    3. Off Topic
    4. Grafana
    5. Grafana / InfluxDB / VIS
      kimukao @OliverIO last edited by
      @oliverio Hab mir das grade mal in Chrome angeschaut. Da wird u.a. folgender Platzhalter angezeigt (das Menu habe ich nicht gescreenshottet):
      Und nach Druck von F12 kommen diese Meldungen:
      Failed to load resource: the server responded with a status of 404 (Not Found)
      metro-bootstrap.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
      fritzdect.js:46 Version fritzdect: 0.0.2
      metro.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
      trashschedule.js:152 Version trashschedule: 2.0.2
      vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
      index.html:12305 Version vis-weather: 2.5.4
      socket.io.js:66 [2022-07-01T16:01:22.029Z] Try to connect
      conn.js:305 2022-07-01T16:01:22.040Z Connected => authenticate
      conn.js:326 2022-07-01T16:01:22.094Z Authenticated: true
      VM82:2 Uncaught ReferenceError: on is not defined
          at <anonymous>:2:1
          at Object.<anonymous> (vis.js:3693:47)
          at vis.js:2062:34
          at conn.js:580:25
      vis.js:3543 Create inner vis object 0_userdata.0.VIS.Kamera
      vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.OverviewTable
      vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.NextExpectedLowBatt
      vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.AllBatterysOk
      vis.js:3543 Create inner vis object javascript.0.BatterieUeberwachung.LastMessage
      vis.js:3543 Create inner vis object 0_userdata.0.VIS.auf-zu
      vis.js:3543 Create inner vis object 0_userdata.0.VIS.Wetter
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cf8c10.status_ex
      vis.js:3543 Create inner vis object 0_userdata.0.VIS.Fenster_Switch
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d05810.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04d06e10.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bfe110.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c86710.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04cdcb10.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bf9410.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04c20010.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04af0b10.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:0017a210.status_ex
      vis.js:3543 Create inner vis object lupusec.0.devices.RF:04bb7610.status_ex
      vis.js:3543 Create inner vis object deconz.0.Sensors.4.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.5.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.6.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.7.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.8.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.9.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.10.open
      vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torautomatik
      vis.js:3543 Create inner vis object nuki.0.724531834.actions.rtoAction
      vis.js:3543 Create inner vis object deconz.0.Sensors.15.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.16.open
      vis.js:3543 Create inner vis object deconz.0.Sensors.17.open
      vis.js:3543 Create inner vis object deconz.0.Lights.28.on
      vis.js:3543 Create inner vis object deconz.0.Lights.9.on
      vis.js:3543 Create inner vis object deconz.0.Lights.6.on
      vis.js:3543 Create inner vis object deconz.0.Lights.27.on
      vis.js:3543 Create inner vis object deconz.0.Lights.19.on
      vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Temperature.Temperature
      vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Wohnbereich.Humidity.Humidity
      vis.js:3543 Create inner vis object deconz.0.Lights.2.on
      vis.js:3543 Create inner vis object deconz.0.Lights.22.level
      vis.js:3543 Create inner vis object deconz.0.Lights.22.on
      vis.js:3543 Create inner vis object deconz.0.Lights.3.on
      vis.js:3543 Create inner vis object deconz.0.Lights.41.on
      vis.js:3543 Create inner vis object deconz.0.Lights.24.level
      vis.js:3543 Create inner vis object deconz.0.Lights.24.on
      vis.js:3543 Create inner vis object deconz.0.Lights.5.on
      vis.js:3543 Create inner vis object deconz.0.Lights.14.on
      vis.js:3543 Create inner vis object lupusec.0.devices.ZS:b11501.level
      vis.js:3543 Create inner vis object deconz.0.Lights.54.on
      vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.actualTemp
      vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.waterFlow
      vis.js:3543 Create inner vis object km200.0.heatSources.systemPressure
      vis.js:3543 Create inner vis object km200.0.heatSources.actualSupplyTemperature
      vis.js:3543 Create inner vis object km200.0.heatingCircuits.hc2.actualSupplyTemperature
      vis.js:3543 Create inner vis object km200.0.dhwCircuits.dhw1.charge
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.connected
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.state
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_mid
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_elapsed
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_duration
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.group_leader_pid
      vis.js:2596 Error in eval[value]: {pid:heos.0.players.-2129318115.group_leader_pid;pidToRgbColor(pid)}
      formatBinding @ vis.js:2596
      vis.js:2597 Error in eval[script]: var pid = "undefined";return pidToRgbColor(pid);
      formatBinding @ vis.js:2597
      vis.js:2598 Error in eval[error]: ReferenceError: pidToRgbColor is not defined
      formatBinding @ vis.js:2598
