    4. Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **
      Tontechniker @OpenSourceNomad last edited by Tontechniker
      @opensourcenomad Da stehen bei mir natürlich Zahlen (jetzt xxx)!
      Mittels IP.
      OpenSourceNomad 1 Reply Last reply Reply Quote 1
      • OpenSourceNomad
        OpenSourceNomad Most Active @Tontechniker last edited by
        @tontechniker siehst du irgendwas unanständiges in dem log von adapter bzw. in esphome logs?
          @opensourcenomad Ich hab mal den Programmiervorgang protokolliert. Wenn ich die Oberfläche von ESPhome mit der Darstellung beider Geräte anschaue und da den Log anwähle, sind beide gleich??
          Using 'COM7' as serial port.
          Connecting....
          Detecting chip type... Unsupported detection protocol, switching and trying again...
          Connecting....
          Detecting chip type... ESP8266
          Connecting. (94 %)Writing at 0x00061200... (100 %)Wrote 415328 bytes (290163 compressed) at 0x00000000 in 6.8 seconds (effective 489.8 kbit/s)...
          Hash of data verified.
          Leaving...
          Hard Resetting...
          Hard resetting via RTS pin...
          Done! Flashing is complete!
          Showing logs:
          [21:49:52][I][logger:242]: Log initialized
          [21:49:52][C][ota:461]: There have been 0 suspected unsuccessful boot attempts.
          [21:49:52][I][app:029]: Running through setup()...
          [21:49:52][I][i2c.arduino:161]: Performing I2C bus recovery
          [21:49:52][C][bmp280.sensor:056]: Setting up BMP280...
          [21:49:52][C][wifi:037]: Setting up WiFi...
          [21:49:52][D][wifi:373]: Starting scan...
          [21:49:52][D][bmp280.sensor:149]: Got temperature=27.1°C pressure=991.4hPa
          [21:49:52][D][sensor:124]: 'Aussentemperatur': Sending state 27.07000 °C with 1 decimals of accuracy
          [21:49:52][D][sensor:124]: 'Luftdruck': Sending state 991.35236 hPa with 1 decimals of accuracy
          [21:49:58][D][wifi:388]: Found networks:
          [21:49:58][I][wifi:431]: - 'Eisenbahn' (F0:B0:14:B0:E8:97) ▂▄▆█
          [21:49:58][D][wifi:433]:     Channel: 1
          [21:49:58][D][wifi:434]:     RSSI: -68 dB
          [21:49:58][I][wifi:431]: - 'Eisenbahn' (C8:0E:14:5B:01:ED) ▂▄▆█
          [21:49:58][D][wifi:434]:     RSSI: -70 dB
          [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (F2:B0:14:B0:E8:97) ▂▄▆█
          [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (CA:0E:14:5B:01:ED) ▂▄▆█
          [21:49:58][D][wifi:436]: - 'FRITZ!Box 7560 XH' (DC:15:C8:D7:BB:66) ▂▄▆█
          [21:49:58][D][wifi:436]: - 'Ansorge' (E8:DF:70:33:48:E6) ▂▄▆█
          [21:49:58][D][wifi:436]: - 'Ansorge Gastzugang' (EA:DF:70:33:48:E6) ▂▄▆█
          [21:49:58][I][wifi:248]: WiFi Connecting to 'Eisenbahn'...
          [21:49:59][I][wifi:505]: WiFi Connected!
          [21:49:59][C][wifi:353]:   Local MAC: 3C:71:BF:32:7E:26
          [21:49:59][C][wifi:354]:   SSID: 'Eisenbahn'
          [21:49:59][C][wifi:355]:   IP Address: 192.168.178.100
          [21:49:59][C][wifi:356]:   BSSID: F0:B0:14:B0:E8:97
          [21:49:59][C][wifi:358]:   Hostname: 'temp-pres-01'
          [21:49:59][C][wifi:360]:   Signal strength: -70 dB ▂▄▆█
          [21:49:59][C][wifi:364]:   Channel: 1
          [21:49:59][C][wifi:365]:   Subnet: 255.255.255.0
          [21:49:59][C][wifi:366]:   Gateway: 192.168.178.1
          [21:49:59][C][wifi:367]:   DNS1: 0.0.0.0
          [21:49:59][C][wifi:368]:   DNS2: 0.0.0.0
          [21:49:59][D][wifi:514]: Disabling AP...
