    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
    • Glasfaser
      Glasfaser @Thomas Braun last edited by
      @thomas-braun sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
      @glasfaser sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
      und wo ist der Rest .... kein Admin usw.
      -u = Der Rest ist aktuell... 🙂
      Mähh , habe -i mit -u vertauscht .... immer diese Autokorrektur 🙂
        paul.honka @Glasfaser last edited by paul.honka
        @glasfaser
        /opt/iobroker $ iobroker update -i
        Used repository: Stable (default)
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "ble"          : 0.12.0   , installed 0.12.0
        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
        Adapter    "email"        : 1.1.3    , installed 1.0.10 [Updatable]
        Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
        Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
        Adapter    "history"      : 1.11.1   , installed 1.11.1
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.4   , installed 1.11.4
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pushover"     : 2.1.0    , installed 2.1.0
        Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "sql"          : 1.16.2   , installed 1.16.2
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "text2command" : 2.2.1    , installed 2.2.1
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        Gruss paul
          paul.honka @Thomas Braun last edited by
          gemacht
           mv /opt/iobroker/node_modules/node-telegram-bot-api /opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2
          /opt/iobroker $  iob upgrade email --debug
          This upgrade of "email" will introduce the following changes:
          -> 1.1.3:
          Make sure the STARTTLS configuration field is displayed
          -> 1.1.2:
          Fix mail.ee settings
          -> 1.1.1:
          Allow to use connections to port 25 unencrypted
          -> 1.1.0:
          Adjust default settings for web.de and 1und1 and add ionos
          Add "Always use STARTTLS" option for custom SMTP settings
          Would you like to upgrade email from @1.0.10 to @1.1.3 now? [(y)es, (n)o]: y
          Update email from @1.0.10 to @1.1.3
          NPM version: 8.11.0
          Installing iobroker.email@1.1.3... (System call)
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/regexp.prototype.flags
          npm ERR! dest /opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/regexp.prototype.flags' -> '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX'
          npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_35_21_368Z-debug-0.log
          host.IOBroker-Sted1 Cannot install iobroker.email@1.1.3: 217
          Drehen wir uns im Kreis ?
          Steht wieder ein rename drin? Immer weiter umbenennen?
          Gruss paul
          Thomas Braun Glasfaser 3 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @paul.honka last edited by
            @paul-honka sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
            Ja.
              Deutet auf verfummelte Rechte hin. Mal als root oder per sudo unterwegs gewesen?
              P 4 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @paul.honka last edited by
                gesehen .... die mal löschen/verschieben !?
                  nein, nur das update auf node 16 vor einiger Zeit mit sudo, um die Einträge in der
                  etc/apt/sources.list.d zu ändern.
                  Gruss paul
                    Noch drei Runden verschieben dreht, dann war der E Mail Adapter uogedatet.
                    -> 1.1.3:
                    -> 1.1.2:
                    -> 1.1.1:
                    -> 1.1.0:
                    NPM version: 8.11.0
                    added 32 packages, removed 45 packages, and changed 8 packages in 1m
                    94 packages are looking for funding
                      run `npm fund` for details
                    Update "system.adapter.email.0"
                    upload [4] email.admin /opt/iobroker/node_modules/iobroker.email/admin/blockly.js blockly.js application/javascript
                    upload [3] email.admin /opt/iobroker/node_modules/iobroker.email/admin/email.png email.png image/png
                    upload [2] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index.html index.html text/html
                    upload [1] email.admin /opt/iobroker/node_modules/iobroker.email/admin/index_m.html index_m.html text/html
                    upload [0] email.admin /opt/iobroker/node_modules/iobroker.email/admin/words.js words.js application/javascript
                    Dann wollte ich flot updaten, das gleiche Spiel nochmal.
