    4. Kein Update mehr möglich mit Node.js 16
      Thomas Braun Most Active @Negalein last edited by Thomas Braun
      @negalein
      Dann deinstallier den Adapter ganz und dann ziehst du den nochmal regulär in Version 0.1.2 rein.
      Oder den
      iobroker fix
      über das System laufen lassen.
      • Negalein
        Negalein Global Moderator @Thomas Braun last edited by
        @thomas-braun sagte in Kein Update mehr möglich mit Node.js 16:
        der zickt rum.
        Deinstalliert und dann mit sudo rm -r /opt/iobroker/node_modules/iobroker.icons-open-icon-library-pngkomplett gelöscht.
        Beim installieren (+) kommt trotzdem wieder
        $ iobroker add icons-open-icon-library-png auto --host ioBroker
        NPM version: 8.11.0
        Installing iobroker.icons-open-icon-library-png@0.1.2... (System call)
        host.ioBroker Cannot install iobroker.icons-open-icon-library-png@0.1.2: 217
        ERROR: Process exited with code 25
          Thomas Braun Most Active last edited by Thomas Braun
          @negalein sagte in Kein Update mehr möglich mit Node.js 16:
          iobroker update
          iobroker add icons-open-icon-library-png auto --host ioBroker --debug
          • Negalein
            iobroker update
            nega@ioBroker:~$ iobroker add icons-open-icon-library-png auto --host ioBroker --debug
            NPM version: 8.11.0
            npm WARN old lockfile
            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
            npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying again.
            npm WARN old lockfile Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
            npm WARN old lockfile     at IntegrityStream.[_onEnd] (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:118:19)
            npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:88:19)
            npm WARN old lockfile     at IntegrityStream.[maybeEmitEnd] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:370:12)
            npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/minipass/index.js:434:29)
            npm WARN old lockfile     at IntegrityStream.emit (/usr/lib/node_modules/npm/node_modules/ssri/lib/index.js:90:18)
            npm WARN old lockfile     at IntegrityStream.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:265:12)
            npm WARN old lockfile     at IntegrityStream.resume (/usr/lib/node_modules/npm/node_modules/minipass/index.js:269:24)
            npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/minipass-pipeline/index.js:105:19)
            npm WARN old lockfile     at CachingMinipassPipeline.emit (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/pipeline.js:37:18)
            npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10)
            npm WARN old lockfile  Could not fetch metadata for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master Error: sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
            npm WARN old lockfile     at CachingMinipassPipeline.[resume] (/usr/lib/node_modules/npm/node_modules/minipass/index.js:259:10) {
            npm WARN old lockfile   code: 'EINTEGRITY',
            npm WARN old lockfile   found: Integrity { sha512: [ [Hash] ] },
            npm WARN old lockfile   expected: [
            npm WARN old lockfile     Hash {
            npm WARN old lockfile       source: 'sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
            npm WARN old lockfile       digest: 'qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==',
            npm WARN old lockfile       algorithm: 'sha512',
            npm WARN old lockfile       options: []
            npm WARN old lockfile     }
            npm WARN old lockfile   ],
            npm WARN old lockfile   sri: Integrity { sha512: [ [Hash] ] }
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/follow-redirects
            npm ERR! dest /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/follow-redirects' -> '/opt/iobroker/node_modules/.follow-redirects-vRGWWNjd'
            npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T12_28_27_316Z-debug-0.log
              @negalein
              Lösch mal den npm cache.
              • Negalein
                da kommt nur eine Fehlermeldung
                nega@ioBroker:~$ npm cache clean --force
                npm WARN using --force Recommended protections disabled.
                  @negalein
                  Das ist a) keine Fehlermeldung und b) stehst du im falschen Verzeichnis.
                  cd /opt/iobroker
                  sudo -H -u iobroker npm cache clean --force
                  cd /home/iobroker
                  • Negalein
                    Ahhh, das überseh ich immer wieder 😞
                    nega@ioBroker:~$ cd /opt/iobroker
                    nega@ioBroker:/opt/iobroker$ sudo -H -u iobroker npm cache clean --force
                    [sudo] password for nega:
                    nega@ioBroker:/opt/iobroker$ cd /home/iobroker
                    nega@ioBroker:/home/iobroker$ sudo -H -u iobroker npm cache clean --force
                    • Negalein
                      hab jetzt nochmal versucht den Adapter zu installieren.
