    3. Off Topic
    4. Grafana
    5. Grafana / InfluxDB / VIS
      kimukao @Glasfaser last edited by
      @glasfaser said in Grafana / InfluxDB / VIS:
      iobroker update -i sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "heos"         : 1.10.0   , installed 1.10.0
      Adapter    "history"      : 1.11.1   , installed 1.11.1
      Adapter    "ical"         : 1.12.1   , installed 1.12.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "km200"        : 2.0.3    , installed 2.0.3
      Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
      Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
      Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
      Adapter    "onvif"        : 0.4.4    , installed 0.4.4
      Adapter    "parcel"       : 0.0.15   , installed 0.0.15
      Adapter    "pushover"     : 2.1.0    , installed 2.1.0
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "sonos"        : 2.1.7    , installed 2.1.7
      Adapter    "sony-bravia"  : 1.0.3    , installed 1.0.3
      Adapter    "synology"     : 2.1.7    , installed 2.1.7
      Adapter    "telegram"     : 1.13.0   , installed 1.13.0
      Adapter    "text2command" : 2.2.1    , installed 2.2.1
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "trashschedule": 2.0.2    , installed 2.0.2
      Adapter    "uv-protect"   : 0.3.5    , installed 0.3.5
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "vw-connect"   : 0.0.50   , installed 0.0.50
      Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      pi
      /home/pi
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      OK:4 https://packages.grafana.com/oss/deb stable InRelease
      OK:5 https://phoscon.de/apt/deconz bullseye InRelease
      OK:6 https://repos.influxdata.com/debian bullseye InRelease
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           16.15.1-deb-1nodesource1
        Installationskandidat: 16.15.1-deb-1nodesource1
        Versionstabelle:
       *** 16.15.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages```
      • Glasfaser
        Glasfaser @kimukao last edited by
        @kimukao sagte in Grafana / InfluxDB / VIS:
        gestern musste ich meinen pi neu booten,
        Nach dem Update auf :
        Node js :
        16.15.1
        8.11.0
        • OliverIO
          OliverIO @kimukao last edited by
          @kimukao
          evtl fehlermeldungen des browser wären auch hilfreich.
          diese können in der developer console (bspw bei chrome/edge mit F12) im Reiter Konsole/Console angeschaut werden. Am besten das auch per Copy/Paste hier im Forum in Code-Tags (Knopf </> oben) einfügen.
          Glasfaser K 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @OliverIO last edited by
            @oliverio
            Was merkwürdig ist , das hier viele nach dem Update auf Nodejs 16 , Probleme mit VIS haben.
            Die Teillösung ist auf ws umstellen
            Beispiel :
            https://forum.iobroker.net/topic/55874/gelöst-vis-kann-nicht-geändert-werden-verbindungsfehler/85
              @glasfaser Ich wollte meine SD Karte durch eine SSD ersetzen. Hab vorher, wie in einem YT Video von haus-automatisierung.com bschrieben, mein System auf Stand gebracht, die SSD mittels balenaEtcher geflasht und den pi dann ordnungsgemäß heruntergefahren. Boot von USB klappte leider nicht, obwohl die Option im System des pi angehakt ist. In der FB Gruppe bekam ich den Hinweis, dass es wahrscheinlich eine Inkompatibilität der SSD ist. Also habe ich wieder von SD gebootet. Seither werden die Diagramme nicht mehr dargestellt.
              • Glasfaser
                @kimukao
                Kannst du mal das testen mit WS ... siehe über deinen Beitrag
                  @glasfaser Hab den ws Adapter grade mal installiert, er springt aber nicht auf grün. Kann das also noch nicht nutzen oder auswählen. Probiere mal ein bisschen damit rum.
                  • OliverIO
                    OliverIO @Glasfaser last edited by
                    @glasfaser
                    aber er fragt doch mittels iframe grafana ab.
                    da hat ws, ausser die bereitstellung der view nicht viel zu tun.
                    wenn da was nicht funktioniert, dann würde die view überhaupt nicht tun
                      @glasfaser Sorry, im Beitrag stand ja auch, dass Socket ausgeschaltet werden muss wegen der simultanen Verwendung von Port 8084. Hab ich jetzt gemacht, WS ist grün, im Web.0 ausgewählt, Diagramme trotzdem Fehlanzeige...
