    4. IOB läuft nicht mehr nach node 14.x update
    • Mr English
      Mr English @Thomas Braun last edited by
      @thomas-braun said in [HowTo] ioBroker Restore unter Linux durchführen:
      cd/opt/iobroker sudo -H -u iobroker npm install iobroker.js-controller
      pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm ERR! cb.apply is not a function
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-01T22_14_47_845Z-debug.log
      das kommt bei ssh wieder raus
      Thomas Braun simatec 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Mr English last edited by
        @mr-english
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Mr English 1 Reply Last reply Reply Quote 0
        • simatec
          simatec Developer Most Active @Mr English last edited by
          This post is deleted!
          • Mr English
            Mr English @Thomas Braun last edited by Mr English
            ich glaube ich muss den iobroker komplett neu aufsetzen und alle Skripte neu schreiben
            wei das hat auch nicht wirklich was gebracht
            pi@raspberrypi4-iob:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
            pi@raspberrypi4-iob:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.19.3
            v14.19.3
            4.6.1
            pi
            /opt/iobroker
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 https://deb.nodesource.com/node_8.x buster InRelease
            OK:3 http://archive.raspberrypi.org/debian buster InRelease
            Alle Pakete sind aktuell.
            nodejs:
              Installiert:           14.19.3-deb-1nodesource1
              Installationskandidat: 14.19.3-deb-1nodesource1
              Versionstabelle:
             *** 14.19.3-deb-1nodesource1 100
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
                 8.17.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_8.x buster/main armhf Packages
              Thomas Braun Most Active @Mr English last edited by Thomas Braun
              @mr-english
              npm4 ist ja auch falsch und das nodesource-Repo hast du auch nicht (richtig) angelegt. Wie kommst du da an node14?
              • Mr English
                ich habe es einfach ge updatet weil der aktuelle "ring" adapter nur mit node 14 läuft
                  @mr-english
                  Und wie? Das hast du nicht nach den Anleitungen für ein node-Upgrade gemacht sondern 'irgendwie anders'
                  • Mr English
                    @mr-english
                    ich habe diese anleitung ver wendet "https://medium.com/@thedyslexiccoder/how-to-update-nodejs-npm-on-a-raspberry-pi-4-da75cad4148c"
                      @mr-english
                      Die ist Mega-Murks.
                      In meiner Signatur steht wie es richtig geht.
                      • Mr English
                        ist der iobroker damit noch zu retten oder ist es hoffnungslos ?
                          @mr-english
                          Zuerst mal musst du nodejs richtig installieren. Dann kann man weiter schauen.
                          Mach dazu einen eigenen Thread auf. Das ist hier komplett am Thema vorbei.
                          • Mr English
                            Mr English @Mr English last edited by
                              @mr-english
                              Wie im anderen Threads schon geschrieben:
                              Installier nodeJS16 neu, aber richtig. Anleitung in meiner Signatur.
                              • Mr English
                                Mr English last edited by Mr English
                                habe ich schon, aber es funktionier trotzdem nicht
                                pi@raspberrypi4-iob:~ $ node -v
                                v16.15.1
                                pi@raspberrypi4-iob:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.15.1
                                v16.15.1
                                8.11.0
                                pi
                                /home/pi
                                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                                OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                nodejs:
                                  Installiert:           16.15.1-deb-1nodesource1
                                  Installationskandidat: 16.15.1-deb-1nodesource1
                                  Versionstabelle:
                                 *** 16.15.1-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                • Mr English
                                  @mr-english
                                  hat sich alles erledigt der IOB ist TOT
                                  pi@raspberrypi4-iob:~ $ iob status
                                  sudo: node: Befehl nicht gefunden
                                    @mr-english
                                    In der nodesource.list steht bullseye drin, du fährst aber buster. Ändern!
                                    Und das System einmal rebooten.
                                    Und dann den js-controller nochmal installieren.
                                    cd /opt/iobroker
                                    692