                      Funktioniert leider nicht
                      nega@ioBroker:/opt/iobrokeriobroker add icons-open-icon-library-png auto --host ioBroker --debug
                      NPM version: 8.11.0
                      npm ERR! errno -39
                      npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T15_32_56_005Z-debug-0.log
                        iobroker stop
                        sudo -u iobroker rm -rf /opt/iobroker/node_modules/.follow-redirects-vRGWWNjd
                        sudo -u iobroker rm /opt/iobroker/package-lock.json
                        iobroker start
                        • Negalein
                          iobroker stop
                          iobroker start
                          und dann wieder iobroker add icons-open-icon-library-png auto --host ioBroker --debug?
                          Das liefert wieder
                          nega@ioBroker:/opt/iobroker$ iobroker add icons-open-icon-library-png auto --host ioBroker --debug
                          NPM version: 8.11.0
                          Installing https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master... (System call)
                          npm ERR! path /opt/iobroker/node_modules/iobroker.ical
                          npm ERR! dest /opt/iobroker/node_modules/.iobroker.ical-rrBOhFW0
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.ical' -> '/opt/iobroker/node_modules/.iobroker.ical-rrBOhFW0'
                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-28T16_12_39_535Z-debug-0.log
                          host.ioBroker Cannot install https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: 217
                            Dann lösch auch das Verzeichnis.
                            Negalein 2 Replies Last reply Reply Quote 0
                            • Negalein
                              Danke, jetzt laufen wieder alle Updates!
                                @negalein Oh, magst du mal
                                iobroker update -i
                                und
                                cd /opt/iobroker
                                npm ls
                                zeigen?
                                • Negalein
                                  iobroker update -i
                                  nega@ioBroker:/opt/iobroker$ iobroker update -i
                                  Used repository: Beta (latest)
                                  Adapter    "admin"        : 6.1.6    , installed 5.4.9  [Updatable]
                                  Adapter    "alexa-timer-vis": 0.1.13 , installed 0.1.13
                                  Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
                                  Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                  Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
                                  Adapter    "bring"        : 1.8.1    , installed 1.8.1
                                  Adapter    "cloud"        : 4.1.2    , installed 4.1.2
                                  Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                                  Adapter    "denon"        : 1.13.4   , installed 1.13.4
                                  Adapter    "devices"      : 1.0.12   , installed 1.0.12
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Adapter    "doorbird"     : 0.1.5    , installed 0.1.5
                                  Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                  Adapter    "email"        : 1.1.3    , installed 1.1.3
                                  Adapter    "eventlist"    : 1.0.1    , installed 1.0.1
                                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                  Adapter    "fronius"      : 1.1.3    , installed 1.1.6
                                  Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                  Adapter    "history"      : 2.1.7    , installed 2.1.7
                                  Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                  Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                  Adapter    "hs100"        : 2.0.7    , installed 2.1.2
                                  Adapter    "hue"          : 3.7.0    , installed 3.7.0
                                  Adapter    "ical"         : 1.13.1   , installed 1.13.1
                                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                  Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                  Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
                                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                                  Adapter    "iot"          : 1.11.8   , installed 1.11.8
                                  Adapter    "iqontrol"     : 2.0.1    , installed 2.0.1
                                  Adapter    "jarvis"       : 3.0.11   , installed 3.1.0-alpha.23
                                  Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                  Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                  Adapter    "meteoalarm"   : 2.1.5    , installed 2.1.5
                                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                  Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                  Adapter    "node-red"     : 3.3.1    , installed 3.3.1
