    4. Error 25
    Error 25
      @thomas-braun wenn die iobroker Befehle nich klappen sondern nur systemctl, wird das jetzt besser?
        sudoers scheint auch 'nen Knick zu haben. Aber ich weiß nicht ob das auf dem DiätPi nicht irgendwie auch auf Diät sitzt und nur Knäckebrot bekommt.
        • Thomas Brodmann
          Thomas Brodmann @Thomas Braun last edited by
          Das Anlegen des Ordners hat geholfen.
          thommy@DietPi:/opt/iobroker$ sudo mkdir /home/iobroker
          thommy@DietPi:/opt/iobroker$ sudo chown iobroker:iobroker /home/iobroker
          thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
          NPM version: 6.14.17
          Installing iobroker.sonoff@2.5.1... (System call)
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
          + iobroker.sonoff@2.5.1
          added 15 packages from 19 contributors in 37.07s
          38 packages are looking for funding
            run `npm fund` for details
          host.DietPi install adapter sonoff
          upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
          upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
          upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
          upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
          host.DietPi object system.adapter.sonoff created/updated
          host.DietPi create instance sonoff
          host.DietPi object system.adapter.sonoff.0.alive created
          host.DietPi object system.adapter.sonoff.0.connected created
          host.DietPi object system.adapter.sonoff.0.compactMode created
          host.DietPi object system.adapter.sonoff.0.cpu created
          host.DietPi object system.adapter.sonoff.0.cputime created
          host.DietPi object system.adapter.sonoff.0.memHeapUsed created
          host.DietPi object system.adapter.sonoff.0.memHeapTotal created
          host.DietPi object system.adapter.sonoff.0.memRss created
          host.DietPi object system.adapter.sonoff.0.uptime created
          host.DietPi object system.adapter.sonoff.0.inputCount created
          host.DietPi object system.adapter.sonoff.0.outputCount created
          host.DietPi object system.adapter.sonoff.0.eventLoopLag created
          host.DietPi object system.adapter.sonoff.0.sigKill created
          host.DietPi object system.adapter.sonoff.0.logLevel created
          host.DietPi object sonoff.0.info created
          host.DietPi object sonoff.0.info.connection created
          host.DietPi object system.adapter.sonoff.0 created
          • Glasfaser
            Glasfaser @Thomas Braun last edited by
            @thomas-braun sagte in Error 25:
            Dietpi ist abgespeckt , habe es als VM ( Grafana / Influx )
              Thomas Braun Most Active @Thomas Brodmann last edited by
              @thomas-brodmann
              ls -la /home/
              Thomas Brodmann 1 Reply Last reply Reply Quote 0
                Homoran Global Moderator Administrators @Glasfaser last edited by
                @glasfaser sagte in Error 25:
                ich hab damals iobroker darauf nicht ans laufen gebracht. Hätte zu viele Klimmzüge gebraucht, wo ich mich nicht mit auskenne
                • Thomas Brodmann
                  thommy@DietPi:/opt/iobroker$ ls -la /home/
                  insgesamt 20
                  drwxr-xr-x  5 root     root     4096 15. Jun 20:09 .
                  drwxr-xr-x 18 root     root     4096 29. Mai 14:11 ..
                  drwxr-xr-x  2 dietpi   dietpi   4096 19. Okt 2021  dietpi
                  drwxr-xr-x  3 iobroker iobroker 4096 15. Jun 20:11 iobroker
                  drwxr-xr-x  9 thommy   thommy   4096 15. Jun 19:58 thommy
                  Vielen lieben Dank für eure Großartige hilfe!!!
                    Homoran Global Moderator Administrators @Thomas Brodmann last edited by
                    @thomas-brodmann
                    und das hier?
                    @Thomas-Braun
                    @homoran sagte in Error 25:
                    @thomas-braun bist du sicher dass da nicht noch mehr krumm ist?
                    ich würde mal in dem Verzeichniss mal schauen was da drin ist ..!?
                    sudo ls -la /home/thommy/
                    • Thomas Brodmann
                      Thomas Brodmann @Homoran last edited by
                      thommy@DietPi:/opt/iobroker$ sudo ls -la /home/thommy/
                      insgesamt 64
                      drwxr-xr-x 9 thommy thommy 4096 15. Jun 19:58 .
                      drwxr-xr-x 5 root   root   4096 15. Jun 20:09 ..
