    4. Test Adapter BMW/Mini v2.0.0
      tombox @bahnuhr last edited by
      @bahnuhr mit 2.5.4 is das Problem behoben
      bahnuhr M 2 Replies Last reply Reply Quote 3
      • bahnuhr
        bahnuhr Forum Testing Most Active @tombox last edited by
        @tombox sagte in Test Adapter BMW v2.0.0:
        und funktioniert.
        Danke.
        lobomau 1 Reply Last reply Reply Quote 1
        • lobomau
          lobomau @bahnuhr last edited by
          Als wenn der Adapter zu oft Daten abfragen würde und ich somit die Quota ausreize.
          Ich habe 1min eingestellt, aber manchmal ruft er die Daten mehrere Male pro Minute ab:
          bmw.0
          2022-06-09 11:54:48.288	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:05:12."}
          bmw.0
          2022-06-09 11:54:48.287	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:54:48.287	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:54:48.232	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:05:12."}
          bmw.0
          2022-06-09 11:54:48.232	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:54:48.231	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:53:47.558	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:06:13."}
          bmw.0
          2022-06-09 11:53:47.558	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:53:47.557	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:53:47.494	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:06:13."}
          bmw.0
          2022-06-09 11:53:47.494	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:53:47.493	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:52:48.969	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:07:12."}
          bmw.0
          2022-06-09 11:52:48.968	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:52:48.965	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:51:47.562	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:08:13."}
          bmw.0
          2022-06-09 11:51:47.562	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:51:47.562	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:51:47.492	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:08:13."}
          bmw.0
          2022-06-09 11:51:47.492	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:51:47.492	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:50:47.577	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:09:13."}
          bmw.0
          2022-06-09 11:50:47.576	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:50:47.576	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:50:47.524	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:09:13."}
          bmw.0
          2022-06-09 11:50:47.523	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:50:47.523	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:49:49.391	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:00:11."}
          bmw.0
          2022-06-09 11:49:49.391	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:49:49.390	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:48:47.456	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:11:13."}
          bmw.0
          2022-06-09 11:48:47.455	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:48:47.455	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:48:43.580	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:11:17."}
          bmw.0
          2022-06-09 11:48:43.580	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:48:43.580	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:48:42.071	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:11:18."}
          bmw.0
          2022-06-09 11:48:42.071	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:48:42.070	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:45:47.521	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:14:13."}
          bmw.0
          2022-06-09 11:45:47.521	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:45:47.520	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:45:47.448	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:14:13."}
          bmw.0
          2022-06-09 11:45:47.448	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:45:47.445	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:44:47.526	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:15:13."}
          bmw.0
          2022-06-09 11:44:47.525	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:44:47.525	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:44:47.474	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:15:13."}
          bmw.0
          2022-06-09 11:44:47.474	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:44:47.474	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:43:47.586	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:16:13."}
          bmw.0
          2022-06-09 11:43:47.586	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:43:47.585	error	getvehicles v2 failed
          bmw.0
          2022-06-09 11:43:47.533	error	{"statusCode":403,"message":"Out of call volume quota. Quota will be replenished in 00:16:13."}
          bmw.0
          2022-06-09 11:43:47.533	error	Error: Request failed with status code 403
          bmw.0
          2022-06-09 11:43:47.532	error	getvehicles v2 failed
            megaron last edited by
            Hallo Leute, seit 1 Woche hab ich das selbe Problem. Bei mit kommt aber die Fehlermeldung 429. Hintergrund ist vermutlich die Änderung der Anmelde Emailadresse im Connected Drive. MyBMW App läuft einwandfrei. Den Adapter bringe ich auch nach Deinstallation und Neueinrichten nicht zum Laufen. 2.5.4 ist installiert.
            Viele Grüße
              Thomas Braun Most Active @megaron last edited by
              @megaron rate limit exceeded deutet eher auf zu häufige Anfragen hin.
                megaron @Thomas Braun last edited by megaron
                @thomas-braun Hab den Anfrage Zyklus auf 5min eingestellt. Bei 3 stellt sich das selbe Problem ein.
                  @megaron
                  Dann stell mal auf 15 Minuten.
                    megaron last edited by megaron
                    @thomas-braun Keine Veränderung, auch bei 15 Minuten. Instanz ist grün. Es werden aber keine Daten abgerufen.
                    Hab auch nochmal Instanz und Adapter gelöscht und neu installiert. Anbei das Protokoll.
                      moulder @megaron last edited by
                      @megaron Ich habe das gleiche Problem.