                    iob upgrade flot --debug
                    This upgrade of "flot" will introduce the following changes:
                    -> 1.11.0:
                    Trust GetHistory results to contain ms resolution timestamps
                    Would you like to upgrade flot from @1.10.7 to @1.11.0 now? [(y)es, (n)o]: y
                    Update flot from @1.10.7 to @1.11.0
                    NPM version: 8.11.0
                    Installing iobroker.flot@1.11.0... (System call)
                    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk
                    npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1
                    npm ERR! errno -39
                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-walk' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.acorn-walk-xHkEOJL1'
                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T08_57_13_800Z-debug-0.log
                    host.IOBroker-Sted1 Cannot install iobroker.flot@1.11.0: 217
                    Gruss paul
                      wo finde ich die package-lock.json, im /opt/obroker/log nicht.
                      Gruss paul
                        Jetzt fängt er an, das ich alle Dateien in /opt/iobroker/node_modules/iobroker.javascript/node_modules/
                        umbennen soll. Natürlich nur eine pro Update Aufruf. Kommt dann das nächste Verzeichnis drann?
                        Da wird es wohl Weihnachten. Das kann nicht die Lösung sein?
                        Gruss paul
                          apollon77 last edited by apollon77
                          Ich bin imme rnoch der Meinung das das nicht richtig ist was wir hier tun ... npm will das umbenennen, wohl weil es da Module gibt mit denen er was tun will ... und er kann es nicht umbenennen. So interpretiere ich diese Meldung. Die Frage ist also jetzt ob das Zielverzeichnis denn schon da ist oder warum er das anmeckert? Dann müsste man eher das aus dem Weg räumen.
                          EDIT: je mehr ich google umso mehr vermute ich das es das Zielverzeichnis ist was man löschen muss - warum auch immer esd da geblieben ist Und dann nochmal versuchen.
                          Das Rename zu machen macht ggf mehr Issues als alles andere
                          P 2 Replies Last reply Reply Quote 1
                            Thomas Braun Most Active last edited by
                            In /opt/iobroker/
                              paul.honka @apollon77 last edited by
                              @apollon77
                              Wenn ich nachher zu Hause bin, dann schaue ich mal nach der Verzeichnisstruktur.
                              Gruss paul
                                taba_luga @taba_luga last edited by
                                @thomas-braun nach drei Tagen umbenennen der Verzeichnisse und immer noch kein Ende in Sicht, habe ich das System jetzt auf den Snapshot mit Debian 10 zurückgerollt. Hier scheint noch alles zu ordentlich zu laufen. Ich werde jetzt erstmal auf diesem Stand bleiben und dort alle Adapter updaten. Wenn das alles ordentlich funktioniert hat, versuche ich nochmal ein Update auf Debian 11 mit NPM 8.
                                  Thomas Braun Most Active @taba_luga last edited by Thomas Braun
                                  @taba_luga sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                  Das Debian-Release hat nichts mit npm8 zu tun.
                                  Schau dir vor einem Upgrade auf node16/npm8 den npm tree an. Der muss möglichst sauber sein.
                                  cd /opt/iobroker
                                  npm ls | grep -E 'ERR|github'
                                  sollte im Altsystem schon ohne Rückmeldung durchlaufen.
                                    taba_luga @Thomas Braun last edited by
                                    Das war unglücklich formuliert von mir. Der Snapshot mit Debian 10 geht einher mit dem Stand Node14/npm6.
                                    xx@iobroker-prod:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                    /usr/bin/nodejs
                                    v14.19.3
                                    /usr/bin/node
                                    v14.19.3
                                    /usr/bin/npm
                                    6.14.17
                                    nodejs:
                                      Installiert:           14.19.3-1nodesource1
                                      Installationskandidat: 14.19.3-1nodesource1
                                      Versionstabelle:
                                     *** 14.19.3-1nodesource1 500
                                            500 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages
                                            100 /var/lib/dpkg/status
                                         10.24.0~dfsg-1~deb10u1 500
                                            500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                            500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                    xx@iobroker-prod:~$
                                    Leider läuft das nicht ohne Rückmeldung durch...