                        kimukao @OliverIO last edited by
                        @oliverio Danke. In Safari finde ich das leider nicht. Probiere es später mal in anderen Browsern.
                          @oliverio Hab mir das grade mal in Chrome angeschaut. Da wird u.a. folgender Platzhalter angezeigt (das Menu habe ich nicht gescreenshottet):
                          Und nach Druck von F12 kommen diese Meldungen:
                          Failed to load resource: the server responded with a status of 404 (Not Found)
                          metro-bootstrap.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                          fritzdect.js:46 Version fritzdect: 0.0.2
                          metro.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                          trashschedule.js:152 Version trashschedule: 2.0.2
                          vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
                          index.html:12305 Version vis-weather: 2.5.4
                          socket.io.js:66 [2022-07-01T16:01:22.029Z] Try to connect
                          conn.js:305 2022-07-01T16:01:22.040Z Connected => authenticate
                          conn.js:326 2022-07-01T16:01:22.094Z Authenticated: true
                          VM82:2 Uncaught ReferenceError: on is not defined
                              at <anonymous>:2:1
                              at Object.<anonymous> (vis.js:3693:47)
                              at vis.js:2062:34
                              at conn.js:580:25
                          vis.js:3543 Create inner vis object 0_userdata.0.VIS.Kamera
                          vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.OverviewTable
                          vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.NextExpectedLowBatt
                          vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.AllBatterysOk
                          vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.LastMessage
                          vis.js:3543 Create inner vis object 0_userdata.0.VIS.auf-zu
                          vis.js:3543 Create inner vis object 0_userdata.0.VIS.Wetter
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cf8c10.status_ex
                          vis.js:3543 Create inner vis object 0_userdata.0.VIS.Fenster_Switch
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d05810.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d06e10.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bfe110.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c86710.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cdcb10.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bf9410.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c20010.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04af0b10.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:0017a210.status_ex
                          vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bb7610.status_ex
                          vis.js:3543 Create inner vis object deconz.0.Sensors.4.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.5.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.6.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.7.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.8.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.9.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.10.open
                          vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torautomatik
                          vis.js:3543 Create inner vis object nuki.0.724531834.actions.rtoAction
                          vis.js:3543 Create inner vis object deconz.0.Sensors.15.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.16.open
                          vis.js:3543 Create inner vis object deconz.0.Sensors.17.open
                          vis.js:3543 Create inner vis object deconz.0.Lights.28.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.9.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.6.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.27.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.19.on
                          vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Temperature.Temperature
                          vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Humidity.Humidity
                          vis.js:3543 Create inner vis object deconz.0.Lights.2.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.22.level
                          vis.js:3543 Create inner vis object deconz.0.Lights.22.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.3.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.41.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.24.level
                          vis.js:3543 Create inner vis object deconz.0.Lights.24.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.5.on
                          vis.js:3543 Create inner vis object deconz.0.Lights.14.on
                          vis.js:3543 Create inner vis object lupusec.0.devices.ZS:b11501.level
                          vis.js:3543 Create inner vis object deconz.0.Lights.54.on
                          vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.actualTemp
                          vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.waterFlow
                          vis.js:3543 Create inner vis object km200.0.heatSources.systemPressure
                          vis.js:3543 Create inner vis object km200.0.heatSources.actualSupplyTemperature
                          vis.js:3543 Create inner vis object km200.0.heatingCircuits.hc2.actualSupplyTemperature
                          vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.charge
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.connected
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.state
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_mid
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_elapsed
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_duration
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.group_leader_pid
                          vis.js:2596 Error in eval[value]: {pid:heos.0.players.-2129318115.group_leader_pid;pidToRgbColor(pid)}
                          formatBinding @ vis.js:2596
                          vis.js:2597 Error in eval[script]: var pid = "undefined";return pidToRgbColor(pid);
                          formatBinding @ vis.js:2597
                          vis.js:2598 Error in eval[error]: ReferenceError: pidToRgbColor is not defined
                          formatBinding @ vis.js:2598
                          vis.js:3543 Create inner vis object heos.0.sources.1028.4.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.4.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.5.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.5.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.8.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.8.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.9.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.9.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.10.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.10.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.11.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.11.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.12.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.12.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.13.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.13.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.14.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.14.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.15.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.15.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.16.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.16.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.1.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.1.image_url
