    4. Test Adapter Z-Wave 2 v2.5.x
      taba_luga @Thomas Braun last edited by
      xx@iobroker-prod:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      xx@iobroker-prod:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.3
      v14.19.3
      6.14.17
      xx
      /home/xx
      OK:1 http://security.debian.org/debian-security stretch/updates InRelease
      Ign:2 http://ftp.de.debian.org/debian stretch InRelease
      OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
      OK:4 http://ftp.de.debian.org/debian stretch Release
      OK:5 https://deb.nodesource.com/node_14.x stretch InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           14.19.3-1nodesource1
        Installationskandidat: 14.19.3-1nodesource1
        Versionstabelle:
       *** 14.19.3-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x stretch/main amd64 Packages
              100 /var/lib/dpkg/status
           4.8.2~dfsg-1 500
              500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
      xx@iobroker-prod:~$ iobroker update -i
      Used repository: Stable (default)
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
      Adapter    "devices"      : 1.0.10   , installed 1.0.10
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.10.7   , installed 1.10.7
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.1  [Updatable]
      Adapter    "heatingcontrol": 2.8.6   , installed 2.8.6
      Adapter    "history"      : 1.11.1   , installed 1.11.1
      Adapter    "hs100"        : 2.0.7    , installed 2.0.6  [Updatable]
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
      Adapter    "iot"          : 1.11.4   , installed 1.11.4
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "lg-thinq"     : 0.0.7    , installed 0.0.7
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
      Adapter    "milight"      : 0.3.6    , installed 0.3.6
      Adapter    "node-red"     : 3.3.0    , installed 3.2.0  [Updatable]
      Adapter    "ping"         : 1.5.3    , installed 1.5.0  [Updatable]
      Adapter    "scenes"       : 2.3.9    , installed 2.3.6  [Updatable]
      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
      Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.12.6   , installed 1.12.2 [Updatable]
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.15 [Updatable]
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-metro"    : 1.2.0    , installed 1.1.2  [Updatable]
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.3  [Updatable]
      Adapter    "web"          : 4.3.0    , installed 4.2.3  [Updatable]
      Adapter    "wifilight"    : 1.1.3    , installed 1.1.0  [Updatable]
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
        Thomas Braun Most Active @taba_luga last edited by
        @taba_luga sagte in Test Adapter Z-Wave 2 v2.5.x:
        stretch
        Debian Stretch ist schon geraume Zeit tot, hat das EOL erreicht. Installier da was lebendiges. Stable ist zur Zeit 'Bullseye' / Debian 11.
          @thomas-braun danke für deinen Hinweis. Ich habe das System jetzt auf Debian 11 und Nodejs 16.15.1 laufen. Leider kommt beim ZWAVE 2 Adapter immer noch die gleiche Fehlermeldung
          host.iobroker-prod
          2022-06-24 08:26:17.952	info	Restart adapter system.adapter.zwave2.0 because enabled
          host.iobroker-prod
          2022-06-24 08:26:17.952	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker-prod
          2022-06-24 08:26:17.952	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
          host.iobroker-prod
          2022-06-24 08:26:17.951	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
          host.iobroker-prod
          2022-06-24 08:26:17.951	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
          host.iobroker-prod
          2022-06-24 08:26:17.951	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
          host.iobroker-prod
          2022-06-24 08:26:17.951	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
          host.iobroker-prod
          2022-06-24 08:26:17.950	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
          host.iobroker-prod
          2022-06-24 08:26:17.950	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
          host.iobroker-prod
          2022-06-24 08:26:17.950	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
          host.iobroker-prod
          2022-06-24 08:26:17.949	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
          host.iobroker-prod
          2022-06-24 08:26:17.949	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
          host.iobroker-prod
          2022-06-24 08:26:17.948	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
          host.iobroker-prod
          2022-06-24 08:26:16.175	info	instance system.adapter.zwave2.0 started with pid 11133
            @thomas-braun nachdem ich den zwave adapter nochmal neu installiert habe, geht es jetzt. Danke für deine Unterstützung!
              @Thomas-Braun nach den ganzen Problemen beim Node16/NPM8 Update, scheine ich diese nun in den Griff bekommen zu haben. Leider startet jetzt der ZWAVE2 Adapter wieder nicht.
              In dem Protokoll steht:
              host.iobroker-prod
              2022-06-29 22:46:45.609	info	Restart adapter system.adapter.zwave2.0 because enabled
              host.iobroker-prod
              2022-06-29 22:46:45.608	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-prod
              2022-06-29 22:46:45.608	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
              host.iobroker-prod
              2022-06-29 22:46:45.608	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
              host.iobroker-prod
              2022-06-29 22:46:45.608	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
              host.iobroker-prod
              2022-06-29 22:46:45.607	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
              host.iobroker-prod
              2022-06-29 22:46:45.607	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
              host.iobroker-prod
              2022-06-29 22:46:45.607	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
              host.iobroker-prod
              2022-06-29 22:46:45.607	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
              host.iobroker-prod
              2022-06-29 22:46:45.607	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
              host.iobroker-prod
              2022-06-29 22:46:45.606	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
              host.iobroker-prod
              2022-06-29 22:46:45.606	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
              host.iobroker-prod
              2022-06-29 22:46:45.605	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
                @taba_luga
                Wie bist du da jetzt unterwegs?
