    4. Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **
      Tontechniker @OpenSourceNomad last edited by Tontechniker
      @opensourcenomad Ich hab mal den Programmiervorgang protokolliert. Wenn ich die Oberfläche von ESPhome mit der Darstellung beider Geräte anschaue und da den Log anwähle, sind beide gleich??
      Using 'COM7' as serial port.
      Connecting....
      Detecting chip type... Unsupported detection protocol, switching and trying again...
      Connecting....
      Detecting chip type... ESP8266
      Connecting. (94 %)Writing at 0x00061200... (100 %)Wrote 415328 bytes (290163 compressed) at 0x00000000 in 6.8 seconds (effective 489.8 kbit/s)...
      Hash of data verified.
      Leaving...
      Hard Resetting...
      Hard resetting via RTS pin...
      Done! Flashing is complete!
      Showing logs:
      [21:49:52][I][logger:242]: Log initialized
      [21:49:52][C][ota:461]: There have been 0 suspected unsuccessful boot attempts.
      [21:49:52][I][app:029]: Running through setup()...
      [21:49:52][I][i2c.arduino:161]: Performing I2C bus recovery
      [21:49:52][C][bmp280.sensor:056]: Setting up BMP280...
      [21:49:52][C][wifi:037]: Setting up WiFi...
      [21:49:52][D][wifi:373]: Starting scan...
      [21:49:52][D][bmp280.sensor:149]: Got temperature=27.1°C pressure=991.4hPa
      [21:49:52][D][sensor:124]: 'Aussentemperatur': Sending state 27.07000 °C with 1 decimals of accuracy
      [21:49:52][D][sensor:124]: 'Luftdruck': Sending state 991.35236 hPa with 1 decimals of accuracy
      [21:49:58][D][wifi:388]: Found networks:
      [21:49:58][I][wifi:431]: - 'Eisenbahn' (F0:B0:14:B0:E8:97) ▂▄▆█
      [21:49:58][D][wifi:433]:     Channel: 1
      [21:49:58][D][wifi:434]:     RSSI: -68 dB
      [21:49:58][I][wifi:431]: - 'Eisenbahn' (C8:0E:14:5B:01:ED) ▂▄▆█
      [21:49:58][D][wifi:434]:     RSSI: -70 dB
      [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (F2:B0:14:B0:E8:97) ▂▄▆█
      [21:49:58][D][wifi:436]: - 'Eisenbahn Gastzugang' (CA:0E:14:5B:01:ED) ▂▄▆█
      [21:49:58][D][wifi:436]: - 'FRITZ!Box 7560 XH' (DC:15:C8:D7:BB:66) ▂▄▆█
      [21:49:58][D][wifi:436]: - 'Ansorge' (E8:DF:70:33:48:E6) ▂▄▆█
      [21:49:58][D][wifi:436]: - 'Ansorge Gastzugang' (EA:DF:70:33:48:E6) ▂▄▆█
      [21:49:58][I][wifi:248]: WiFi Connecting to 'Eisenbahn'...
      [21:49:59][I][wifi:505]: WiFi Connected!
      [21:49:59][C][wifi:353]:   Local MAC: 3C:71:BF:32:7E:26
      [21:49:59][C][wifi:354]:   SSID: 'Eisenbahn'
      [21:49:59][C][wifi:355]:   IP Address: 192.168.178.100
      [21:49:59][C][wifi:356]:   BSSID: F0:B0:14:B0:E8:97
      [21:49:59][C][wifi:358]:   Hostname: 'temp-pres-01'
      [21:49:59][C][wifi:360]:   Signal strength: -70 dB ▂▄▆█
      [21:49:59][C][wifi:364]:   Channel: 1
      [21:49:59][C][wifi:365]:   Subnet: 255.255.255.0
      [21:49:59][C][wifi:366]:   Gateway: 192.168.178.1
      [21:49:59][C][wifi:367]:   DNS1: 0.0.0.0
      [21:49:59][C][wifi:368]:   DNS2: 0.0.0.0
      [21:49:59][D][wifi:514]: Disabling AP...
      [21:49:59][C][ota:085]: Over-The-Air Updates:
      [21:49:59][C][ota:086]:   Address: 192.168.178.100:8266
      [21:49:59][C][ota:089]:   Using Password.
      [21:49:59][C][api:025]: Setting up Home Assistant API server...
      [21:49:59][I][app:062]: setup() finished successfully!