          [21:49:59][C][ota:085]: Over-The-Air Updates:
          [21:49:59][C][ota:086]:   Address: 192.168.178.100:8266
          [21:49:59][C][ota:089]:   Using Password.
          [21:49:59][C][api:025]: Setting up Home Assistant API server...
          [21:49:59][I][app:062]: setup() finished successfully!
          [21:49:59][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 15 2022, 21:27:44
          [21:49:59][C][wifi:491]: WiFi:
          [21:49:59][C][logger:274]: Logger:
          [21:49:59][C][logger:275]:   Level: DEBUG
          [21:49:59][C][logger:276]:   Log Baud Rate: 115200
          [21:49:59][C][logger:277]:   Hardware UART: UART0
          [21:49:59][C][i2c.arduino:038]: I2C Bus:
          [21:49:59][C][i2c.arduino:039]:   SDA Pin: GPIO4
          [21:49:59][C][i2c.arduino:040]:   SCL Pin: GPIO5
          [21:49:59][C][i2c.arduino:041]:   Frequency: 100000 Hz
          [21:49:59][C][i2c.arduino:044]:   Recovery: bus successfully recovered
          [21:49:59][I][i2c.arduino:054]: Results from i2c bus scan:
          [21:49:59][I][i2c.arduino:060]: Found i2c device at address 0x76
          [21:49:59][C][bmp280.sensor:098]: BMP280:
          [21:49:59][C][bmp280.sensor:099]:   Address: 0x76
          [21:49:59][C][bmp280.sensor:111]:   IIR Filter: OFF
          [21:49:59][C][bmp280.sensor:112]:   Update Interval: 10.0s
          [21:49:59][C][bmp280.sensor:114]:   Temperature 'Aussentemperatur'
          [21:49:59][C][bmp280.sensor:114]:     Device Class: 'temperature'
          [21:49:59][C][bmp280.sensor:114]:     State Class: 'measurement'
          [21:49:59][C][bmp280.sensor:114]:     Unit of Measurement: '°C'
          [21:49:59][C][bmp280.sensor:114]:     Accuracy Decimals: 1
          [21:49:59][C][bmp280.sensor:115]:     Oversampling: 16x
          [21:49:59][C][bmp280.sensor:116]:   Pressure 'Luftdruck'
          [21:49:59][C][bmp280.sensor:116]:     Device Class: 'pressure'
          [21:49:59][C][bmp280.sensor:116]:     State Class: 'measurement'
          [21:49:59][C][bmp280.sensor:116]:     Unit of Measurement: 'hPa'
          [21:49:59][C][bmp280.sensor:116]:     Accuracy Decimals: 1
          [21:49:59][C][bmp280.sensor:117]:     Oversampling: 16x
          [21:49:59][C][captive_portal:088]: Captive Portal:
          [21:49:59][C][mdns:084]: mDNS:
          [21:49:59][C][mdns:085]:   Hostname: temp-pres-01
          [21:49:59][C][api:138]: API Server:
          [21:49:59][C][api:139]:   Address: 192.168.178.100:6053
          [21:49:59][C][api:143]:   Using noise encryption: NO
          [21:50:00][D][bmp280.sensor:149]: Got temperature=27.0°C pressure=991.3hPa
          [21:50:00][D][sensor:124]: 'Aussentemperatur': Sending state 27.04000 °C with 1 decimals of accuracy
          [21:50:00][D][sensor:124]: 'Luftdruck': Sending state 991.28705 hPa with 1 decimals of accuracy
          [21:50:10][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
          [21:50:10][D][sensor:124]: 'Aussentemperatur': Sending state 27.26000 °C with 1 decimals of accuracy
          [21:50:10][D][sensor:124]: 'Luftdruck': Sending state 991.69330 hPa with 1 decimals of accuracy
          [21:50:20][D][bmp280.sensor:149]: Got temperature=27.2°C pressure=991.7hPa
          [21:50:20][D][sensor:124]: 'Aussentemperatur': Sending state 27.25000 °C with 1 decimals of accuracy
          [21:50:20][D][sensor:124]: 'Luftdruck': Sending state 991.65674 hPa with 1 decimals of accuracy
          [21:50:30][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
          [21:50:30][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
          [21:50:30][D][sensor:124]: 'Luftdruck': Sending state 991.68585 hPa with 1 decimals of accuracy
          [21:50:40][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
          [21:50:40][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
          [21:50:40][D][sensor:124]: 'Luftdruck': Sending state 991.67389 hPa with 1 decimals of accuracy
          Und der andere (ist der "normale" Log:
          INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/test01.yaml...
