[Problem] rfLink wirft Error Code 13 bei Installationsversuch
Weil es nicht in einen Post passte hier Teil 2 des Logs:
make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1gyp ERR! build error
gyp ERR! stack Error:make
failed with exit code: 2
! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
gyp ERR! stack at ChildProcess.emit (events.js:191:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
gyp ERR! System Linux 4.4.16
gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
gyp ERR!
node -v v6.10.3gyp
ERR! node-gyp -v v3.4.0gyp ERR! not ok
! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
! gyp
WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/.node-gyp"
! make: *** No rule to make target '../.node-gyp/6.10.3/include/node/common.gypi', needed by 'Makefile'. Schluss.
gyp ERR! build error gyp ERR! stack Error:make
gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build/Release"
gyp ERR! cwd /opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport
gyp ERR! node -v v6.10.3
gyp ERR! node-gyp -v v3.6.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/build/Release' (1)
node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
node-pre-gyp ERR!
stack at ChildProcess.emit (events.js:191:7)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:886:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
node-pre-gyp ERR! System Linux 4.4.16
node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /opt/iobroker/node_modules/avrgirl-arduino/node_modules/serialport
node-pre-gyp ERR! node -v v6.10.3
node-pre-gyp ERR! node-pre-gyp -v v0.6.32
node-pre-gyp ERR! not ok
! gypWARN EACCES
EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/utf-8-validate/.node-gyp"
In file included from ../node_modules/nan/nan.h:82:0, from ../src/validation.cc:15:
../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handlev8::integer) [with T = v8::Int32; v8::Handle v8::integer= v8::Localv8::integer]’:
../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
Tov8::int32(v8::Handle v8::integeri) { return i->ToInt32(); }
^! ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handlev8::integer) [with T = v8::Uint32; v8::Handle v8::integer= v8::Localv8::integer]’:../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local v8::uint32v8::Value::ToUint32() const’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declarations]
Tov8::uint32(v8::Handle v8::integeri) { return i->ToUint32(); }
! In file included from ../node_modules/nan/nan_new.h:189:0, from ../node_modules/nan/nan.h:82,
../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::booleanobject::return_t NanIntern::Factoryv8::booleanobject::New(bool)’:
../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local v8::valuev8::BooleanObject::New(bool)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:4008): Pass an isolate [-Wdeprecated-declarations]
return v8::BooleanObject::New(value).Asv8::booleanobject();
! ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::script::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string)’:../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
! ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::script::return_t NanIntern::Factoryv8::script::New(v8::Localv8::string, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
! ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::string::return_t NanIntern::Factoryv8::string::New(const uint8_t*, int)’:../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local v8::stringv8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:2332): Use maybe version [-Wdeprecated-declarations]
v8::String::kNormalString, length);
../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::string::return_t NanIntern::Factoryv8::string::New(v8::String::ExternalStringResource*)’:
../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local v8::stringv8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:2371): Use maybe version [-Wdeprecated-declarations]
return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
! ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::unboundscript::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string)’:../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
! ../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBasev8::unboundscript::return_t NanIntern::Factoryv8::unboundscript::New(v8::Localv8::string, const v8::ScriptOrigin&)’:../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
! In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h: At global scope:
../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’
NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
! ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:
../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declarations]
return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
! ../node_modules/nan/nan.h: At global scope:../node_modules/nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
v8::Isolate::GCEpilogueCallback callback
! ../node_modules/nan/nan.h:473:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’ v8::Isolate::GCEpilogueCallback callback
../node_modules/nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
, v8::GCType gc_type_filter = v8::kGCTypeAll) {
../node_modules/nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
v8::Isolate::GCEpilogueCallback callback) {
../node_modules/nan/nan.h:479:7: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
! ../node_modules/nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void v8::Isolate::GCPrologueCallback callback
../node_modules/nan/nan.h:484:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
../node_modules/nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
../node_modules/nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
v8::Isolate::GCPrologueCallback callback) {
../node_modules/nan/nan.h:490:7: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
! ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
! ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’ , node::smalloc::FreeCallback callback
../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(char*, size_t, int)’:
../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
v8::Isolate::GetCurrent(), data, length, callback, hint);
../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
In file included from ../src/validation.cc:10:0:
/opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/node_buffer.h:46:40: note: initializing argument 2 of ‘v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)’
NODE_EXTERN v8::MaybeLocal v8::objectNew(v8::Isolate* isolate,
../node_modules/nan/nan.h:672:67: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), size)’ from ‘v8::MaybeLocalv8::object’ to ‘v8::Localv8::object’
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(uint32_t)’:../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), size)’ from ‘v8::MaybeLocalv8::object’ to ‘v8::Localv8::object’
return node::Buffer::New(v8::Isolate::GetCurrent(), size);
../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanBufferUse(char*, uint32_t)’:
../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string)’:../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
! ../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handlev8::object)’:../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, const char [12], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
! ../src/validation.cc:112:62: note: candidates are:In file included from ../src/validation.cc:8:0:
/opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Localv8::template, const char*, v8::FunctionCallback)
inline void NODE_SET_METHOD(v8::Local v8::templaterecv,
/opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/node.h:257:13: note: void node::NODE_SET_METHOD(v8::Localv8::object, const char*, v8::FunctionCallback)
inline void NODE_SET_METHOD(v8::Local v8::objectrecv,
! make: *** [Release/obj.target/validation/src/validation.o] Error 1
failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
! gyp ERR! System Linux 4.4.16gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
gyp ERR!
