    4. Blink Camera System
    Blink Camera System
      Pischleuder @Soukai last edited by
      @soukai
      versuche doch bitte einmal Dein script in den /opt/iobroker Ordner zu kopieren und starte das
      in der Konsole normal, also ohne sudo und poste das Ergebnis.
        Soukai @Pischleuder last edited by Soukai
        @pischleuder Hey,
        inzwischen dies hier, aber wahrscheinlich wegen der neuen blink doorbell. bild2 ist ohne json credentials. 1 mit. Ist aber der gleiche text wie im blinkpy ordner
        saeko@raspberrypi:/opt/iobroker $ python bild2.py
        Could not extract camera info: {'message': 'Camera not found', 'code': 500}
        Expected json response from https://rest-e004.immedia-semi.com/network/unknown/camera/unknown/signals, but received: 406: Not Acceptable
        Could not retrieve calibrated temperature.
        Could not find thumbnail for camera unknown
        Did not receive valid response from server.
        Haustür
        {'name': 'Haustür', 'camera_id': '68316', 'serial': 'G8T1GJ0003118F0H', 'temperature': 69, 'temperature_c': 20.6, 'temperature_calibrated': 69, 'battery': 'ok', 'battery_voltage': 168, 'thumbnail': 'https://rest-e004.immedia-semi.com/api/v3/media/accounts/62195/networks/66328/catalina/68316/thumbnail/thumbnail.jpg?ts=1655932081&ext=', 'video': None, 'motion_enabled': True, 'motion_detected': False, 'wifi_strength': -70, 'network_id': 66328, 'sync_module': 'Zuhause', 'last_record': None, 'type': 'catalina'}
        Türklingel
        {'name': 'unknown', 'camera_id': 'unknown', 'serial': None, 'temperature': None, 'temperature_c': None, 'temperature_calibrated': None, 'battery': None, 'battery_voltage': None, 'thumbnail': None, 'video': None, 'motion_enabled': 'unknown', 'motion_detected': False, 'wifi_strength': None, 'network_id': 66328, 'sync_module': 'Zuhause', 'last_record': None, 'type': None}
        Expected json response from https://rest-e004.immedia-semi.com/network/66328/camera/unknown/config, but received: 406: Not Acceptable
        Could not extract camera info: None
        saeko@raspberrypi:/opt/iobroker $ python bild.py
        saeko@raspberrypi:~/blinkpy $ saeko@raspberrypi:~/blinkpy $ python bild.py
        saeko@raspberrypi:~/blinkpy $ python bild2.py
        python3.8: can't open file 'bild2.py': [Errno 2] No such file or directory
        Haustür
        {'name': 'Haustür', 'camera_id': '68316', 'serial': 'G8T1GJ0003118F0H', 'temperature': 69, 'temperature_c': 20.6, 'temperature_calibrated': 69, 'battery': 'ok', 'battery_voltage': 168, 'thumbnail': 'https://rest-e004.immedia-semi.com/api/v3/media/accounts/62195/networks/66328/catalina/68316/thumbnail/thumbnail.jpg?ts=1655932467&ext=', 'video': None, 'motion_enabled': True, 'motion_detected': False, 'wifi_strength': -70, 'network_id': 66328, 'sync_module': 'Zuhause', 'last_record': None, 'type': 'catalina'}
        Türklingel
          Pischleuder @Soukai last edited by Pischleuder
          @soukai
          der Aufruf mit python vorab ist falsch, da das im script bereits definiert ist. Das script muss lokal (in /opt/iobroker) so ausgeführt werden:
          ./bild.py
          Ausserdem fehlt in Deinem script etwas:
          from blinkpy.camera import BlinkCamera
          Ansonsten muss es sich um ein Rechteproblem des scriptes handeln, oder Du hast blink nicht für den user iobroker richtig installiert, da es mit sudo ja funktioniert. Dieses Problem hatte ich ja auch, wie in Deinem oben genannten Link erwähnt.