          WARNING GPIO2 is a Strapping PIN and should be avoided.
          Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
          See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
          INFO Starting log output from 192.168.178.100 using esphome API
          INFO Successfully connected to 192.168.178.100
          [21:42:06][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 14 2022, 20:35:50
          [21:42:06][C][status_led:019]: Status LED:
          [21:42:06][C][status_led:020]:   Pin: GPIO2
          [21:42:06][C][wifi:491]: WiFi:
          [21:42:06][C][wifi:353]:   Local MAC: 3C:71:BF:AA:80:80
          [21:42:06][C][wifi:354]:   SSID: [redacted]
          [21:42:06][C][wifi:355]:   IP Address: 192.168.178.100
          [21:42:06][C][wifi:357]:   BSSID: [redacted]
          [21:42:06][C][wifi:358]:   Hostname: 'test01'
          [21:42:06][C][wifi:360]:   Signal strength: -73 dB ▂▄▆█
          [21:42:06][C][wifi:364]:   Channel: 1
          [21:42:06][C][wifi:365]:   Subnet: 255.255.255.0
          [21:42:06][C][wifi:366]:   Gateway: 192.168.178.1
          [21:42:06][C][wifi:367]:   DNS1: 0.0.0.0
          [21:42:06][C][wifi:368]:   DNS2: 0.0.0.0
          [21:42:06][C][logger:274]: Logger:
          [21:42:06][C][logger:275]:   Level: DEBUG
          [21:42:06][C][logger:276]:   Log Baud Rate: 115200
          [21:42:06][C][logger:277]:   Hardware UART: UART0
          [21:42:06][C][i2c.arduino:038]: I2C Bus:
          [21:42:06][C][i2c.arduino:039]:   SDA Pin: GPIO21
          [21:42:06][C][i2c.arduino:040]:   SCL Pin: GPIO22
          [21:42:06][C][i2c.arduino:041]:   Frequency: 100000 Hz
          [21:42:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
          [21:42:06][I][i2c.arduino:054]: Results from i2c bus scan:
          [21:42:06][I][i2c.arduino:060]: Found i2c device at address 0x40
          [21:42:06][C][hdc1080:031]: HDC1080:
          [21:42:06][C][hdc1080:032]:   Address: 0x40
          [21:42:06][C][hdc1080:036]:   Update Interval: 60.0s
          [21:42:06][C][hdc1080:037]:   Temperature 'Wintergarten Temperature'
          [21:42:06][C][hdc1080:037]:     Device Class: 'temperature'
          [21:42:06][C][hdc1080:037]:     State Class: 'measurement'
          [21:42:06][C][hdc1080:037]:     Unit of Measurement: '°C'
          [21:42:06][C][hdc1080:037]:     Accuracy Decimals: 1
          [21:42:06][C][hdc1080:038]:   Humidity 'Wintergarten Feuchte'
          [21:42:06][C][hdc1080:038]:     Device Class: 'humidity'
          [21:42:06][C][hdc1080:038]:     State Class: 'measurement'
          [21:42:06][C][hdc1080:038]:     Unit of Measurement: '%'
          [21:42:06][C][hdc1080:038]:     Accuracy Decimals: 0
          [21:42:06][C][captive_portal:088]: Captive Portal:
          [21:42:06][C][web_server:129]: Web Server:
          [21:42:06][C][web_server:130]:   Address: 192.168.178.100:80
          [21:42:06][C][mdns:084]: mDNS:
          [21:42:06][C][mdns:085]:   Hostname: test01
          [21:42:06][C][ota:085]: Over-The-Air Updates:
          [21:42:06][C][ota:086]:   Address: 192.168.178.100:3232
          [21:42:06][C][ota:089]:   Using Password.