                                  Adapter    "nut"          : 1.5.1    , installed 1.5.1
                                  Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
                                  Adapter    "parser"       : 1.1.8    , installed 1.1.8
                                  Adapter    "pegelalarm"   : 1.2.8    , installed 1.2.8
                                  Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                  Adapter    "plex"         : 0.9.1    , installed 0.9.1
                                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                  Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                  Adapter    "proxy"        : 1.3.1    , installed 1.3.1
                                  Adapter    "puppeteer"    : 0.2.1    , installed 0.2.1
                                  Adapter    "seq"          : 0.2.10   , installed 0.2.10
                                  Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                                  Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
                                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                  Adapter    "snmp"         : 1.0.0    , installed 1.0.0
                                  Adapter    "socketio"     : 6.1.7    , installed 6.1.7
                                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                  Adapter    "synology"     : 2.1.8    , installed 2.1.8
                                  Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                                  Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                  Adapter    "unifi"        : 0.6.1    , installed 0.6.1
                                  Adapter    "vis"          : 1.4.15   , installed 1.4.15
                                  Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                  Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                  Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
                                  Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                                  Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
                                  Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                  Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                  Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                  Adapter    "web"          : 5.2.3    , installed 5.2.3
                                  Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                                  Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
                                  Adapter    "ws"           : 2.1.2    , installed 2.1.2
                                  npm ls
                                  nega@ioBroker:/opt/iobroker$ npm ls
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  +-- iobroker.admin@5.4.9
                                  +-- iobroker.alexa-timer-vis@0.1.13
                                  +-- iobroker.alexa2@3.12.0
                                  +-- iobroker.alias-manager@1.2.6
                                  +-- iobroker.backitup@2.4.9
                                  +-- iobroker.birthdays@2.1.0
                                  +-- iobroker.bring@1.8.1
                                  +-- iobroker.cloud@4.1.2
                                  +-- iobroker.daswetter@3.1.3
                                  +-- iobroker.denon@1.13.4
                                  +-- iobroker.devices@1.0.12
                                  +-- iobroker.discovery@3.0.5
                                  +-- iobroker.doorbird@0.1.5
                                  +-- iobroker.dwd@2.8.3
                                  +-- iobroker.email@1.1.3
                                  +-- iobroker.enigma2@1.3.3 (git+ssh://git@github.com/Matten-Matten/ioBroker.enigma2.git#975e828ab4595b81333bcca5b32af3cbf3c287bc)
                                  +-- iobroker.eventlist@1.0.1
                                  +-- iobroker.feiertage@1.1.0
                                  +-- iobroker.flot@1.11.0
                                  +-- iobroker.fronius-solarweb@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.fronius-solarweb.git#bf873fc05ce1eecdff2aff880793b3e9f0a6c417)
                                  +-- iobroker.fronius@1.1.6 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.fronius.git#c644a95d480403a1ef277e822df6232ffc66daf5)
                                  +-- iobroker.harmony@1.2.2
                                  +-- iobroker.history@2.1.7
                                  +-- iobroker.hm-rega@3.0.40
                                  +-- iobroker.hm-rpc@1.15.12
                                  +-- iobroker.hs100@2.1.2 (git+ssh://git@github.com/arteck/ioBroker.hs100.git#ee2cfded55b787bcc5431f7b0d1ba7e31117aace)
                                  +-- iobroker.hue@3.7.0
                                  +-- iobroker.ical@1.13.1
                                  +-- iobroker.icons-addictive-flavour-png@0.1.0
                                  +-- iobroker.icons-fatcow-hosting@0.1.0
                                  +-- iobroker.icons-icons8@0.0.1
                                  +-- iobroker.icons-material-png@0.1.0