                                     xx@iobroker-prod:~$ cd /opt/iobroker
                                    xx@iobroker-prod:/opt/iobroker$ npm ls | grep -E 'ERR|github'
                                    [sudo] Passwort für xx:
                                    │ │ │ ├── github-from-package@0.0.0
                                    npm ERR! extraneous: @abandonware/noble@1.9.2-1 /opt/iobroker/node_modules/@abandonware/noble
                                    npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
                                    npm ERR! extraneous: @frankjoke/myadapter@1.2.4 /opt/iobroker/node_modules/@frankjoke/myadapter
                                    npm ERR! extraneous: @serialport/bindings@2.0.8 /opt/iobroker/node_modules/@serialport/bindings
                                    npm ERR! extraneous: @serialport/parser-byte-length@1.0.5 /opt/iobroker/node_modules/@serialport/parser-byte-length
                                    npm ERR! extraneous: @serialport/parser-cctalk@1.0.5 /opt/iobroker/node_modules/@serialport/parser-cctalk
                                    npm ERR! extraneous: @serialport/parser-readline@1.0.5 /opt/iobroker/node_modules/@serialport/parser-readline
                                    npm ERR! extraneous: @serialport/parser-ready@1.0.5 /opt/iobroker/node_modules/@serialport/parser-ready
                                    npm ERR! extraneous: @serialport/parser-regex@1.0.5 /opt/iobroker/node_modules/@serialport/parser-regex
                                    npm ERR! extraneous: @serialport/stream@2.0.5 /opt/iobroker/node_modules/@serialport/stream
                                    npm ERR! extraneous: iobroker.rflink /opt/iobroker/node_modules/iobroker.rflink
                                    npm ERR! error in /opt/iobroker/node_modules/iobroker.rflink: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.rflink/package.json'
                                    npm ERR! extraneous: alexa-remote2@1.0.0 /opt/iobroker/node_modules/alexa-remote2
                                    npm ERR! extraneous: axios@0.18.0 /opt/iobroker/node_modules/axios
                                    npm ERR! extraneous: dropbox-v2-api@2.4.0 /opt/iobroker/node_modules/dropbox-v2-api
                                    npm ERR! extraneous: express-fileupload@0.1.4 /opt/iobroker/node_modules/express-fileupload
                                    npm ERR! extraneous: fs-extra@0.22.1 /opt/iobroker/node_modules/fs-extra
                                    npm ERR! extraneous: googleapis@40.0.1 /opt/iobroker/node_modules/googleapis
                                    npm ERR! extraneous: iobroker@1.0.2 /opt/iobroker/node_modules/iobroker
                                    npm ERR! extraneous: iobroker.icons-material-png@0.1.0 /opt/iobroker/node_modules/iobroker.icons-material-png
                                    npm ERR! extraneous: iobroker.milight@0.3.6 /opt/iobroker/node_modules/iobroker.milight
                                    npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                    npm ERR! extraneous: joi@6.10.1 /opt/iobroker/node_modules/joi
                                    npm ERR! extraneous: js2xmlparser@3.0.0 /opt/iobroker/node_modules/js2xmlparser
                                    npm ERR! extraneous: jsonwebtoken@8.1.0 /opt/iobroker/node_modules/jsonwebtoken
                                    npm ERR! extraneous: md5@2.2.1 /opt/iobroker/node_modules/md5
                                    npm ERR! extraneous: mongodb@3.3.2 /opt/iobroker/node_modules/mongodb
                                    npm ERR! extraneous: mqtt-connection@3.2.0 /opt/iobroker/node_modules/mqtt-connection
                                    npm ERR! extraneous: nearest-color@0.4.2 /opt/iobroker/node_modules/nearest-color