          Also vergewissere Dich bitte, ob Du das bereits gemacht hast (aus dem blink git Ordner):
          als normaler user saeko
          pip3 install blinkpy
          mit sudo
          sudo -H -u iobroker pip3 install blinkpy
            @pischleuder said in Blink Camera System:
            @soukai
            ./bild.py
            Habe folgendes probiert (mit python und ohne) und es hat sich leider nichts geändert:
            Zeile wurde jetzt eingefügt.
            mein script bis jetzt:
            #!/usr/bin/python3
            import requests
            from blinkpy.blinkpy import Blink
            from blinkpy.auth import Auth
            from blinkpy.helpers.util import json_load
            blink = Blink()
            auth = Auth(json_load("/home/saeko/blink/cred.json"))
            blink.auth = auth
            blink.start()
            #auth.send_auth_key(blink, "x")
            #blink.setup_post_verify()
            ###### hier den Dateinamen/Pfad eintragen, den das snapshot Bild erhalten soll >
            bild = './haustuer.jpg'
            #bild2 = '/home/saeko/blinkpy/Tuerklingel.jpg'
            #for name, camera in blink.cameras.items(): print(name), print(camera.attribute>
            #### hier Eure Kamera 1 eintragen und weitere Einträge für mehr Kameras vornehm>
            camera = blink.cameras['Haustür']
            camera.snap_picture()
            blink.refresh()
            camera.image_to_file(bild)
            #payload = {'value':bild}
            #r = requests.get("http://192.168.178.92:8081/set/0_userdata.0.snapcamera1", pa>
            #### hier Eure Kamera 2 eintragen und weitere Einträge für mehr Kameras vornehm>
            #camera = blink.cameras['Türklingel']
            #camera.snap_picture()
            #blink.refresh()
            #camera.image_to_file(bild2)
            mit sudo
            Hatte dies schon installiert, leider auch keine Änderung 😕
            saeko@raspberrypi:~/blinkpy $ pip3 install blinkpy
            Defaulting to user installation because normal site-packages is not writeable
            Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
            Requirement already satisfied: blinkpy in /home/saeko/.local/lib/python3.8/site-packages (0.20.0.dev0)
            Requirement already satisfied: requests>=2.24.0 in /home/saeko/.local/lib/python3.8/site-packages (from blinkpy) (2.27.1)
            Requirement already satisfied: python-dateutil>=2.8.1 in /home/saeko/.local/lib/python3.8/site-packages (from blinkpy) (2.8.2)
            Requirement already satisfied: python-slugify>=4.0.1 in /home/saeko/.local/lib/python3.8/site-packages (from blinkpy) (6.1.2)
            Requirement already satisfied: six>=1.5 in /home/saeko/.local/lib/python3.8/site-packages (from python-dateutil>=2.8.1->blinkpy) (1.16.0)
            Requirement already satisfied: text-unidecode>=1.3 in /home/saeko/.local/lib/python3.8/site-packages (from python-slugify>=4.0.1->blinkpy) (1.3)
            Requirement already satisfied: urllib3<1.27,>=1.21.1 in /home/saeko/.local/lib/python3.8/site-packages (from requests>=2.24.0->blinkpy) (1.26.9)
            Requirement already satisfied: idna<4,>=2.5 in /home/saeko/.local/lib/python3.8/site-packages (from requests>=2.24.0->blinkpy) (3.3)
            Requirement already satisfied: charset-normalizer~=2.0.0 in /home/saeko/.local/lib/python3.8/site-packages (from requests>=2.24.0->blinkpy) (2.0.12)
            Requirement already satisfied: certifi>=2017.4.17 in /home/saeko/.local/lib/python3.8/site-packages (from requests>=2.24.0->blinkpy) (2022.5.18.1)
            saeko@raspberrypi:~/blinkpy $ sudo -H -u iobroker pip3 install blinkpy
            Requirement already satisfied: blinkpy in /usr/local/lib/python3.9/dist-packages (0.20.0.dev0)
            Requirement already satisfied: requests>=2.24.0 in /usr/local/lib/python3.9/dist-packages (from blinkpy) (2.27.1)
            Requirement already satisfied: python-slugify>=4.0.1 in /usr/local/lib/python3.9/dist-packages (from blinkpy) (4.0.1)
