    4. JavaScript
    5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
      LassMichIchMachDasSelberKaputt @LassMichIchMachDasSelberKaputt last edited by
      Ich habe jetzt mal VNC installiert und gesehen dass die Datei welche ich per wget kopiert habe nicht den richtigen Inhalt hatte. Das habe ich geändert. Nun läuft das Script weiter aber produziert einen neuen Fehler:
      11.4.2022, 17:41:30.005	[info ]: javascript.0 (385244) Start javascript script.js.Xiaomi.MiHomeScript
      11.4.2022, 17:41:30.010	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Starting AllMyMi V.0.2.29
      11.4.2022, 17:41:30.011	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: registered 0 subscriptions and 0 schedules
      11.4.2022, 17:41:30.012	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: You are already logged in, login canceled
      11.4.2022, 17:41:30.012	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Retrieving your in de registered MiHome Devices
      11.4.2022, 17:41:30.152	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Found 5 MiHome Devices, those are:
      11.4.2022, 17:41:30.152	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Videokamera
      11.4.2022, 17:41:30.153	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Mi Air Purifier 3/3H
      11.4.2022, 17:41:30.153	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Eve
      11.4.2022, 17:41:30.153	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Ventilator Schlafzimmer
      11.4.2022, 17:41:30.153	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Mi Electric Scooter Pro 2 series
      11.4.2022, 17:41:30.154	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Now searching for supported Devices...
      11.4.2022, 17:41:30.154	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Device Mi Air Purifier 3/3H is supported, creating DataPoints if necessary
      11.4.2022, 17:41:30.154	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Device Ventilator Schlafzimmer is supported, creating DataPoints if necessary
      11.4.2022, 17:41:30.169	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Now creating device for zhimi.airpurifier.mb3 / 359561707 / 192.168.3.56 / f0c2418e128fce7315ed211901198273 / 10000
      11.4.2022, 17:41:30.170	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Created device {"_events": GEKÜRZT
      11.4.2022, 17:41:30.757	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Init Device# 0 - device="zhimi.airpurifier.mb3"
      11.4.2022, 17:41:30.757	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Now creating device for dmaker.fan.p18 / GEKÜRZT
      11.4.2022, 17:41:30.758	[info ]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: Created device {"_events": GEKÜRZT
      11.4.2022, 17:41:30.832	[error]: javascript.0 (385244) script.js.Xiaomi.MiHomeScript: TypeError: Cannot read property 'forEach' of undefined
      11.4.2022, 17:41:30.833	[error]: javascript.0 (385244)     at CreateDevices (script.js.Xiaomi.MiHomeScript:924:17)
      11.4.2022, 17:41:30.834	[error]: javascript.0 (385244)     at main (script.js.Xiaomi.MiHomeScript:842:5)
        Pittini Developer @LassMichIchMachDasSelberKaputt last edited by
        @lassmichichmachdasselberkaputt Du erwähnst "die Datei", da Du aber 2 unterstützte Geräte haste müssten es aber auch 2 DateiEN sein. Haste die vom Venti evtl. vergessen?
        L 3 Replies Last reply Reply Quote 0
          LassMichIchMachDasSelberKaputt @Pittini last edited by LassMichIchMachDasSelberKaputt
          @pittini
          Hallo Pittini!
          Ich habe jetzt die Dateien für den 3H UND den Fan 2 geupdated. es bleibt bei folgenden errors am Ende:
          18:34:34.164	error	javascript.0 (401850) script.js.Xiaomi.MiHomeScript: TypeError: Cannot read property 'forEach' of undefined
          18:34:34.167	error	javascript.0 (401850) at CreateDevices (script.js.Xiaomi.MiHomeScript:924:17)
          18:34:34.167	error	javascript.0 (401850) at main (script.js.Xiaomi.MiHomeScript:842:5)
          er zeigt den Fehler also nach Zeile 923, denn "now fetching data" wird im log noch angezeigt:
          Device 0 wäre der 3H, der hat jetzt allerdings die frische Config Datei erhalten...
          EDIT:
          Sehe gerade dass node-mihome auch fehler zeigt:
          javascript.0
          2022-04-11 18:50:18.774	error	at main (script.js.Xiaomi.MiHomeScript:842:5)
          javascript.0
          2022-04-11 18:50:18.773	error	at CreateDevices (script.js.Xiaomi.MiHomeScript:924:17)
          javascript.0
          2022-04-11 18:50:18.773	error	at module.exports.init (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/device-miio.js:43:7)
          javascript.0
          2022-04-11 18:50:18.773	error	at processTicksAndRejections (internal/process/task_queues.js:95:5)
          javascript.0
          2022-04-11 18:50:18.773	error	at runMicrotasks (<anonymous>:null:null)
          javascript.0
          2022-04-11 18:50:18.773	error	at module.exports.miotFetchSpec (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/device-miio.js:190:14)
          javascript.0
          2022-04-11 18:50:18.773	error	at Array.forEach (<anonymous>:null:null)
          javascript.0
          2022-04-11 18:50:18.772	error	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/device-miio.js:192:18
          javascript.0
          2022-04-11 18:50:18.772	error	script.js.Xiaomi.MiHomeScript: TypeError: Cannot read property 'forEach' of undefined
            @pittini
            Erst mal Danke für das Skript, das sieht nach einer menge Arbeit aus!