      vis.js:3543 Create inner vis object heos.0.sources.1028.4.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.4.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.5.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.5.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.8.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.8.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.9.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.9.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.10.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.10.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.11.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.11.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.12.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.12.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.13.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.13.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.14.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.14.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.15.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.15.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.16.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.16.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.1.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.1.image_url
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_audio_format
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitrate
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_sample_rate
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_bitdepth
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.muted
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_up
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.state_simple
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.volume_down
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.prev
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.next
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.name
      vis.js:3543 Create inner vis object heos.0.sources.1028.6.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.6.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.7.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.7.image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.2.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.2.image_url
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_artist
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_color_background
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_source_image_url
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_station
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.last_error
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.error
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_title
      vis.js:3543 Create inner vis object heos.0.players.-2129318115.current_image_url
      vis.js:3543 Create inner vis object heos.0.sources.1028.3.play
      vis.js:3543 Create inner vis object heos.0.sources.1028.3.image_url
      vis.js:3543 Create inner vis object 0_userdata.0.heos.browse_result_html
      vis.js:3543 Create inner vis object 0_userdata.0.heos.queue_html
      vis.js:3543 Create inner vis object lupusec.0.status.apple_home_a1
      vis.js:3543 Create inner vis object 0_userdata.0.Tor.varTargetDoorState
      vis.js:3543 Create inner vis object 0_userdata.0.Tor.Torstatus
      vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Tuerstatus
      vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.haustür.state.batteryCritical
      vis.js:3543 Create inner vis object 0_userdata.0.Nuki.Garagentuer_Status
      vis.js:3543 Create inner vis object nuki-extended.0.smartlocks.garage.state.batteryCritical
      vis.js:3543 Create inner vis object trashschedule.0.type.json
      vis.js:3543 Create inner vis object lupusec.0.devices.NK:2c005dec.nuki_action
      vis.js:3543 Create inner vis object lupusec.0.devices.NK:1d5d05f5.nuki_action
      vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Temperature.Temperature
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_desc
      vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Außenmodul.Humidity.Humidity
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmin_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.tempmax_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.windgusts_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.wind_dir
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.iconURL
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.symbol_desc
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmin_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.tempmax_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_2.iconURL
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.symbol_desc
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmin_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.tempmax_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_3.iconURL
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.symbol_desc
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmin_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.tempmax_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_4.iconURL
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.symbol_desc
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmin_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.tempmax_value
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_5.iconURL
      vis.js:3543 Create inner vis object netatmo.0.iPrex-Home-(Netatmo-Keller-Innenstation).Netatmo-Keller-Innenstation.Temperature.Temperature
      vis.js:3543 Create inner vis object daswetter.0.NextHours.Location_1.Day_1.current.symbol_value
      vis.js:2597 Error in eval[script]: var pid = "";return pidToRgbColor(pid);
      hqwidgets.js:907 Version vis-hqwidgets: 1.2.0
      7Refused to display '<URL>' in a frame because it set 'X-Frame-Options' to 'deny'.
      undefined:1          Failed to load resource: the server responded with a status of 404 (Not Found)
      (index):6775 crbug/1173575, non-JS module files deprecated.
      (anonymous) @ (index):6775
      iconFont.min.css:1          Failed to load resource: the server responded with a status of 404 (Not Found)
      Glasfaser OliverIO 3 Replies Last reply Reply Quote 0
        TT-Tom @kimukao last edited by TT-Tom
        @kimukao sagte in Grafana / InfluxDB / VIS:
        @oliverio Danke. In Safari finde ich das leider nicht. Probiere es später mal in anderen Browsern.
        in safari muss du in die Einstellungen und das Entwicklermenü einblenden, dann kannst du die Seitenquelltext einschalten.
