    4. Test Adapter Meteoalarm v2.0.x
    • Latzi
      Latzi @jackblackson last edited by
      @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
      Könntest du es mir mal mit "Debug" laufen lassen, damit ich das komplette Protokoll sehe?
      Bitte sehr:
      2022-05-31 22:28:00.030 - info: host.ioBroker instance system.adapter.meteoalarm.0 started with pid 910529
      2022-05-31 22:28:00.509 - debug: meteoalarm.0 (910529) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2022-05-31 22:28:00.557 - debug: meteoalarm.0 (910529) Objects client ready ... initialize now
      2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create System PubSub Client
      2022-05-31 22:28:00.558 - debug: meteoalarm.0 (910529) Objects create User PubSub Client
      2022-05-31 22:28:00.624 - debug: meteoalarm.0 (910529) Objects client initialize lua scripts
      2022-05-31 22:28:00.626 - debug: meteoalarm.0 (910529) Objects connected to redis: 0.0.0.0:9001
      2022-05-31 22:28:00.655 - debug: meteoalarm.0 (910529) Redis States: Use Redis connection: 0.0.0.0:9000
      2022-05-31 22:28:00.679 - debug: meteoalarm.0 (910529) States create System PubSub Client
      2022-05-31 22:28:00.680 - debug: meteoalarm.0 (910529) States create User PubSub Client
      2022-05-31 22:28:00.721 - debug: meteoalarm.0 (910529) States connected to redis: 0.0.0.0:9000
      2022-05-31 22:28:00.909 - debug: meteoalarm.0 (910529) Plugin sentry Initialize Plugin (enabled=true)
      2022-05-31 22:28:01.142 - info: meteoalarm.0 (910529) starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
      2022-05-31 22:28:01.170 - debug: meteoalarm.0 (910529) Language: de
      2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
      2022-05-31 22:28:01.171 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
      2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) XML Language: de-DE
      2022-05-31 22:28:01.172 - debug: meteoalarm.0 (910529) 0: Delete Alarms
      2022-05-31 22:28:01.174 - debug: meteoalarm.0 (910529) Language: de
      2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Setup found: country AT and region AT007 - Oberösterreich
      2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) Sentry aktiv - Breadcrumb gesetzt
      2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) XML Language: de-DE
      2022-05-31 22:28:01.175 - debug: meteoalarm.0 (910529) 0: Delete Alarms
      2022-05-31 22:28:01.236 - warn: host.ioBroker-Server Objects 127.0.0.1:33394 Error from InMemDB: Error: Not exists
      2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
      2022-05-31 22:28:01.301 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
      2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 1: Parsed CSV File
      2022-05-31 22:28:01.414 - debug: meteoalarm.0 (910529) 2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-austria
      2022-05-31 22:28:01.613 - debug: meteoalarm.0 (910529) 3: Received Atom
      2022-05-31 22:28:01.714 - debug: meteoalarm.0 (910529) 4: Process Atom
      2022-05-31 22:28:01.715 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
      2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
      2022-05-31 22:28:01.726 - debug: meteoalarm.0 (910529) 5: Processed Atom
      2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
      2022-05-31 22:28:01.727 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
      2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 11: Set State for Widget
      2022-05-31 22:28:01.751 - debug: meteoalarm.0 (910529) 12: All Done
      2022-05-31 22:28:01.751 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
      2022-05-31 22:28:01.752 - debug: meteoalarm.0 (910529) Plugin sentry destroyed
      2022-05-31 22:28:01.752 - info: meteoalarm.0 (910529) Terminated (NO_ERROR): Without reason
      2022-05-31 22:28:01.872 - debug: meteoalarm.0 (910529) 3: Received Atom
      2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4: Process Atom
      2022-05-31 22:28:01.989 - debug: meteoalarm.0 (910529) 4.1.1: Check Entries
      2022-05-31 22:28:01.996 - debug: meteoalarm.0 (910529) 4.2: Checked relevance, found 0 relevant alarms
      2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5: Processed Atom
      2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 5.1 Found 0 URLs
      2022-05-31 22:28:02.019 - debug: meteoalarm.0 (910529) 10: Creating HTML Widget
      2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 11: Set State for Widget
      2022-05-31 22:28:02.083 - debug: meteoalarm.0 (910529) 12: All Done
      2022-05-31 22:28:02.083 - info: meteoalarm.0 (910529) Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
      2022-05-31 22:28:02.267 - info: host.ioBroker instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
      • da_Woody
        da_Woody @jackblackson last edited by
        @jackblackson jau, 2 l8... 😄 heute keine warnungen.
