    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
    • DJMarc75
      DJMarc75 last edited by
      Frage zu Hue-Extended: eigentlich dachte ich dass da der Status meiner Leuchtmittel aufgeführt wird. Aber dem ist nicht so. Hab da zwar einige Einträge in der JSON aber eher auf Battery bezogen, was ja bei Leuchtmitteln eher unpraktisch ist.
      {"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"20 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"155 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"149 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"6 Stunden"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"5 Tagen"},{"Device":"State","Adapter":"Hue Extended","Battery":" - ","Last_contact":"5 Stunden"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"7 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Config","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"}
      kleiner Auszug 👍
        A Former User @DJMarc75 last edited by
        @djmarc75 kannst du mir mal ein screenshot der Objekt Struktur senden? Habe Hue Extended nur aus screenshots auf gut Glück mit reingenommen. Was aktuelles würde mir vielleicht helfen.
        • DJMarc75
          DJMarc75 @Guest last edited by DJMarc75
          @ciddi89
          Das wäre der eigentlich sinnvolle Datenpunkt für Deinen tollen Adapter
          hue-extended.0.xxx.state.reachable
          Edit: xxx = Porno und quasi zu ersetzen 😂
            @djmarc75 said in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
            und Geräte mit Batterien liegen in
            hue-extended.0.xxx.config.battery
            • DJMarc75
              @ciddi89 sagte in Test Adapter Device-Watcher v0.0.x GitHub/Latest:
              mit Batterien
              Du ich hab da von Philips nur die Dimmer Switches und da sind die in
              hue-extended.0.sensors.xxx.config.battery
              Da gibts ja noch Bewegungsmelder aber da hab ich keinen. Möglicherwisse sind die auch unter Sensors aufgeführt ?!
                Denke ich mal. Habe es gerade neu hochgeladen. Kannst du bitte einmal den Adapter drüber installieren und gucken ob es nun passt? Bei der mega Verschachtelung musste ich die Pfade noch eine ebene weiter zerlegen damit er den korrekten device Namen und battery state, falls vorhanden, nimmt.
                • DJMarc75
                  @ciddi89
                  {"Device":"Wohnzimmer 2","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Wohnzimmer 4","Adapter":"Hue Extended","Battery":" - ","Last_contact":"159 Tagen"},{"Device":"Wohnzimmer 6","Adapter":"Hue Extended","Battery":" - ","Last_contact":"8 Stunden"},{"Device":"Play rechts","Adapter":"Hue Extended","Battery":" - ","Last_contact":"5 Tagen"},{"Device":"Kinderzimmer","Adapter":"Hue Extended","Battery":" - ","Last_contact":"7 Stunden"},{"Device":"Nachttisch Iris","Adapter":"Hue Extended","Battery":"100%","Last_contact":"159 Tagen"
                  kleiner Auszug .... hm, da scheint das mit dem "last contact" schon nicht zu passen. Battery wird aber angezeigt
                    @djmarc75 sieht aber schon mal deutlich besser aus als vorher. Was sagen denn die Zeit Stempel von zb. deinem Device ‚Wohnzimmer 2‘ ?
                    Scheint so als würde der Datenpunkt nicht regelmäßig aktualisiert werden. Wäre ja auch nicht so schlimm wenn es so wäre da die Geräte erst als offline gelten wenn der Datenpunkt auf false ist. Hier spielt der Zeitfaktor keine Rolle.
                    • DJMarc75
                      Von welchem Datenpunkt ?
                      Wenn Du den "reachable" meinst dann steht Zeitstempel und zuletzt geändert auf 09.01.2022. Am 9.1. hab ich mein System neu aufgesetzt, falls Du fragst. 😀
                        @djmarc75 ja genau. Dann passt es ja aber. Ansonsten brauche ich einen anderen Datenpunkt wo er sich zumindest die Zeit zieht.
                        • david83
                          david83 last edited by
                          @ciddi89
                          Mit dem Ping Adapter funktioniert wunderbar. Danke
                          • DJMarc75
                            Da wirds dann etwas knifflig da der HueExtendedAdapter die Lampen, nach eingestellter Pollzeit, quasi immer als "true" erkennt - wenn diese mit Strom versorgt und damit im HUB angemeldet sind.
                              @djmarc75 ja das weiß ich noch das der pollt. Hatte den ja damals auch mal eine Zeit genutzt zum Testen. Solange aber der Datenpunkt reachable zuverlässig auf false geht wenn die Lampe nicht mehr erreichbar ist, ist alles gut dann kann man die Zeit außer acht lassen. Knifflig ist es aber auch nicht. Solange da ein Datenpunkt ist der regelmäßig aktualisiert wird, könnte man den für den für Zeitpunkt des letzten Kontakt nehmen. Es wird aber trotzdem für die Erreichbarkeit Der reachable genutzt. Geht ja nur um die Zeit wann man zuletzt mit dem Geräte kommuniziert hat. Wenn da aber so ein Datenpunkt nicht mit bei ist dann muss man damit so leben 🙈
                              • DJMarc75
                                Grad nochmal getestet und JA schaltet zuverlässig beim Polling.
                                  @djmarc75 ok danke für die Rückmeldung 😊
                                  • david83
                                    david83 last edited by david83
                                    @ciddi89
                                    Ich hab da mal ne Frage, jedesmal wenn der Cron läuft (10 min Intervall) wird die Offlinezeit der Geräte auf die aktuelle Uhrzeit geändert. Dies passiert beim Ping und DECT Adapter. Beim ZigBee Adapter werden Geräte die offline sind in Stunden und Tagen angezeigt.
                                    Das ist doch nicht richtig oder?
                                      A Former User @david83 last edited by
                                      @david83 doch das ist so richtig. Am Anfang des topics hieß es das es sonst zur Verwirrung kommen kann wenn da steht letzter Kontakt 5 min aber der letzte Lauf des Adapters vor 45 min war. Muss sagen mich persönlich störte es nicht. Man weiß ja das der Adapter nur alle X min durch läuft. Und ich denke ich werde sowieso die Standard Zeit von 60 min runter setzen. Naja langer Rede kurzer Sinn: Testweise ist es nun so das alles was unter drei Stunden ist wird nun als Uhrzeit angezeigt.
                                      david83 da_Woody 2 Replies Last reply Reply Quote 0
                                      • david83
                                        david83 @Guest last edited by david83
                                        @ciddi89
                                        --- Naja langer Rede kurzer Sinn: Testweise ist es nun so das alles was unter drei Stunden ist wird nun als Uhrzeit angezeigt. ---
                                        OK das stört mich nicht, aber zumindest das Gerät David Handy ist definitiv seit Freitag 17:00 nicht mehr im Netz und ist offline. Angezeigt werden trotzdem keine Stunden oder Tage...
                                          @david83 ok das steht auch so im Zeitstempel vom Datenpunkt Alive?
                                          david83 1 Reply Last reply Reply Quote 0
                                          • Jabba_the_Hutt
                                            Jabba_the_Hutt last edited by
                                            ESPHome auch geplant?
                                            1462
                                            499998
