    4. Test Adapter Repetier v0.0.x
    • coyote
      coyote Most Active @skvarel last edited by
      @skvarel Mist, ist nur ein Tippfehler. Moment.
      • coyote
        @skvarel jetzt nochmal bitte.
        • skvarel
          skvarel Developer last edited by
          LÄUFT 🙂
          Ich danke Dir !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          coyote 1 Reply Last reply Reply Quote 1
          • coyote
            @skvarel gerne👍
            • ostseereiter
              ostseereiter last edited by
              Hallo Freunde
              auch dieser Beitrag ist schon sehr alt. Trotzdem wer von euch benutzt diesen Adapter. Ich habe ihm probeweise installiert nur leider verliert er immer die Verbindung. Wer weiß warum?
              nstance system.adapter.repetier.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              repetier.0
              2022-06-20 11:40:00.596	error	The id "192_168_178_180." is invalid. Ids are not allowed to end in "."
              repetier.0
              2022-06-20 11:40:00.596	error	Error: The id "192_168_178_180." is invalid. Ids are not allowed to end in "." at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:148:23) at Adapter.setObjectNotExists (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:3181:23) at Request._callback (/opt/iobroker/node_modules/iobroker.repetier/main.js:474:37) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) at Request.emit (events.js:400:28) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10) at Request.emit (events.js:400:28) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12) at Object.onceWrapper (events.js:519:28) at IncomingMessage.emit (events.js:412:35)
              repetier.0
              2022-06-20 11:40:00.595	error	unhandled promise rejection: The id "192_168_178_180." is invalid. Ids are not allowed to end in "."
              repetier.0
              2022-06-20 11:40:00.594	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              repetier.0
              2022-06-20 11:40:00.584	error	The id "192_168_178_180." is invalid. Ids are not allowed to end in "."
              • Glasfaser
                Glasfaser @ostseereiter last edited by
                @ostseereiter sagte in Test Adapter Repetier v0.0.x:
                Laut LOG :
                Ein . am Ende der IP . Konfig von der Instanz richtig !?
                ostseereiter 1 Reply Last reply Reply Quote 0
                • ostseereiter
                  ostseereiter @Glasfaser last edited by
                  @glasfaser
                  das wundert mich auch ich habe dort kein Punkt nur die normale IP Adresse.
                    Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                    @ostseereiter
                    https://github.com/coyote1/ioBroker.repetier/issues/9
                    https://github.com/coyote1/ioBroker.repetier/issues/10
                    Der Adapter scheint aber verwaist zu sein.
                    philipphunger created this issue in coyote1/ioBroker.repetier
                    open Error ID when connecting #9
                    kollabo89 created this issue in coyote1/ioBroker.repetier
                    open problems connecting #10
                    • ostseereiter
                      ostseereiter @Thomas Braun last edited by
                      das soll in der main.js datei geändert werden nun muss ich die aber erst ma finden.
                        @ostseereiter
                        Die dürfte in
                        liegen.
                        • ostseereiter
                          Danke nun ist es grün.
                          31.7k
                          79.8k
                          3d drucker repetier adapter repetier server
                          12
                          69
                          5260