      [21:49:59][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 15 2022, 21:27:44
      [21:49:59][C][wifi:491]: WiFi:
      [21:49:59][C][logger:274]: Logger:
      [21:49:59][C][logger:275]:   Level: DEBUG
      [21:49:59][C][logger:276]:   Log Baud Rate: 115200
      [21:49:59][C][logger:277]:   Hardware UART: UART0
      [21:49:59][C][i2c.arduino:038]: I2C Bus:
      [21:49:59][C][i2c.arduino:039]:   SDA Pin: GPIO4
      [21:49:59][C][i2c.arduino:040]:   SCL Pin: GPIO5
      [21:49:59][C][i2c.arduino:041]:   Frequency: 100000 Hz
      [21:49:59][C][i2c.arduino:044]:   Recovery: bus successfully recovered
      [21:49:59][I][i2c.arduino:054]: Results from i2c bus scan:
      [21:49:59][I][i2c.arduino:060]: Found i2c device at address 0x76
      [21:49:59][C][bmp280.sensor:098]: BMP280:
      [21:49:59][C][bmp280.sensor:099]:   Address: 0x76
      [21:49:59][C][bmp280.sensor:111]:   IIR Filter: OFF
      [21:49:59][C][bmp280.sensor:112]:   Update Interval: 10.0s
      [21:49:59][C][bmp280.sensor:114]:   Temperature 'Aussentemperatur'
      [21:49:59][C][bmp280.sensor:114]:     Device Class: 'temperature'
      [21:49:59][C][bmp280.sensor:114]:     State Class: 'measurement'
      [21:49:59][C][bmp280.sensor:114]:     Unit of Measurement: '°C'
      [21:49:59][C][bmp280.sensor:114]:     Accuracy Decimals: 1
      [21:49:59][C][bmp280.sensor:115]:     Oversampling: 16x
      [21:49:59][C][bmp280.sensor:116]:   Pressure 'Luftdruck'
      [21:49:59][C][bmp280.sensor:116]:     Device Class: 'pressure'
      [21:49:59][C][bmp280.sensor:116]:     State Class: 'measurement'
      [21:49:59][C][bmp280.sensor:116]:     Unit of Measurement: 'hPa'
      [21:49:59][C][bmp280.sensor:116]:     Accuracy Decimals: 1
      [21:49:59][C][bmp280.sensor:117]:     Oversampling: 16x
      [21:49:59][C][captive_portal:088]: Captive Portal:
      [21:49:59][C][mdns:084]: mDNS:
      [21:49:59][C][mdns:085]:   Hostname: temp-pres-01
      [21:49:59][C][api:138]: API Server:
      [21:49:59][C][api:139]:   Address: 192.168.178.100:6053
      [21:49:59][C][api:143]:   Using noise encryption: NO
      [21:50:00][D][bmp280.sensor:149]: Got temperature=27.0°C pressure=991.3hPa
      [21:50:00][D][sensor:124]: 'Aussentemperatur': Sending state 27.04000 °C with 1 decimals of accuracy
      [21:50:00][D][sensor:124]: 'Luftdruck': Sending state 991.28705 hPa with 1 decimals of accuracy
      [21:50:10][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
      [21:50:10][D][sensor:124]: 'Aussentemperatur': Sending state 27.26000 °C with 1 decimals of accuracy
      [21:50:10][D][sensor:124]: 'Luftdruck': Sending state 991.69330 hPa with 1 decimals of accuracy
      [21:50:20][D][bmp280.sensor:149]: Got temperature=27.2°C pressure=991.7hPa
      [21:50:20][D][sensor:124]: 'Aussentemperatur': Sending state 27.25000 °C with 1 decimals of accuracy
      [21:50:20][D][sensor:124]: 'Luftdruck': Sending state 991.65674 hPa with 1 decimals of accuracy
      [21:50:30][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
      [21:50:30][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
      [21:50:30][D][sensor:124]: 'Luftdruck': Sending state 991.68585 hPa with 1 decimals of accuracy
      [21:50:40][D][bmp280.sensor:149]: Got temperature=27.3°C pressure=991.7hPa
      [21:50:40][D][sensor:124]: 'Aussentemperatur': Sending state 27.30000 °C with 1 decimals of accuracy
      [21:50:40][D][sensor:124]: 'Luftdruck': Sending state 991.67389 hPa with 1 decimals of accuracy
      Und der andere (ist der "normale" Log:
      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/test01.yaml...
