    4. Test Adapter Nuki-extended v2.0.x
      firebowl @Thomas Braun last edited by
      @thomas-braun Das Ergebnis sieht so aus:
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "bshb"         : 0.1.20   , installed 0.1.20
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "echarts"      : 1.0.7    , installed 1.0.7
      Adapter    "eusec"        : 0.9.1    , installed 0.9.1
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
      Adapter    "homeconnect"  : 1.0.1    , installed 1.0.1
      Adapter    "hs100"        : 2.0.7    , installed 2.0.7
      Adapter    "hue"          : 3.7.0    , installed 3.7.0
      Adapter    "ical"         : 1.12.1   , installed 1.12.1
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.4   , installed 1.11.4
      Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
      Adapter    "meross"       : 1.10.5   , installed 1.10.5
      Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
      Adapter    "nuki-extended": 2.3.1    , installed 2.6.5
      Adapter    "nut"          : 1.5.1    , installed 1.5.1
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pushover"     : 2.1.0    , installed 2.1.0
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
      Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "trashschedule": 2.0.2    , installed 2.0.2
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      x86_64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.19.3
      v16.15.1
      8.11.0
      mike
      OK:1 http://de.archive.ubuntu.com/ubuntu impish InRelease
      OK:2 https://packages.grafana.com/oss/deb stable InRelease
      OK:3 http://de.archive.ubuntu.com/ubuntu impish-updates InRelease
      OK:4 https://repos.influxdata.com/ubuntu bionic InRelease
      OK:5 https://deb.nodesource.com/node_14.x impish InRelease
      OK:6 http://de.archive.ubuntu.com/ubuntu impish-backports InRelease
      OK:7 http://de.archive.ubuntu.com/ubuntu impish-security InRelease
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           14.19.3-deb-1nodesource1
        Installationskandidat: 14.19.3-deb-1nodesource1
        Versionstabelle:
       *** 14.19.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x impish/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.5~dfsg-5ubuntu1 500
              500 http://de.archive.ubuntu.com/ubuntu impish/universe amd64 Packages
        Thomas Braun Most Active @firebowl last edited by Thomas Braun
        @firebowl Dann kann ich dir sagen, dass nodejs falsch installiert ist und die .list-Datei für influxdb hat auch einen falschen Eintrag.
        Dein Ubuntu wird noch 3 Wochen unterstützt. Wechsel auf die derzeitige LTS-Version. 22.04 ist das wohl
        Die wichtigste Frage ist:
        Wie hast du nodejs16 installiert? Welche Anleitung?
          @thomas-braun aktuell läuft das release upgrade. Ich hätte schwören können, ich hab nodejs16 über die Anleitung für ioBroker installiert. In dieser VM läuft auch sonst nix anderes, die Maschine ist rein der ioBroker mit InfluxDB und Grafana.
            @firebowl sagte in Test Adapter Nuki-extended v2.0.x:
            Welche?
              @thomas-braun Kann ich dir nicht mehr genau sagen. Ich vermute es war diese.
              Welche ist denn die "richtige"? Release upgrade ist durch.
                @firebowl
                Och Mann, warum können sich die ganzen 'Falschinstallierer' denn nie daran erinnern wie sie zu den Installationen in /usr/local/bin kommen?
                In meiner Signatur steht drin, wie man es macht.
                Wobei die Anleitung von stabilostick auch zum richtigen Ergebnis führen sollte. Was wird also immer anders gemacht?
                  firebowl @Thomas Braun last edited by firebowl
                  @thomas-braun Hab versucht es nach deiner Anleitung zu fixen aber ich glaub jetzt ist mehr kaputt als vorher. Die Pfade passen jetzt zwar aber jetzt passen ihm Abhängigkeiten nicht mehr.