          [21:42:06][C][api:138]: API Server:
          [21:42:06][C][api:139]:   Address: 192.168.178.100:6053
          [21:42:06][C][api:143]:   Using noise encryption: NO
          [21:42:13][D][sensor:125]: 'Wintergarten Temperature': Sending state 26.44714 °C with 1 decimals of accuracy
          [21:42:13][D][sensor:125]: 'Wintergarten Feuchte': Sending state 54.81568 % with 0 decimals of accuracy
          [21:42:13][D][hdc1080:069]: Got temperature=26.4°C humidity=54.8%
          Endlich fertig!
          • OpenSourceNomad
            @tontechniker said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
            sind beide gleich??
            also die haben zwei verschiedene Namen und sind offensichtlich auch zwei verschiedene Geräte aber die haben die gleiche statische IP Adresse konfiguriert? 🤔
            T 2 Replies Last reply Reply Quote 1
              @opensourcenomad Manche Dinge sind soooo einfach!!!
              Danke für Deine Hilfe!
              Ich hatte im Laufe meiner Versuche schon mal ohne Erfolg eine andere Webadresse eingegeben. Da war aber bestimmt noch etwas anderes nicht O.K.!
              Dir noch einen schönen Abend!
              Hans
                @opensourcenomad Hast Du mal ein yaml-Beispiel für mich, um eine LED auf dem Board blinken zu lassen? Habe schon einiges getestet, aber leider nicht erfolgreich.
                • OpenSourceNomad
                  Einfach so permanent direkt nach dem start oder soll es irgendeinen "Auslöser" (z.B. wenn er mit der Zentrale verbunden ist) geben?
                    @opensourcenomad Ohne Auslöser,nach dem Start.
                    • OpenSourceNomad
                      OpenSourceNomad Most Active @Tontechniker last edited by OpenSourceNomad
                      Okay, sprich wir machen das on_boot, dieser gehört in deinen vorhanden esphome: block 👇
                      # https://esphome.io/components/esphome.html#on-boot
                      esphome:
                        on_boot:
                          then:
                            - light.turn_on:
                                effect: pulse
                      Aber natürlich brauchen wir auch noch das light (monochromatic) mit der id meinetolleled (und den passenden output 👉 hier muss du deinen Pin definieren an dem die LED hängt!) 💡
                      # https://esphome.io/components/light/monochromatic.html
                      light:
                        - platform: monochromatic
                          name: "Meine tolle LED"
                          output: led_output
                          effects:
                            - pulse:
                      # Example output entry
                      output:
                        - platform: esp8266_pwm
                          pin: D1
                        @opensourcenomad Vielen Dank! Es funktioniert bei der esp8266, aber wie mache ich das bei der esp32 (er meckert "8266_pwm" an). Habe in esphome.io gesucht und habe nicht das Richtige gefunden.
                        • OpenSourceNomad
                          Der esp32 macht pwm in hardware, die passende Komponente hierfür schimpt sich ledc (zu finden unter den output components).
