    4. Kein Update mehr möglich mit Node.js 16
    • Glasfaser
      Glasfaser @Negalein last edited by
      @negalein sagte in Kein Update mehr möglich mit Node.js 16:
      was kann ich noch machen?
      Ausgabe mit debug , dann sieht man mehr
      iobroker upgrade cloud@4.1.2 --debug
      • Negalein
        Negalein Global Moderator @Glasfaser last edited by
        @glasfaser sagte in Kein Update mehr möglich mit Node.js 16:
        nega@ioBroker:~$ iobroker upgrade cloud@4.1.2 --debug
        This upgrade of "cloud" will introduce the following changes:
        -> 4.1.2:
        Added preparations for Admin 6
        Added better error reporting
        Removed outdated `request` library
        Used common sockets (could be buggy)
        Would you like to upgrade cloud from @4.1.1 to @4.1.2 now? [(y)es, (n)o]: y
        Update cloud from @4.1.1 to @4.1.2
        NPM version: 8.11.0
        Installing iobroker.cloud@4.1.2... (System call)
        npm WARN old lockfile
        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
        npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
        npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
        npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
        npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
        npm WARN old lockfile     at IntegrityStream.end (/usr/lib/node_modules/npm/node_modules/minipass/index.js:248:27)
        npm WARN old lockfile     at Yallist.<anonymous> (/usr/lib/node_modules/npm/node_modules/minipass/index.js:409:18)
        npm WARN old lockfile     at Yallist.forEach (/usr/lib/node_modules/npm/node_modules/yallist/yallist.js:156:8)
        npm WARN old lockfile     at Minipass.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:406:18)
        npm WARN old lockfile     at Minipass.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
        npm WARN old lockfile     at Minipass.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
        npm WARN old lockfile     at Minipass.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
        npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
        npm WARN old lockfile     at Minipass.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
        npm WARN old lockfile   code: 'EINTEGRITY',
        npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
        npm WARN old lockfile   expected: [
        npm WARN old lockfile     Hash {
        npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
        npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
        npm WARN old lockfile       algorithm: 'sha512',
        npm WARN old lockfile       options: []
        npm WARN old lockfile     }
        npm WARN old lockfile   ],
        npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/follow-redirects
        npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
        npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T09_01_36_002Z-debug-0.log
        host.ioBroker Cannot install iobroker.cloud@4.1.2: 217
          Thomas Braun Most Active @Negalein last edited by
          nega@ioBroker:~$ npm ls | grep ERR
          Du stehst im falschen Verzeichnis.
          cd /opt/iobroker
          npm ls | grep -E 'ERR|github'
          Adapter aus dem github auf eine Version aus einem Repo drücken, wenn möglich.
          • Negalein
            Negalein Global Moderator @Thomas Braun last edited by
            @thomas-braun sagte in Kein Update mehr möglich mit Node.js 16:
            +-- iobroker.enigma2@1.3.3 (git+ssh://git@github.com/Matten-Matten/ioBroker.enigma2.git#975e828ab4595b81333bcca5b32af3cbf3c287bc)
            +-- iobroker.fronius-solarweb@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#bf873fc05ce1eecdff2aff880793b3e9f0a6c417)
            +-- iobroker.fronius@1.1.6 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fronius.git#04dcfa98e3ca0e5d888dc8182a314717f65b390c)
            +-- iobroker.hs100@2.1.2 (git+ssh://git@github.com/arteck/ioBroker.hs100.git#9a5ada63aa2a381f934e2152a8d5155ebad8f16f)
            +-- iobroker.jarvis@3.0.12-beta.3 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#bacd7221d9990610ee6c684e0ec6fddd397cde79)
            +-- iobroker.logparser@1.1.0 (git+ssh://git@github.com/Mic-M/ioBroker.logparser.git#f767910b12124a39c65132d4f835f71e9c9a03a8)
            +-- iobroker.octoprint@4.0.0 (git+ssh://git@github.com/klein0r/ioBroker.octoprint.git#d08a293e8f63fd36d6221ce9da014a2d67d5c9ec)
            +-- iobroker.pegelalarm@1.2.7 (git+ssh://git@github.com/simatec/ioBroker.pegelalarm.git#d5515a48667d9ced7f8c29fc187d967b557f495e)
            +-- iobroker.vis-knob@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.vis-knob.git#a1dc9e3758987a921c893c0d63497e742d5c3526)
            +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git#294107d34a0e873959795bbc00c09e9def6e3a42)
            npm ERR! code ELSPROBLEMS
            npm ERR! invalid: iobroker.ical@1.13.1 /opt/iobroker/node_modules/iobroker.ical
            npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T09_10_03_705Z-debug-0.log
            wie meinst du das?
              wie meinst du das?
              Damit meine ich, diese Adapter aus einem Repo zu installieren, falls es den denn in stable oder beta-Versionen gibt.
              • Negalein
                diese
                oder alle die aktuell nicht zu installieren sind?
                • Negalein
                  PS: installiere ich von Git, kommt auch der Error 25
                  $ iobroker url simatec/ioBroker.pegelalarm --host ioBroker
                  install simatec/ioBroker.pegelalarm
                  NPM version: 8.11.0
                  Installing simatec/ioBroker.pegelalarm... (System call)
                  host.ioBroker Cannot install simatec/ioBroker.pegelalarm: 217
                  ERROR: Process exited with code 25
                    @negalein
                    So viele wie möglich aus github rausheben.