              @pittini @haselchen
              Hallo Leute!
              Ich bin dem Problem etwas näher gekommen, kann es aber nicht lösen: Nehme ich den Ventilator aus meinem Xiaomi Account, läuft das script durch und ich bekomme sowohl Werte und Steuerungsmöglichkeiten für den Luftfilter.
              Ist der Lüfter dabei und kommentiere folgende Stelle aus, läuft das script auch durch, jedoch bekomme ich für keines der Geräte Werte, mit Ausnahme von den Werten im jeweiligen Objekt Ordner Info:
              Auf Systemebene gibt es dann auch keinen Fehler mehr von node-mihome. Die Datei für Mi Smart Standing Fan 2 - dmaker.fan.p18 - (voll/voll) ist in den entsprechenden Ordner kopiert und kontrolliert. Auch das Verhalten des scriptes ändert sich wenn die Datei kopiert wurde wie ich schon mal gezeigt habe. Mit der Definitionsdatei wird u.a. ein link erzeugt, der auf https://miot-spec.org/miot-spec-v2/instance?type=urn:miot-spec-v2:device:fan:0000A005:dmaker-p18:1 zeigt. Der funktioniert auch...
              Ich kann echt kein JavaScript und komme nicht weiter. Ich habe das Gefühl ich übersehe etwas offensichtliches...
                A Former User last edited by
                Darf ich in die Runde fragen, ob der 3er nun reibungslos funktioniert? Also mit ioBroker zusammen?
                Und wie schaut es mit dem "Xiaomi Smart Air Purifier 4" aus? Falls nicht, so würde ich ihn mir eventuell nicht kaufen. Weiß nicht so recht. In den Kommentaren steht immer, jaja, alles geht mit ioBroker, aber dann dauert es Monate und Jahre bis es funktioniert.
                crunchip 1 Reply Last reply Reply Quote 1
                  crunchip Forum Testing Most Active @Guest last edited by
                  @paul-ol Der 3H funktioniert, haben ja einige am laufen
                    Hi Ihr,
                    ich betreibe seit heute meinen "Smartmi Standing Fan 2S" (zhimi.fan.za4) mit dem genialen Skript. VIELEN DANK @Pittini !!!
                    Es klappt hervorragend.
                    Jetzt noch speziell zu meinem Gerät:
                    Drei Variable funktionieren nicht. Dort ist die Geräte-Datei zumindest für mein Gerät nicht korrekt. Kann hier jemand helfen?
                    Ich habe das hier mal zusammengetragen:
                    "buzzer" und "child_lock" ist wie in der App ein boolean.
                    "led_b" ist im Skript boolean, in der App könnte es aber auch was anderes sein, denn dort wählt man "hell, dunkel und aus" aus.
                    Bei "power_off" muss in der Device-Datei "m" in "s" geändert werden. Gut, das wäre das Einzige, was ich selbst schaffen würde 😉
                    Was noch zur Anleitung hinzugefügt werden könnte, sofern sich das auf längere Sicht bewahrheitet:
                    • Gerät kann nach erfolgreicher Verknüpfung (z.B. in einer FritzBox) vom Internet gekappt werden
                    • Gerät kann nach erfolgreicher Verknüpfung aus der Xiaomi-App gelöscht werden
                    • Gerät wird direkt im eigenen Netzwerk bedient. Der Umweg über das Internet, die Cloud ist nicht notwendig!!!
                    Soweit so erfolgreich heute. Ich glaube ich kaufe noch ein paar von den Dingern. Nochmal dickes DANKE!!!
                    HANNES
                      Pittini Developer @Guest last edited by
                      @hannnes sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                      Zu den Fehlern kann ich wenig sagen, da ich das Gerät nicht habe, da müßten mal andere User reagieren und das bestätigen oder nicht.
                      Was sicher nicht geht sind die 3 Vorschläge. Das Skript simuliert ja quasi nur die App, machste da das Inet weg kommen weder Daten noch kannste was steuern. Löschen des Gerätes in der App (und somit in der CLoud) sorgt dafür dass das Skript das GErät auch nimmer "sieht". Und doch, der Umweg über Internet/Cloud is nötig.