                            @opensourcenomad
                            Ich habe mal das "Enable fallback hotspot (captive portal) in case wifi connection fails" getestet (falsche wifi-Adresse eingegeben). Nach einer Minute ist das entsprechende Gerät im wifi-Netzwerk zu sehen. Wenn ich mich dann einlogge, erscheint immer die msn-Seite (Microsoft-Network) im Browser. Es sollte doch das "captive portal" im Browser erscheinen??
                            • OpenSourceNomad
                              Internet Explorer 6 vielleicht?
                              Du solltest per DHCP eine IP bekommen (nach dem du dich mit dem Fallback AP verbunden hast) und im Browser dann die 192.168.4.1 auflösen können wo sich das captive portal befindet.
                                @opensourcenomad said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                192.168.4.1
                                Auf meinem PC läuft Windows 10 und firefox. Habe als gateway die Adresse meiner FritzBox angegeben. Eben auch nochmal anstelle der FritzBox-Adresse mit 192.168.4.1 vesucht - keinen Erfolg!
                                • OpenSourceNomad
                                  @tontechniker nein, nix an der Fritze doktorn.
                                  Wenn ein ESP eine Fallback AP öffnet dann verbindest du dich aktiv mit deinem Endgerät (sprich Mobilfunkdelefen, Laptop, Computer) per WLAN mit genau diesem ESP. Du hast dann kein Internet (weil du nicht mehr mit deiner Fritze verbunden bist), aber dafür die Möglichkeit eben die WLAN Daten des esp's zu ändern. 💡
                                    @opensourcenomad Habe das entspr. Video auf youtube mehrfach angesehen und alles so gemacht wie angegeben. Leider keinen Erfolg!
                                    EDIT:
                                    Ursache der Fehlfunktion war eine falsche WLAN-Einstellung.
                                    • draexler
                                      draexler @OpenSourceNomad last edited by draexler
                                      @opensourcenomad @Tontechniker: Das verstehe ich nicht… Ich habe das nicht in meinen Code. Ich habe den ESP OTA geupdatet und seitdem bekomme ich ich diesen nicht mehr in die esphome.0 Instanz. Es kommt immer die Meldung: „Bad format. Expected 0 at the begin“
                                      Was kann ich machen?
                                      EDIT: hat sich erledigt. Problem war das ich einen Button eingebaut habe. Das wird nicht unterstützt. Habe einen Switch reingepackt und schon geht es.
                                      • david83
                                        david83 last edited by
                                        wer kann einem esphome Neuling helfen?
                                        Ich habe den Adapter installiert und einen Wemos d1 mini geflasht. Dieser verbindet sich auch und wird als online im esphome Dashboard angezeigt.
                                        Ich habe einen PN532 Rfid Tag Leser an Gpio4 und 5 angelötet und dieser wird auch laut Log erkannt. Ich bekomme es aber einfach nicht hin das der auch Tags liest. Wenn ich einen Tag auflege passiert einfach nichts. Auch keine Log ausgabe. Hat jemand eine Idee was ich falsch mache?
                                        Die Config:
                                        esphome:
                                        esp8266:
                                          board: esp01_1m
                                        # Enable logging
                                        logger:
                                        # Enable Home Assistant API
                                        api:
                                          password: "xxx"
                                        # OTA Update
                                        ota:
                                          password: "xxx"
                                        web_server:
                                          port: 80
                                        wifi:
                                          ssid: !secret wifi_ssid
                                          password: !secret wifi_password
                                          # Enable fallback hotspot (captive portal) in case wifi connection fails
                                          ap:
                                            ssid: "Esphome-Web-6Eed9A"
                                            password: "xxx"
                                        captive_portal:
                                        i2c:
                                          scan: false
                                          frequency: 400kHz
                                        pn532_i2c:
                                          update_interval: 1s
                                          on_tag:
                                            then:
                                              - text_sensor.template.publish:
                                                 state: !lambda 'return x;'
                                        text_sensor:
                                          - platform: template
                                        Das Log:
                                        INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-6eed9a.yaml...
