    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
      Thomas Braun Most Active @taba_luga last edited by
      @taba_luga
      iobroker update -i
      zeigt?
        taba_luga @Thomas Braun last edited by
        iobroker update -i
        Installation broken or unknown objects type: jsonl configured.
          Thomas Braun Most Active @taba_luga last edited by Thomas Braun
          @taba_luga
          Mehr nicht? Bitte besser die kompletten Ein- und Ausgabezeilen zeigen, dann kann man das besser einordnen.
          iobroker status
          iobroker list instances
          iobroker list adapters
            @thomas-braun mehr wird nicht in der Console angezeigt:
            xx@iobroker-prod:~$ iobroker update -i
            xx@iobroker-prod:~$ iobroker list instances
            xx@iobroker-prod:~$ iobroker list adapters
            xx@iobroker-prod:~$
              @taba_luga
              Installier den js-controller nochmal drüber
                Homoran Global Moderator Administrators @taba_luga last edited by
                @taba_luga xx ist auch ein einfallsreicher Username 😂
                  taba_luga @Thomas Braun last edited by taba_luga
                  xx@iobroker-prod:~$ npm install iobroker.js-controller
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  added 309 packages, and audited 310 packages in 1m
                  18 packages are looking for funding
                    run `npm fund` for details
                  4 vulnerabilities (3 moderate, 1 high)
                  To address all issues, run:
                    npm audit fix
                  Run `npm audit` for details.
                  xx@iobroker-prod:~$
                  und hier npm audit und npm audit --force
                  xx@iobroker-prod:~$ npm audit
                  # npm audit report
                  node-forge  <=1.2.1
                  Severity: high
                  Open Redirect in node-forge - https://github.com/advisories/GHSA-8fr3-hfg3-gpgp
                  Prototype Pollution in node-forge debug API. - https://github.com/advisories/GHSA-5rrq-pxf6-6jx5
                  Prototype Pollution in node-forge util.setPath API - https://github.com/advisories/GHSA-wxgw-qj99-44c2
                  URL parsing in node-forge could lead to undesired behavior. - https://github.com/advisories/GHSA-gf8q-jrpm-jvxq
                  Prototype Pollution in node-forge - https://github.com/advisories/GHSA-92xj-mqp7-vmcj
                  Improper Verification of Cryptographic Signature in `node-forge` - https://github.com/advisories/GHSA-2r2c-g63r-vccr
                  Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-x4jg-mjrx-434g
                  Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-cfm4-qjh2-4765
                  fix available via `npm audit fix --force`
                  Will install iobroker.js-controller@1.5.3, which is a breaking change
                  node_modules/rsa-compat/node_modules/node-forge
                    rsa-compat  <=1.9.4
                    Depends on vulnerable versions of node-forge
                      le-acme-core  *
                      Depends on vulnerable versions of rsa-compat
                      node_modules/le-acme-core
                        iobroker.js-controller  >=1.5.4
                        Depends on vulnerable versions of le-acme-core
                        node_modules/iobroker.js-controller
                  To address all issues (including breaking changes), run:
                  xx@iobroker-prod:~$ npm audit fix --force
                  npm WARN using --force Recommended protections disabled.
                  npm WARN audit Updating iobroker.js-controller to 1.5.3,which is a SemVer major change.
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                  added 173 packages, removed 145 packages, changed 48 packages, and audited 334 packages in 51s
                  13 packages are looking for funding
                  # npm audit report
                  debug  <2.6.9
                  Regular Expression Denial of Service in debug - https://github.com/advisories/GHSA-gxpj-cx7g-858c
                  Will install iobroker.js-controller@4.0.23, which is a breaking change
                  node_modules/engine.io-client/node_modules/debug
                  node_modules/engine.io/node_modules/debug
                  node_modules/socket.io-adapter/node_modules/debug
                  node_modules/socket.io-client/node_modules/debug
                  node_modules/socket.io-parser/node_modules/debug
                  node_modules/socket.io/node_modules/debug
                    engine.io  <=4.0.0-alpha.1
                    Depends on vulnerable versions of debug
                    Depends on vulnerable versions of ws
                      socket.io  <=2.4.1
                      Depends on vulnerable versions of engine.io
                      Depends on vulnerable versions of socket.io-adapter
                      Depends on vulnerable versions of socket.io-client
                      Depends on vulnerable versions of socket.io-parser
                        iobroker.js-controller  <=2.1.1
                        Depends on vulnerable versions of redis
                        Depends on vulnerable versions of winston-daily-rotate-file
                        Depends on vulnerable versions of yargs
                    engine.io-client  <=3.3.2 || 3.4.0 - 3.5.1 || 4.0.0-alpha.0 - 4.1.3
                    Depends on vulnerable versions of parsejson
                    Depends on vulnerable versions of xmlhttprequest-ssl
                      socket.io-client  1.0.0-pre - 2.1.1 || 2.3.0 - 2.3.1 || 3.0.0-rc1 - 3.0.5