        das witzige, da waren keine zeiten dabei. aber im burgenland zufällig gesehn, daß eine der 3 warnungen für eisenstadt-umgebung verschwand und ca. 3 min später wieder angezeigt wurde.
        liegt ja nicht am adapter, wollts nur vermelden... 😉
        • da_Woody
          da_Woody last edited by
          @jackblackson es ist wieder soweit!
          hab jetzt aus den objekten htmlToday rauskopiert.
          <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 16:00 - Morgen 03:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 16:00 - Morgen 03:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "></td></tr></tbody></table>
          2x die selbe warnung. warum allerdings die zeit nicht mehr angezeigt wird...
          oha, beim testen auf einer testseite bin ich auf was draufgekommen. muss aber mit meinen einstellungen in iQontrol zu tun haben. hab jetzt mal screentogif mitlaufen lassen. kurzzeitig (ein aufblitzen) wird die zeit angezeigt.
          a4468160-711a-4c72-bf7d-a74527a9f6c1-grafik.png 934199f2-f767-4c52-99f9-75a2022cc28c-grafik.png a413fa1f-ae05-4dc0-a157-14b4aa370bb2-grafik.png
          um dann ausgeblendet zu werden...
          so, das auch hinbekommen! 😄
          inzwischen sinds 3 warnungen. 🤡 alle mit selber zeit.
            liv-in-sky @jackblackson last edited by
            @jackblackson
            ich habe diese meldung bzw. warning auch
            zeile 25-26
            meteoalarm.0
            2022-06-01 16:41:03.596	debug	4.2: Checked relevance, found 0 relevant alarms
            meteoalarm.0
            2022-06-01 16:41:03.544	debug	4.1.1: Check Entries
            meteoalarm.0
            2022-06-01 16:41:03.541	debug	4: Process Atom
            meteoalarm.0
            2022-06-01 16:41:03.089	debug	3: Received Atom
            meteoalarm.0
            2022-06-01 16:41:02.592	debug	2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-germany
            meteoalarm.0
            2022-06-01 16:41:02.592	debug	1: Parsed CSV File
            meteoalarm.0
            2022-06-01 16:41:02.453	debug	2: Request Atom from https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-germany
            meteoalarm.0
            2022-06-01 16:41:02.453	debug	1: Parsed CSV File
            host.iobroker59
            2022-06-01 16:41:02.317	warn	host.iobroker59-Server Objects 127.0.0.1:52978 Error from InMemDB: Error: Not exists
            meteoalarm.0
            2022-06-01 16:41:02.210	debug	0: Delete Alarms
            meteoalarm.0
            2022-06-01 16:41:02.210	debug	XML Language: de-DE
            meteoalarm.0
            2022-06-01 16:41:02.209	debug	Sentry aktiv - Breadcrumb gesetzt
            meteoalarm.0
            2022-06-01 16:41:02.209	debug	Setup found: country DE and region DE374 - Kreis Freising
            meteoalarm.0
            2022-06-01 16:41:02.208	debug	Language: de
            meteoalarm.0
            2022-06-01 16:41:02.194	debug	0: Delete Alarms
            meteoalarm.0
            2022-06-01 16:41:02.193	debug	XML Language: de-DE
            meteoalarm.0
            2022-06-01 16:41:02.192	debug	Sentry aktiv - Breadcrumb gesetzt
            meteoalarm.0
            2022-06-01 16:41:02.192	debug	Setup found: country DE and region DE374 - Kreis Freising
            meteoalarm.0
            2022-06-01 16:41:02.190	debug	Language: de
            meteoalarm.0
            2022-06-01 16:41:02.137	info	starting. Version 2.1.4 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.0, js-controller: 4.0.23
            meteoalarm.0
            2022-06-01 16:41:01.714	debug	Plugin sentry Initialize Plugin (enabled=true)
            • da_Woody
              da_Woody @jackblackson last edited by da_Woody
              @jackblackson 😵 heute geht wirklich die post ab! da gehn sogar die icons aus... 😄
              <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr></tbody></table>
              <table style="border-collapse: collapse; width: 100%;"><tbody><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t3.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Gewitterwarnung: Heute 18:00 - Morgen 00:00</h4>Gewitter mit Sturmböen sind zu erwarten.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;" width="35" height="35" alt="Warningimmage" src="/meteoalarm.admin/icons/white/t5.png"/></td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr><tr><td style="width: 1%; border-style: none; "></td><td style="width: 9%; border-style: none; "><img style="display:block;"</td><td style="width: 90%; border-style: none; "><h4 style = "margin-top: 5px;margin-bottom: 1px;">Hitzewarnung: Morgen 00:00 - 23:59</h4>Es ist mit erhöhter Hitzebelastung zu rechnen.</td></tr></tbody></table>
              oder im klartext