                      ? 1 Reply Last reply Reply Quote 1
                        A Former User @Pittini last edited by
                        @pittini said in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                        Antwort:
                        Das Verrückte ist, dass ich in der Fritz!Box dem Ventilator den Internetzugriff ja tatsächlich entzogen habe
                        d905b6ed-f0ad-4851-9548-ebe9f5b07dce-2022-06-25_15-25-31.png /var/folders/21/gzf2n3jj16j4pzdqpl9rc3gh0000gn/T/2022-06-25_15-25-31.png
                        und in der App ihn rausgeschmissen hatte
                        32ff59d8-a7c2-46ed-b642-2fe6f0a2daea-2022-06-25_15-30-12.png /var/folders/21/gzf2n3jj16j4pzdqpl9rc3gh0000gn/T/2022-06-25_15-30-12.png
                        Wenn das, was Du schreibst stimmen würde, und ich glaube Dir, dass Du Dir ganz sicher bist, dann würde man zu anderen Schlussfolgerungen kommen müssen, oder?
                        Die Xiaomi-App vergisst nie, wäre so eine Begründung, und die FritzBox kann alles blocken, aber keine Geräte von Xiaomi.
                        Wer weiß, was Da alles an Zaubertechnologie nötig wäre, um das möglich zu machen, aber eines weiß ich ganz sicher, wenn das Kabel zwischen FritzBox und Telefondose ausgesteckt ist, hat mein Netzwerk wirklich kein Internet mehr (ich habe kein 5G-Notfallnetz oder ähnliches...), dann kann er ja nicht mehr funktionieren.
                        Und trotzdem lässt er sich fernsteuern! Habe es gerade getestet.
                        Am besten Du testest es selbst einfach mal mit einem ähnlichen Produkt, das Du hast. Für mich ist das DIE Lösung!! Genau so wollte ich es haben.
                        • haselchen
                          haselchen Most Active @Guest last edited by
                          @hannnes
                          Zeig mal bitte, wie du ihn steuerst.....
                            A Former User @haselchen last edited by
                            @haselchen
                            im Moment noch so:
                            5cde27f4-0f51-43de-a979-f10951d80de5-2022-06-25_15-54-17.png /var/folders/21/gzf2n3jj16j4pzdqpl9rc3gh0000gn/T/2022-06-25_15-54-17.png
                            oder war die Frage anders gemeint?
                            • haselchen
                              @hannnes
                              Rein praktisch, wie schaltest du ihn ein oder aus?
                              Über Alexa, Blockly, manuell in den Datenpunkt schreiben?
                                @haselchen
                                aktuell Datenpunkt auswählen.
                                d33e025e-0eda-4ede-b7a9-583a66705603-2022-06-25_16-01-30 (1).gif /Users/hannes/Pictures/Snagit/Autosaved Captures.localized/2022-06-25_16-01-30 (1).gif
                                • haselchen
                                  haselchen Most Active @Guest last edited by haselchen
                                  @hannnes
                                  Also definitiv muss was an deinem Netzwerk haken.
                                  Wie Pittini schon schrieb, geht es ohne Verbindung mit dem INet nicht.
                                  Ich habs nachgestellt.
                                  Edit:
                                  @Hannnes ich nehme alles zurück und behaupte das Gegenteil.
                                  @Pittini trotz INet Sperre kann ich per Eingabe in den Datenpunkte das Gewünschte einstellen.
                                  An / Aus , Natürliche Brise etc. , es wird alles ausgeführt.
                                    @haselchen
                                    gut zu lesen! Ich dachte schon Du hältst mich für verrückt.
                                    Inzwischen habe ich das Gerät (im vom Internet abgeschnittenen Zustand) in HomeKit eingebunden. Klappt mega gut.
                                    • haselchen
                                      @hannnes
                                      Einerseits natürlich mysteriös.
                                      Aber wenns so auch klappt , umso besser.
                                      Aber das warum würde mich trotzdem interessieren.
                                      ? P 2 Replies Last reply Reply Quote 0
                                        A Former User @haselchen last edited by A Former User
                                        @haselchen
                                        mich auch
                                        Fernbedienung via Home Widget gebastelt.
                                          Pittini Developer @haselchen last edited by
                                          @haselchen sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
                                          Tatsächlich mysterös. Das einzige was ich mir noch vorstellen kann, ist, dass nach Authentifizierung das ganze lokal läuft. Dann sollte aber spätestens nach Neustart des JS Controller Feierabend sein, weil sich das Skript ja nimmer an der Cloud anmelden kann. @Hannnes probier das mal.
                                            A Former User @Pittini last edited by A Former User
                                            @pittini
                                            Ok, Test beendet:
                                            Dein Skript funktioniert nach SkriptAdaptet-Neustart nicht mehr.
                                            Die HomeBridge jedoch schon. Also theoretisch könnte man dem Skript bestimmt beibringen auch ohne Cloud zu leben, ohne das jetzt selbst zu können. Mir zeigt das aber, dass der Ventilator nach wie vor lauscht und das Skript ohne Nachfrage bei der Cloud senden kann.
                                            EDIT:
                                            Ein restart der HomeBridge hat nichts lahmgelegt. Der Fan 2S ist weiterhin über HomeKit steuerbar.
                                            458
                                            92013