      WARNING GPIO2 is a Strapping PIN and should be avoided.
      Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
      See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
      INFO Starting log output from 192.168.178.100 using esphome API
      INFO Successfully connected to 192.168.178.100
      [21:42:06][I][app:102]: ESPHome version 2022.5.1 compiled on Jun 14 2022, 20:35:50
      [21:42:06][C][status_led:019]: Status LED:
      [21:42:06][C][status_led:020]:   Pin: GPIO2
      [21:42:06][C][wifi:491]: WiFi:
      [21:42:06][C][wifi:353]:   Local MAC: 3C:71:BF:AA:80:80
      [21:42:06][C][wifi:354]:   SSID: [redacted]
      [21:42:06][C][wifi:355]:   IP Address: 192.168.178.100
      [21:42:06][C][wifi:357]:   BSSID: [redacted]
      [21:42:06][C][wifi:358]:   Hostname: 'test01'
      [21:42:06][C][wifi:360]:   Signal strength: -73 dB ▂▄▆█
      [21:42:06][C][wifi:364]:   Channel: 1
      [21:42:06][C][wifi:365]:   Subnet: 255.255.255.0
      [21:42:06][C][wifi:366]:   Gateway: 192.168.178.1
      [21:42:06][C][wifi:367]:   DNS1: 0.0.0.0
      [21:42:06][C][wifi:368]:   DNS2: 0.0.0.0
      [21:42:06][C][logger:274]: Logger:
      [21:42:06][C][logger:275]:   Level: DEBUG
      [21:42:06][C][logger:276]:   Log Baud Rate: 115200
      [21:42:06][C][logger:277]:   Hardware UART: UART0
      [21:42:06][C][i2c.arduino:038]: I2C Bus:
      [21:42:06][C][i2c.arduino:039]:   SDA Pin: GPIO21
      [21:42:06][C][i2c.arduino:040]:   SCL Pin: GPIO22
      [21:42:06][C][i2c.arduino:041]:   Frequency: 100000 Hz
      [21:42:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
      [21:42:06][I][i2c.arduino:054]: Results from i2c bus scan:
      [21:42:06][I][i2c.arduino:060]: Found i2c device at address 0x40
      [21:42:06][C][hdc1080:031]: HDC1080:
      [21:42:06][C][hdc1080:032]:   Address: 0x40
      [21:42:06][C][hdc1080:036]:   Update Interval: 60.0s
      [21:42:06][C][hdc1080:037]:   Temperature 'Wintergarten Temperature'
      [21:42:06][C][hdc1080:037]:     Device Class: 'temperature'
      [21:42:06][C][hdc1080:037]:     State Class: 'measurement'
      [21:42:06][C][hdc1080:037]:     Unit of Measurement: '°C'
      [21:42:06][C][hdc1080:037]:     Accuracy Decimals: 1
      [21:42:06][C][hdc1080:038]:   Humidity 'Wintergarten Feuchte'
      [21:42:06][C][hdc1080:038]:     Device Class: 'humidity'
      [21:42:06][C][hdc1080:038]:     State Class: 'measurement'
      [21:42:06][C][hdc1080:038]:     Unit of Measurement: '%'
      [21:42:06][C][hdc1080:038]:     Accuracy Decimals: 0
      [21:42:06][C][captive_portal:088]: Captive Portal:
      [21:42:06][C][web_server:129]: Web Server:
      [21:42:06][C][web_server:130]:   Address: 192.168.178.100:80
      [21:42:06][C][mdns:084]: mDNS:
      [21:42:06][C][mdns:085]:   Hostname: test01
      [21:42:06][C][ota:085]: Over-The-Air Updates:
      [21:42:06][C][ota:086]:   Address: 192.168.178.100:3232
      [21:42:06][C][ota:089]:   Using Password.
      [21:42:06][C][api:138]: API Server:
      [21:42:06][C][api:139]:   Address: 192.168.178.100:6053
      [21:42:06][C][api:143]:   Using noise encryption: NO
      [21:42:13][D][sensor:125]: 'Wintergarten Temperature': Sending state 26.44714 °C with 1 decimals of accuracy
      [21:42:13][D][sensor:125]: 'Wintergarten Feuchte': Sending state 54.81568 % with 0 decimals of accuracy
      [21:42:13][D][hdc1080:069]: Got temperature=26.4°C humidity=54.8%
      Endlich fertig!
