    4. Material Design Widgets: Calendar Widget
    • Damrak2022
      Damrak2022 @TT-Tom last edited by
      @tt-tom Danke Dir
      • Damrak2022
        Damrak2022 @Damrak2022 last edited by
        @damrak2022 So sieht jetzt mein komplettes Script aus:
        // momentjs is required as dependecies in javascript adapter
        const moment = require("moment");
        var instances = $(`[id=ical.*.data.table]`);
        instances.on(ical2CalendarWidget);
        // remove this, if you know to use your own datapoint
        let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
        createState(datapointId, "[]", {
          read: true,
          write: false,
          desc: "JSON String for Calendar Widget",
          type: "string",
          def: "[]"
        function ical2CalendarWidget() {
            try {
                let calList = [];
                for (var inst = 0; inst <= instances.length - 1; inst++) {
                    let icalObj = getState(instances[inst]).val;
                    if (icalObj) {
                        for (var i = 0; i <= icalObj.length - 1; i++) {
                            let item = icalObj[i];
                            // extract calendar color
                            let calendarName = item._class.split(' ')[0].replace('ical_', '');
        console.log(calendarName);
                            let startTime = moment(item._date);
                            let endTime = moment(item._end);
                            let start = startTime.format("YYYY-MM-DD HH:mm");
                            let end = endTime.format("YYYY-MM-DD HH:mm");
                            if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                                // is full-day event
                                if (endTime.diff(startTime, 'hours') === 24) {
                                    // full-day event, one day
                                    start = startTime.format("YYYY-MM-DD");
                                    end = startTime.format("YYYY-MM-DD");
                                } else {
                                    // full-day event, multiple days
                                    end = endTime.format("YYYY-MM-DD");
                            // create object for calendar widget
                            calList.push({
                                color: getMyCalendarColor(calendarName),
                                colorText: getMyCalendarTextColor(calendarName),
                                start: start,
                                end: end
                        function getMyCalendarColor(calendarName) {
                            // assign colors via the calendar names, use calendar name as set in ical
                             if (calendarName === 'ioBroker') {
                                return '#F16BBFB';
                            } else if (calendarName === 'Finanzen') {
                                return '#DA0B05'
                            } else if (calendarName === 'Gesundheit') {
                                return '#DA0B05'
                            }else if (calendarName === 'Urlaub')  {
                                return '#FC5307'
                            }else if (calendarName === 'Marktforschung Andy') {
                                return '#043DCC'
                            }else if (calendarName === 'Kfz')   {
                                return '#B3B3B3'
                            }else if (calendarName === 'Office')    {
                                return '#A3D87A'
                            }else if (calendarName === 'Haushalt')   {
                                return '#FDA49F'
                            }else if (calendarName === 'Freizeit')   {
                                return '#66028D'
                            }else if (calendarName === 'Arbeit') {
                                return '#FCC131'}}
                        function getMyCalendarTextColor(calendarName) {
                                return '#8bf46c';
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'
                                return '#8bf46c'}}
                    // Enter the destination data point that is to be used as object ID in the widget
                    setState(datapointId, JSON.stringify(calList), true);
            } catch (e) {
                console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
        ical2CalendarWidget();
        Im Log gibt es diesen Fehler:
        javascript.0
        2022-06-12 11:42:20.854	error	script.js.common.Kalender.Kalender_ical compile failed:
        at script.js.common.Kalender.Kalender_ical:108
        Und danach noch diese:
        javascript.0
        2022-06-12 11:42:20.857	error	at processImmediate (internal/timers.js:466:21)
        javascript.0
        2022-06-12 11:42:20.857	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1472:17)
        javascript.0
        2022-06-12 11:42:20.857	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2001:17
        javascript.0
        2022-06-12 11:42:20.856	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1900:37)
        javascript.0
        2022-06-12 11:42:20.856	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1647:28)
        javascript.0
        2022-06-12 11:42:20.856	error	at Object.createScript (vm.js:262:10)
        javascript.0
        2022-06-12 11:42:20.856	error	at new Script (vm.js:102:7)
        javascript.0
        2022-06-12 11:42:20.855	error	SyntaxError: Missing catch or finally after try
          TT-Tom @Damrak2022 last edited by TT-Tom
          @damrak2022
          Hi du hast in der Zeile 105 zwei Klammern zu viel. Jede Klammer die du öffnest, musst du auch wieder schliessen. Bei Verschachtelungen musst du von innen nach aussen prüfen. Im Script-Editor bei IoBroker siehst du immer den Gegenspieler, wenn du den Cursor an eine Klammer setzt. Ich habe das Script jetzt angepasst sollte so laufen.
