    4. Error 25
    Error 25
    • Thomas Brodmann
      Thomas Brodmann @Thomas Braun last edited by
      Das Anlegen des Ordners hat geholfen.
      thommy@DietPi:/opt/iobroker$ sudo mkdir /home/iobroker
      thommy@DietPi:/opt/iobroker$ sudo chown iobroker:iobroker /home/iobroker
      thommy@DietPi:/opt/iobroker$ iobroker add sonoff --host DietPi --debug
      NPM version: 6.14.17
      Installing iobroker.sonoff@2.5.1... (System call)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      + iobroker.sonoff@2.5.1
      added 15 packages from 19 contributors in 37.07s
      38 packages are looking for funding
        run `npm fund` for details
      host.DietPi install adapter sonoff
      upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
      upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m.html index_m.html text/html
      upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.png sonoff.png image/png
      upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.js words.js application/javascript
      host.DietPi object system.adapter.sonoff created/updated
      host.DietPi create instance sonoff
      host.DietPi object system.adapter.sonoff.0.alive created
      host.DietPi object system.adapter.sonoff.0.connected created
      host.DietPi object system.adapter.sonoff.0.compactMode created
      host.DietPi object system.adapter.sonoff.0.cpu created
      host.DietPi object system.adapter.sonoff.0.cputime created
      host.DietPi object system.adapter.sonoff.0.memHeapUsed created
      host.DietPi object system.adapter.sonoff.0.memHeapTotal created
      host.DietPi object system.adapter.sonoff.0.memRss created
      host.DietPi object system.adapter.sonoff.0.uptime created
      host.DietPi object system.adapter.sonoff.0.inputCount created
      host.DietPi object system.adapter.sonoff.0.outputCount created
      host.DietPi object system.adapter.sonoff.0.eventLoopLag created
      host.DietPi object system.adapter.sonoff.0.sigKill created
      host.DietPi object system.adapter.sonoff.0.logLevel created
      host.DietPi object sonoff.0.info created
      host.DietPi object sonoff.0.info.connection created
      host.DietPi object system.adapter.sonoff.0 created
      • Glasfaser
        Glasfaser @Thomas Braun last edited by
        @thomas-braun sagte in Error 25:
        auch auf Diät sitzt und nur Knäckebrot bekommt.
        Dietpi ist abgespeckt , habe es als VM ( Grafana / Influx )
          Thomas Braun Most Active @Thomas Brodmann last edited by
          @thomas-brodmann
          ls -la /home/
          Thomas Brodmann 1 Reply Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Glasfaser last edited by
            @glasfaser sagte in Error 25:
            ich hab damals iobroker darauf nicht ans laufen gebracht. Hätte zu viele Klimmzüge gebraucht, wo ich mich nicht mit auskenne
            • Thomas Brodmann
              thommy@DietPi:/opt/iobroker$ ls -la /home/
              insgesamt 20
              drwxr-xr-x  5 root     root     4096 15. Jun 20:09 .
              drwxr-xr-x 18 root     root     4096 29. Mai 14:11 ..
              drwxr-xr-x  2 dietpi   dietpi   4096 19. Okt 2021  dietpi
              drwxr-xr-x  3 iobroker iobroker 4096 15. Jun 20:11 iobroker
              drwxr-xr-x  9 thommy   thommy   4096 15. Jun 19:58 thommy
              Vielen lieben Dank für eure Großartige hilfe!!!
                Homoran Global Moderator Administrators @Thomas Brodmann last edited by
                @thomas-brodmann
                und das hier?
                @Thomas-Braun
                @homoran sagte in Error 25:
                @thomas-braun bist du sicher dass da nicht noch mehr krumm ist?
                ich würde mal in dem Verzeichniss mal schauen was da drin ist ..!?
                sudo ls -la /home/thommy/
                • Thomas Brodmann
                  Thomas Brodmann @Homoran last edited by
                  thommy@DietPi:/opt/iobroker$ sudo ls -la /home/thommy/
                  insgesamt 64
                  drwxr-xr-x 9 thommy thommy 4096 15. Jun 19:58 .
                  drwxr-xr-x 5 root   root   4096 15. Jun 20:09 ..