      • OpenSourceNomad
        OpenSourceNomad Most Active @Tontechniker last edited by
        @tontechniker said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
        sind beide gleich??
        also die haben zwei verschiedene Namen und sind offensichtlich auch zwei verschiedene Geräte aber die haben die gleiche statische IP Adresse konfiguriert? 🤔
        T 2 Replies Last reply Reply Quote 1
          @opensourcenomad Manche Dinge sind soooo einfach!!!
          Danke für Deine Hilfe!
          Ich hatte im Laufe meiner Versuche schon mal ohne Erfolg eine andere Webadresse eingegeben. Da war aber bestimmt noch etwas anderes nicht O.K.!
          Dir noch einen schönen Abend!
          Hans
            @opensourcenomad Hast Du mal ein yaml-Beispiel für mich, um eine LED auf dem Board blinken zu lassen? Habe schon einiges getestet, aber leider nicht erfolgreich.
            • OpenSourceNomad
              Einfach so permanent direkt nach dem start oder soll es irgendeinen "Auslöser" (z.B. wenn er mit der Zentrale verbunden ist) geben?
                @opensourcenomad Ohne Auslöser,nach dem Start.
                • OpenSourceNomad
                  OpenSourceNomad Most Active @Tontechniker last edited by OpenSourceNomad
                  Okay, sprich wir machen das on_boot, dieser gehört in deinen vorhanden esphome: block 👇
                  # https://esphome.io/components/esphome.html#on-boot
                  esphome:
                    on_boot:
                      then:
                        - light.turn_on:
                            effect: pulse
                  Aber natürlich brauchen wir auch noch das light (monochromatic) mit der id meinetolleled (und den passenden output 👉 hier muss du deinen Pin definieren an dem die LED hängt!) 💡
                  # https://esphome.io/components/light/monochromatic.html
                  light:
                    - platform: monochromatic
                      name: "Meine tolle LED"
                      output: led_output
                      effects:
                        - pulse:
                  # Example output entry
                  output:
                    - platform: esp8266_pwm
                      pin: D1
                    @opensourcenomad Vielen Dank! Es funktioniert bei der esp8266, aber wie mache ich das bei der esp32 (er meckert "8266_pwm" an). Habe in esphome.io gesucht und habe nicht das Richtige gefunden.
                    • OpenSourceNomad
                      Der esp32 macht pwm in hardware, die passende Komponente hierfür schimpt sich ledc (zu finden unter den output components).
                        @opensourcenomad
                        Ich habe mal das "Enable fallback hotspot (captive portal) in case wifi connection fails" getestet (falsche wifi-Adresse eingegeben). Nach einer Minute ist das entsprechende Gerät im wifi-Netzwerk zu sehen. Wenn ich mich dann einlogge, erscheint immer die msn-Seite (Microsoft-Network) im Browser. Es sollte doch das "captive portal" im Browser erscheinen??
                        • OpenSourceNomad
                          Internet Explorer 6 vielleicht?
                          Du solltest per DHCP eine IP bekommen (nach dem du dich mit dem Fallback AP verbunden hast) und im Browser dann die 192.168.4.1 auflösen können wo sich das captive portal befindet.
                            @opensourcenomad said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                            192.168.4.1
                            Auf meinem PC läuft Windows 10 und firefox. Habe als gateway die Adresse meiner FritzBox angegeben. Eben auch nochmal anstelle der FritzBox-Adresse mit 192.168.4.1 vesucht - keinen Erfolg!
                            • OpenSourceNomad
                              @tontechniker nein, nix an der Fritze doktorn.
                              Wenn ein ESP eine Fallback AP öffnet dann verbindest du dich aktiv mit deinem Endgerät (sprich Mobilfunkdelefen, Laptop, Computer) per WLAN mit genau diesem ESP. Du hast dann kein Internet (weil du nicht mehr mit deiner Fritze verbunden bist), aber dafür die Möglichkeit eben die WLAN Daten des esp's zu ändern. 💡
                                @opensourcenomad Habe das entspr. Video auf youtube mehrfach angesehen und alles so gemacht wie angegeben. Leider keinen Erfolg!
                                EDIT:
                                Ursache der Fehlfunktion war eine falsche WLAN-Einstellung.