                                    npm ERR! extraneous: net-ping@1.2.3 /opt/iobroker/node_modules/net-ping
                                    npm ERR! extraneous: noble@1.9.1 /opt/iobroker/node_modules/noble
                                    npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                                    npm ERR! extraneous: node-bluetooth@1.2.6 /opt/iobroker/node_modules/node-bluetooth
                                    npm ERR! extraneous: node-red@0.20.8 /opt/iobroker/node_modules/node-red
                                    npm ERR! extraneous: node-red-contrib-aggregator@1.5.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
                                    npm ERR! extraneous: node-red-contrib-os@0.1.7 /opt/iobroker/node_modules/node-red-contrib-os
                                    npm ERR! extraneous: node-red-contrib-polymer@0.0.21 /opt/iobroker/node_modules/node-red-contrib-polymer
                                    npm ERR! extraneous: node-red-dashboard@2.16.2 /opt/iobroker/node_modules/node-red-dashboard
                                    npm ERR! extraneous: node-ssdp@3.2.5 /opt/iobroker/node_modules/node-ssdp
                                    npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
                                    npm ERR! extraneous: openzwave-shared@1.4.0 /opt/iobroker/node_modules/openzwave-shared
                                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                    npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
                                    npm ERR! extraneous: prebuild-install@4.0.0 /opt/iobroker/node_modules/prebuild-install
                                    npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
                                    npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
                                    npm ERR! extraneous: pushover-notifications@0.2.4 /opt/iobroker/node_modules/pushover-notifications
                                    npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                                    npm ERR! extraneous: systeminformation@4.5.1 /opt/iobroker/node_modules/systeminformation
                                    npm ERR! extraneous: typescript@2.6.2 /opt/iobroker/node_modules/typescript
                                    npm ERR! extraneous: virtual-device-sdk@1.5.1 /opt/iobroker/node_modules/virtual-device-sdk
                                    npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
                                    npm ERR! extraneous: zwave-js@5.4.0 /opt/iobroker/node_modules/zwave-js
                                    npm ERR! peer dep missing: @zwave-js/core@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                                    npm ERR! peer dep missing: @zwave-js/shared@>=9.0.4, required by @zwave-js/log-transport-json@2.0.1
                                      Da vermute ich den Troublemaker:
                                        paul.honka @apollon77 last edited by paul.honka
                                        @apollon77 Noch mal ein Versuch
                                        -> 1.11.0:
                                        NPM version: 8.11.0
                                        npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless
                                        npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.caseless-E7EBKTiW'
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T16_56_44_129Z-debug-0.log
                                        und jetzt das Verzeichnis /opt/iobroker/node_modules/iobroker.javascript/node_modules
                                        659370 40 drwxrwxr-x+  91 iobroker iobroker 36864 Jun 28 18:56 .
                                         658280  4 drwxrwxr-x+   8 iobroker iobroker  4096 Jun  2 00:18 ..
