    4. Parkside Zigbee Bewässerung an CC25x2r1
      Ja.rod @Thomas Braun last edited by
      @thomas-braun So habe den Zigbee-Adapter neu gestartet und wieder den Pfad für den externen Converter eingetragen. Gleiches Fehlerbild wie vorher auch:
      zigbee.0
      	2021-08-22 15:38:10.374	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      	2021-08-22 15:38:10.362	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/../lib/exposes' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      zigbee.0
      	2021-08-22 15:38:10.361	error	internal/modules/cjs/loader.js:818 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/../lib/exposes' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at evalmachine.<anonymous>:3:17 at Script.runInContext (vm.js:130:18) at Script.runInNewContext (vm.js:135:17) at Object.runInNewContext (vm.js:302:38) at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:186:16) at getExternalDefinition.next (<anonymous>)
      zigbee.0
      	2021-08-22 15:38:10.360	error	unhandled promise rejection: Cannot find module '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/../lib/exposes' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      zigbee.0
      	2021-08-22 15:38:10.359	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Thomas Braun arteck 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Ja.rod last edited by
        @ja-rod
        externen Converter hab ich nicht im Einsatz.
          arteck Developer Most Active @Ja.rod last edited by arteck
          @ja-rod sagemal was machst du ... welche externen converter willst du da installieren..
          du brauchst doch nur die Datei anlegen und diese in den EINSTELLUNGEN des ADAPTER eintragen
          wie Asgothian es geschrieben hat
          https://forum.iobroker.net/post/653596
          oder du installierst die neue Version des adapter da ist es schon drin
            Ja.rod @arteck last edited by
            @arteck Nicht "installieren", ist der falsche Begriff. Ich habe den Pfad in den Einstellungen unter "Externer Converter" eingetragen werden. Sobald ich das aber mache bleibt der Adapter rot.
            Wie du schon geschrieben hast, hat sich das erledigt. Ich habe die neue Version installiert und jetzt kann ich auch den Timer setzen.
            Ja.rod
            • nukleuz
              nukleuz @Asgothian last edited by nukleuz
              @asgothian sagte in Parkside Zigbee Bewässerung an CC25x2r1:
              Für alle die nicht auf den allerneusten Herdsman Wechseln können / wollen
              Wie mache ich den Wechsel auf den neuen Herdsman?
              Bin erst seit gestern mit dem Zigbee-Adapter am Gange...
              EDIT: Ich bin auf 1.5.6
              Wie das bei Master/Slave geht weiss ich nicht.
              Das geht genauso wie auf dem Master. Man muss deine o.g. Schritte eben nur auf dem Slave ausführen - fertig.
              Vorraussetzung ist natürlich, dass der Adapter auch korrekt auf dem Slave installiert wurde.
                arteck Developer Most Active @nukleuz last edited by
                @nukleuz said in Parkside Zigbee Bewässerung an CC25x2r1:
                und nur auf dem SLAVE..wenn dieser da laufen soll
                  Mike Hellracer @Asgothian last edited by
                  @asgothian
                  habe gesehen das die Lidl.js im Github für den Converter mit dem Lidl Bewässerungsautomat erweitert wurde.
                  Hat jemand einen Erfahrungswert wann diese dann im offiziellen stable Zigbee Adapter zur Verfügung steht bzw. verwendet werden kann?
                    arteck Developer Most Active @Mike Hellracer last edited by
                    @mike-hellracer installier dir die GIT version dann hast du es sofort
                      cb187 @arteck last edited by
                      ist das bei euch auch so wenn die Bewässerungszeit abgelaufen ist das State on/off nicht umgeschaltet wird?
                      arteck crunchip M R 4 Replies Last reply Reply Quote 0
                        arteck Developer Most Active @cb187 last edited by
                        @cb187 kein plan hab das Gerät nicht
                          crunchip Forum Testing Most Active @cb187 last edited by
                          @cb187 habe zwei, die liegen aber seit 2Jahren neben dem Schreibtisch, muss ich die Tage mal testen.
