    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
      Homoran Global Moderator Administrators @taba_luga last edited by
      @taba_luga xx ist auch ein einfallsreicher Username 😂
        taba_luga @Thomas Braun last edited by taba_luga
        xx@iobroker-prod:~$ npm install iobroker.js-controller
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 309 packages, and audited 310 packages in 1m
        18 packages are looking for funding
          run `npm fund` for details
        4 vulnerabilities (3 moderate, 1 high)
        To address all issues, run:
          npm audit fix
        Run `npm audit` for details.
        xx@iobroker-prod:~$
        und hier npm audit und npm audit --force
        xx@iobroker-prod:~$ npm audit
        # npm audit report
        node-forge  <=1.2.1
        Severity: high
        Open Redirect in node-forge - https://github.com/advisories/GHSA-8fr3-hfg3-gpgp
        Prototype Pollution in node-forge debug API. - https://github.com/advisories/GHSA-5rrq-pxf6-6jx5
        Prototype Pollution in node-forge util.setPath API - https://github.com/advisories/GHSA-wxgw-qj99-44c2
        URL parsing in node-forge could lead to undesired behavior. - https://github.com/advisories/GHSA-gf8q-jrpm-jvxq
        Prototype Pollution in node-forge - https://github.com/advisories/GHSA-92xj-mqp7-vmcj
        Improper Verification of Cryptographic Signature in `node-forge` - https://github.com/advisories/GHSA-2r2c-g63r-vccr
        Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-x4jg-mjrx-434g
        Improper Verification of Cryptographic Signature in node-forge - https://github.com/advisories/GHSA-cfm4-qjh2-4765
        fix available via `npm audit fix --force`
        Will install iobroker.js-controller@1.5.3, which is a breaking change
        node_modules/rsa-compat/node_modules/node-forge
          rsa-compat  <=1.9.4
          Depends on vulnerable versions of node-forge
            le-acme-core  *
            Depends on vulnerable versions of rsa-compat
            node_modules/le-acme-core
              iobroker.js-controller  >=1.5.4
              Depends on vulnerable versions of le-acme-core
              node_modules/iobroker.js-controller
        To address all issues (including breaking changes), run:
        xx@iobroker-prod:~$ npm audit fix --force
        npm WARN using --force Recommended protections disabled.
        npm WARN audit Updating iobroker.js-controller to 1.5.3,which is a SemVer major change.
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
        added 173 packages, removed 145 packages, changed 48 packages, and audited 334 packages in 51s
        13 packages are looking for funding
        # npm audit report
        debug  <2.6.9
        Regular Expression Denial of Service in debug - https://github.com/advisories/GHSA-gxpj-cx7g-858c
        Will install iobroker.js-controller@4.0.23, which is a breaking change
        node_modules/engine.io-client/node_modules/debug
        node_modules/engine.io/node_modules/debug
        node_modules/socket.io-adapter/node_modules/debug
        node_modules/socket.io-client/node_modules/debug
        node_modules/socket.io-parser/node_modules/debug
        node_modules/socket.io/node_modules/debug
          engine.io  <=4.0.0-alpha.1
          Depends on vulnerable versions of debug
          Depends on vulnerable versions of ws
            socket.io  <=2.4.1
            Depends on vulnerable versions of engine.io
            Depends on vulnerable versions of socket.io-adapter
            Depends on vulnerable versions of socket.io-client
            Depends on vulnerable versions of socket.io-parser
              iobroker.js-controller  <=2.1.1
              Depends on vulnerable versions of redis
              Depends on vulnerable versions of winston-daily-rotate-file
              Depends on vulnerable versions of yargs
          engine.io-client  <=3.3.2 || 3.4.0 - 3.5.1 || 4.0.0-alpha.0 - 4.1.3
          Depends on vulnerable versions of parsejson
