @tombox last edited by
                            @tombox Das kann ich urlaubsbedingt erstmal nicht testen, habe den Adapter deinstalliert und den Fronius-Adapter wieder laufen, der direkt die WR-Daten liest.
                            • chrira2507
                              chrira2507 last edited by
                              @tombox erstmals Danke für den Adapter, ich hab einen Ohmpilot installiert und kann keine aktuellen Werte (Datenpunkte) über Temperatur (vom Sensor) und Leistung Ohmpilot finden. Alle anderen Infos über den Ohmpilot sind vorhanden.
                                tombox @chrira2507 last edited by
                                @chrira2507 In der App sind die Informationen sichtbar?
                                chrira2507 1 Reply Last reply Reply Quote 0
                                • chrira2507
                                  chrira2507 @tombox last edited by
                                  @tombox auf solarweb.com also im Browser sind sie sichtbar, in der Fronius App (Android) nicht.
                                    @chrira2507 Bräuchte ich mal Zugangsdaten per pn um zu sehen was da gemacht wird
                                      @chrira2507 die GitHub version sollte jetzt ohm pilot Daten anzeigen
                                      • chrira2507
                                        @tombox die Datenpunkte sind da!!! Super vielen vielen Dank!
                                        die Fehlermeldungen im Log sind nun auch weg, schätze du hast das gefixt.
                                        nochmals Danke!
                                          @chrira2507 jetzt sollte das 24h problem auch gefixt sein
                                          • chrira2507
                                            @tombox sagte in Test Adapter fronius-solarweb:
                                            ja das passt. Danke
                                            bekomme jetzt leider im 15min Takt nachstehende Fehler.
                                            31.7k
                                            79.8k
                                            207
                                            27261