                            Medea @cb187 last edited by
                            @cb187 ja, ist bei mir auch der Fall.
                              rewenode @cb187 last edited by
                              @cb187 Ist bei mir auch so. Aber ansonsten jetzt seit ca. 4 Wochen keine Probleme.
                                Roadrunner last edited by
                                ich habe die Teile jetzt mal eingebunden und über Nacht draußen gelassen. Da diese sich weder über den Zigbee-Adapter noch manuell schalten lassen, geh ich mal davon aus, dass die Frosterkennung aktiv ist. Gibt es hier vielleicht einen Workaround zum Reset ohne die Batterien zu entfernen? Diese scheinen ja bei einigen schon länger in Betrieb.
                                Schöne Grüße
                                • gelberlemmy
                                  gelberlemmy @bassface last edited by
                                  @bassface Guten Morgen, habe es jetzt auch so realisiert. Wie sieht es denn mit der Haltbarkeit der Batterie aus ? bei mir wäre es so für einen Zyklus eine halbe Stunde. Dies würde ja bedeueten über 30 mal ein ansteuern über Zigbee.
                                    bassface @gelberlemmy last edited by
                                    @gelberlemmy moin, mit der Batterie hatte ich nie große Probleme. Ich meinen, dass ich einmal im Sommer getauscht habe. Weiß es aber gar nicht mehr so genau...
                                    Zudem hat der Frost das Teil auf dem Gewissen 🙈😁
                                    Bin zum WOOX Ventil gewechselt und sehr zu frieden. Hier brauchts keinen Workaround.
                                    gelberlemmy 1 Reply Last reply Reply Quote 0
                                    • gelberlemmy
                                      @bassface Ja aber der Woox hat einen Nachteil. Der kann kaltes Wetter nicht ab. Ich habe von den Dingern schon zwei durch. Wobei ich diesen im Winter immer abgebaut habe. Aber der Herbst hat da schon angegriffen. Ich schaue einmal. Wenn dass nicht so gut läuft, werde ich wieder Woox wechseln und diesen dann noch früher abbauen
                                        @gelberlemmy
                                        Ah okay, ja im Winter würde ich normal auch immer abbauen. Hab ich beim letzten Mal verplant.
                                        Okay dann achte ich mal drauf, vielleicht mal ne extra Lage Isolierband um die Öffnung oder so 😁
                                        • haselchen
                                          haselchen Most Active @bassface last edited by
                                          @bassface
                                          @gelberlemmy
                                          Gibt es bei euch Beiden Neuigkeiten bezüglich der Computer?
                                          Bin da auch gerade dran am Thema und wäre über Erfahrungen dankbar.
                                            bassface @haselchen last edited by bassface
                                            @haselchen
                                            Moin,
                                            das Gerät (Woox) läuft bei mir zu verlässig.
                                            Bisher ist die Batterie noch bei 75%. Hängt aber auch sicher stark von der Nutzung ab...
                                            Dort wo das Gerät zum Batterietausch geöffnet wird, habe ich zusätzlich einmal Isolierband herumgeklebt. Die Dichtung sah mir nicht so bündig aus.
                                            Ansonsten brauchen die Einschaltsignale vom Senden bis zur wirklichen Aktion ab und an bis zu 10/15 Sekunden. Das muss man bei Skripten berücksichtigen.
                                            Macht mit aber keinen Stress, nachdem ich nen Timeout eingebaut habe.
                                            Was den Durchfluss angeht, kann ich mich auch nicht beschweren. Hängt allerdings auch nur am Hausanschluss mit einer recht schlanken Zuleitung (1/2 Zoll glaube ich).
                                            Ich würde mir das Gerät wieder beschaffen.
                                            Wenn es konkrete Fragen gibt, dann gern melden...
                                            246
                                            40196