          Depends on vulnerable versions of xmlhttprequest-ssl
            socket.io-client  1.0.0-pre - 2.1.1 || 2.3.0 - 2.3.1 || 3.0.0-rc1 - 3.0.5
            Depends on vulnerable versions of engine.io-client
          socket.io-adapter  <=1.1.0
          socket.io-parser  <=3.3.1
        minimist  <=1.2.5
        Severity: critical
        Prototype Pollution in minimist - https://github.com/advisories/GHSA-xvch-5gv4-984h
        Prototype Pollution in minimist - https://github.com/advisories/GHSA-vh95-rmgr-6w4m
        node_modules/winston-daily-rotate-file/node_modules/minimist
          mkdirp  0.4.1 - 0.5.1
          Depends on vulnerable versions of minimist
          node_modules/winston-daily-rotate-file/node_modules/mkdirp
            winston-daily-rotate-file  1.7.0 - 1.7.2
            Depends on vulnerable versions of mkdirp
        parsejson  *
        Severity: high
        Regular Expression Denial of Service in parsejson - https://github.com/advisories/GHSA-q75g-2496-mxpp
        node_modules/parsejson
        redis  2.6.0 - 3.1.0
        Severity: high
        Potential exponential regex in monitor mode - https://github.com/advisories/GHSA-35q2-47q7-3pc3
        node_modules/redis
        ws  <=1.1.4
        Severity: high
        Denial of Service in ws - https://github.com/advisories/GHSA-5v72-xg48-5rpm
        node_modules/engine.io-client/node_modules/ws
        node_modules/engine.io/node_modules/ws
        xmlhttprequest-ssl  <=1.6.1
        Severity: critical
        Improper Certificate Validation in xmlhttprequest-ssl - https://github.com/advisories/GHSA-72mh-269x-7mh5
        Arbitrary Code Injection - https://github.com/advisories/GHSA-h4j5-c7cj-74xg
        node_modules/xmlhttprequest-ssl
        yargs-parser  6.0.0 - 13.1.1
        Severity: moderate
        Prototype Pollution in yargs-parser - https://github.com/advisories/GHSA-p9pc-299p-vxgp
        node_modules/yargs-parser
          yargs  8.0.0-candidate.0 - 12.0.5
          Depends on vulnerable versions of yargs-parser
          node_modules/yargs
        17 vulnerabilities (1 low, 4 moderate, 8 high, 4 critical)
        To address issues that do not require attention, run:
          npm audit fix
        xx@iobroker-prod:~$
        Das hat leider zu keiner Verbesserung geführt
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Homoran apollon77 Thomas Braun 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @taba_luga last edited by Homoran
          @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
          wieso machst du so etwas?
            taba_luga @Homoran last edited by
            @homoran wie ich oben schon schrieb, ich bin leider kein Linux Profi. Hab ich das etwas getan, was ich nicht hätte machen sollen? 🤦‍♂️
              apollon77 @taba_luga last edited by
              @taba_luga hoffe das npm install war im richtigen ordner (/opt/iobroker) und ja audit fix lassen
                Thomas Braun Most Active @taba_luga last edited by
                Falsches Verzeichnis:
                Naja, jetzt hast du es doppelt 'installiert'...
                Mach es so:
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                  taba_luga @apollon77 last edited by taba_luga
                  @apollon77 ich befürchte nicht... Ich hatte vorher nicht das Verzeichnis gewechselt. Habe ich mir jetzt restlos alles zerschossen? Dann würde ich meinen Snapshot wieder hervor holen und bis zu diesem Punkt erst mal alles wiederholen.
                  [edit] der Post von @Thomas-Braun hat sich mit meiner Antwort hier überschnitten.
                  apollon77 Thomas Braun 2 Replies Last reply Reply Quote 0
                    @taba_luga In welchem verzeichnis haste es denn ausgeführt? WEnn in deinem User verzeichnis dann liegt da jetzt nur ein node_modules mit Zeug drin ... löschen und ende
                      Thomas Braun Most Active @taba_luga last edited by Thomas Braun
                      Nein, du hast nur den js-controller im /home-Verzeichnis des users xx versenkt.
