    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
      paul.honka @Homoran last edited by
      Hallo ,
      habe auch das Error 25 Problem.
      Nach iob upgrade email --debug
      kamen diese Logs
      This upgrade of "email" will introduce the following changes:
      -> 1.1.3:
      Make sure the STARTTLS configuration field is displayed
      -> 1.1.2:
      Fix mail.ee settings
      -> 1.1.1:
      Allow to use connections to port 25 unencrypted
      -> 1.1.0:
      Adjust default settings for web.de and 1und1 and add ionos
      Add "Always use STARTTLS" option for custom SMTP settings
      Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
      Update email from @1.0.10 to @1.1.3
      NPM version: 8.11.0
      Installing iobroker.email@1.1.3... (System call)
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/define-properties
      npm ERR! dest /opt/iobroker/node_modules/.define-properties-gzFzeOn0
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/define-properties' -> '/opt/iobroker/node_modules/.define-properties-gzFzeOn0'
      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_51_01_894Z-debug-0.log
      host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
      Danach
      mv /opt/iobroker/node_modules/define-properties /opt/iobroker/node_modules/.define-properties-gzFzeOn0
      und Nach iob upgrade email --debug
      dann diese logs
      -> 1.1.3:
      -> 1.1.2:
      -> 1.1.1:
      -> 1.1.0:
      NPM version: 8.11.0
      npm ERR! path /opt/iobroker/node_modules/follow-redirects
      npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T04_53_25_440Z-debug-0.log
      Danach
      mv /opt/iobroker/node_modules/follow-redirects /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
      und wieder
      mit folgendem log
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module 'follow-redirects'
      Require stack:
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
      - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
      - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Module.require (node:internal/modules/cjs/loader:1005:19)
          at require (node:internal/modules/cjs/helpers:102:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
          at Module._compile (node:internal/modules/cjs/loader:1105:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
          at Module.load (node:internal/modules/cjs/loader:981:32)
          at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          at Module.require (node:internal/modules/cjs/loader:1005:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
          '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Die Instanzen der Adapter laufen, nach Neustart bleiben die im Stop.
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      Was lief da denn falsch.
      Gruss paul
        apollon77 @paul.honka last edited by
        @paul-honka Mach das letzte rename mal rückgängig .. du hast dasmit dem Axios eine Dep weggenommen.
        Ich bin nicht sivher das das ausführen der Renames die er selbst tun will und nicht kann wirklich die Lösung ist.
        Ich wäre eher dabei zu prüfen ob denn das ZIELVerzeichnis wohin er es renamen will vllt schon da ist und wenn ja dieses zu löschen.
        Im letzten Fall also /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd ... aber das ist jetzt bei dir irrelevant.
        Auch die Frage ist ob es hilt "Iob fix" vorher auszuführen
          paul.honka @apollon77 last edited by paul.honka
          @apollon77 Habe das letzte mv wieder rückgangig gemacht und den iob fix gestartet.
          Dann wieder iob upgrade email --debug
          und diesmal kommt die folgende Meldung
          npm ERR! path /opt/iobroker/node_modules/node-telegram-bot-api
          npm ERR! dest /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/node-telegram-bot-api' -> '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2'
          Telegramm???
          Ich glaub ich spiel mal ein Backup ein.
          Gruss paul
          Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @paul.honka last edited by
            @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
            Ich glaub ich spiel malt ein Backup ein.
            Das wird dir vermutlich nichts bringen.
              paul.honka @Thomas Braun last edited by paul.honka
              Wieso, Warum? Vor einer Woche konnte ich noch einige Adapter updaten?
              Gruss paul
              Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @paul.honka last edited by
                @paul-honka
                v16.15.1
                v16.15.1
                8.11.0
                vor oder nach dem Update auf 16 !?