                      Depends on vulnerable versions of engine.io-client
                    socket.io-adapter  <=1.1.0
                    socket.io-parser  <=3.3.1
                  minimist  <=1.2.5
                  Severity: critical
                  Prototype Pollution in minimist - https://github.com/advisories/GHSA-xvch-5gv4-984h
                  Prototype Pollution in minimist - https://github.com/advisories/GHSA-vh95-rmgr-6w4m
                  node_modules/winston-daily-rotate-file/node_modules/minimist
                    mkdirp  0.4.1 - 0.5.1
                    Depends on vulnerable versions of minimist
                    node_modules/winston-daily-rotate-file/node_modules/mkdirp
                      winston-daily-rotate-file  1.7.0 - 1.7.2
                      Depends on vulnerable versions of mkdirp
                  parsejson  *
                  Severity: high
                  Regular Expression Denial of Service in parsejson - https://github.com/advisories/GHSA-q75g-2496-mxpp
                  node_modules/parsejson
                  redis  2.6.0 - 3.1.0
                  Severity: high
                  Potential exponential regex in monitor mode - https://github.com/advisories/GHSA-35q2-47q7-3pc3
                  node_modules/redis
                  ws  <=1.1.4
                  Severity: high
                  Denial of Service in ws - https://github.com/advisories/GHSA-5v72-xg48-5rpm
                  node_modules/engine.io-client/node_modules/ws
                  node_modules/engine.io/node_modules/ws
                  xmlhttprequest-ssl  <=1.6.1
                  Severity: critical
                  Improper Certificate Validation in xmlhttprequest-ssl - https://github.com/advisories/GHSA-72mh-269x-7mh5
                  Arbitrary Code Injection - https://github.com/advisories/GHSA-h4j5-c7cj-74xg
                  node_modules/xmlhttprequest-ssl
                  yargs-parser  6.0.0 - 13.1.1
                  Severity: moderate
                  Prototype Pollution in yargs-parser - https://github.com/advisories/GHSA-p9pc-299p-vxgp
                  node_modules/yargs-parser
                    yargs  8.0.0-candidate.0 - 12.0.5
                    Depends on vulnerable versions of yargs-parser
                    node_modules/yargs
                  17 vulnerabilities (1 low, 4 moderate, 8 high, 4 critical)
                  To address issues that do not require attention, run:
                    npm audit fix
                  xx@iobroker-prod:~$
                  Das hat leider zu keiner Verbesserung geführt
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                  Homoran apollon77 Thomas Braun 3 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @taba_luga last edited by Homoran
                    @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                    wieso machst du so etwas?
                      taba_luga @Homoran last edited by
                      @homoran wie ich oben schon schrieb, ich bin leider kein Linux Profi. Hab ich das etwas getan, was ich nicht hätte machen sollen? 🤦‍♂️
                        apollon77 @taba_luga last edited by
                        @taba_luga hoffe das npm install war im richtigen ordner (/opt/iobroker) und ja audit fix lassen
                          Falsches Verzeichnis:
                          Naja, jetzt hast du es doppelt 'installiert'...
                          Mach es so:
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install iobroker.js-controller
                            taba_luga @apollon77 last edited by taba_luga
                            @apollon77 ich befürchte nicht... Ich hatte vorher nicht das Verzeichnis gewechselt. Habe ich mir jetzt restlos alles zerschossen? Dann würde ich meinen Snapshot wieder hervor holen und bis zu diesem Punkt erst mal alles wiederholen.
                            [edit] der Post von @Thomas-Braun hat sich mit meiner Antwort hier überschnitten.
                            apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                              @taba_luga In welchem verzeichnis haste es denn ausgeführt? WEnn in deinem User verzeichnis dann liegt da jetzt nur ein node_modules mit Zeug drin ... löschen und ende
                                Nein, du hast nur den js-controller im /home-Verzeichnis des users xx versenkt.
                                Aber da den den ja auch dort auditiert und gefixt hast...
                                ...lösch das dort.
                                Die Hauptinstallation immer noch defekt.
                                  jetzt geht der Spaß mit den Ordnern wieder los...
                                  xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                                  npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                                  Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                                  • N
                                    nhbischo last edited by
                                    Moin !
                                    Leider habe auch ich ein kleines Problem. Update nach
                                    https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
                                    Danach den berühmten Error 25 bei der Installation von Adaptern. Es geht weder ein Update noch eine Neuinstallation eines Adapters. Nun also hier die Meldung im Forum, da ich nun auch nicht mehr ohne Hilfe weiter komme.
                                    Nach dem Durchlesen hier habe ich mal einige Snapshots gemacht und diese stelle ich hier mit ein. Da der Fehler in der Regel beim User sitzt .............. Es ist ja leider meist so.