                      Aber da den den ja auch dort auditiert und gefixt hast...
                      ...lösch das dort.
                      Die Hauptinstallation immer noch defekt.
                        jetzt geht der Spaß mit den Ordnern wieder los...
                        xx@iobroker-prod:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/alexa-cookie2
                        npm ERR! dest /opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-cookie2' -> '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-24T11_45_06_568Z-debug-0.log
                        Die benenne ich dann erst mal wieder um und melde mich dann wieder bei euch. Vielen DANK schon mal zwischendurch für euren super Support!!!
                        • N
                          nhbischo last edited by
                          Moin !
                          Leider habe auch ich ein kleines Problem. Update nach
                          https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition
                          Danach den berühmten Error 25 bei der Installation von Adaptern. Es geht weder ein Update noch eine Neuinstallation eines Adapters. Nun also hier die Meldung im Forum, da ich nun auch nicht mehr ohne Hilfe weiter komme.
                          Nach dem Durchlesen hier habe ich mal einige Snapshots gemacht und diese stelle ich hier mit ein. Da der Fehler in der Regel beim User sitzt .............. Es ist ja leider meist so.
                          Wer mir da helfen kann ......... VG Mathias
                            Homoran Global Moderator Administrators @nhbischo last edited by
                            @nhbischo sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                            keine Screenshots von Text!
                            Diesen als Text in code-tags posten
                              Thomas Braun Most Active @nhbischo last edited by
                              @nhbischo
                              Keine krümeligen Screenshots aus der Konsole.
                              Als Text in CodeTags eingebettet hier rein.
                              • N
                                pi@raspberrypi:/opt/iobroker $ iobroker upgrade smartgarden --debug
                                This upgrade of "smartgarden" will introduce the following changes:
                                -> 2.0.0:
                                support for new login procedure to Gardena webservice; admin5 is necessary
                                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C        HANGES!
                                Would you like to upgrade smartgarden from @1.0.6 to @2.0.0 now? [(y)es, (n)o]:        y
                                Update smartgarden from @1.0.6 to @2.0.0
                                NPM version: 8.11.0
                                Installing iobroker.smartgarden@2.0.0... (System call)
                                npm WARN old lockfile
                                npm WARN old lockfile The package-lock.json file was created with an old version        of npm,
                                npm WARN old lockfile so supplemental metadata must be fetched from the registry        .
                                npm WARN old lockfile This is a one-time fix-up, please be patient...
                                npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT        +z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
                                npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wan        ted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4        gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                                npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
                                npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
                                npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
                                npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
                                npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
                                npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12)
                                npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24)
                                npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
                                npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
                                npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
                                npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Erro        r: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+        z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2D        Cg==. (64751136 bytes)
                                npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
                                npm WARN old lockfile   code: 'EINTEGRITY',
                                npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
                                npm WARN old lockfile   expected: [
                                npm WARN old lockfile     Hash {
                                npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                                npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
                                npm WARN old lockfile       algorithm: 'sha512',
                                npm WARN old lockfile       options: []
                                npm WARN old lockfile     }
                                npm WARN old lockfile   ],
                                npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
                                npm ERR! path /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                                npm ERR! dest /opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG
                                npm ERR! errno -39
                                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png' -> '/opt/iobroker/node_modules/.iobroker.icons-open-icon-li        brary-png-dWPxt8qG'
                                npm ERR!     /home/iobroker/.npm/_logs/2022-06-26T15_08_41_333Z-debug-0.log
                                host.raspberrypi Cannot install iobroker.smartgarden@2.0.0: 217
                                pi@raspberrypi:/opt/iobroker $ npm ls canvas
                                iobroker.inst@2.0.3 /opt/iobroker
                                ├─┬ iobroker.echarts@1.0.10 extraneous
                                │ ├── canvas@2.9.1
                                │ └─┬ jsdom@19.0.0
                                │   └── canvas@2.9.1 deduped
                                ├─┬ iobroker.iot@1.11.7
                                └─┬ iobroker.mihome-vacuum@3.4.1
                                pi@raspberrypi:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt        policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.15.1
                                v16.15.1
                                8.11.0
                                pi
                                /opt/iobroker
                                OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                OK:3 http://phoscon.de/apt/deconz buster InRelease
                                OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                                OK:5 https://www.pivccu.de/piVCCU stable InRelease
                                Alle Pakete sind aktuell.