                  [sudo] password for mike:
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.19.3
                  v14.19.3
                  6.14.17
                  mike
                  /home/mike
                  OK:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                  OK:2 https://deb.nodesource.com/node_14.x impish InRelease
                  OK:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                  OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                  OK:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
                  nodejs:
                    Versionstabelle:
                       12.22.9~dfsg-1ubuntu3 500
                          500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                  npm ERR! missing: @angular/common@14.0.3, required by iobroker.inst@3.0.0
                  npm ERR! missing: @angular/core@14.0.3, required by iobroker.inst@3.0.0
                  npm ERR! missing: zone.js@0.11.6, required by iobroker.inst@3.0.0
                  npm ERR! missing: iobroker.device-watcher@git+ssh://git@github.com/ciddi89/ioBroker.device-watcher.git#da0035195e1c35025429da30187e7443fe503bed, required by iobroker.inst@3.0.0
                  npm ERR! missing: iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42, required by iobroker.inst@3.0.0
                  npm ERR! missing: iobroker.switchbot-hub@git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e, required by iobroker.inst@3.0.0
                  npm ERR! extraneous: @angular/common@14.0.3 /opt/iobroker/node_modules/@angular/common
                  npm ERR! extraneous: @angular/core@14.0.3 /opt/iobroker/node_modules/@angular/core
                  npm ERR! extraneous: zone.js@0.11.6 /opt/iobroker/node_modules/zone.js
                  npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.device-watcher@git+ssh://git@github.com/ciddi89/ioBroker.device-watcher.git#da0035195e1c35025429da30187e7443fe503bed
                  npm ERR! missing: @types/iobroker@4.0.4, required by @iobroker/adapter-core@2.6.0
                  npm ERR! missing: @types/node@12.20.55, required by iobroker.javascript@5.7.0
                  npm ERR! missing: @types/node@12.20.55, required by @types/iobroker@4.0.3
                  npm ERR! missing: @iobroker/adapter-core@2.6.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                  npm ERR! missing: body-parser@1.20.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                  npm ERR! missing: express@4.18.1, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                  npm ERR! missing: ip@2.0.0, required by iobroker.nuki-extended@git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#f51ac1065821bda1ab407c0235f40ecb093c8f42
                  npm ERR! missing: bytes@3.1.2, required by body-parser@1.20.0
                  npm ERR! missing: depd@2.0.0, required by body-parser@1.20.0
                  npm ERR! missing: destroy@1.2.0, required by body-parser@1.20.0
                  npm ERR! missing: http-errors@2.0.0, required by body-parser@1.20.0
                  npm ERR! missing: on-finished@2.4.1, required by body-parser@1.20.0
                  npm ERR! missing: qs@6.10.3, required by body-parser@1.20.0
                  npm ERR! missing: raw-body@2.5.1, required by body-parser@1.20.0
                  npm ERR! missing: depd@2.0.0, required by http-errors@2.0.0
                  npm ERR! missing: inherits@2.0.4, required by http-errors@2.0.0
                  npm ERR! missing: setprototypeof@1.2.0, required by http-errors@2.0.0
                  npm ERR! missing: statuses@2.0.1, required by http-errors@2.0.0
                  npm ERR! missing: toidentifier@1.0.1, required by http-errors@2.0.0
                  npm ERR! missing: bytes@3.1.2, required by raw-body@2.5.1
                  npm ERR! missing: http-errors@2.0.0, required by raw-body@2.5.1
                  npm ERR! missing: accepts@1.3.8, required by express@4.18.1
                  npm ERR! missing: body-parser@1.20.0, required by express@4.18.1
                  npm ERR! missing: content-disposition@0.5.4, required by express@4.18.1
                  npm ERR! missing: cookie@0.5.0, required by express@4.18.1
                  npm ERR! missing: depd@2.0.0, required by express@4.18.1
                  npm ERR! missing: finalhandler@1.2.0, required by express@4.18.1
                  npm ERR! missing: http-errors@2.0.0, required by express@4.18.1
                  npm ERR! missing: on-finished@2.4.1, required by express@4.18.1
                  npm ERR! missing: qs@6.10.3, required by express@4.18.1
                  npm ERR! missing: safe-buffer@5.2.1, required by express@4.18.1
                  npm ERR! missing: send@0.18.0, required by express@4.18.1
                  npm ERR! missing: serve-static@1.15.0, required by express@4.18.1
                  npm ERR! missing: setprototypeof@1.2.0, required by express@4.18.1
                  npm ERR! missing: statuses@2.0.1, required by express@4.18.1
                  npm ERR! missing: negotiator@0.6.3, required by accepts@1.3.8
                  npm ERR! missing: safe-buffer@5.2.1, required by content-disposition@0.5.4
                  npm ERR! missing: on-finished@2.4.1, required by finalhandler@1.2.0
                  npm ERR! missing: statuses@2.0.1, required by finalhandler@1.2.0
                  npm ERR! missing: depd@2.0.0, required by send@0.18.0
                  npm ERR! missing: destroy@1.2.0, required by send@0.18.0
                  npm ERR! missing: http-errors@2.0.0, required by send@0.18.0
                  npm ERR! missing: ms@2.1.3, required by send@0.18.0
                  npm ERR! missing: on-finished@2.4.1, required by send@0.18.0
                  npm ERR! missing: statuses@2.0.1, required by send@0.18.0
                  npm ERR! missing: send@0.18.0, required by serve-static@1.15.0
                  npm ERR! missing: axios@0.21.4, required by iobroker.switchbot-hub@git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e
                  mike@iobroker:/opt/iobroker$
                  Korrektur, war mein Fehler. Jetzt sieht es so aus:
                  mike@iobroker:~$ iobroker update -i
                  sudo ln -s /usr/bin/node /usr/bin/nodejs
                  uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  cd /opt/iobroker
                  npm ls | grep 'ERR|github'
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.15.1
                  v16.15.1
                  8.11.0
                  mike
                  /home/mike
                  OK:6 https://deb.nodesource.com/node_14.x bullseye InRelease
                  OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
                  nodejs:
                    Installiert:           16.15.1-deb-1nodesource1
                    Installationskandidat: 16.15.1-deb-1nodesource1
                    Versionstabelle:
                   *** 16.15.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                          500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                    @firebowl
                    Immer noch Chaos...