                                  +-- iobroker.icons-material-svg@0.1.0
                                  +-- iobroker.icons-mfd-png@1.1.0
                                  +-- iobroker.icons-mfd-svg@1.1.0
                                  +-- iobroker.icons-open-icon-library-png@0.1.2
                                  +-- iobroker.icons-ultimate-png@1.0.1
                                  +-- iobroker.influxdb@3.1.7
                                  +-- iobroker.info@1.9.19
                                  +-- iobroker.iot@1.11.8
                                  +-- iobroker.iqontrol@2.0.1
                                  +-- iobroker.jarvis@3.1.0-alpha.23 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#133d68fd7f5d19e51492cca35f4d5bb9351a505c)
                                  +-- iobroker.javascript@5.7.0
                                  +-- iobroker.js-controller@4.0.23
                                  +-- iobroker.linkeddevices@1.5.5
                                  +-- iobroker.linux-control@1.1.5
                                  +-- iobroker.logparser@1.1.0 (git+ssh://git@github.com/Mic-M/ioBroker.logparser.git#f767910b12124a39c65132d4f835f71e9c9a03a8)
                                  +-- iobroker.meteoalarm@2.1.5
                                  +-- iobroker.mihome@1.4.0
                                  +-- iobroker.mytime@0.7.12
                                  +-- iobroker.nina@0.0.25
                                  +-- iobroker.node-red@3.3.1
                                  +-- iobroker.nut@1.5.1
                                  +-- iobroker.octoprint@4.0.0 (git+ssh://git@github.com/klein0r/ioBroker.octoprint.git#43f169d03ec623c8bb08ff16f3131ff6be363d09)
                                  +-- iobroker.parser@1.1.8
                                  +-- iobroker.pegelalarm@1.2.8 (git+ssh://git@github.com/simatec/ioBroker.pegelalarm.git#46029e9011909fcbbcf2e37394a5efdfbe9ae1cd)
                                  +-- iobroker.pi-hole@1.3.4
                                  +-- iobroker.ping@1.5.3
                                  +-- iobroker.plex@0.9.1
                                  +-- iobroker.pollenflug@1.0.6
                                  +-- iobroker.proxmox@1.3.4
                                  +-- iobroker.proxy@1.3.1
                                  +-- iobroker.puppeteer@0.2.1
                                  +-- iobroker.seq@0.2.10
                                  +-- iobroker.shelly@5.3.2
                                  +-- iobroker.shuttercontrol@1.4.14
                                  +-- iobroker.simple-api@2.7.0
                                  +-- iobroker.snmp@1.0.0
                                  +-- iobroker.socketio@6.1.7
                                  +-- iobroker.sourceanalytix@0.4.14
                                  +-- iobroker.synology@2.1.8
                                  +-- iobroker.telegram@1.13.0
                                  +-- iobroker.trashschedule@2.0.3
                                  +-- iobroker.unifi@0.6.1
                                  +-- iobroker.vis-bars@0.1.4
                                  +-- iobroker.vis-canvas-gauges@0.1.5
                                  +-- iobroker.vis-colorpicker@1.2.0
                                  +-- iobroker.vis-fancyswitch@1.1.0
                                  +-- iobroker.vis-google-fonts@1.0.3
                                  +-- iobroker.vis-history@1.0.0
                                  +-- iobroker.vis-hqwidgets@1.2.0
                                  +-- iobroker.vis-icontwo@0.87.0
                                  +-- iobroker.vis-inventwo@3.3.3
                                  +-- iobroker.vis-jqui-mfd@1.0.12
                                  +-- iobroker.vis-justgage@1.0.2
                                  +-- iobroker.vis-knob@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.vis-knob.git#a1dc9e3758987a921c893c0d63497e742d5c3526)
                                  +-- iobroker.vis-map@1.0.4
                                  +-- iobroker.vis-material@0.1.3
                                  +-- iobroker.vis-materialdesign@0.5.5
                                  +-- iobroker.vis-metro@1.2.0
                                  +-- iobroker.vis-players@0.1.6
                                  +-- iobroker.vis-rgraph@0.0.2
                                  +-- iobroker.vis-timeandweather@1.1.7
                                  +-- iobroker.vis-weather@2.5.5
                                  +-- iobroker.vis@1.4.15
                                  +-- iobroker.weatherunderground@3.4.2
                                  +-- iobroker.web-speedy@0.2.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git#294107d34a0e873959795bbc00c09e9def6e3a42)
                                  +-- iobroker.web@5.2.3
                                  +-- iobroker.wireguard@1.2.1
                                  `-- iobroker.ws@2.1.2
                                  tobasium 1 Reply Last reply Reply Quote 0
                                  • tobasium
                                    tobasium @Negalein last edited by tobasium
                                    hi zusammen, also ich habe auch probleme sobald ich npm auf Version 8 hab geht bei mir kein down oder update mehr. Ich blick auch ehrlich gesagt nicht mehr durch. Wie ich ran gehen soll oder nicht hab den thread jetzt mehrfach gelesen aber irgendwie bin ich raus.