                                • draexler
                                  draexler @OpenSourceNomad last edited by draexler
                                  @opensourcenomad @Tontechniker: Das verstehe ich nicht… Ich habe das nicht in meinen Code. Ich habe den ESP OTA geupdatet und seitdem bekomme ich ich diesen nicht mehr in die esphome.0 Instanz. Es kommt immer die Meldung: „Bad format. Expected 0 at the begin“
                                  Was kann ich machen?
                                  EDIT: hat sich erledigt. Problem war das ich einen Button eingebaut habe. Das wird nicht unterstützt. Habe einen Switch reingepackt und schon geht es.
                                  • david83
                                    david83 last edited by
                                    wer kann einem esphome Neuling helfen?
                                    Ich habe den Adapter installiert und einen Wemos d1 mini geflasht. Dieser verbindet sich auch und wird als online im esphome Dashboard angezeigt.
                                    Ich habe einen PN532 Rfid Tag Leser an Gpio4 und 5 angelötet und dieser wird auch laut Log erkannt. Ich bekomme es aber einfach nicht hin das der auch Tags liest. Wenn ich einen Tag auflege passiert einfach nichts. Auch keine Log ausgabe. Hat jemand eine Idee was ich falsch mache?
                                    Die Config:
                                    esphome:
                                    esp8266:
                                      board: esp01_1m
                                    # Enable logging
                                    logger:
                                    # Enable Home Assistant API
                                    api:
                                      password: "xxx"
                                    # OTA Update
                                    ota:
                                      password: "xxx"
                                    web_server:
                                      port: 80
                                    wifi:
                                      ssid: !secret wifi_ssid
                                      password: !secret wifi_password
                                      # Enable fallback hotspot (captive portal) in case wifi connection fails
                                      ap:
                                        ssid: "Esphome-Web-6Eed9A"
                                        password: "xxx"
                                    captive_portal:
                                    i2c:
                                      scan: false
                                      frequency: 400kHz
                                    pn532_i2c:
                                      update_interval: 1s
                                      on_tag:
                                        then:
                                          - text_sensor.template.publish:
                                             state: !lambda 'return x;'
                                    text_sensor:
                                      - platform: template
                                    Das Log:
                                    INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-6eed9a.yaml...
                                    INFO Starting log output from esphome-web-6eed9a.local using esphome API
                                    INFO Successfully connected to esphome-web-6eed9a.local
                                    [20:27:06][I][app:102]: ESPHome version 2022.2.6 compiled on Jul 20 2022, 20:11:31
                                    [20:27:06][C][wifi:491]: WiFi:
                                    [20:27:06][C][wifi:353]:   Local MAC: EC:FA:BC:6E:ED:9A
                                    [20:27:06][C][wifi:354]:   SSID: [redacted]
                                    [20:27:06][C][wifi:355]:   IP Address: 192.168.178.34
                                    [20:27:06][C][wifi:356]:   BSSID: [redacted]
                                    [20:27:06][C][wifi:358]:   Hostname: 'esphome-web-6eed9a'
                                    [20:27:06][C][wifi:360]:   Signal strength: -62 dB ▂▄▆█
                                    [20:27:06][C][wifi:364]:   Channel: 2
                                    [20:27:06][C][wifi:365]:   Subnet: 255.255.255.0
                                    [20:27:06][C][wifi:366]:   Gateway: 192.168.178.1
                                    [20:27:06][C][wifi:367]:   DNS1: 192.168.178.1
                                    [20:27:06][C][wifi:368]:   DNS2: 0.0.0.0
                                    [20:27:06][C][logger:233]: Logger:
                                    [20:27:06][C][logger:234]:   Level: DEBUG
                                    [20:27:06][C][logger:235]:   Log Baud Rate: 115200
                                    [20:27:06][C][logger:236]:   Hardware UART: UART0
                                    [20:27:06][C][i2c.arduino:038]: I2C Bus:
                                    [20:27:06][C][i2c.arduino:039]:   SDA Pin: GPIO4
                                    [20:27:06][C][i2c.arduino:040]:   SCL Pin: GPIO5
                                    [20:27:06][C][i2c.arduino:041]:   Frequency: 400000 Hz
                                    [20:27:06][C][i2c.arduino:044]:   Recovery: bus successfully recovered
                                    [20:27:06][C][template.text_sensor:021]: Template Sensor 'RFID Tag'
                                    [20:27:06][C][pn532:347]: PN532:
                                    [20:27:06][C][pn532:359]:   Update Interval: 1.0s
                                    [20:27:06][C][pn532_i2c:128]:   Address: 0x24
                                    [20:27:06][C][captive_portal:144]: Captive Portal:
                                    [20:27:06][C][web_server:179]: Web Server:
                                    [20:27:06][C][web_server:180]:   Address: esphome-web-6eed9a.local:80
                                    [20:27:06][C][mdns:084]: mDNS:
                                    [20:27:06][C][mdns:085]:   Hostname: esphome-web-6eed9a
                                    [20:27:06][C][ota:085]: Over-The-Air Updates:
                                    [20:27:06][C][ota:086]:   Address: esphome-web-6eed9a.local:8266
                                    [20:27:06][C][ota:089]:   Using Password.
