    3. Off Topic
    4. [erledigt] Updates der Adapter schlagen fehl
      Erl @Thomas Braun last edited by
      @thomas-braun said in Updates der Adapter schlagen fehl:
      @erl
      Das was du da eingetippt hast habe ich nicht geschrieben!
      pi@broker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /
      -bash: name: Kommando nicht gefunden.
      pi@broker:~ $ name -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      pi@broker:~ $ iobroker update -i sudo ln -s /usr/bin/node /usr/bin/nodejs
      Used repository: sudo
      failed to download new sources, use cached sources
      update done
      Adapter    "admin"         : 5.3.8    , installed 4.2.2 [Updateable]
      Adapter    "backitup"      : 2.4.9    , installed 2.1.13 [Updateable]
      Adapter    "discovery"     : 3.0.3    , installed 3.0.3
      Adapter    "influxdb"      : 2.6.3    , installed 1.9.5 [Updateable]
      Adapter    "info"          : 1.9.19   , installed 1.9.19
      Adapter    "javascript"    : 5.7.0    , installed 5.1.3 [Updateable]
      Controller "js-controller" : 4.0.23   , installed 3.2.16 [Updateable]
      Adapter    "mqtt"          : 3.0.6    , installed 2.4.0 [Updateable]
      Adapter    "terminal"      : 0.2.6    , installed 0.2.6
      Adapter    "worx"          : 1.5.5    , installed 1.5.5
      Adapter    "xterm"         : 0.3.2    , installed 0.3.2
      pi@broker:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.2
      v12.22.2
      6.14.13
      pi
      /home/pi
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://repos.influxdata.com/debian stretch InRelease
      OK:4 https://deb.nodesource.com/node_12.x buster InRelease
      OK:5 https://packages.grafana.com/oss/deb stable InRelease
      Aktualisierung für 97 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      nodejs:
        Installiert:           12.22.2-1nodesource1
        Installationskandidat: 12.22.12-deb-1nodesource1
        Versionstabelle:
           12.22.12-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
       *** 12.22.2-1nodesource1 100
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      Used repository: default
      hash unchanged, use cached sources
      update done
      pi@broker:~ $
      Ich dachte jede Zeile sei ein Befehl...habe dann alle 3 Zeilen komplett abgeschickt
      • DJMarc75
        DJMarc75 @Erl last edited by
        @erl stretch und buster verquirrlt... node auch falsch... 97 Pakete verfügbar, WOHOOOO....
          Erl @DJMarc75 last edited by
          @djmarc75 said in Updates der Adapter schlagen fehl:
          Danke für die Info.
          Ja ich habe lange keine updates gefahren, aber warum Stretch und bester "verquirlt" sind Weißich nicht. ich habe das System nur einmal aufgesetzt und dann ioBroker benutzt. das war alles stressfrei...
          • DJMarc75
            @erl sagte in Updates der Adapter schlagen fehl:
            ich auch nicht 😬 aber da hast Du iwann mal was verbogen... seis drum... musst halt korrigieren😳
            • DJMarc75
              DJMarc75 @DJMarc75 last edited by
              @djmarc75 node ist auch krumm (alt)
                Wie kann ich das fixen "node" und "influxdata"?
                Bzw.: Kann ich das fixen?
                DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  influxdata
                  Das vergiss mal hier bitte in diesem Thread... hat hier nix zu suchen (wenn dann eigenen influx Thread aufmachen - offtopic)
                  Um dein System zu korrigieren gibts bei @thomas-braun in der Signatur perfekte Anleitungen.
                    ich hatte diesen schon in OffTopic geschoben, weil es zuerst nur ims Passwort für SSH ging.
                    und zwar sehr lange. Inzwischen gibt es Bei Updates Versionen, die nur noch unter einem höheren Node und höheren Controller laufen.
                    ich an deiner Stelle würde eine neue Karte nehmen, neu installieren und Backup einspielen.
                    dann hast du dein altes System noch als Hardware backup auf der alten Karte
                      Thomas Braun Most Active @Erl last edited by
                      Ja, kann man alles fixen. Die Frage ist eher, lohnt es sich nicht hier einen Schnitt zu machen und einen frischen 'Bullseye' (64bit - Lite) neuaufzusetzen. Der 'Buster' wird in wenigen Wochen ohnehin sein End-of-Life erreichen.
                      • DJMarc75
                        DJMarc75 @Thomas Braun last edited by
                        @thomas-braun sagte in Updates der Adapter schlagen fehl:
                        'Buster'
                        da ist sogar noch STRETCH im Einsatz ....
                          Thomas Braun Most Active @DJMarc75 last edited by
                          @djmarc75 sagte in Updates der Adapter schlagen fehl:
                          Nein, da ist nur die .list-Datei für Grafana falsch.
                          Die hätte auf buster eingestellt sein müssen.
                          DJMarc75 1 Reply Last reply Reply Quote 1
                          • DJMarc75
                            Wenn Profis online sind, dann leg ich meine Brille lieber weg 😁 😂 👍
                            1.0k
                            794