          Ps was noch ein Problem machen kann ist das Leerzeichen im Kalender Marktforschung, hier ggf. mit einem Unterstrich arbeiten.
            read: true,
            write: false,
            type: "string",
            def: "[]"
              try {
                  let calList = [];
                      if (icalObj) {
                              //console.log(calendarName);
                                  } else {
                              calList.push({
                                  start: start,
                                  end: end
                                  return '#F16BBFB';
                                  return '#DA0B05'
                                  return '#DA0B05'
                                  return '#FC5307'
                                  return '#043DCC'
                                  return '#B3B3B3'
                                  return '#A3D87A'
                                  return '#FDA49F'
                                  return '#66028D'
                                  return '#FCC131'
                                  return '#8bf46c';
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
                                  return '#8bf46c'
              } catch (e) {
          Damrak2022 2 Replies Last reply Reply Quote 1
          • Damrak2022
            Damrak2022 @TT-Tom last edited by Damrak2022
            @tt-tom Danke, jetzt klappt alles. Den Kalender Marktforschung habe ich vorher angepasst.
            Jetzt versuche ich mich an den restlichen Anpassungen.
            • Damrak2022
              @tt-tom Eine Frage habe ich noch: Wo passe ich die Farben für die umrandeten Bereiche an?
              Ich vermute per css von dem ich keine Ahnung habe.
                @damrak2022
                Da bin ich raus. Das muss ich auch immer nachlesen und kopieren.
                • Damrak2022
                  @tt-tom Okay, vielleicht kann mir ja jemand anders erklären wie ich die gewünschten Bereiche auswähle. Wie ich die Farbe ändere habe ich mittlerweile gelesen.
                  • O
                    Oli @Damrak2022 last edited by
                    @damrak2022
                    Die Farben kannst du im Adapter einstellen
                    Damrak2022 3 Replies Last reply Reply Quote 0
                    • Damrak2022
                      Damrak2022 @Oli last edited by
                      @oli Danke, ich habe es heute dann entdeckt
                      • Damrak2022
                        Damrak2022 @Oli last edited by Damrak2022
                        @oli Wie bekomme ich es hin, das mir Kalendereinträge nicht abgeschnitten werden, wenn es z.B. 2 oder mehr Termine im selben Zeitfenster sind. Es wäre gut, wenn da ein Zeilenumbruch erfolgen würde:
                        • O
                          @damrak2022
                          Das kann ich dir nicht sagen, ich trage meine Termine immer so ein, dass sie sich nicht überschneiden. Der erste Termin würde bei mir enden, wenn der zweite beginnt. Da kann dir aber bestimmt @Scrounger helfen.
                          • Damrak2022
                            @oli Das würde ich auch so machen, aber da die Kalender mit mehreren Personen genutzt werden, lassen sich Überschneidungen nicht vermeiden.
                            • Damrak2022
                              @oli Hallo, ich habe vor mehr als einer Stunde einen Termin im Kalender eingetragen, welcher aber nicht im Calendar Widget erscheint.
                              Das Script läuft ohne Fehlermeldung
                              Die Abfrage Zeit des ical Adapters steht auf 10 Minuten
                              Kalender ist dort eingetragen und auch aktiv.
                              Ich habe auch mehrfach einen Browserrefresh gemacht und auch eine anderen Browser ausprobiert.
                              Hast Du eine Idee, warum der Termin nicht angezeigt wird.
                              • O
                                @damrak2022
                                Da kann ich dir im Moment nicht helfen, da ich im Urlaub bin.
                                • Damrak2022
                                  @oli Genieße erstmal Deinen Urlaub.
                                    @damrak2022
                                    Prüf bitte mal den Zeitstempel vom iCal Datenpunkt ical.0.data.table, wann wurde der letztes mal aktualisiert?
                                    Hast du mehrere Instanzen?
                                    • Damrak2022
                                      @tt-tom Das funktioniert jetzt. Der Eintrag ist nun vorhanden.Da steht als Zeitstempel das drin:
                                      Was ich aber nicht verstehe, ist das meine gestrigen Termine nicht mehr sichtbar sind. Im Ical Adapter habe ich 14 Tage Vorschau und 10 Tage bei vergangenen Terminen eingestellt. Muss ich da noch was gesondert einstellen?
                                      Und eventuell kannst Du mir erklären, wie ich einen Zeilenumbruch hinbekomme, wenn mehrere Termin die gleiche Uhrzeit haben, was bei uns öfters passiert
                                      T M 2 Replies Last reply Reply Quote 0
                                        @damrak2022
                                        wie du den Zeilenumbruch erstellen kannst, keine Ahnung.
                                        Schau mal ins Log, ob auch alle Kalender abgerufen werden. Hast du dir die Json mal im Editor angesehen, ob die Termine wirklich fehlen? Nicht das es ein Darstellungsproblem in der Vis ist.
                                        Die Tage gelten für alle Kalender.
                                        • Damrak2022
                                          @tt-tom Das habe ich mir gerade angeschaut. Da stimmt alles. Jetzt ist auch alles vorhanden.
                                            koljad last edited by
                                            Ich bin noch relativ neu mit Iobroker. Ich habe den kompletten Thread dachte ich eigentlich quer gelesen aber wie realisiert ihr das denn, dass sich das Skript alle x Minuten Stunden neu läd damit mein Kalender mit neuen Einträger aktualisiert wird?
                                            vis
                                            45
                                            200
                                            31466
