    4. Material Design Widgets: Calendar Widget
    • Damrak2022
      Damrak2022 @TT-Tom last edited by Damrak2022
      @tt-tom Ich habe das mit 2 Gleichheitszeichen und auch mit dem Semikolon probiert. Das ist es nicht. Die Kalendernamen sind identisch mit dem was im ical Adapter hinterlegt ist.
      Hier nochmal das komplette Script was ich von hier übernommen habe:
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      // remove this, if you know to use your own datapoint
      let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
      createState(datapointId, "[]", {
        read: true,
        write: false,
        desc: "JSON String for Calendar Widget",
        type: "string",
        def: "[]"
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'ioBroker') {
                              return '#F16BBFB';
                          } else if (calendarName === 'Finanzen') {
                              return '#DA0B05'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                          if (calendarName === 'calendar1') {
                              return '#FFFFFF';
                          } else if (calendarName === 'calendar2') {
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState(datapointId, JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
        TT-Tom @Damrak2022 last edited by TT-Tom
        @damrak2022
        Okay, bei mir läuft das Script ohne Probleme. Schreibe mal in Zeile 30
        console.log(calendarName);
        Und prüfe mal die Ausgaben im Log. Vielleicht ein Leerzeichen versteckt.
        • Damrak2022
          @tt-tom Dann erscheint das:
          2022-06-12 04:56:41.170	error	script.js.common.Kalender.Kalender_ical: ical2MaterialDesignCalendarWidget: message: iobroker is not defined, stack: ReferenceError: iobroker is not defined at ical2CalendarWidget (script.js.common.Kalender.Kalender_ical:31:99) at script.js.common.Kalender.Kalender_ical:93:1 at script.js.common.Kalender.Kalender_ical:94:3 at Script.runInContext (vm.js:144:12) at Script.runInNewContext (vm.js:149:17) at execute (/opt/iobroker/node_modules/iobroker.javascript/main.js:1687:27) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1901:38) at /opt/iobroker/node_modules/iobroker.javascript/main.js:2001:17 at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1472:17) at processImmediate (internal/timers.js:466:21)
          Das hatte ich eingetragen:
          Wie behebe ich Calendar iobroker ist not defined
            @damrak2022
            Okay bei dir ist es Zeile 31. das Semikolon raus und dafür den Befehl so wie ich ihn geschrieben habe. Du möchtest im log den Inhalt der Variable sehen.
            • Damrak2022
              @tt-tom Soory,
              07:45:18.278	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Gesundheit
              07:45:18.279	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Freizeit
              07:45:18.281	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Haushalt
              07:45:18.282	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Haushalt
              07:45:18.284	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Gesundheit
              07:45:18.285	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Arbeit
              07:45:18.287	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Freizeit
              07:45:18.289	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: registered 1 subscription and 0 schedules
              Wieso steht da was ganz anderes als meine Einstellungen in ical?
                @damrak2022
                Stop
                • Damrak2022
                  @tt-tom Hier nochmal aus Zeile 31
                  07:49:27.938	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Gesundheit
                  07:49:27.939	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Freizeit
                  07:49:27.940	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Haushalt
                  07:49:27.941	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Haushalt
                  07:49:27.942	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Gesundheit
                  07:49:27.944	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Arbeit
                  07:49:27.945	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: Freizeit
                  07:49:27.946	info	javascript.0 (952) script.js.common.Kalender.Kalender_ical: registered 1 subscription and 0 schedules
                  Script ist gestoppt
                  Habe das Semikolon am Anfang entfernt - selbe Ausgabe
                    @damrak2022
                    Langsam habe nur das Handy am Start.
                    Das Script liest vermutlich nicht die Farben vom Adapter. Das muss ich mir Zuhause ansehen, am Rechner heute Abend.
                    Jetzt ist es so das der Name vom Kalender ermittelt wird und ihm dann vom Script eine Farbe für Hintergrund und Schrift zugewiesen wird.
                    • Damrak2022
                      @tt-tom Ja, kein Problem, lass Dir Zeit. Aber es werden ja auch völlig falsche Kalendernamen eingelesen - siehe ical Screenshot.
                      Okay, bis später
                        @damrak2022
                        Haben allen Kalender aktuell Daten, schau mal in den Objekten von iCal nach. Das würde erklären warum er nicht alle Kalender logt.
