    4. Error 25
    Error 25
    • Thomas Brodmann
      Thomas Brodmann @Glasfaser last edited by
      @glasfaser
      thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
      NPM version: 6.14.17
      Installing iobroker.sonoff@2.5.1... (System call)
      npm ERR! code EACCES
      npm ERR! syscall mkdir
      npm ERR! path /home/iobroker
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, mkdir '/home/iobroker'
      npm ERR!  [OperationalError: EACCES: permission denied, mkdir '/home/iobroker'] {
      npm ERR!   cause: [Error: EACCES: permission denied, mkdir '/home/iobroker'] {
      npm ERR!     errno: -13,
      npm ERR!     code: 'EACCES',
      npm ERR!     syscall: 'mkdir',
      npm ERR!     path: '/home/iobroker'
      npm ERR!   },
      npm ERR!   isOperational: true,
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      host.DietPi Cannot install iobroker.sonoff@2.5.1: 243
      • Thomas Brodmann
        Thomas Brodmann @Thomas Braun last edited by
        @thomas-braun sagte in Error 25:
        ls -la /home/iobroker/
        thommy@DietPi:/opt/iobroker$ ls -la /home/iobroker/
        ls: Zugriff auf '/home/iobroker/' nicht möglich: Datei oder Verzeichnis nicht gefunden
          Thomas Braun Most Active @Thomas Brodmann last edited by
          @thomas-brodmann
          Warum hast du denn keinen user iobroker (inkl. entsprechendem home für diesen)?
          cat /etc/passwd | sort
          Homoran Thomas Brodmann 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
            nur kein Recht den zu sehen und zu betreten!
            der fix hat nie gegriffen weil iobroker nie gestoppt wurde
            Thomas Brodmann 1 Reply Last reply Reply Quote 0
            • Thomas Brodmann
              thommy@DietPi:/opt/iobroker$ cat /etc/passwd | sort
              _apt:x:100:65534::/nonexistent:/usr/sbin/nologin
              backup:x:34:34:backup:/var/backups:/usr/sbin/nologin
              bin:x:2:2:bin:/bin:/usr/sbin/nologin
              _chrony:x:106:113:Chrony daemon,,,:/var/lib/chrony:/usr/sbin/nologin
              daemon:x:1:1:daemon:/usr/sbin:/usr/sbin/nologin
              dietpi:x:1000:1000::/home/dietpi:/bin/bash
              games:x:5:60:games:/usr/games:/usr/sbin/nologin
              gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
              iobroker:x:1002:1002::/home/iobroker:/usr/sbin/nologin
              irc:x:39:39:ircd:/run/ircd:/usr/sbin/nologin
              list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
              lp:x:7:7:lp:/var/spool/lpd:/usr/sbin/nologin
              mail:x:8:8:mail:/var/mail:/usr/sbin/nologin
              man:x:6:12:man:/var/cache/man:/usr/sbin/nologin
              messagebus:x:104:105::/nonexistent:/usr/sbin/nologin
              news:x:9:9:news:/var/spool/news:/usr/sbin/nologin
              nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
              proxy:x:13:13:proxy:/bin:/usr/sbin/nologin
              root:x:0:0:root:/root:/usr/bin/bash
              _rpc:x:107:65534::/run/rpcbind:/usr/sbin/nologin
              statd:x:108:65534::/var/lib/nfs:/usr/sbin/nologin
              sync:x:4:65534:sync:/bin:/bin/sync
              systemd-coredump:x:999:999:systemd Core Dumper:/:/usr/sbin/nologin
              systemd-network:x:102:103:systemd Network Management,,,:/run/systemd:/usr/sbin/nologin
              systemd-resolve:x:103:104:systemd Resolver,,,:/run/systemd:/usr/sbin/nologin
              systemd-timesync:x:101:101:systemd Time Synchronization,,,:/run/systemd:/usr/sbin/nologin
              sys:x:3:3:sys:/dev:/usr/sbin/nologin
              thommy:x:1001:1001:,,,:/home/thommy:/usr/bin/bash
              uucp:x:10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
              www-data:x:33:33:www-data:/var/www:/usr/sbin/nologin
              • Thomas Brodmann
                Thomas Brodmann @Homoran last edited by
                Dann mache ich den stop jetzt mit:
                sudo systemctl stop iobroker
                Dann werde ich den Fix ausführen
                  @thomas-brodmann
                  sudo -u iobroker whoami
                  sudo -u iobroker ls -la /home/iobroker
                  • Thomas Brodmann
                    Thomas Brodmann @Thomas Brodmann last edited by
                    @thomas-brodmann
                    thommy@DietPi:/opt/iobroker$ sudo systemctl stop iobroker
                    thommy@DietPi:/opt/iobroker$ iobroker fix
                    library: loaded
                    Library version=2022-06-15
                        Welcome to the ioBroker installation fixer!