            Requirement already satisfied: python-dateutil>=2.8.1 in /usr/local/lib/python3.9/dist-packages (from blinkpy) (2.8.2)
            Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.8.1->blinkpy) (1.16.0)
            Requirement already satisfied: text-unidecode>=1.3 in /usr/local/lib/python3.9/dist-packages (from python-slugify>=4.0.1->blinkpy) (1.3)
            Requirement already satisfied: idna<4,>=2.5 in /usr/lib/python3/dist-packages (from requests>=2.24.0->blinkpy) (2.10)
            Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.9/dist-packages (from requests>=2.24.0->blinkpy) (2.0.12)
            Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests>=2.24.0->blinkpy) (1.25.11)
            Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests>=2.24.0->blinkpy) (2020.6.20)
            Normaler aufruf per Konsole:
            Per iobroker aufruf sudo -u iobroker python3 ./bild.py kommt nun folgendes:
            saeko@raspberrypi:/opt/iobroker $ sudo -u iobroker python3 ./bild.py
            Traceback (most recent call last):
              File "/opt/iobroker/./bild.py", line 4, in <module>
            ModuleNotFoundError: No module named 'blinkpy'
            P 3 Replies Last reply Reply Quote 0
              @soukai
              Jep, du rufst das script mit dem json parameter auf und das wird nicht akzeptiert
              Warum?
              Was steht da drin ? --> Username und Passwort ?
                @pischleuder
                meinst du
                da stehen die Kontodaten drin. Ich probiers mal ohne. sollte sich aber eigentlich nichts ändern
                japp
                  @soukai sagte in Blink Camera System:
                  Wie gesagt, das ist komplett falsch und Du solltest das aus Deinen Gedanken streichen 🙂
                    Dieser Aufruf wird nur mit ./bild.py gemacht, weil die Definition bereits für python im script ist und zwar mit
                    #!/usr/bin/python3
                      Pischleuder @Pischleuder last edited by
                      @pischleuder
                      ggf. einmal dieses script erstellen und laufen lassen:
                      #!/usr/bin/python3
                      ###### zuerst ein pip3 install request ausführen, wenn nicht bereits installiert #####
                      import requests
                      import time
                      #from pushover import init, Client
                      blink = Blink()
                      auth = Auth({"username": "E-Mail", "password": "Passwort"}, no_prompt=True)
                      blink.auth = auth
                      blink.start()
                      auth.send_auth_key(blink, "hier blink key")
                      for name, camera in blink.cameras.items(): print(name), print(camera.attributes)
                      Nicht das bei den / der Kamera was nicht stimmt.
                        @pischleuder
                        #!/usr/bin/python3
                        import requests
                        import time
                        blink = Blink()
                        blink.auth = auth
                        blink.start()
                        Das kam dabei raus:
                        saeko@raspberrypi:/opt/iobroker $ python bildneu.py
                        Haustür
                        {'name': 'Haustür', 'camera_id': '68316', 'serial': 'G8T1GJ0003118F0H', 'temperature': 102, 'temperature_c': 38.9, 'temperature_calibrated': 102, 'battery': 'ok', 'battery_voltage': 168, 'thumbnail': 'https://rest-e004.immedia-semi.com/api/v3/media/accounts/62195/networks/66328/catalina/68316/thumbnail/thumbnail.jpg?ts=1655982587&ext=', 'video': None, 'motion_enabled': True, 'motion_detected': False, 'wifi_strength': -70, 'network_id': 66328, 'sync_module': 'Zuhause', 'last_record': None, 'type': 'catalina'}
                        Türklingel
                        Das json zu streichen hat auch nichts neues gebracht.