                  -rw------- 1 thommy thommy 5313 15. Jun 16:44 .bash_history
                  -rw-r--r-- 1 thommy thommy  220  4. Nov 2021  .bash_logout
                  -rw-r--r-- 1 thommy thommy 3716 15. Jun 19:58 .bashrc
                  drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .cache
                  drwx------ 4 thommy thommy 4096  4. Nov 2021  .config
                  drwxr-xr-x 3 thommy thommy 4096 15. Jun 12:49 i0broker
                  drwxr-xr-x 2 thommy thommy 4096  4. Nov 2021  .iobroker
                  drwx------ 3 thommy thommy 4096  4. Nov 2021  .local
                  lrwxrwxrwx 1 root   root     13 15. Jun 18:31 node -> /usr/bin/node
                  lrwxrwxrwx 1 root   root     15 15. Jun 18:31 nodejs -> /usr/bin/nodejs
                  -rw------- 1 thommy thommy    0 15. Jun 18:37 .node_repl_history
                  drwxr-xr-x 5 thommy thommy 4096 15. Jun 14:14 .npm
                  -rw------- 1 thommy thommy   36 15. Jun 14:09 .npmrc
                  -rw-r--r-- 1 thommy thommy  807  4. Nov 2021  .profile
                  drwxr-xr-x 3 thommy thommy 4096  4. Nov 2021  .terminfo
                  -rw-r--r-- 1 thommy thommy 2945  1. Mai 07:27 terminfo.txt
                  Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Glasfaser @Thomas Brodmann last edited by
                    @thomas-brodmann
                    sieht schon Witzig aus .... das Verzeichniss
                      @thomas-brodmann
                      Die Essentials sind dann jetzt da.
                      Warum der iobroker kein Zuhause hat(te) wäre aber interessant zu wissen.
                      Muss mir vielleicht das Diät-Zeuch mal anschauen, wie das so tickt.
                      Hast du die Kiste mal komplett neugebootet?
                      Danach bitte den
                      iobroker fix
                      nochmal. Vielleicht ruckelt sich sudoers mit vorhandenem ~ jetzt zurecht.
                      Homoran Thomas Brodmann 2 Replies Last reply Reply Quote 0
                        @thomas-brodmann sagte in Error 25:
                        @Glasfaser
                        Das ist viel 'witziger'...
                        Also doch wieder als root rumgepfuscht...
                          @thomas-brodmann
                          ist das eine Null in i0Broker??
                          • Thomas Brodmann
                            Node und nodejs muss doch als sudo installiert werden.
                            Oder nicht?
                            • Glasfaser
                              Glasfaser @Homoran last edited by
                              Ja ... wie Null Bock
                                aber nicht so wie @Thomas-Brodmann node vorher mit der Hand installieren
                                Da hab ich auch noch keine Antwort
                                  Oder nicht?
                                  Nein!
                                  die müssen gar nicht installiert wrden, das macht der Installer.
                                  • Thomas Brodmann
                                    Steht aber so in der Beschreibung:
                                    Node.js neu installieren für Linux und Raspberry 2/3
                                    curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                    sudo apt install -y nodejs
                                    sudo reboot]
                                      Homoran Global Moderator Administrators @Thomas Brodmann last edited by Homoran
                                      wo?
                                      rotes Ausrufezeichen gelesen?
                                      mit dem aktuellen Installer von ioBroker (siehe unten) wird auf einem System ohne node.js automatisch die aktuell empfohlene Version von node.js mit installiert! Eine vorherige separate Installation von node.js ist somit nicht mehr nötig.
                                      • Thomas Brodmann
                                        thommy@DietPi:~$ iobroker stop
                                        Stopping iobroker controller daemon...
                                        iobroker controller daemon stopped.
                                        No "killall.sh" script found. Just stop.
                                        thommy@DietPi:~$ iobroker fix
                                        library: loaded
                                        Library version=2022-06-15
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2022-06-03
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/3)
                                        [sudo] Passwort für thommy:
                                        OK:1 https://deb.debian.org/debian bullseye InRelease
                                        OK:2 https://deb.debian.org/debian bullseye-updates InRelease
                                        OK:3 https://deb.debian.org/debian-security bullseye-security InRelease
                                        OK:4 https://deb.debian.org/debian bullseye-backports InRelease
                                        OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                                        OK:5 https://armbian.site-meganet.com/apt bullseye InRelease
                                        Paketlisten werden gelesen… Fertig
                                        Installed gcc-c++
                                            Checking ioBroker user and directory permissions (2/3)
                                        Created /etc/sudoers.d/iobroker
                                        Fixing directory permissions...
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        thommy@DietPi:~$ iobroker start
                                        Starting iobroker controller daemon...
                                        iobroker controller daemon started. PID: 2094
                                        thommy@DietPi:~$
                                          Thomas Braun Most Active @Thomas Brodmann last edited by Thomas Braun
                                          Oder nicht?
                                          Pakete installiert grundsätzlich natürlich immer mit root-Rechten.
                                          Das führt aber nicht zu Links dazu im /home von thommy. (Die dann auch noch dem root gehören.)
                                          • Thomas Brodmann
                                            Da seit ihr besser in dem Thema als ich.
                                            error 25 error process exited with cod
                                            1939