                    Die Releasenames müssen passen. Jetzt haste da jammy, impish, bullseye und was weiß ich noch drin. Das ist falsch! Das muss alles gleich lauten! Und zwar auf das verwendete Release.
                      @thomas-braun Danke für den Hinweis aber leider bekomme ich die Einträge nicht weg:
                      mike@iobroker:~$ sudo apt update
                      Meine sources.list sieht meiner Meinung nach ok aus:
                        GNU nano 6.2                                      /etc/apt/sources.list *
                      ## team. Also, please note that software in universe WILL NOT receive any
                      ## review or updates from the Ubuntu security team.
                      deb http://de.archive.ubuntu.com/ubuntu jammy universe
                      deb http://de.archive.ubuntu.com/ubuntu jammy-updates universe
                      ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
                      ## team, and may not be under a free licence. Please satisfy yourself as to
                      ## your rights to use the software. Also, please note that software in
                      ## multiverse WILL NOT receive any review or updates from the Ubuntu
                      ## security team.
                      deb http://de.archive.ubuntu.com/ubuntu jammy multiverse
                      deb http://de.archive.ubuntu.com/ubuntu jammy-updates multiverse
                      ## N.B. software from this repository may not have been tested as
                      ## extensively as that contained in the main release, although it includes
                      ## newer versions of some applications which may provide useful features.
                      ## Also, please note that software in backports WILL NOT receive any review
                      ## or updates from the Ubuntu security team.
                      deb http://de.archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
                      deb http://de.archive.ubuntu.com/ubuntu jammy-security main restricted
                      deb http://de.archive.ubuntu.com/ubuntu jammy-security universe
                      deb http://de.archive.ubuntu.com/ubuntu jammy-security multiverse
                        @firebowl
                        Die weiteren Dateien liegen in /etc/apt/sources.list.d/
                        Die müssen alle auf jammy umgestellt werden.
                        Sollte aber nur die nodesource.list betreffen
                          @thomas-braun Argh, die hatte ich übersehen, danke dir.
                          cd /opt/iobroker
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          mike
                          /home/mike
                          OK:2 https://deb.nodesource.com/node_14.x jammy InRelease
                          OK:6 https://deb.nodesource.com/node_16.x jammy InRelease
                          nodejs:
                            Versionstabelle:
                                  500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                                  500 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages
                            @firebowl
                            Und dein Problem ist jetzt behoben?
                              @thomas-braun Sieht so aus, lag scheinbar an der veralteten NPM, wie Du gesagt hast. 🙂
                              Vielen Dank für die Unterstützung!
                                A Former User last edited by
                                Bei mir steht gelegentlich. "verbunden mit Gerät oder Dienst" das dies rot oder gelb ist. Also das scheint nicht grün zu sein. Wenn ich den Adapter dann aber neu starte, geht wieder alle. Kann ich eine Routine einbauen, die das automatisch macht? Habt ihr diese Anomalie auch?
                                • Horst Böttcher
                                  Horst Böttcher @Thomas Braun last edited by
                                  @thomas-braun wenn ich auf die katze gehe habe ich kein vom npm installieren
                                    Thomas Braun Most Active @Horst Böttcher last edited by
                                    @horst-böttcher
                                    Ich schon. Screenshot?
                                    Horst Böttcher 1 Reply Last reply Reply Quote 0
                                    • Horst Böttcher
                                        @horst-böttcher
                                        iobroker update -i
                                        zeigen.
                                        • Horst Böttcher
                                          pi@raspberrypi:/opt/iobroker $ iobroker update -i
                                          Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                                          Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                          Adapter    "chromecast"   : 2.3.1    , installed 3.0.1
                                          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                          Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                          Adapter    "devices"      : 1.0.12   , installed 1.0.12
                                          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                          Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                                          Adapter    "history"      : 1.11.1   , installed 1.11.1
                                          Adapter    "hmip"         : 1.17.0   , installed 1.17.0
                                          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                                          Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                          Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                          Adapter    "node-red"     : 3.3.1    , installed 3.3.0  [Updatable]
                                          Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
                                          Adapter    "openweathermap": 0.2.4   , installed 0.2.4
                                          Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
                                          Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                          Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                          Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                          Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                          Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                                          Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                          Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                          Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                                          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                          Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                          Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                            @horst-böttcher
                                            Hast du im Admin noch auf 'alte Oberfläche' gestellt?
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            113217