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_audio_format
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitrate
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_sample_rate
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitdepth
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.muted
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_up
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.state_simple
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_down
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.prev
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.next
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.name
                          vis.js:3543 Create inner vis object heos.0.sources.1028.6.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.6.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.7.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.7.image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.2.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.2.image_url
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_artist
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_color_background
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_source_image_url
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_station
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.last_error
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.error
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_title
                          vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_url
                          vis.js:3543 Create inner vis object heos.0.sources.1028.3.play
                          vis.js:3543 Create inner vis object heos.0.sources.1028.3.image_url
                          vis.js:3543 Create inner vis object 0_userdata.0.heos.browse_result_html
                          vis.js:3543 Create inner vis object 0_userdata.0.heos.queue_html
                          vis.js:3543 Create inner vis object lupusec.0.status.apple_home_a1
                          vis.js:3543 Create inner vis object 0_userdata.0.Tor.varTargetDoorState
                          vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torstatus
                          vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Tuerstatus
                          vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.haustür.state.batteryCritical
                          vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Garagentuer_Status
                          vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.garage.state.batteryCritical
                          vis.js:3543 Create inner vis object trashschedule.0.type.json
                          vis.js:3543 Create inner vis object lupusec.0.devices.NK:2c005dec.nuki_action
                          vis.js:3543 Create inner vis object lupusec.0.devices.NK:1d5d05f5.nuki_action
                          vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Temperature.Temperature
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_desc
                          vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Humidity.Humidity
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmin_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmax_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.windgusts_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.wind_dir
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.iconURL
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.symbol_desc
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmin_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmax_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.iconURL
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.symbol_desc
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmin_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmax_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.iconURL
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.symbol_desc
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmin_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmax_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.iconURL
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.symbol_desc
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmin_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmax_value
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.iconURL
                          vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Keller-Innenstation.Temperature.Temperature
                          vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_value
                          vis.js:2597 Error in eval[script]: var pid = "";return pidToRgbColor(pid);
                          hqwidgets.js:907 Version vis-hqwidgets: 1.2.0
                          7Refused to display '<URL>' in a frame because it set 'X-Frame-Options' to 'deny'.
                          undefined:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                          (index):6775 crbug/1173575, non-JS module files deprecated.
                          (anonymous) @ (index):6775
                          iconFont.min.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
                          Glasfaser OliverIO 3 Replies Last reply Reply Quote 0
                            TT-Tom @kimukao last edited by TT-Tom
                            in safari muss du in die Einstellungen und das Entwicklermenü einblenden, dann kannst du die Seitenquelltext einschalten.
                            • Glasfaser
                              @kimukao
                              Du schreibst SSD neu aufgesetzt ...
                              wo ist denn Grafana installiert , hast du die Grafana Config der Externen Freigabe verändert !?
                              K Glasfaser 3 Replies Last reply Reply Quote 0
                                @glasfaser Konnte ja von der SSD nicht booten, deshalb kam die alte SD wieder zum Einsatz. Mit der wurden die Diagramme ja vor dem Wechselversuch in der VIS dargestellt.
                                • Glasfaser
                                  Glasfaser @Glasfaser last edited by
                                  @glasfaser sagte in Grafana / InfluxDB / VIS:
                                    kimukao @Glasfaser last edited by kimukao
                                    nicht, dass ich wüsste.. Grafana läuft auf demselben pi, auf dem auch iobroker läuft
                                    • Glasfaser
                                      @kimukao
                                      Nochmal:
                                      WO IST GRAFANA INSTALLIERT !?
                                      • Glasfaser
                                        @kimukao
                                        Nochmal:
                                        EDIT :
                                        Ja OK , du hast EDIT dazu gemacht .
                                        • Glasfaser
                                          bitte nachschauen , ob es sich verändert hat !
                                          https://forum.iobroker.net/topic/26211/gelöst-grafana-ini-für-embed-in-vis-bearbeiten
                                            Wie kann ich die Config denn abfragen, um zu prüfen, ob die Rechtezuweisung stimmt? Im Browser komme ich per Direkteingabe der per iframe eingebundenen URL ja zur Diagrammansicht. Heißt das nicht, dass die Rechte vorhanden sein müssten?
                                            1.2k
                                            6183