        • Glasfaser
          Glasfaser @kimukao last edited by
          @kimukao
          Du schreibst SSD neu aufgesetzt ...
          wo ist denn Grafana installiert , hast du die Grafana Config der Externen Freigabe verändert !?
          K Glasfaser 3 Replies Last reply Reply Quote 0
            kimukao @Glasfaser last edited by
            @glasfaser Konnte ja von der SSD nicht booten, deshalb kam die alte SD wieder zum Einsatz. Mit der wurden die Diagramme ja vor dem Wechselversuch in der VIS dargestellt.
            • Glasfaser
              Glasfaser @Glasfaser last edited by
              @glasfaser sagte in Grafana / InfluxDB / VIS:
                kimukao @Glasfaser last edited by kimukao
                @glasfaser said in Grafana / InfluxDB / VIS:
                nicht, dass ich wüsste.. Grafana läuft auf demselben pi, auf dem auch iobroker läuft
                • Glasfaser
                  @kimukao
                  Nochmal:
                  WO IST GRAFANA INSTALLIERT !?
                  • Glasfaser
                    @kimukao
                    Nochmal:
                    EDIT :
                    Ja OK , du hast EDIT dazu gemacht .
                    • Glasfaser
                      bitte nachschauen , ob es sich verändert hat !
                      https://forum.iobroker.net/topic/26211/gelöst-grafana-ini-für-embed-in-vis-bearbeiten
                        Wie kann ich die Config denn abfragen, um zu prüfen, ob die Rechtezuweisung stimmt? Im Browser komme ich per Direkteingabe der per iframe eingebundenen URL ja zur Diagrammansicht. Heißt das nicht, dass die Rechte vorhanden sein müssten?
                        • Glasfaser
                          Was meinst du damit !?
                          Screenshot dazu ...
                            TT-Tom last edited by
                            könnte es an einer neuen IP liegen, die der Raps jetzt vielleicht hat. nur mal laut gedacht.
                            K Glasfaser 2 Replies Last reply Reply Quote 0
                              kimukao @TT-Tom last edited by
                              Muss zu nem Termin, schaue später nochmal nach. Tausend Dank schonmal bis hierher!!
                              • Glasfaser
                                Glasfaser @TT-Tom last edited by
                                @tt-tom sagte in Grafana / InfluxDB / VIS:
                                Deshalb habe ich oben danach gefragt :
                                Was ist wenn du ein neues Iframe Widget nimmst ( in einer neuen View ) und dort die Url aufrufst ,!
                                  TT-Tom @Glasfaser last edited by
                                  @glasfaser
                                  wenn er die URL direkt eingibt kommt er auf das Diagramm.
                                  • Glasfaser
                                    Glasfaser @TT-Tom last edited by Glasfaser
                                    @tt-tom
                                    Ja ,aber die Frage ist ja ... was ist mit einem Widget ... innerhalb von ioBroker
                                    und das wollte ich wissen .
                                    und nicht per Browser direkt die URL aufrufen
                                      Screenshot dazu ...
                                      Ich meinte, dass das Diagramm angezeigt wird, wenn ich die per iframe in meiner VIS eingebundene URL direkt in die Adresszeile des Browsers eingebe. Screenshot:
                                        Genau. Im iobroker geht es nicht. Un meine Frage ist, warum. Vorher ging es ja. Die IP Adresse hat sich nicht geändert. Und im Browser wird es dargestellt. Also ist Grafana auf dem pi ja auch erreichbar.
                                        • OliverIO
                                          OliverIO @kimukao last edited by
                                          at <anonymous>:2:1
                                          at vis.js:2062:34
                                          at conn.js:580:25
                                          an 2062 in vis scheint er die views laden zu wollen.
                                          dann stelle mal so wie oben schon mal erwähnt auf ws um
                                          in den einstellungen zum web adapter, reine websockets verwenden ankreuzen
                                            @oliverio said in Grafana / InfluxDB / VIS:
                                            Hab das so eingestellt, funktioniert aber leider nicht.
                                            1.2k
                                            6182
