    3. Off Topic
    4. [erledigt] Updates der Adapter schlagen fehl
    • DJMarc75
      DJMarc75 @Erl last edited by
      @erl Na dann ist Dein Post quasi gelöst ... Glückwunsch 👍
        Erl @DJMarc75 last edited by
        @djmarc75 said in Updates der Adapter schlagen fehl:
        der war gut! 😬
        Aber recht hast du...ich schaue mir jetzt mal entsprechende posts an, ob ich mir jetzt selbst helfen kann.
        Diesen Post lasse ich erstmal auf !?
          Thomas Braun Most Active @Erl last edited by
          @erl
          Dann fang von vorne an:
          sudo ln -s /usr/bin/node /usr/bin/nodejs
          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          iobroker update -i
            Erl @Thomas Braun last edited by
            @thomas-braun said in Updates der Adapter schlagen fehl:
            pi@broker:~ $ iobroker update -i sudo ln -s /usr/bin/node /usr/bin/nodejs
            Used repository: sudo
            failed to download new sources, use cached sources
            update done
            Adapter    "admin"         : 5.3.8    , installed 4.2.2 [Updateable]
            Adapter    "backitup"      : 2.4.9    , installed 2.1.13 [Updateable]
            Adapter    "discovery"     : 3.0.3    , installed 3.0.3
            Adapter    "influxdb"      : 2.6.3    , installed 1.9.5 [Updateable]
            Adapter    "info"          : 1.9.19   , installed 1.9.19
            Adapter    "javascript"    : 5.7.0    , installed 5.1.3 [Updateable]
            Controller "js-controller" : 4.0.23   , installed 3.2.16 [Updateable]
            Adapter    "mqtt"          : 3.0.6    , installed 2.4.0 [Updateable]
            Adapter    "terminal"      : 0.2.6    , installed 0.2.6
            Adapter    "worx"          : 1.5.5    , installed 1.5.5
            Adapter    "xterm"         : 0.3.2    , installed 0.3.2
            pi@broker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.2
            v12.22.2
            6.14.13
            pi
            /home/pi
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://repos.influxdata.com/debian stretch InRelease
            OK:4 https://deb.nodesource.com/node_12.x buster InRelease
            OK:5 https://packages.grafana.com/oss/deb stable InRelease
            Aktualisierung für 97 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            nodejs:
              Installiert:           12.22.2-1nodesource1
              Installationskandidat: 12.22.12-deb-1nodesource1
              Versionstabelle:
                 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             *** 12.22.2-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
            Used repository: default
            hash unchanged, use cached sources
            update done
              @erl
              Das was du da eingetippt hast habe ich nicht geschrieben!
                @erl
                pi@broker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /
                -bash: name: Kommando nicht gefunden.
                pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                update done
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.2
                v12.22.2
                6.14.13
                pi
                /home/pi
                nodejs:
                  Versionstabelle:
                update done
                pi@broker:~ $
                Ich dachte jede Zeile sei ein Befehl...habe dann alle 3 Zeilen komplett abgeschickt
                • DJMarc75
                  @erl stretch und buster verquirrlt... node auch falsch... 97 Pakete verfügbar, WOHOOOO....
                    Danke für die Info.
                    Ja ich habe lange keine updates gefahren, aber warum Stretch und bester "verquirlt" sind Weißich nicht. ich habe das System nur einmal aufgesetzt und dann ioBroker benutzt. das war alles stressfrei...
                    • DJMarc75
                      @erl sagte in Updates der Adapter schlagen fehl:
                      ich auch nicht 😬 aber da hast Du iwann mal was verbogen... seis drum... musst halt korrigieren😳
                      • DJMarc75
                        DJMarc75 @DJMarc75 last edited by
                        @djmarc75 node ist auch krumm (alt)
                          Wie kann ich das fixen "node" und "influxdata"?
                          Bzw.: Kann ich das fixen?
                          DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            influxdata
                            Das vergiss mal hier bitte in diesem Thread... hat hier nix zu suchen (wenn dann eigenen influx Thread aufmachen - offtopic)
                            Um dein System zu korrigieren gibts bei @thomas-braun in der Signatur perfekte Anleitungen.
                              ich hatte diesen schon in OffTopic geschoben, weil es zuerst nur ims Passwort für SSH ging.
                              und zwar sehr lange. Inzwischen gibt es Bei Updates Versionen, die nur noch unter einem höheren Node und höheren Controller laufen.
                              ich an deiner Stelle würde eine neue Karte nehmen, neu installieren und Backup einspielen.
                              dann hast du dein altes System noch als Hardware backup auf der alten Karte
                                Ja, kann man alles fixen. Die Frage ist eher, lohnt es sich nicht hier einen Schnitt zu machen und einen frischen 'Bullseye' (64bit - Lite) neuaufzusetzen. Der 'Buster' wird in wenigen Wochen ohnehin sein End-of-Life erreichen.
                                • DJMarc75
                                  DJMarc75 @Thomas Braun last edited by
                                  @thomas-braun sagte in Updates der Adapter schlagen fehl:
                                  'Buster'
                                  da ist sogar noch STRETCH im Einsatz ....
                                    Thomas Braun Most Active @DJMarc75 last edited by
                                    @djmarc75 sagte in Updates der Adapter schlagen fehl:
                                    Nein, da ist nur die .list-Datei für Grafana falsch.
                                    Die hätte auf buster eingestellt sein müssen.
                                    DJMarc75 1 Reply Last reply Reply Quote 1
                                    • DJMarc75
                                      Wenn Profis online sind, dann leg ich meine Brille lieber weg 😁 😂 👍
                                      1.0k
                                      794