                iobroker update -i
                  taba_luga @Thomas Braun last edited by taba_luga
                  @thomas-braun sagte in Test Adapter Z-Wave 2 v2.5.x:
                  Jetzt schaut es bei mir so aus:
                  alex@iobroker-prod:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.15.1
                  v16.15.1
                  8.11.0
                  alex
                  /home/alex
                  [sudo] Passwort für alex:
                  OK:1 http://ftp.de.debian.org/debian bullseye InRelease
                  OK:2 http://ftp.de.debian.org/debian bullseye-updates InRelease
                  OK:3 http://security.debian.org/debian-security bullseye-security InRelease
                  OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  Paketlisten werden gelesen… Fertig
                  Abhängigkeitsbaum wird aufgebaut… Fertig
                  Statusinformationen werden eingelesen… Fertig
                  nodejs:
                    Installiert:           16.15.1-deb-1nodesource1
                    Installationskandidat: 16.15.1-deb-1nodesource1
                    Versionstabelle:
                   *** 16.15.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                       12.22.12~dfsg-1~deb11u1 500
                          500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                       12.22.5~dfsg-2~11u1 500
                          500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                  alex@iobroker-prod:~$ iobroker update -i
                  Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                  Adapter    "devices"      : 1.0.12   , installed 1.0.12
                  Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                  Adapter    "hs100"        : 2.0.7    , installed 2.0.7
                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                  Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
                  Adapter    "node-red"     : 3.3.1    , installed 3.2.0  [Updatable]
                  Adapter    "ping"         : 1.5.3    , installed 1.5.3
                  Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                  Adapter    "telegram"     : 1.13.0   , installed 1.13.0
                  Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                  Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                  Adapter    "wifilight"    : 1.1.3    , installed 1.1.3
                    taba_luga @taba_luga last edited by
                    x86_64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.15.1
                    v16.15.1
                    8.11.0
                    alex
                    /home/alex
                    nodejs:
                      Versionstabelle:
                    Hallo zusammen, kann mir hier jemand bei meinem Problem eventuell helfen? Ich komme hier alleine leider nicht weiter.
                    Danke euch.
                      @taba_luga
                      Die Basis ist i. O.
                      Zum Problem selber kann ich nix sagen. Vielleicht postest du den Neustart des Adapters mal?
                        @thomas-braun Ich verstehe es nicht. Ich habe den Adapter/die Instanz über die Iobroker Oberfläche bei den Instanzen diverse male gestoppt und neu gestartet. Er wollte einfach nicht starten... Die Meldung bei der Instanz war immer, dass sie nicht mit dem Host verbunden ist und kein Lebenszeichen hat. Mit dem Gerät oder Dienst (ZWaveStick) war sie immer verbunden.
                        Ich habe den Adapter jetzt über die Konsole manuell gestoppt und neu gestartet. Jetzt läuft er wieder. 🙂
                        Danke euch und ein schönes Wochende!
                          @taba_luga
                          Die Konsole ist halt 'mächtiger'.
                            @AlCalzone allerdings funktioniert die Anzeige der Logs leider nicht:
                            Das Fenster bleibt immer leer. Wenn ich das Log File herunterlade, dann sehe ich allerdings die Log Einträge in der *.log Datei.
                            2022-07-01T10:04:36.270Z SERIAL « 0x01100004000d0a3202213204db0000000010                              (18 bytes)
                            2022-07-01T10:04:37.243Z SERIAL « 0x010b0004000d0526036363fe23                                        (13 bytes)
                            2022-07-01T10:04:37.247Z CNTRLR   [Node 013] [~] [Multilevel Switch] targetValue: 90 => 99          [Endpoint 0]
                            2022-07-01T10:04:37.252Z CNTRLR   [Node 013] [~] [Multilevel Switch] duration: "unknown" => "unknow [Endpoint 0]
                                                              n"
                            2022-07-01T10:04:37.254Z CNTRLR   [Node 013] [~] [Multilevel Switch] currentValue: 90 => 99         [Endpoint 0]
                            2022-07-01T10:04:37.256Z SERIAL » [ACK]        (0x06)
                            2022-07-01T10:04:37.259Z DRIVER « [Node 013] [REQ] [ApplicationCommand]
                                                              └─[MultilevelSwitchCCReport]
        current value: 99
        target value:  99
        duration:      unknown
                            2022-07-01T10:04:39.803Z SERIAL « 0x01100004000d0a32022132000000000000cf                              (18 bytes)
                              @taba_luga
                              Hast du da vielleicht die alte Oberfläche noch aktiv?
                                @thomas-braun wie meinst du? Welche alte Oberfläche?
                                  @taba_luga
                                  Kann man in den Einstellungen zum 'admin' aktiv schalten.
                                  Es gibt aber mittlerweile Adapter, die mit dieser Einstellung nicht mehr kompatibel sind.
                                    nein, benutze alte Benutzeroberfläche ist in den Admin Adapter Einstellungen deaktiviert.
                                    • AlCalzone
                                      Issue ist bekannt, das ist ein bug im CSS des Adapters.
                                      79.9k
                                      test zwave2
                                      828