                                        1708173  4 drwxrwxr-x+  12 iobroker iobroker  4096 Jun 28 10:55 @alcalzone
                                        1708174  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @babel
                                         794382  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 18:45 .bin
                                        1313831  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 coffee-script
                                        1313856  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 combined-stream
                                        1313868  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 core-util-is
                                        1313873  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 cron-parser
                                        1313884  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 dashdash
                                        1313887  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 debug
                                        1313900  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 define-properties
                                        1313908  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 delayed-stream
                                        2232767  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 dewpoint
                                        1313924  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 ecc-jsbn
                                        1708178  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @eslint
                                        1577393  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 extend
                                        1577772  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 extsprintf
                                        1577808  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 fast-deep-equal
                                        1577828  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 fast-json-stable-stringify
                                        2109566  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 forever-agent
                                        2109567  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 form-data
                                        2109573  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 function-bind
                                        2109577  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 get-intrinsic
                                        2109580  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 getpass
                                        2109594  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-schema
                                        2109595  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 har-validator
                                        2109596  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has
                                        2109598  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-property-descriptors
                                        2109599  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 has-symbols
                                        2109604  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 http-signature
                                        1708175  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 @humanwhocodes
                                        2109607  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 immediate
                                        2109612  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 inherits
                                         659375  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 18:56 @iobroker
                                        2109640  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isarray
                                        2109626  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 is-nan
                                        2109643  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 isstream
                                        2109634  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 is-typedarray
                                        2109647  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsbn
                                        2109652  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 jsonata
                                        2109648  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema
                                        2109649  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-schema-traverse
                                        2109651  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 json-stringify-safe
                                        2109654  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 jsprim
                                        2109655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 jszip
                                        2109663  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 lie
                                        2232582  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 long-timeout
                                        2232584  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 lru-cache
                                        2232585  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 luxon
                                        2232590  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-db
                                        2232591  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 mime-types
                                        2232594  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 minimist
                                        2232595  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 ms
                                        2232601  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-inspect
                                        1708176  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 @nodelib
                                        2232602  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 node-schedule
                                        2232607  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 oauth-sign
                                        2232609  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 object-keys
                                        2232624  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 pako
                                        2232640  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 performance-now
                                        2232641  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 picocolors
                                        2232649  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 process-nextick-args
                                        2232651  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 psl
                                        2232654  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 punycode
                                        2232655  4 drwxrwxr-x+   6 iobroker iobroker  4096 Jun 28 10:55 qs
                                        2232658  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 readable-stream
                                        2232843  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 request
                                         794224 24 drwxrwxr-x+ 478 pi       pi       24576 Jun 28 18:43 res
                                        2232680  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safe-buffer
                                        2232682  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 safer-buffer
                                         658277  4 drwxrwxr-x+   7 iobroker iobroker  4096 Jun  2 00:18 semver
                                        2232686  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 setimmediate
                                        2232692  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 sorted-array-functions
                                        2232702  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 sshpk
                                        2232707  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 string_decoder
                                        2232713  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 suncalc2
                                        2232727  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 tough-cookie
                                        2232728  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tunnel-agent
                                        2232729  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 tweetnacl
                                         659374  4 drwxrwxr-x+  13 iobroker iobroker  4096 Jun 28 18:56 @types
                                         658278  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun  2 00:18 typescript
                                        1708182  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 @ungap
                                        2232741  4 drwxrwxr-x+   3 iobroker iobroker  4096 Jun 28 10:55 uri-js
                                        2232744  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 util-deprecate
                                        2232745  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 uuid
                                        2232858  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 verror
                                        2232752  4 drwxrwxr-x+   4 iobroker iobroker  4096 Jun 28 10:55 virtual-tsc
                                        2232857  4 drwxrwxr-x+   5 iobroker iobroker  4096 Jun 28 10:55 vm2
                                        2232753  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 wake_on_lan
                                        2232762  4 drwxrwxr-x+   2 iobroker iobroker  4096 Jun 28 10:55 yallist
                                        Wenig . Verzeichnisse dabei, sonst war zu jedem Verzeichnis auch ein .Verzeichnis vorhanden-
                                        zB. coffee-script und .coffee-script
                                        Vielleicht hat jemand ne Idee.
                                        Gruss paul
                                          /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                                          Lösch das Verzeichnis mal
                                          sudo -u iobroker rm -rf /opt/iobroker/node_modules/iobroker.javascript/node_modules/.core-util-is-eZ4fUaee
                                            paul.honka @Thomas Braun last edited by paul.honka
                                            pi@IOBroker-Sted1:/opt/iobroker $ iob upgrade flot --debug
                                            -> 1.11.0:
                                            NPM version: 8.11.0
                                            npm ERR! errno -39
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T17_07_00_023Z-debug-0.log
                                            Endlosschleife?
                                            Gruss paul
                                            errormeldung nodejs 16.15.1
                                            15
                                            169
                                            22060