                        Das kommt von der Konsole wenn ichs streich. Wahrscheinlich nicht wichtig aber ich schicks mal.
                        Nagut 😶
                        #!/usr/bin/python3
                        Meinst du in der Konsole oder in Iobroker dann? habe das mal versuchshalber ausprobiert in der Konsole und in iobroker:
                        ./bild.py
                        aber konnte nicht aufgerufen werden. Habe auch das "#" entfernt probeweise im Script. Keine Änderung.
                        kommt folgendes in Konsole:
                        saeko@raspberrypi:/opt/iobroker $ sudo ./bild.py
                        sudo: ./bild.py: command not found
                        saeko@raspberrypi:/opt/iobroker $ ./bild.py
                        -bash: ./bild.py: Permission denied
                          @soukai
                          Servus,
                          also nochmal : lass alles ! mit sudo und python davorgestellt weg, sowohl in der Konsole (Terminal) als auch im iobroker blockly
                          Ist das script ausführbar gemacht mit chmod 755 scriptname ?
                          Im script lässt du die Zeile mit python bitte genau so stehen, wie ich es gepostet hatte.
                          mach mal bitte ein ls -ldh bild.py und poste das Ergebnis.
                            @pischleuder
                            Danke für deine Geduld! Habs jetzt wie du sagtest geändert. Rechte sind geändert und script läuft. Jedoch streikt er aber bei deinem Script, warum auch immer 😕
                            saeko@raspberrypi:/opt/iobroker $ chmod 755 bildneu.py
                            saeko@raspberrypi:/opt/iobroker $ ./bildneu.py
                            -bash: ./bildneu.py: /usr/bin/python3^M: bad interpreter: No such file or directory
                            saeko@raspberrypi:/opt/iobroker $ chmod 755 bild.py
                            Hier ein das Ergebnis von ls -ldh bild.py und bildneu.py (dein script):
                            saeko@raspberrypi:/opt/iobroker $ ls -ldh bild.py
                            -rwxr-xr-x+ 1 saeko saeko 1.3K Jun 23 13:21 bild.py
                            saeko@raspberrypi:/opt/iobroker $ ls -ldh bildneu.py
                            -rwxr-xr-x+ 1 saeko saeko 612 Jun 24 14:48 bildneu.py
                              @pischleuder
                              Weil Du offensichtlich python3 nicht installiert hast , sondern nur python 🙂
                              Jep, jetzt sieht man auch, warum das script aus blockly nicht ausgeführt wird. Die Rechte müssen auf iobroker sein. Bei mir sieht das so aus:
                              -rwxrwxrwx+ 1 iobroker iobroker 1,7K Apr  6 15:41 blink-cameras.py
                              pi@raspberrypi2:/opt/iobroker $
                                @pischleuder
                                ist das nicht python 3?
                                saeko@raspberrypi:/opt/iobroker $ python --version
                                Python 3.8.4
                                hoffentlich ist es das 😧 kannst mir vielleicht eben sagen wie ich die Rechte auf iobroker änder?
                                  @soukai
                                  ja, mach mal ein
                                  chown iobroker deinscript.py
                                  danach nochmal ls -ldh
                                    @pischleuder
                                    -rwxr-xr-x+ 1 iobroker saeko 1.3K Jun 23 13:21 bild.py
                                      @soukai
                                      ok, mach folgendes:
                                      chown iobroker:iobroker deinscript.py
                                        @pischleuder
                                        -rwxr-xr-x+ 1 iobroker iobroker 1.3K Jun 23 13:21 bild.py
                                          @soukai
                                          nun sollte es hoffentlich laufen...
                                            @pischleuder leider macht blockly immer noch kein bild in das Verzeichnis 😕
                                            leider immer noch nichts. Egal wie
                                            blink xt camera
                                            63
                                            406
                                            117055