              36f820f1-57ec-4ddd-9813-cdf157e21cc0-grafik.png b974d149-5295-4fcc-a252-3e28bcbc7a52-grafik.png
              jackblackson 1 Reply Last reply Reply Quote 0
              • jackblackson
                jackblackson @da_Woody last edited by
                @da_woody Wild...ich bin momentan unterwegs, aber werde versuchen, hier diese doppelten bzw. mehrfachen Einträge irgendwie rauszufiltern, so macht dass wirklich keinen Sinn
                • da_Woody
                  @jackblackson keinen stress!
                  wenn du da was tun kannst, okidoki. aber die jungs sollten sich das mal anlinsen.
                  wenn man denen helfen kann mit den meldungen, ists für mich ok! IMHO hast du ja kontakt zu den mädelz.
                  • jackblackson
                    @da_woody Hab denen beim ZAMG mal geschrieben, wieso das so eskaliert manchmal - bzw. wie ich hier auslesen kann, was da relevant ist und was nicht.
                    da_Woody 1 Reply Last reply Reply Quote 1
                    • da_Woody
                      @jackblackson super. 👍 heute gehts ja, gestern hatte ich noch 5-6 gewitterwarnings drinnen...
                      • JackDaniel
                        JackDaniel last edited by
                        host.iobroker-Server
                        2022-06-13 10:20:05.198	warn	Objects 127.0.0.1:50282 Error from InMemDB: Error: Not exists
                        meteoalarm.0
                        2022-06-13 10:20:05.093	info	starting. Version 2.1.4 (non-npm: jack-blackson/ioBroker.meteoalarm#ede698b1889dd70f6cc38eea295463cc34e459e9) in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                        wann wird der fix dafür öffentlich gemacht?
                        danke im voraus
                        jackblackson 1 Reply Last reply Reply Quote 2
                        • jackblackson
                          jackblackson @JackDaniel last edited by
                          @jackdaniel Hallo! Sorry, hat jetzt doch länger gedauert, da ich in das Update noch eine andere Änderung einbauen wollte, das hab ich aber jetzt verschoben, und gerade die 2.1.5 im Latest freigegeben - damit sollte der Fehler verschwinden.
                          • JackDaniel
                            danke tut wieder ohne fehler 👍
                            host.iobroker
                            2022-06-14 09:30:06.214	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            meteoalarm.0
                            2022-06-14 09:30:05.186	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            host.iobroker
                            2022-06-14 09:30:04.048	info	instance system.adapter.meteoalarm.0 started with pid 1086108
                            host.iobroker
                            2022-06-14 09:20:06.074	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            meteoalarm.0
                            2022-06-14 09:20:05.171	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            host.iobroker
                            2022-06-14 09:20:04.058	info	instance system.adapter.meteoalarm.0 started with pid 1085719
                            host.iobroker
                            2022-06-14 09:10:06.125	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            meteoalarm.0
                            2022-06-14 09:10:05.150	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            host.iobroker
                            2022-06-14 09:10:04.058	info	instance system.adapter.meteoalarm.0 started with pid 1085344
                            host.iobroker
                            2022-06-14 09:00:06.211	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            meteoalarm.0
                            2022-06-14 09:00:05.188	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            host.iobroker
                            2022-06-14 09:00:04.071	info	instance system.adapter.meteoalarm.0 started with pid 1084912
                            host.iobroker
                            2022-06-14 08:50:02.150	info	instance system.adapter.meteoalarm.0 terminated with code 0 (NO_ERROR)
                            meteoalarm.0
                            2022-06-14 08:50:01.255	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v14.19.3, js-controller: 4.0.23
                            host.iobroker
                            2022-06-14 08:50:00.039	info	instance system.adapter.meteoalarm.0 started with pid 1084526
                            host.iobroker
                            2022-06-14 08:49:23.586	info	instance scheduled system.adapter.meteoalarm.0 */10 * * * *
                            • da_Woody
                              @jackblackson sag mal, siehst du eine möglichkeit nicht nur html, sonder das auch als JSON auszugeben in den objekten?