                                    Kann jemand das nochmal mit mir durchkauen // Iobroker läuft im docker auf einer synology // buanet image
                                    npm ERR! code 128
                                    npm ERR! An unknown git error occurred
                                    npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/MeisterTR/syno.git
                                    npm ERR! ssh -oStrictHostKeyChecking=accept-new: 1: ssh: not found
                                    npm ERR! fatal: Could not read from remote repository.
                                    npm ERR!
                                    npm ERR! Please make sure you have the correct access rights
                                    npm ERR! and the repository exists.
                                    npm ERR!     /root/.npm/_logs/2022-07-10T18_36_38_660Z-debug-0.log
                                    • Glasfaser
                                      Glasfaser @tobasium last edited by
                                      @tobasium
                                      Zeige mal als gesamtes ..
                                      npm ls | grep -E 'github.com|ERR'
                                      da du auch hier im Thread Probleme mit anderen Adaptern hast
                                      https://forum.iobroker.net/topic/55730/iobroker-probleme-mit-npm-8-11-0-nodejs
                                      • tobasium
                                        tobasium @Glasfaser last edited by
                                        @glasfaser sagte in Kein Update mehr möglich mit Node.js 16:
                                        Also ich hab das Ding glaub komplett gekillt das ist nur noch rot. vorher kam da mal gar nichts
                                        npm error.txt
                                        • tobasium
                                          tobasium last edited by tobasium
                                          @glasfaser ich bin jetzt nochmal auf 6 zurück, damit kann ich auch wieder Pakete updaten. Aber das ist halt nicht die Lösung
                                          sudo npm install -g npm@6
                                          dan npm prune
                                          root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
                                          sudo: unable to resolve host iobroker: Name or service not known
                                          npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                                          npm ERR! extraneous: error-ex /opt/iobroker/node_modules/error-ex
                                          npm ERR! error in /opt/iobroker/node_modules/error-ex: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/error-ex/package.json'
                                          npm ERR! extraneous: iobroker.javascript /opt/iobroker/node_modules/iobroker.javascript
                                          npm ERR! error in /opt/iobroker/node_modules/iobroker.javascript: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/package.json'
                                          npm ERR! extraneous: utile /opt/iobroker/node_modules/utile
                                          npm ERR! error in /opt/iobroker/node_modules/utile: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/utile/package.json'
                                          npm ERR! extraneous: zigbee-herdsman /opt/iobroker/node_modules/zigbee-herdsman
                                          npm ERR! error in /opt/iobroker/node_modules/zigbee-herdsman: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman/package.json'
                                          npm ERR! extraneous: zigbee-herdsman-converters /opt/iobroker/node_modules/zigbee-herdsman-converters
                                          npm ERR! error in /opt/iobroker/node_modules/zigbee-herdsman-converters: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/zigbee-herdsman-converters/package.json'
                                          • Glasfaser
                                            @tobasium
                                            in deiner Liste mit NodeJS 16 ,
                                            npm ERR! invalid: iobroker.admin@5.3.8 /opt/iobroker/node_modules/iobroker.admin
                                            npm ERR! invalid: iobroker.backitup@2.4.9 /opt/iobroker/node_modules/iobroker.backitup
                                            npm ERR! invalid: iobroker.discovery@3.0.3 /opt/iobroker/node_modules/iobroker.discovery
                                            npm ERR! invalid: iobroker.js-controller@4.0.23 /opt/iobroker/node_modules/iobroker.js-controller
                                            Versuche mal
                                            iobroker upgrade admin@5.3.8
                                            iobroker upgrade backitup@2.4.9
                                            iobroker upgrade discovery@3.0.3
                                            iobroker upgrade js-controller@4.0.23
                                            die extraneous mit
                                            npm prune
                                            die Frage wäre auch durch dein hin und her wechseln mit den Versionen ob die 16 überhaupt sauber ist .
                                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                                            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            node js
                                            16
                                            335
                                            38661