                      Der BMW Server scheint irgendwie seit einiger Zeit ziemlich empfindlich auf die Anfragen (& Befehle) zu reagieren. Wenn ich das Intervall auf 15min Stelle und nichts weiter mache (also keine weiteren Abfragen & Befehle sende), läuft er ohne Errors durch. Aber sobald ich einmal mehr eine Abfrage oder Befehl sende, gibt er mir auch immer die Fehler aus.
                        megaron @moulder last edited by megaron
                        @moulder und bei dir werden die Objekte sprich Fahrzeug/e unter bmw.0 aktualisiert? Bei mir werden die Inhalte nicht aktualisiert. Auch bei 15 min nicht. Hast du auch die Fehlermeldung 429?
                        lobomau 1 Reply Last reply Reply Quote 0
                        • lobomau
                          lobomau @megaron last edited by
                          @megaron @moulder habt ihr auch mal eine Tag gewartet? Vielleicht ist es ja ein Tageslimit, dass dann ausgereizt ist? Ich hatte sonst 1min eingestellt. Bin auf 3min und scheint weg zu sein.
                            megaron @lobomau last edited by
                            @lobomau hab den Zyklus auf 15 min eingestellt und wie empfohlen die Instanz in Ruhe gelassen. Hat funktioniert. Die Objekte sind in der Vis aktuell. Sobald ich aber wieder im IoBroker einsteige kommen die Fehlermeldungen mit 429 im Protokoll. Sehr seltsam.
                              mischelle @tombox last edited by
                              @tombox
                              hallo tom,
                              hab gestern auf 2.5.4 upgedated.
                              heute folgendes aus dem Log:
                              bmw.0
                              2022-06-14 18:12:48.613 error {"statusCode":429,"message":"Rate limit is exceeded. Try again in 1 seconds."}
                              bmw.0
                              2022-06-14 18:12:48.613 error Error: Request failed with status code 429
                              bmw.0
                              2022-06-14 18:12:48.612 error getvehicles v2 failed
                              bmw.0
                              2022-06-14 18:11:48.678 error {"statusCode":429,"message":"Rate limit is exceeded. Try again in 2 seconds."}
                              bmw.0
                              2022-06-14 18:11:48.678 error Error: Request failed with status code 429
                              bmw.0
                              2022-06-14 18:11:48.677 error getvehicles v2 failed
                              bmw.0
                              2022-06-14 18:11:48.559 error {"statusCode":429,"message":"Rate limit is exceeded. Try again in 1 seconds."}
                              bmw.0
                              2022-06-14 18:11:48.559 error Error: Request failed with status code 429
                              bmw.0
                              2022-06-14 18:11:48.558 error getvehicles v2 failed
                              alle ca. 0,1 s wird die Abfrage gestartet.
                              hatte gestern die Instanz angehalten und heute Mittag gestartet.
                              mit dem Bugfix. von marl bin ich seit Ende Mai ganz gut gefahren. und jetzt geht leider garnichts mehr.
                                tombox @mischelle last edited by
                                @mischelle Kannst ja mal via github installieren ob sich das verhalten gebessert hat
                                wieviele fahrzeuge hast du denn
                                  megaron @megaron last edited by
                                  @megaron Update: nach einmaligem aktualisieren hängt der Adapter wieder und ruft keine Daten ab. Egal welche Zeit man einstellt.
                                    tombox @megaron last edited by
                                    @megaron Ein debug log per pn wäre hier hilfreich
                                      megaron @tombox last edited by megaron
                                      @tombox Anbei der Log nachdem ich die Instanz neu gestartet hab. Davor hatte ich keine Fehlereinträge im Protokoll.2 Fahrzeuge sind in Connected Drive registriert. Das eine Fahrzeug wird wie gehabt aktualisiert. Das andere nicht. Zeigt aber auch keine Veränderung in der My BMW App. Ich vermute mal der Fehler liegt in der Verbindung zwischen dem ein Fahrzeug und der BMW App.
                                      L T 2 Replies Last reply Reply Quote 0
                                        lessthanmore @megaron last edited by
                                        @megaron Hast du mal das iDrive im Auto neugestartet? Bei laufendem Motor > 30 Sekunden den An-/ Ausschalter gedrückt halten his Navi und Co. neustartet.
                                        Das hilft bei mir wenn die App keine aktuellen Daten vom Auto mehr anzeigt oder die Klima nicht mehr gestartet werden kann.
                                          @megaron und Adapter ausschalten 10min warten und dann starten
                                            @tombox Ausschalten/Einschalten hat nichts gebracht.
                                            674
                                            149363