                Zeige mal ( Ein/Ausgabe in Code-Tags setzen ) :
                iobroker update -u
                sudo ln -s /usr/bin/node /usr/bin/nodejs
                uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  Thomas Braun Most Active @paul.honka last edited by Thomas Braun
                  Das war auch bestimmt vor einem Upgrade auf nodejs16/npm8.
                  cd /opt/iobroker
                  npm ls | grep -E 'ERR|github'
                  liefert?
                    gibt es opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2 denn?
                      @thomas-braun mal ohne code tak, ok mit
                      ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59)
                      ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5)
                      npm ERR! code ELSPROBLEMS
                      npm ERR! invalid: iobroker.telegram@1.13.0 /opt/iobroker/node_modules/iobroker.telegram
                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_15_02_392Z-debug-0.log
                      Gruss paul
                      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                        mal ohne code tak
                        Warum?
                          paul.honka @Glasfaser last edited by
                          @glasfaser
                           iobroker update -u
                          Used repository: Stable (default)
                          Adapter    "email"        : 1.1.3    , installed 1.0.10 [Updatable]
                          Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                          Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
                          pi@IOBroker-Sted1:/opt/iobroker $
                          pi@IOBroker-Sted1:/opt/iobroker $ cd /opt/iobroker
                          pi@IOBroker-Sted1:/opt/iobroker $ npm ls | grep -E 'ERR|github'
                          pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -u
                          pi@IOBroker-Sted1:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                          pi@IOBroker-Sted1:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.15.1
                          v16.15.1
                          8.11.0
                          pi
                          /opt/iobroker
                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                          Alle Pakete sind aktuell.
                          nodejs:
                            Installiert:           16.15.1-deb-1nodesource1
                            Installationskandidat: 16.15.1-deb-1nodesource1
                            Versionstabelle:
                           *** 16.15.1-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                  100 /var/lib/dpkg/status
                               10.24.0~dfsg-1~deb10u1 500
                          Gruss paul
                          • Glasfaser
                            Bitte in Code-Tags setzten und auch nicht die Aus/Eingabe kürzen !
                            • Glasfaser
                              iobroker update -u
                              und wo ist der Rest .... kein Admin usw.
                              Thomas Braun P 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @Glasfaser last edited by
                                @glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                -u = Der Rest ist aktuell... 🙂
                                Glasfaser 1 Reply Last reply Reply Quote 1
                                  @glasfaser
                                  Das frage ich auch?
                                  Gruss paul
                                    @paul-honka
                                    Soweit i. O.
                                    Dann folge den Vorschlägen des Systems:
                                    • Glasfaser
                                      Glasfaser @Thomas Braun last edited by
                                      @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                      Mähh , habe -i mit -u vertauscht .... immer diese Autokorrektur 🙂
                                        paul.honka @Glasfaser last edited by paul.honka
                                        @glasfaser
                                        /opt/iobroker $ iobroker update -i
                                        Adapter    "admin"        : 5.3.8    , installed 5.3.8
                                        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                        Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                                        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                                        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                        Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
                                        Adapter    "history"      : 1.11.1   , installed 1.11.1
                                        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                                        Adapter    "iot"          : 1.11.4   , installed 1.11.4
                                        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                        Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                        Adapter    "pushover"     : 2.1.0    , installed 2.1.0
                                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                        Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                        Adapter    "text2command" : 2.2.1    , installed 2.2.1
                                        Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                        Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                        Gruss paul
                                          gemacht
                                           mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
                                          /opt/iobroker $  iob upgrade email --debug
                                          -> 1.1.3:
                                          -> 1.1.2:
                                          -> 1.1.1:
                                          -> 1.1.0:
                                          NPM version: 8.11.0
                                          npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
                                          npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
                                          npm ERR! errno -39
                                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
                                          Drehen wir uns im Kreis ?
                                          Steht wieder ein rename drin? Immer weiter umbenennen?
                                          Gruss paul
                                          Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
                                            Ja.
                                            errormeldung nodejs 16.15.1
                                            15
                                            169
                                            22099
