    4. Error 25
    Error 25
    • Thomas Brodmann
      Thomas Brodmann @Homoran last edited by
      Dann mache ich den stop jetzt mit:
      sudo systemctl stop iobroker
      Dann werde ich den Fix ausführen
      Thomas Brodmann 1 Reply Last reply Reply Quote 0
        Thomas Braun Most Active @Thomas Brodmann last edited by
        @thomas-brodmann
        sudo -u iobroker whoami
        sudo -u iobroker ls -la /home/iobroker
        • Thomas Brodmann
          Thomas Brodmann @Thomas Brodmann last edited by
          @thomas-brodmann
          thommy@DietPi:/opt/iobroker$ sudo systemctl stop iobroker
          thommy@DietPi:/opt/iobroker$ iobroker fix
          library: loaded
          Library version=2022-06-15
              Welcome to the ioBroker installation fixer!
              Script version: 2022-06-03
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          [sudo] Passwort für thommy:
          OK:1 https://deb.debian.org/debian bullseye InRelease
          OK:2 https://deb.nodesource.com/node_14.x bullseye InRelease
          OK:3 https://deb.debian.org/debian bullseye-updates InRelease
          OK:4 https://deb.debian.org/debian-security bullseye-security InRelease
          OK:5 https://deb.debian.org/debian bullseye-backports InRelease
          OK:6 http://mirrors.xtom.de/armbian bullseye InRelease
          Paketlisten werden gelesen… Fertig
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
          Fixing directory permissions...
              Checking autostart (3/3)
          Enabling autostart...
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          thommy@DietPi:/opt/iobroker$ sudo systemctl start iobroker
          Warning: The unit file, source configuration file or drop-ins of iobroker.service changed on disk. Run 'systemctl daemon-reload' to reload units.
          thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi
          NPM version: 6.14.17
          Installing iobroker.sonoff@2.5.1... (System call)
          host.DietPi Cannot install iobroker.sonoff@2.5.1: 243
          Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
          • Thomas Brodmann
            Thomas Brodmann @Thomas Braun last edited by
            @thomas-braun sagte in Error 25:
            thommy@DietPi:/opt/iobroker$ sudo -u iobroker whoami
            iobroker
            thommy@DietPi:/opt/iobroker$ sudo -u iobroker ls -la /home/iobroker
            ls: Zugriff auf '/home/iobroker' nicht möglich: Datei oder Verzeichnis nicht gefunden
              @thomas-brodmann sagte in Error 25:
              Versuch mal
              sudo -H -u iobroker iobroker add sonoff --host DietPi
                Homoran Global Moderator Administrators @Thomas Brodmann last edited by
                @thomas-brodmann so sieht ein gelaufener fix aus
                  @thomas-brodmann
                  sudo ls -la /home/
                    Homoran Global Moderator Administrators @Thomas Brodmann last edited by Homoran
                    was ist denn da bei dir los?
                    • Thomas Brodmann
                      thommy@DietPi:/opt/iobroker$ sudo -H -u iobroker iobroker add sonoff --host DietPi
                      • Thomas Brodmann
                        thommy@DietPi:/opt/iobroker$ sudo ls -la /home/
                        insgesamt 16
                        drwxr-xr-x  4 root   root   4096 15. Jun 13:36 .
                        drwxr-xr-x 18 root   root   4096 29. Mai 14:11 ..
                        drwxr-xr-x  2 dietpi dietpi 4096 19. Okt 2021  dietpi
                        drwxr-xr-x  9 thommy thommy 4096 15. Jun 19:58 thommy
                          Thomas Braun Most Active @Thomas Brodmann last edited by Thomas Braun
                          @thomas-brodmann
                          Siehste...
                          Kein /home für iobroker
                          sudo mkdir /home/iobroker
                          sudo chown iobroker:iobroker /home/iobroker
                          sudo chmod 755 /home/iobroker
                          Homoran Thomas Brodmann 2 Replies Last reply Reply Quote 0
                            @thomas-braun bist du sicher dass da nicht noch mehr krumm ist?
                            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                              @homoran sagte in Error 25:
                              Nein.
                              • Glasfaser
                                Glasfaser @Homoran last edited by
                                @Thomas-Braun
                                ich würde mal in dem Verzeichniss mal schauen was da drin ist ..!?
                                sudo ls -la /home/thommy/
                                  @thomas-braun wenn die iobroker Befehle nich klappen sondern nur systemctl, wird das jetzt besser?
                                    sudoers scheint auch 'nen Knick zu haben. Aber ich weiß nicht ob das auf dem DiätPi nicht irgendwie auch auf Diät sitzt und nur Knäckebrot bekommt.
                                    • Thomas Brodmann
                                      Das Anlegen des Ordners hat geholfen.
                                      thommy@DietPi:/opt/iobroker$ sudo mkdir /home/iobroker
                                      thommy@DietPi:/opt/iobroker$ sudo chown iobroker:iobroker /home/iobroker
                                      thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                      + iobroker.sonoff@2.5.1
                                      added 15 packages from 19 contributors in 37.07s
                                      38 packages are looking for funding
                                        run `npm fund` for details
                                      host.DietPi install adapter sonoff
                                      upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                                      upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
                                      upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
                                      upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
                                      host.DietPi object system.adapter.sonoff created/updated
                                      host.DietPi create instance sonoff
                                      host.DietPi object system.adapter.sonoff.0.alive created
                                      host.DietPi object system.adapter.sonoff.0.connected created
                                      host.DietPi object system.adapter.sonoff.0.compactMode created
                                      host.DietPi object system.adapter.sonoff.0.cpu created
                                      host.DietPi object system.adapter.sonoff.0.cputime created
                                      host.DietPi object system.adapter.sonoff.0.memHeapUsed created
                                      host.DietPi object system.adapter.sonoff.0.memHeapTotal created
                                      host.DietPi object system.adapter.sonoff.0.memRss created
                                      host.DietPi object system.adapter.sonoff.0.uptime created
                                      host.DietPi object system.adapter.sonoff.0.inputCount created
                                      host.DietPi object system.adapter.sonoff.0.outputCount created
                                      host.DietPi object system.adapter.sonoff.0.eventLoopLag created
                                      host.DietPi object system.adapter.sonoff.0.sigKill created
                                      host.DietPi object system.adapter.sonoff.0.logLevel created
                                      host.DietPi object sonoff.0.info created
                                      host.DietPi object sonoff.0.info.connection created
                                      host.DietPi object system.adapter.sonoff.0 created
                                      • Glasfaser
                                        Glasfaser @Thomas Braun last edited by
                                        Dietpi ist abgespeckt , habe es als VM ( Grafana / Influx )
                                          @thomas-brodmann
                                          ls -la /home/
                                            Homoran Global Moderator Administrators @Glasfaser last edited by
                                            @glasfaser sagte in Error 25:
                                            ich hab damals iobroker darauf nicht ans laufen gebracht. Hätte zu viele Klimmzüge gebraucht, wo ich mich nicht mit auskenne
                                            error 25 error process exited with cod
                                            1939