! node-pre-gyp
ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)
! gyp
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"
gypERR! build error
gyp
failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)! gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack at ChildProcess.emit (events.js:191:7)
! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)gyp ERR! System Linux 4.4.16
gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
gyp ERR! cwd /opt/iobroker/node_modules/serialport
gyp ERR! not ok
! node-pre-gyp
ERR! build error
node-pre-gypERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)node-pre-gyp ERR!
stack
at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)! node-pre-gyp ERR! System Linux 4.4.16node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialportnode-pre-gyp ERR! node -v v6.10.3
node-pre-gyp ERR! node-pre-gyp -v v0.6.28
! npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install:node-gyp rebuild
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/avrgirl-arduino/node_modules/serialport):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install:node-pre-gyp install --fallback-to-build
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install:node-gyp rebuild
npm ERR! Linux 4.4.16
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"
npm ERR! node v6.10.3
npm ERR! npm v3.10.10
npm ERR! code ELIFECYCLE
! npm ERR! serialport@3.1.2 install:node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the serialport@3.1.2 install script 'node-pre-gyp install --fallback-to-build'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the serialport package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-pre-gyp install --fallback-to-build
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs serialport
npm ERR! Or if that isn't available, you can get their info via:
npm ERR! npm owner ls serialport
npm ERR! There is likely additional logging output above.
! npm ERR! Please include the following file with any support request:
npm ERR! /opt/npm-debug.log
npm ERR! code 1
host.ioBroker-Tinker install adapter rflink
! npm install iobroker.rflink --production --prefix "/opt/iobroker" (System call)
gyp
WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/bufferutil/.node-gyp"
! In file included from ../node_modules/nan/nan.h:82:0, from ../src/bufferutil.cc:16:
../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
! ../node_modules/nan/nan_new.h: In function ‘v8::Local NanIntern::To(v8::Handlev8::integer) [with T = v8::Uint32; v8::Handle v8::integer= v8::Localv8::integer]’:../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local v8::uint32v8::Value::ToUint32() const’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local v8::valuev8::BooleanObject::New(bool)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:4008): Pass an isolate [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local v8::stringv8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:2332): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local v8::stringv8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:2371): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
! In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h: At global scope:
../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declarations]
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
In file included from ../src/bufferutil.cc:10:0:
/opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/node_buffer.h:46:40: note: initializing argument 2 of ‘v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)’
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::scriptNanCompileScript(v8::Localv8::string, const v8::ScriptOrigin&)’:../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
! ../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handlev8::object)’:../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, const char [7], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
../src/bufferutil.cc:30:52: note: candidates are:
! In file included from ../src/bufferutil.cc:8:0:/opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Localv8::template, const char*, v8::FunctionCallback)
/opt/iobroker/node_modules/bufferutil/.node-gyp/6.10.3/include/node/node.h:257:13: note: void node::NODE_SET_METHOD(v8::Localv8::object, const char*, v8::FunctionCallback)
../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, const char [5], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
../src/bufferutil.cc:31:48: note: candidates are:
../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Localv8::functiontemplate&, const char [6], void (&)(const v8::FunctionCallbackInfov8::value&))’ is ambiguous
NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
../src/bufferutil.cc:32:50: note: candidates are:
! make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1gyp ERR! build error
! gyp ERR! stack Error:make
gyp ERR!
command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/bufferutil
gyp ERR! node-gyp -v v3.4.0
gyp ERR! not ok
! node-pre-gypERR!
Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.3 (node-v48 ABI) (falling back to source compile with node-gyp)! gyp
WARN
gyp
WARN EACCES
gypERR! build error gyp ERR! stack Error:
make
gyp ERR! not ok
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
node-pre-gyp ERR! not ok! gyp
WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/utf-8-validate/.node-gyp"
! In file included from ../node_modules/nan/nan.h:82:0, from ../src/validation.cc:15:
! ../node_modules/nan/nan.h: In function ‘bool NanIdleNotification(int)’:../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared at /opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declarations]
! ../node_modules/nan/nan.h: In function ‘v8::Local v8::objectNanBufferUse(char*, uint32_t)’:../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
! In file included from ../src/validation.cc:8:0:/opt/iobroker/node_modules/utf-8-validate/.node-gyp/6.10.3/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Localv8::template, const char*, v8::FunctionCallback)
! make: *** [Release/obj.target/validation/src/validation.o] Error 1gyp ERR! build error
gyp ERR! not ok
! node-pre-gypERR!
gyp
WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"! make: *** No rule to make target '../.node-gyp/6.10.3/include/node/common.gypi', needed by 'Makefile'. Schluss.gyp ERR! build error
gyp ERR! not ok
! node-pre-gyp ERR! build error node-pre-gyp ERR!
stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
! npm
npm
npm WARN optional
SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):npm WARN
! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 (node_modules/avrgirl-arduino/node_modules/serialport):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@4.0.7 install:node-pre-gyp install --fallback-to-build
! npm
ERR! Linux 4.4.16npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"
! npm
npm ERR!
! npm ERR! You can get information on how to open an issue for this project with:npm ERR! npm bugs serialport
! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
npm ERR! code 1
! host.ioBroker-Tinker install adapter rflink
ERROR: host.ioBroker-Tinker Cannot install rflink
ERROR: process exited with code 13</anonymous></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::string></v8::string></v8::string></v8::string></v8::string></v8::string></v8::script></v8::string></v8::script></v8::script></v8::script></v8::string></v8::script></v8::script></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer></anonymous></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::string></v8::string></v8::string></v8::string></v8::string></v8::string></v8::script></v8::string></v8::script></v8::script></v8::script></v8::string></v8::script></v8::script></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer></anonymous></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::string></v8::string></v8::string></v8::string></v8::string></v8::string></v8::script></v8::string></v8::script></v8::script></v8::script></v8::string></v8::script></v8::script></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer></anonymous>Gruß Rainer
Mal wieder serialport … hm ... versuch mal mit root bitte
Das Problem liegt IMHO nicht an den EACCESS vom Serialport.
Dort habe ich festgestellt, dass es an der Installation des gesamten Systems liegt. Dieses muss als echter Root durchgeführt werden, wenn es als User xy mit sudo oder sudo su durchgeführt, behauptet die Konsole zwar, dass die Installation als root durchgeführt wird, der Besitzer bleibt aber der User xy.
das wirft dann den EACCESS Fehler, das make läuft dann aber ohne Probleme in einem temporären Ordner.
Inzwischen installiere ich keinen root-Zugang mehr per SSH, auch nicht mehr in meinen Images. Es wurde ja auch schon angemeckert, dass ich bei meinen Images dazu auffordere die Passworte zu ändern
Wenn du dir sicher bist, dass es daran liegt werde ich hier nochmal ein root Passwort vergeben und den root Zugang für SSH freigeben. Dies sollte aber aus Sicherheitsgründen standardmäßig nicht üblich sein.
Rainer
Mit
sudo su -
irst Du root. Brauchst kein Passwort
Aber der Besitzer der Daten bleibt in meinem Fall linaro.
Und das führt zu dem EACCESS. Der Besitzer müsste wahrscheinlich root sein.