                        Das Script erstellt die Farben für Hintergrund und Schrift selber. Du musst die Funktion erweitern für deine Kalender. Aktuell sind es ja nur für drei.
                        • Damrak2022
                          @tt-tom Momentan sieht das bei den Objekten so aus:
                          Im Kalender selbst so:
                          Da stehen Termin drin
                          Ich werde das erstmal erweitern
                            @damrak2022
                            Melde mich heute Abend nochmal. Bin jetzt weg
                            • Damrak2022
                              @tt-tom Ja, alles okay,
                              ich habe das jetzt erweitert, aber hier werden manche Einträge blass dargestellt und unten ist noch ein Teil der wahrscheinlich weg kann
                                @damrak2022
                                Falsche Klammern, vergleiche mit der ersten if
                                Das erste else muss auch weg
                                Der untere Teil ist für die Schriftfarbe, wenn dein Hintergrund schwarz ist musst du hier weiß ein stellen für den Kalender
                                • Damrak2022
                                  @tt-tom Garnicht so einfach, wenn die Augen nicht mehr so Top sind und man sich mit JS nicht auskennt.
                                  Jetzt habe ich das angepasst, aber 3 Einträge sind immer noch blass dargestellt
                                  Muss ich den unteren Bereich auch bis auf die 7 Kalender erweitern, und überall meine gewünschte Schriftfarbe einstellen?
                                    @damrak2022 sagte in Material Design Widgets: Calendar Widget:
                                    Nein, nur für die, die nicht schwarz sein sollen.
                                    Du hast oben immer noch ein Problem mit den Klammern.
                                    Ab Office fehlt die Klammer } vor else und hinter dem letzten Return müssen zwei
                                    Vergleiche mit dem Original, da kannst du es erkennen.
                                    So bin mal wieder weg.
                                    • Damrak2022
                                      @tt-tom Danke, aber mach Dir keinen Stress. Heute Abend, oder morgen ist völlig ausreichend
                                        @damrak2022
                                        Ich schau heute Abend rein.
                                        • Damrak2022
                                          @tt-tom Danke Dir
                                          • Damrak2022
                                            Damrak2022 @Damrak2022 last edited by
                                            @damrak2022 So sieht jetzt mein komplettes Script aus:
                                              read: true,
                                              write: false,
                                              type: "string",
                                              def: "[]"
                                                try {
                                                    let calList = [];
                                                        if (icalObj) {
        } else {
        calList.push({
        start: start,
        end: end
        return '#F16BBFB';
        return '#DA0B05'
        } else if (calendarName === 'Gesundheit') {
        return '#DA0B05'
        }else if (calendarName === 'Urlaub')  {
        return '#FC5307'
        }else if (calendarName === 'Marktforschung Andy') {
        return '#043DCC'
        }else if (calendarName === 'Kfz')   {
        return '#B3B3B3'
        }else if (calendarName === 'Office')    {
        return '#A3D87A'
        }else if (calendarName === 'Haushalt')   {
        return '#FDA49F'
        }else if (calendarName === 'Freizeit')   {
        return '#66028D'
        }else if (calendarName === 'Arbeit') {
        return '#FCC131'}}
        return '#8bf46c';
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'
        return '#8bf46c'}}
                                                } catch (e) {
                                            Im Log gibt es diesen Fehler:
                                            javascript.0
                                            2022-06-12 11:42:20.854	error	script.js.common.Kalender.Kalender_ical compile failed:
                                            at script.js.common.Kalender.Kalender_ical:108
                                            Und danach noch diese:
                                            javascript.0
                                            2022-06-12 11:42:20.857	error	at processImmediate (internal/timers.js:466:21)
                                            javascript.0
                                            2022-06-12 11:42:20.857	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1472:17)
                                            javascript.0
                                            2022-06-12 11:42:20.857	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2001:17
                                            javascript.0
                                            2022-06-12 11:42:20.856	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1900:37)
                                            javascript.0
                                            2022-06-12 11:42:20.856	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1647:28)
                                            javascript.0
                                            2022-06-12 11:42:20.856	error	at Object.createScript (vm.js:262:10)
                                            javascript.0
                                            2022-06-12 11:42:20.856	error	at new Script (vm.js:102:7)
                                            javascript.0
                                            2022-06-12 11:42:20.855	error	SyntaxError: Missing catch or finally after try
                                            vis
                                            45
                                            200
                                            31446