                    • Negalein
                      Ah, du meinst "weg von Github"?
                      Hmm, das ist doof.
                      Ich hab die 10 upzudatenden Adapter alle im Beta.
                      Dann muss ich abwarten bis das gefixt ist, oder doch jetzt schon auf Admin 6 updaten.
                        @negalein
                        Alle Adapter mit git+ssh://git@github.com sind derzeitig über github installiert, nicht aus den Repos.
                        • Negalein
                          stimmt. Die benötige ich mit dieser Version.
                          Aber Cloud und IOT sind nicht aus Github. Zumindest stehen sie nicht in obiger Liste.
                          Bringen aber auch der Error 25.
                          Ist das akzuell ein generelles Problem von Git, oder von meinem System?
                            Thomas Braun Most Active @Negalein last edited by Thomas Braun
                            Das rührt (denke ich) aus dem geänderten Format der package-lock und weiterer Dateien aus der npm-Ecke her.
                            Da liegt iobroker.icons-open-icon-library-png irgendwie quer, das löst für alle npm-Aktionen den Fehler 25 aus.
                            • Negalein
                              kann man das selber beheben?
                                Wo klemmt es denn konkret mit dem Ding?
                                Hast du das in Version 0.1.2 'ordentlich' aus einem Repo?
                                github:	0.1.3
                                latest:	0.1.2 for 78 months
                                stable:	0.1.2 for 78 months
                                • Negalein
                                  wie schau ich da nach?
                                    @negalein
                                    iobroker update -i
                                    • Negalein
                                      iobroker update -i
                                      nega@ioBroker:~$ iobroker update -i
                                      Used repository: Beta (latest)
                                      Adapter    "admin"        : 6.1.6    , installed 5.4.9  [Updatable]
                                      Adapter    "alexa-timer-vis": 0.1.13 , installed 0.1.13
                                      Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
                                      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                      Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
                                      Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                      Adapter    "cloud"        : 4.1.2    , installed 4.1.1  [Updatable]
                                      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                                      Adapter    "denon"        : 1.13.4   , installed 1.13.4
                                      Adapter    "devices"      : 1.0.12   , installed 1.0.12
                                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                      Adapter    "doorbird"     : 0.1.5    , installed 0.1.5
                                      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                      Adapter    "email"        : 1.1.3    , installed 1.1.3
                                      Adapter    "eventlist"    : 1.0.1    , installed 1.0.0  [Updatable]
                                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                      Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                      Adapter    "fronius"      : 1.1.3    , installed 1.1.6
                                      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                      Adapter    "history"      : 2.1.7    , installed 2.1.4  [Updatable]
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "hs100"        : 2.0.7    , installed 2.1.2
                                      Adapter    "hue"          : 3.7.0    , installed 3.7.0
                                      Adapter    "ical"         : 1.13.1   , installed 1.13.1
                                      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                                      Adapter    "influxdb"     : 3.1.7    , installed 3.1.5  [Updatable]
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.11.8   , installed 1.11.7 [Updatable]
                                      Adapter    "iqontrol"     : 2.0.1    , installed 2.0.1
                                      Adapter    "jarvis"       : 3.0.11   , installed 3.0.12-beta.3
                                      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                      Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                      Adapter    "meteoalarm"   : 2.1.5    , installed 2.1.5
                                      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                      Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                      Adapter    "node-red"     : 3.3.1    , installed 3.3.1
                                      Adapter    "nut"          : 1.5.1    , installed 1.5.1
                                      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                                      Adapter    "parser"       : 1.1.8    , installed 1.1.7  [Updatable]
                                      Adapter    "pegelalarm"   : 1.2.8    , installed 1.2.7  [Updatable]
                                      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                                      Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                      Adapter    "plex"         : 0.9.1    , installed 0.9.1
                                      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                      Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                      Adapter    "proxy"        : 1.3.1    , installed 1.3.1
                                      Adapter    "puppeteer"    : 0.2.1    , installed 0.2.1
                                      Adapter    "seq"          : 0.2.10   , installed 0.2.10
                                      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                                      Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                      Adapter    "snmp"         : 1.0.0    , installed 1.0.0
                                      Adapter    "socketio"     : 6.1.7    , installed 6.1.7
                                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                      Adapter    "synology"     : 2.1.8    , installed 2.1.8
                                      Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                      Adapter    "unifi"        : 0.6.1    , installed 0.6.1
                                      Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                      Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                      Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
                                      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                      Adapter    "web"          : 5.2.3    , installed 5.2.3
                                      Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                                      Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
                                      Adapter    "ws"           : 2.1.2    , installed 2.1.2
                                        Drück das auf 0.1.2:
                                        iobroker upgrade icons-open-icon-library-png@0.1.2
                                        • Negalein
                                          nega@ioBroker:~$ iobroker upgrade icons-open-icon-library-png@0.1.2
                                          Would you like to downgrade icons-open-icon-library-png from @0.1.3 to @0.1.2 now? [(y)es, (n)o]: y
                                          Update icons-open-icon-library-png from @0.1.3 to @0.1.2
                                          NPM version: 8.11.0
                                          Installing https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master... (System call)
                                          host.ioBroker Cannot install https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: 217
                                          nega@ioBroker:~$
                                            @negalein
                                            Dann deinstallier den Adapter ganz und dann ziehst du den nochmal regulär in Version 0.1.2 rein.
                                            Oder den
                                            iobroker fix
                                            über das System laufen lassen.
                                            node js
                                            16
                                            335
                                            38453