                        Script version: 2022-06-03
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/3)
                    [sudo] Passwort für thommy:
                    OK:1 https://deb.debian.org/debian bullseye InRelease
                    OK:2 https://deb.nodesource.com/node_14.x bullseye InRelease
                    OK:3 https://deb.debian.org/debian bullseye-updates InRelease
                    OK:4 https://deb.debian.org/debian-security bullseye-security InRelease
                    OK:5 https://deb.debian.org/debian bullseye-backports InRelease
                    OK:6 http://mirrors.xtom.de/armbian bullseye InRelease
                    Paketlisten werden gelesen… Fertig
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/3)
                    Created /etc/sudoers.d/iobroker
                    Fixing directory permissions...
                        Checking autostart (3/3)
                    Enabling autostart...
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    thommy@DietPi:/opt/iobroker$ sudo systemctl start iobroker
                    Warning: The unit file, source configuration file or drop-ins of iobroker.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                    Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                    • Thomas Brodmann
                      thommy@DietPi:/opt/iobroker$ sudo -u iobroker whoami
                      iobroker
                      thommy@DietPi:/opt/iobroker$ sudo -u iobroker ls -la /home/iobroker
                      ls: Zugriff auf '/home/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
                        @thomas-brodmann sagte in Error 25:
                        Versuch mal
                        sudo -H -u iobroker iobroker add sonoff --host DietPi
                          Homoran Global Moderator Administrators @Thomas Brodmann last edited by
                          @thomas-brodmann so sieht ein gelaufener fix aus
                            @thomas-brodmann
                            sudo ls -la /home/
                              Homoran Global Moderator Administrators @Thomas Brodmann last edited by Homoran
                              was ist denn da bei dir los?
                              • Thomas Brodmann
                                thommy@DietPi:/opt/iobroker$ sudo -H -u iobroker iobroker add sonoff --host DietPi
                                • Thomas Brodmann
                                  thommy@DietPi:/opt/iobroker$ sudo ls -la /home/
                                  insgesamt 16
                                  drwxr-xr-x  4 root   root   4096 15. Jun 13:36 .
                                  drwxr-xr-x 18 root   root   4096 29. Mai 14:11 ..
                                  drwxr-xr-x  2 dietpi dietpi 4096 19. Okt 2021  dietpi
                                  drwxr-xr-x  9 thommy thommy 4096 15. Jun 19:58 thommy
                                    Thomas Braun Most Active @Thomas Brodmann last edited by Thomas Braun
                                    @thomas-brodmann
                                    Siehste...
                                    Kein /home für iobroker
                                    sudo mkdir /home/iobroker
                                    sudo chown iobroker:iobroker /home/iobroker
                                    sudo chmod 755 /home/iobroker
                                      @thomas-braun bist du sicher dass da nicht noch mehr krumm ist?
                                      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                        @homoran sagte in Error 25:
                                        Nein.
                                        • Glasfaser
                                          Glasfaser @Homoran last edited by
                                          @Thomas-Braun
                                          ich würde mal in dem Verzeichniss mal schauen was da drin ist ..!?
                                          sudo ls -la /home/thommy/
                                            @thomas-braun wenn die iobroker Befehle nich klappen sondern nur systemctl, wird das jetzt besser?
                                            error 25 error process exited with cod
                                            1939