                                nodejs:
                                  Installiert:           16.15.1-deb-1nodesource1
                                  Installationskandidat: 16.15.1-deb-1nodesource1
                                  Versionstabelle:
                                 *** 16.15.1-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                        100 /var/lib/dpkg/status
                                     10.24.0~dfsg-1~deb10u1 500
                                pi@raspberrypi:/opt/iobroker $ iobroker status
                                Objects type: jsonl
                                States  type: jsonl
                                pi@raspberrypi:/opt/iobroker $ iobroker list instances
                                + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                  system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
                                  system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
                                  system.adapter.calendar.0               : calendar              : raspberrypi                              - disabled, port: 8095
                                + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                + system.adapter.contact.0                : contact               : raspberrypi                              -  enabled, port: 8096
                                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                  system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
                                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
                                + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                  system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                                  system.adapter.gardena.0                : gardena               : raspberrypi                              - disabled
                                  system.adapter.habpanel.0               : habpanel              : raspberrypi                              - disabled
                                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                  system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.4                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.5                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.6                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.7                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.ical.8                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                                  system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                  system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 192.168.178.147, run as: admin
                                  system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
                                  system.adapter.meteoalarm.0             : meteoalarm            : raspberrypi                              - disabled
                                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                                  system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 192.168.178.145
                                + system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 8899
                                  system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
                                + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
                                  system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                  system.adapter.parser.0                 : parser                : raspberrypi                              - disabled
                                + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
                                  system.adapter.radar2.0                 : radar2                : raspberrypi                              - disabled
                                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                  system.adapter.samsung.0                : samsung               : raspberrypi                              - disabled
                                  system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                                  system.adapter.samsung_tizen.1          : samsung_tizen         : raspberrypi                              - disabled, port: 8002
                                + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                                  system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                  system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                                  system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
                                + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                                + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                                  system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.147
                                + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                                  system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                  system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                                + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
                                  system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
                                + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                                  system.adapter.uv-protect.0             : uv-protect            : raspberrypi                              -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                  system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
                                  system.adapter.vis-material.0           : vis-material          : raspberrypi                              - disabled
                                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                  system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                  system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.withings.0               : withings              : raspberrypi                              -  enabled
                                + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
                                • N
                                  Sorry. Hoffe nun in Ordnung
                                    @nhbischo
                                    Mach das doch.
                                      • N
                                        @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                        Unknown regexp modifier "/b" at (user-supplied code), at end of line
                                        Unknown regexp modifier "/r" at (user-supplied code), at end of line
                                        Unknown regexp modifier "/k" at (user-supplied code), at end of line
                                        Unknown regexp modifier "/e" at (user-supplied code), at end of line
                                          @nhbischo
                                          Was machst du da?
                                          • N
                                            nhbischo @Homoran last edited by
                                            Ich hatte wie hier ja schon beschrieben wurde in /opt/iobroker die Datei 'package-lock.json' auch schon umbenannt und gespeíchert. Dann den Updateprozess neu angestossen. Dort erschien der gleiche Fehler wieder. In der Vorgehensweise etwas falsch gewesen ?
                                            VG Mathias
                                            Thomas Braun N 2 Replies Last reply Reply Quote 0
                                            errormeldung nodejs 16.15.1
                                            15
                                            169
                                            22060