                                    [20:27:06][C][api:138]: API Server:
                                    [20:27:06][C][api:139]:   Address: esphome-web-6eed9a.local:6053
                                    [20:27:06][C][api:143]:   Using noise encryption: NO
                                    T FredF 2 Replies Last reply Reply Quote 0
                                      Tontechniker @david83 last edited by
                                      @david83 said in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                      esp01_1m
                                      Hast Du das 532-Board im Set mit den RFID-Tags gekauft, oder separat? Ich frage, da es RFID-Tags mit unterschiedlichen Frequenzen gibt.
                                      david83 1 Reply Last reply Reply Quote 0
                                      • david83
                                        david83 @Tontechniker last edited by
                                        @tontechniker
                                        Ich habe das Board und die Tags getrennt gekauft. Allerdings habe ich das gleiche Setting schon im Einsatz mit EspEasy. Gleicher RFID Leser gleiche Tags und gleicher Ds Mini.
                                        Irgendwie hängt das aus meiner Sicht mit esphome zusammen. Vielleicht ist die config falsch?
                                        • FredF
                                          FredF Most Active Forum Testing @david83 last edited by
                                          @david83 sagte in Benutzen von ESPHome an einem Beispiel **Update 05.01.22 **:
                                          PN532
                                          Hab den nicht in Benutzung, wenn ich aber hier nach gehe, fehlt dir der komplette Zweig binary sensor mit der eindeutigen ID des Tags.
                                          Y 1 Reply Last reply Reply Quote 0
                                          • Y
                                            Yoshi @FredF last edited by Yoshi
                                            Hallo Leute,
                                            ich komme einfach nicht mehr weiter. Ich habe einen ESP und einen mmwave Radar Sensor verlötet.
                                            Wenn ich nun alles überspiele, dann baut der ESP zum ESPHome keine richtige Verbindung auf. Immer kommen diese Fehermeldungen.
                                            Was ich auch komisch finde ist. In der Anleitung oben soll ich ja das Passwort für OTA vergeben und dann bei zufügen des Devices eingeben, aber er sagt immer falsches Passwort und wenn ich keins eingebe, dann nimmt er es. Baut sich kurz auf und dann warst das.
                                            esphome.0
                                            2022-07-22 17:15:41.347	warn	Client 192.168.0.88 Timeout, connection Lost, will reconnect automatically when device is available!
                                            esphome.0
                                            2022-07-22 17:15:36.384	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                            esphome.0
                                            2022-07-22 17:15:36.370	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                            esphome.0
                                            2022-07-22 17:15:06.315	warn	Client 192.168.0.88 Timeout, connection Lost, will reconnect automatically when device is available!
                                            esphome.0
                                            2022-07-22 17:15:01.348	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                            esphome.0
                                            2022-07-22 17:15:01.330	error	ESPHome client 192.168.0.88 TypeError: Cannot read property 'deserializeBinary' of undefined
                                            Wenn ich mich über Web draufwähle läuft es an sich. Ich sehe wie sich die Zustände ändern, aber auch hier bekomme ich das die Verbindung schliesst.