                              • jackblackson
                                @da_woody Möglich ist alles. Die Frage ist, wie sollte dass aussehen - sprich welche Spalten, mit Überschrift,…?
                                • da_Woody
                                  @jackblackson mein problem ist, daß iQontrol mit dem html die höhe der kachel nicht anpassen kann. dadurch muss ich html als state verwenden, da wird aber dann die datum/zeit nicht angezeigt. ist das die überschrift? ist blöd, weil gestern schon die warnung für heute drinnen war.
                                  wenn ich die json aber in ein widget einbinde, wird die höhe angepasst. sieht man da jetzt nicht, da nur eine meldung ist, bei mehreren wird dann unten abgeschnitten.
                                  aufgefallen ist mir das beim neuen device watcher adapter. der passt als widget mit einer jsontable die höhe automatisch an...
                                  hoffe dich jetzt genug verwirrt zu haben... 😄 mitm erklären ist das so eine sache bei mir. 😉
                                  als nichtprogger kann ich nicht abschätzen wie kompliziert das ist. wenns zuviel arbeit macht, muss ich mir was anderes einfallen lassen.
                                  • jackblackson
                                    @da_woody 🙂 Ist doch schon mal eine super Erklärung. Die Idee des HTML Widgets war natürlich, dass man es nutzen kann ohne selbst etwas an der Formatierung groß anzupassen. Du würdest in dem Fall aber eher gerne eine reine Tabelle haben, vermute ich? Damit es dann wie beim Device Watcher dargestellt werden kann.
                                    Ich könnte es mir so vorstellen, da hier jeder vielleicht einen anderen Bedraft hat, dass die Spalten frei wählbar sind - damit jeder selbst entscheiden kann, ob er den Alarmtyp haben will, das Icon, oder was auch immer. Ich glaub, da müssen dann auch etwas abstriche gemacht werden, wenn es nebeneinander angezeigt wird. Oder weißt du, ob er hier auch Zeilenumbrüche macht? Ich selbst hab iQontrol noch nie ausprobiert.
                                    • da_Woody
                                      @jackblackson im prinzip würde es ja so passen. den level kann ich ja mit der umrandung anzeigen. den hintergrund muss ich dann natürlich ändern wegen der schriftfarbe.
                                      an den muss sich ja in den instanzeneinstellungen nichts ändern.
                                      69f00d92-a7da-457f-ab94-c2ae6f95dab6-grafik.png 7b040d08-d1f0-4d3f-a9f7-b212bc9aa77e-grafik.png
                                      ist ja im prinzip nichts anderes, wie es in vis dargestellt wird.
                                      nur, daß deinem halt durch die fenstergröße halt zeilenumbrüche drinnen sind.
                                      ich hau dir da mal vom watcher das listAll objekt rein. da kann man sich über die 3 punkte auch die spaltenansicht einstellen.