                                        INFO Starting log output from esphome-web-6eed9a.local using esphome API
                                        INFO Successfully connected to esphome-web-6eed9a.local
                                        [20:27:06][I][app:102]: ESPHome version 2022.2.6 compiled on Jul 20 2022, 20:11:31
                                        [20:27:06][C][wifi:491]: WiFi:
                                        [20:27:06][C][wifi:353]:   Local MAC: EC:FA:BC:6E:ED:9A
                                        [20:27:06][C][wifi:354]:   SSID: [redacted]
                                        [20:27:06][C][wifi:355]:   IP Address: 192.168.178.34
                                        [20:27:06][C][wifi:356]:   BSSID: [redacted]
                                        [20:27:06][C][wifi:358]:   Hostname: 'esphome-web-6eed9a'
                                        [20:27:06][C][wifi:360]:   Signal strength: -62 dB ▂▄▆█
                                        [20:27:06][C][wifi:364]:   Channel: 2
                                        [20:27:06][C][wifi:365]:   Subnet: 255.255.255.0
                                        [20:27:06][C][wifi:366]:   Gateway: 192.168.178.1
                                        [20:27:06][C][wifi:367]:   DNS1: 192.168.178.1
                                        [20:27:06][C][wifi:368]:   DNS2: 0.0.0.0
                                        [20:27:06][C][logger:233]: Logger:
                                        [20:27:06][C][logger:234]:   Level: DEBUG
                                        [20:27:06][C][logger:235]:   Log Baud Rate: 115200
                                        [20:27:06][C][logger:236]:   Hardware UART: UART0
                                        [20:27:06][C][i2c.arduino:038]: I2C Bus:
                                        [20:27:06][C][i2c.arduino:039]:   SDA Pin: GPIO4
                                        [20:27:06][C][i2c.arduino:040]:   SCL Pin: GPIO5
                                        [20:27:06][C][i2c.arduino:041]:   Frequency: 400000 Hz
                                        [20:27:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
                                        [20:27:06][C][template.text_sensor:021]: Template Sensor 'RFID Tag'
                                        [20:27:06][C][pn532:347]: PN532:
                                        [20:27:06][C][pn532:359]:   Update Interval: 1.0s
                                        [20:27:06][C][pn532_i2c:128]:   Address: 0x24
                                        [20:27:06][C][captive_portal:144]: Captive Portal:
                                        [20:27:06][C][web_server:179]: Web Server:
                                        [20:27:06][C][web_server:180]:   Address: esphome-web-6eed9a.local:80
                                        [20:27:06][C][mdns:084]: mDNS:
                                        [20:27:06][C][mdns:085]:   Hostname: esphome-web-6eed9a
                                        [20:27:06][C][ota:085]: Over-The-Air Updates:
                                        [20:27:06][C][ota:086]:   Address: esphome-web-6eed9a.local:8266
                                        [20:27:06][C][ota:089]:   Using Password.
                                        [20:27:06][C][api:138]: API Server:
                                        [20:27:06][C][api:139]:   Address: esphome-web-6eed9a.local:6053
                                        [20:27:06][C][api:143]:   Using noise encryption: NO
                                        T FredF 2 Replies Last reply Reply Quote 0
                                          Tontechniker @david83 last edited by
                                          @david83 said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                          esp01_1m
                                          Hast Du das 532-Board im Set mit den RFID-Tags gekauft, oder separat? Ich frage, da es RFID-Tags mit unterschiedlichen Frequenzen gibt.
                                          david83 1 Reply Last reply Reply Quote 0
                                          • david83
                                            david83 @Tontechniker last edited by
                                            @tontechniker
                                            Ich habe das Board und die Tags getrennt gekauft. Allerdings habe ich das gleiche Setting schon im Einsatz mit EspEasy. Gleicher RFID Leser gleiche Tags und gleicher Ds Mini.
                                            Irgendwie hängt das aus meiner Sicht mit esphome zusammen. Vielleicht ist die config falsch?
                                            esphome
                                            41
                                            165
                                            48217