                                    Wer mir da helfen kann ......... VG Mathias
                                      Homoran Global Moderator Administrators @nhbischo last edited by
                                      @nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                      keine Screenshots von Text!
                                      Diesen als Text in code-tags posten
                                        Thomas Braun Most Active @nhbischo last edited by
                                        @nhbischo
                                        Keine krümeligen Screenshots aus der Konsole.
                                        Als Text in CodeTags eingebettet hier rein.
                                        • N
                                          pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug
                                          This upgrade of "smartgarden" will introduce the following changes:
                                          -> 2.0.0:
                                          support for new login procedure to Gardena webservice; admin5 is necessary
                                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C        HANGES!
                                          Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]:        y
                                          Update smartgarden from @1.0.6 to @2.0.0
                                          NPM version: 8.11.0
                                          Installing iobroker.smartgarden@2.0.0... (System call)
                                          npm WARN old lockfile
                                          npm WARN old lockfile The package-lock.json file was created with an old version        of npm,
                                          npm WARN old lockfile so supplemental metadata must be fetched from the registry        .
                                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                                          npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT        +z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
                                          npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wan        ted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4        gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                                          npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
                                          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
                                          npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
                                          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
                                          npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
                                          npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12)
                                          npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24)
                                          npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
                                          npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
                                          npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
                                          npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Erro        r: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+        z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2D        Cg==. (64751136 bytes)
                                          npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
                                          npm WARN old lockfile   code: 'EINTEGRITY',
                                          npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
                                          npm WARN old lockfile   expected: [
                                          npm WARN old lockfile     Hash {
                                          npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                                          npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                                          npm WARN old lockfile       algorithm: 'sha512',
                                          npm WARN old lockfile       options: []
                                          npm WARN old lockfile     }
                                          npm WARN old lockfile   ],
                                          npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
                                          npm ERR! path /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                                          npm ERR! dest /opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png' -> '/opt/iobroker/node_modules/.iobroker.icons-open-icon-li        brary-png-dWPxt8qG'
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T15_08_41_333Z-debug-0.log
                                          host.raspberrypi Cannot install iobroker.smartgarden@2.0.0: 217
                                          pi@raspberrypi:/opt/iobroker $ npm ls canvas
                                          iobroker.inst@2.0.3 /opt/iobroker
                                          ├─┬ iobroker.echarts@1.0.10 extraneous
                                          │ ├── canvas@2.9.1
                                          │ └─┬ jsdom@19.0.0
                                          │   └── canvas@2.9.1 deduped
                                          ├─┬ iobroker.iot@1.11.7
                                          └─┬ iobroker.mihome-vacuum@3.4.1
                                          pi@raspberrypi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt        policy nodejs
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.15.1
                                          v16.15.1
                                          8.11.0
                                          pi
                                          /opt/iobroker
                                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          OK:3 http://phoscon.de/apt/deconz buster InRelease
                                          OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                          OK:5 https://www.pivccu.de/piVCCU stable InRelease
                                          Alle Pakete sind aktuell.
                                          nodejs:
                                            Installiert:           16.15.1-deb-1nodesource1
                                            Installationskandidat: 16.15.1-deb-1nodesource1
                                            Versionstabelle:
                                           *** 16.15.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               10.24.0~dfsg-1~deb10u1 500
                                          pi@raspberrypi:/opt/iobroker $ iobroker status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          pi@raspberrypi:/opt/iobroker $ iobroker list instances
                                          + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                                            system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                                            system.adapter.calendar.0               : calendar              : raspberrypi                              - disabled, port: 8095
                                          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                          + system.adapter.contact.0                : contact               : raspberrypi                              -  enabled, port: 8096
                                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                          + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                                          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                          + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                                            system.adapter.gardena.0                : gardena               : raspberrypi                              - disabled
                                            system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
                                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                          + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                            system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.4                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.5                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.6                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.7                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.ical.8                   : ical                  : raspberrypi                              -  enabled
                                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                                            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                            system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 192.168.178.147, run as: admin
                                            system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
                                            system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              - disabled
                                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                            system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 192.168.178.145
                                          + system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 8899
                                            system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                          + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                            system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
                                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                                            system.adapter.radar2.0                 : radar2                : raspberrypi                              - disabled
                                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                            system.adapter.samsung.0                : samsung               : raspberrypi                              - disabled
                                            system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                                            system.adapter.samsung_tizen.1          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                                          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                                            system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                                          + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                                          + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                                            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.147
                                          + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                                            system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                            system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                                          + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
                                            system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                          + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                                            system.adapter.uv-protect.0             : uv-protect            : raspberrypi                              -  enabled
                                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
                                            system.adapter.vis-material.0           : vis-material          : raspberrypi                              - disabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                            system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
                                          + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                          • N
                                            Sorry. Hoffe nun in Ordnung
                                            errormeldung nodejs 16.15.1
                                            15
                                            169
                                            22071