Rainer
Als Root ein chown -R root.root * würde das auch fixen … glaube aber das ist egal. Root darf eh alles
Root darf eh alles `
Davon war ich auch ausgegangen, aberuser "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.3"
Rainer
Rainer `
Ich hatte letztens auch was versucht zu installieren, habe dann als root (nach sudo su) versucht, ging nicht als root. Dann trotz root noch ein sudo davor und es ging. Kann das sein? -
habe dann als root (nach sudo su) versucht, ging nicht als root. Dann trotz root noch ein sudo davor und es ging. Kann das sein? `
ich fürchte so einen Effekt auch schon beobachtet zu habenGruß
Rainer
Mit sudo su lässt sich der Adapter installieren.
zumindest ist er zu sehen, auch eine Instanz lässt sich einrichten, aber er läuft nicht
root@ioBroker-Tinker:/opt/iobroker# sudo npm cache clean
root@ioBroker-Tinker:/opt/iobroker# sudo iobroker install rflink
../node_modules/nan/nan_new.h:34:64: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8202): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_new.h:39:65: warning: ‘v8::Local v8::uint32v8::Value::ToUint32() const’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:8196): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local v8::valuev8::BooleanObject::New(bool)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:4008): Pass an isolate [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local v8::stringv8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:2332): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local v8::stringv8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:2371): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local v8::unboundscriptv8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1333): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:6114): use IdleNotificationDeadline() [-Wdeprecated-declarations]
/root/.node-gyp/6.10.3/include/node/node_buffer.h:46:40: note: initializing argument 2 of ‘v8::MaybeLocal v8::objectnode::Buffer::New(v8::Isolate*, char*, size_t)’
../node_modules/nan/nan.h:710:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
../node_modules/nan/nan.h:717:74: warning: ‘static v8::Local v8::scriptv8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated (declared at /root/.node-gyp/6.10.3/include/node/v8.h:1352): Use maybe version [-Wdeprecated-declarations]
/root/.node-gyp/6.10.3/include/node/node.h:244:13: note: void node::NODE_SET_METHOD(v8::Localv8::template, const char*, v8::FunctionCallback)
/root/.node-gyp/6.10.3/include/node/node.h:257:13: note: void node::NODE_SET_METHOD(v8::Localv8::object, const char*, v8::FunctionCallback)
gyp ERR! not ok
gyp ERR! not ok
host.ioBroker-Tinker object system.adapter.rflink created
got /opt/iobroker/node_modules/iobroker.rflink/admin
upload [2] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/rflink.png rflink.png image/png
upload [1] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/parse.js parse.js application/javascript
upload [0] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/index.html index.html text/html
root@ioBroker-Tinker:/opt/iobroker#</v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::string></v8::string></v8::string></v8::string></v8::string></v8::string></v8::script></v8::string></v8::script></v8::script></v8::script></v8::string></v8::script></v8::script></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::object></v8::template></v8::template></v8::value></v8::functiontemplate></v8::object></v8::script></v8::string></v8::script></v8::script></v8::string></v8::script></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></v8::object></class></class></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::unboundscript></v8::string></v8::unboundscript></v8::unboundscript></v8::string></v8::string></v8::string></v8::string></v8::string></v8::string></v8::script></v8::string></v8::script></v8::script></v8::script></v8::string></v8::script></v8::script></v8::booleanobject></v8::value></v8::booleanobject></v8::booleanobject></v8::integer></v8::uint32></v8::uint32></v8::integer></v8::integer></v8::integer></v8::integer></v8::int32></v8::int32></v8::integer></v8::integer></v8::integer> -
Vor dem Update von rflink als es funktionierte, hattest du bereits node 6.x?
Hab ich gerade überprüft.
auf dem Pine64 war/ist noch 4.6.1.
Aber da läuft es auch nicht mehr seit dem letzten update.
Rainer
Habe jetzt auf dem Pine64 auch nochmal radikal alle möglichen Reste vom rf-Link entsorgt, npm cache geleert und anschließend mit sudo su die Installation angestoßen.
Es läuft dort tatsächlich.
Hier ist der dev/ttyUSB0 verfügbar.
Unter node6, bzw auf dem Tinkerboard ist dieser Port nicht verfügbar gewesen, nur dev/ttyS0 - dev/ttyS3 (beim Pine64 sind es ttyS0 - ttyS4 + ttyUSB0)
Rainer