                                            [16:02:53][D][api:102]: Accepted 192.168.0.64
                                            [16:02:54][D][api:102]: Accepted 192.168.0.64
                                            [16:02:54][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                            [16:02:58][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                            [16:02:59][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                            [16:03:03][D][api:102]: Accepted 192.168.0.64
                                            [16:03:03][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                            [16:03:19][D][api:102]: Accepted 192.168.0.64
                                            [16:03:19][W][api.connection:083]: raspberrypi4-iob (192.168.0.64): Connection closed
                                            [16:03:21][D][api:102]: Accepted 192.168.0.64
                                            mein Yaml
                                            esphome:
                                              platform: ESP8266
                                              board: esp01_1m
                                            substitutions:
                                              device_name: tinypico-mmwave
                                            # Enable logging
                                            logger:
                                            api:
                                            ota:
                                              password: "yadda"
                                            mdns:
                                              disabled: false
                                            wifi:
                                              power_save_mode: none
                                            web_server:
                                              port: 80
                                              ota: false
                                            switch:
                                              - platform: safe_mode
                                                internal: true
                                                optimistic: true
                                                restore_state: true
                                                assumed_state: true
                                                turn_on_action:
                                                  - uart.write: "sensorStart"
                                                  - delay: 1s
                                                turn_off_action:
                                                  - uart.write: "sensorStop"
                                                  - delay: 1s
                                                optimistic: true
                                                restore_state: true
                                                assumed_state: true
                                                turn_on_action:
                                                  - switch.turn_off: mmwave_sensor
                                                  - delay: 1s
                                                  - uart.write: "setLedMode 1 0"
                                                  - delay: 1s
                                                  - uart.write: "saveConfig"
                                                  - delay: 3s
                                                  - switch.turn_on: mmwave_sensor
                                                turn_off_action:
                                                  - delay: 1s
                                                  - uart.write: "setLedMode 1 1"
                                                  - delay: 1s
                                                  - delay: 3s
                                                optimistic: true
                                                restore_state: true
                                                assumed_state: true
                                                turn_on_action:
                                                  - delay: 1s
                                                  - uart.write: "setUartOutput 1 1"
                                                  - delay: 1s
                                                  - delay: 3s
                                                turn_off_action:
                                                  - delay: 1s
                                                  - uart.write: "setUartOutput 1 0"
                                                  - delay: 1s
                                                  - delay: 3s
                                                optimistic: true
                                                restore_state: true
                                                assumed_state: false
                                                turn_on_action:
                                                  - delay: 1s
                                                  - uart.write: "setUartOutput 2 1 1 1"
                                                  - delay: 1s
                                                  - delay: 3s
                                                turn_off_action:
                                                  - delay: 1s
                                                  - uart.write: "setUartOutput 2 0"
                                                  - delay: 1s
                                                  - delay: 3s
                                            binary_sensor:
                                            - platform: gpio
                                              pin:
                                                number: GPIO16
                                                mode: INPUT_PULLDOWN
                                            uart:
                                              tx_pin: GPIO4
                                              rx_pin: GPIO5
                                              baud_rate: 115200
                                              debug:
                                                direction: BOTH
                                                dummy_receiver: true
                                                after:
                                                  delimiter: "\n"
                                                sequence:
                                                  - lambda: UARTDebug::log_string(direction, bytes);
                                            number:
                                                min_value: 0
                                                max_value: 1350
                                                initial_value: 315
                                                optimistic: true
                                                step: 15
                                                restore_value: true
                                                unit_of_measurement: cm
                                                mode: box
                                                set_action:
                                                  - delay: 1s
                                                  - uart.write: !lambda
        int cm = (int)ceil(x / 15.0);
        std::string cms = "detRangeCfg -1 0 " + to_string(cm);
        return std::vector<unsigned char>(cms.begin(), cms.end());
                                                  - delay: 1s
                                                  - uart.write: "saveCfg 0x45670123 0xCDEF89AB 0x956128C6 0xDF54AC89"
                                                  - delay: 1s
                                                min_value: 0
                                                max_value: 65000
                                                initial_value: 12500
                                                optimistic: true
                                                step: 25
                                                restore_value: true
                                                unit_of_measurement: ms
                                                mode: box
                                                set_action:
                                                  - delay: 1s
        int ms = (int)ceil(x / 25.0);
        std::string mss = "outputLatency -1 0 " + to_string(ms);
        return std::vector<unsigned char>(mss.begin(), mss.end());
                                                  - delay: 1s
                                                  - delay: 1s
                                                min_value: 0
                                                max_value: 9
                                                initial_value: 7
                                                optimistic: true
                                                step: 1
                                                restore_value: true
                                                set_action:
                                                  - delay: 1s
        std::string mss = "setSensitivity " + to_string((int)x);
                                                  - delay: 1s
                                                  - delay: 1s
                                            button:
                                              - platform: restart
                                                name: Restart $device_name
                                                on_press:
                                                  - delay: 1s
                                                  - uart.write: "resetCfg"
                                                  - delay: 3s
                                            esphome
                                            41
                                            165
                                            48226