                                      [{"Device":"Andy","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":70},{"Device":"Büro","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":76},{"Device":"D1mini_Bad","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":64},{"Device":"D1mini_Pool","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":70},{"Device":"Ender","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":96},{"Device":"Gästezimmer","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:02 Uhr","Link_quality":68},{"Device":"Küche","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":64},{"Device":"Terra","Adapter":"Sonoff","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":94},{"Device":"Duo1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Duo2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Wohnungstür","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"Duo4","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-57},{"Device":"Duo6","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-56},{"Device":"Duo5","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Duo3","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"WC-Licht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:12 Uhr","Link_quality":-81},{"Device":"Duo7","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"Terra3","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-73},{"Device":"Terra2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Terra1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-83},{"Device":"Klingel","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-76},{"Device":"Luster_Taster","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-74},{"Device":"Schreibtisch","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-84},{"Device":"Tür","Adapter":"Shelly","Battery":"100%","Last_contact":"8 Tagen","Link_quality":-60},{"Device":"Tor","Adapter":"Shelly","Battery":"100%","Last_contact":"3 Stunden","Link_quality":-61},{"Device":"Werkstatt Strom","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-36},{"Device":"HT Zentrale","Adapter":"Shelly","Battery":" - ","Last_contact":"06:55 Uhr","Link_quality":-54},{"Device":"HT Studio","Adapter":"Shelly","Battery":" - ","Last_contact":"2 Stunden","Link_quality":-81},{"Device":"HT Büro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:05 Uhr","Link_quality":-42},{"Device":"HT Waschküche","Adapter":"Shelly","Battery":" - ","Last_contact":"06:51 Uhr","Link_quality":-57},{"Device":"HT Gästezimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:13 Uhr","Link_quality":-74},{"Device":"HT Wohnzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-31},{"Device":"HT Schlafzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"23 Stunden","Link_quality":-61},{"Device":"HT Küche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-66},{"Device":"HT Holz","Adapter":"Shelly","Battery":" - ","Last_contact":"06:57 Uhr","Link_quality":-51},{"Device":"HT Lager","Adapter":"Shelly","Battery":" - ","Last_contact":"06:55 Uhr","Link_quality":-59},{"Device":"Alarm","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-60},{"Device":"Lötplatz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-76},{"Device":"Waschmaschine","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Dose1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-59},{"Device":"Dose2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-57},{"Device":"Woody","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-82},{"Device":"Tiefkühlkasten","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"Salz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-58},{"Device":"Trockner","Adapter":"Shelly","Battery":" - ","Last_contact":"07:06 Uhr","Link_quality":-53},{"Device":"Bad-RGB","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-61},{"Device":"RGBW Pool","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-47},{"Device":"RGBW Wohnzimmer","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-71},{"Device":"BüroLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-68},{"Device":"Garage_Taster","Adapter":"Shelly","Battery":" - ","Last_contact":"07:13 Uhr","Link_quality":-56},{"Device":"Aussenplatz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-44},{"Device":"LackLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-40},{"Device":"Lüftung","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-49},{"Device":"WC Ventilator","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-70},{"Device":"Massagelicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-81},{"Device":"Allibert","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-78},{"Device":"HolzLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-72},{"Device":"StudioLicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-75},{"Device":"Lagerlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-47},{"Device":"Interactive","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-26},{"Device":"Arbeitsfläche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-68},{"Device":"Küchenlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-68},{"Device":"Test","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-79},{"Device":"Rollo2","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"Rollo1","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"RolloBüro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-71},{"Device":"RolloLager","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-60},{"Device":"Deckenlicht","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-65},{"Device":"Pool","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-47},{"Device":"Infra Lager","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-60},{"Device":"Infra Studio","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-69},{"Device":"Infra WZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-61},{"Device":"Infra GZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-92},{"Device":"Infra SZ","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-78},{"Device":"Infra Z","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-67},{"Device":"Infra Büro","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-54},{"Device":"Infra Küche","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-77},{"Device":"Infra Holz","Adapter":"Shelly","Battery":" - ","Last_contact":"07:16 Uhr","Link_quality":-62},{"Device":"Heizung WK","Adapter":"Shelly","Battery":" - ","Last_contact":"07:18 Uhr","Link_quality":-81},{"Device":"Eiskasten","Adapter":"Shelly","Battery":" - ","Last_contact":"07:17 Uhr","Link_quality":-89}]
                                      • jackblackson
                                        @da_woody Danke - werd ich mir die nächsten Wochen ansehen und mich bei dir melden
                                        • Nashra
                                          Moin, mir werden die Warningimages nicht mehr angezeigt. Installierte Version 2.1.3
                                          Im Pfad steht "/meteoalarm.admin/icons/black/t.png" was es aber nicht gibt, hier
                                          müßte für heute t5.png enthalten sein.
                                          • da_Woody
                                            da_Woody @Nashra last edited by
                                            @nashra hmm, beta ist schon 2.1.5 frage, welchen pfad meinst du? upload schon versucht?
                                            1.2k
                                            412
                                            82224