                      -rw------- 1 thommy thommy 5313 15. Jun 16:44 .bash_history
                      -rw-r--r-- 1 thommy thommy  220  4. Nov 2021  .bash_logout
                      -rw-r--r-- 1 thommy thommy 3716 15. Jun 19:58 .bashrc
                      drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .cache
                      drwx------ 4 thommy thommy 4096  4. Nov 2021  .config
                      drwxr-xr-x 3 thommy thommy 4096 15. Jun 12:49 i0broker
                      drwxr-xr-x 2 thommy thommy 4096  4. Nov 2021  .iobroker
                      drwx------ 3 thommy thommy 4096  4. Nov 2021  .local
                      lrwxrwxrwx 1 root   root     13 15. Jun 18:31 node -> /usr/bin/node
                      lrwxrwxrwx 1 root   root     15 15. Jun 18:31 nodejs -> /usr/bin/nodejs
                      -rw------- 1 thommy thommy    0 15. Jun 18:37 .node_repl_history
                      drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .npm
                      -rw------- 1 thommy thommy   36 15. Jun 14:09 .npmrc
                      -rw-r--r-- 1 thommy thommy  807  4. Nov 2021  .profile
                      drwxr-xr-x 3 thommy thommy 4096  4. Nov 2021  .terminfo
                      -rw-r--r-- 1 thommy thommy 2945  1. Mai 07:27 terminfo.txt
                      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        Glasfaser @Thomas Brodmann last edited by
                        @thomas-brodmann
                        sieht schon Witzig aus .... das Verzeichniss
                          @thomas-brodmann
                          Die Essentials sind dann jetzt da.
                          Warum der iobroker kein Zuhause hat(te) wäre aber interessant zu wissen.
                          Muss mir vielleicht das Diät-Zeuch mal anschauen, wie das so tickt.
                          Hast du die Kiste mal komplett neugebootet?
                          Danach bitte den
                          iobroker fix
                          nochmal. Vielleicht ruckelt sich sudoers mit vorhandenem ~ jetzt zurecht.
                          Homoran Thomas Brodmann 2 Replies Last reply Reply Quote 0
                            @thomas-brodmann sagte in Error 25:
                            @Glasfaser
                            Das ist viel 'witziger'...
                            Also doch wieder als root rumgepfuscht...
                              @thomas-brodmann
                              ist das eine Null in i0Broker??
                              • Thomas Brodmann
                                Node und nodejs muss doch als sudo installiert werden.
                                Oder nicht?
                                • Glasfaser
                                  Glasfaser @Homoran last edited by
                                  Ja ... wie Null Bock
                                    aber nicht so wie @Thomas-Brodmann node vorher mit der Hand installieren
                                    Da hab ich auch noch keine Antwort
                                      Oder nicht?
                                      Nein!
                                      die müssen gar nicht installiert wrden, das macht der Installer.
                                      • Thomas Brodmann
                                        Steht aber so in der Beschreibung:
                                        Node.js neu installieren für Linux und Raspberry 2/3
                                        curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                        sudo apt install -y nodejs
                                        sudo reboot]
                                          Homoran Global Moderator Administrators @Thomas Brodmann last edited by Homoran
                                          wo?
                                          rotes Ausrufezeichen gelesen?
                                          mit dem aktuellen Installer von ioBroker (siehe unten) wird auf einem System ohne node.js automatisch die aktuell empfohlene Version von node.js mit installiert! Eine vorherige separate Installation von node.js ist somit nicht mehr nötig.
                                          • Thomas Brodmann
                                            thommy@DietPi:~$ iobroker stop
                                            Stopping iobroker controller daemon...
                                            iobroker controller daemon stopped.
                                            No "killall.sh" script found. Just stop.
                                            thommy@DietPi:~$ iobroker fix
                                            library: loaded
                                            Library version=2022-06-15
                                                Welcome to the ioBroker installation fixer!
                                                Script version: 2022-06-03
                                                You might need to enter your password a couple of times.
                                                Installing prerequisites (1/3)
                                            [sudo] Passwort für thommy:
                                            OK:1 https://deb.debian.org/debian bullseye InRelease
                                            OK:2 https://deb.debian.org/debian bullseye-updates InRelease
                                            OK:3 https://deb.debian.org/debian-security bullseye-security InRelease
                                            OK:4 https://deb.debian.org/debian bullseye-backports InRelease
                                            OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                                            OK:5 https://armbian.site-meganet.com/apt bullseye InRelease
                                            Paketlisten werden gelesen… Fertig
                                            Installed gcc-c++
                                                Checking ioBroker user and directory permissions (2/3)
                                            Created /etc/sudoers.d/iobroker
                                            Fixing directory permissions...
                                                Checking autostart (3/3)
                                            Enabling autostart...
                                                Your installation was fixed successfully
                                                Run iobroker start to start ioBroker again!
                                            thommy@DietPi:~$ iobroker start
                                            Starting iobroker controller daemon...
                                            iobroker controller daemon started. PID: 2094
                                            thommy@DietPi:~$
                                            error 25 error process exited with cod
                                            1939
