    4. Adapter mbus - Fehler im log
      apollon77 @Hant0r last edited by
      @hant0r bitte mal debug log auch vom Start. Der bekommt keine echten Daten bei der Abfrage.
      Hant0r 1 Reply Last reply Reply Quote 0
      • Hant0r
        Hant0r @apollon77 last edited by
        @apollon77 Dachte der wäre dabei gewesen, sorry:
        Debug-Start:
        mbus.0
        2022-06-13 18:00:32.936	debug	Create State ELR-29020256.data.lastStatus
        mbus.0
        2022-06-13 18:00:32.934	debug	Create State ELR-29020256.info.address
        mbus.0
        2022-06-13 18:00:32.932	debug	Create State ELR-29020256.info.Signature
        mbus.0
        2022-06-13 18:00:32.929	debug	Create State ELR-29020256.info.Status
        mbus.0
        2022-06-13 18:00:32.927	debug	Create State ELR-29020256.info.AccessNumber
        mbus.0
        2022-06-13 18:00:32.925	debug	Create State ELR-29020256.info.Medium
        mbus.0
        2022-06-13 18:00:32.922	debug	Create State ELR-29020256.info.ProductName
        mbus.0
        2022-06-13 18:00:32.920	debug	Create State ELR-29020256.info.Version
        mbus.0
        2022-06-13 18:00:32.917	debug	Create State ELR-29020256.info.Manufacturer
        mbus.0
        2022-06-13 18:00:32.914	debug	Create State ELR-29020256.info.Id
        mbus.0
        2022-06-13 18:00:32.868	debug	M-Bus ID 1 data: { "SlaveInformation": { "Id": 29020256, "Manufacturer": "ELR", "Version": 255, "ProductName": "", "Medium": "Water", "AccessNumber": 83, "Status": 0, "Signature": 0 } }
        mbus.0
        2022-06-13 18:00:31.417	debug	Process: 1
        mbus.0
        2022-06-13 18:00:31.018	debug	connected set to true
        mbus.0
        2022-06-13 18:00:30.943	debug	connected set to true
        mbus.0
        2022-06-13 18:00:30.915	info	Schedule initialization for M-Bus-ID 1 with update interval 300
        mbus.0
        2022-06-13 18:00:30.912	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
        mbus.0
        2022-06-13 18:00:30.912	info	Default Update Interval: 600
        mbus.0
        2022-06-13 18:00:30.884	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mbus, node: v14.19.3, js-controller: 4.0.23
        mbus.0
        2022-06-13 18:00:30.525	debug	Plugin sentry Initialize Plugin (enabled=true)
        mbus.0
        2022-06-13 18:00:20.053	debug	connected set to false
        mbus.0
        2022-06-13 18:00:20.045	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        mbus.0
        2022-06-13 18:00:20.045	debug	Plugin sentry destroyed
        mbus.0
        2022-06-13 18:00:20.044	info	terminating
        mbus.0
        2022-06-13 18:00:20.042	info	Got terminate signal TERMINATE_YOURSELF
        Habe nun alle Datenpunkte nochmal gelöscht, weil er nur dann die Daten aktualisierte, nun macht er das auch nicht mehr und bekommt gar keine Werte mehr 😕
        Neustart ohne Datenpunkte
        mbus.0
        2022-06-13 18:06:01.420	debug	Create State ELR-29020256.data.lastStatus
        mbus.0
        2022-06-13 18:06:01.411	debug	Create State ELR-29020256.info.address
        mbus.0
        2022-06-13 18:06:01.404	debug	Create State ELR-29020256.info.Signature
        mbus.0
        2022-06-13 18:06:01.397	debug	Create State ELR-29020256.info.Status
        mbus.0
        2022-06-13 18:06:01.390	debug	Create State ELR-29020256.info.AccessNumber
        mbus.0
        2022-06-13 18:06:01.384	debug	Create State ELR-29020256.info.Medium
        mbus.0
        2022-06-13 18:06:01.362	debug	Create State ELR-29020256.info.ProductName
        mbus.0
        2022-06-13 18:06:01.350	debug	Create State ELR-29020256.info.Version
        mbus.0
        2022-06-13 18:06:01.342	debug	Create State ELR-29020256.info.Manufacturer
        mbus.0
        2022-06-13 18:06:01.334	debug	Create State ELR-29020256.info.Id
        mbus.0
        2022-06-13 18:06:01.261	debug	M-Bus ID 1 data: { "SlaveInformation": { "Id": 29020256, "Manufacturer": "ELR", "Version": 255, "ProductName": "", "Medium": "Water", "AccessNumber": 85, "Status": 0, "Signature": 0 }}
        mbus.0
        2022-06-13 18:05:59.824	debug	Process: 1
        mbus.0
        2022-06-13 18:05:59.428	debug	connected set to true
        mbus.0
        2022-06-13 18:05:59.385	debug	connected set to true
        mbus.0
        2022-06-13 18:05:59.322	info	Schedule initialization for M-Bus-ID 1 with update interval 300
        mbus.0
        2022-06-13 18:05:59.319	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
        mbus.0
        2022-06-13 18:05:59.319	info	Default Update Interval: 600
        mbus.0
        2022-06-13 18:05:59.292	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mbus, node: v14.19.3, js-controller: 4.0.23
        mbus.0
        2022-06-13 18:05:58.940	debug	Plugin sentry Initialize Plugin (enabled=true)
        mbus.0
        2022-06-13 18:05:58.588	debug	States connected to redis: 10.1.1.5:9000
        mbus.0
        2022-06-13 18:05:58.489	debug	States create User PubSub Client
        mbus.0
        2022-06-13 18:05:58.487	debug	States create System PubSub Client
        mbus.0
        2022-06-13 18:05:58.455	debug	Redis States: Use Redis connection: 10.1.1.5:9000
        mbus.0
        2022-06-13 18:05:58.403	debug	Objects connected to redis: 10.1.1.5:9001
        mbus.0
        2022-06-13 18:05:58.395	debug	Objects client initialize lua scripts
        mbus.0
        2022-06-13 18:05:58.289	debug	Objects create User PubSub Client
        mbus.0
        2022-06-13 18:05:58.288	debug	Objects create System PubSub Client
        mbus.0
        2022-06-13 18:05:58.286	debug	Objects client ready ... initialize now
        mbus.0
        2022-06-13 18:05:58.224	debug	Redis Objects: Use Redis connection: 10.1.1.5:9001
        • Hant0r
          Hant0r @Hant0r last edited by Hant0r
          Ok das ist etwas strange.
          Fand es Merkwürdig, wieso er auf einmal gar keine Daten mehr Empfangen hat. Also habe ich es wiederholt wie heute Mittag.
          Wenn ich das Modul über den Laptop auslese, ihn dann an die Diskstation anschließe und den Adapter starte, dann liest er alles korrekt aus, wie es sein sollte:
          mbus.0
          2022-06-13 20:21:52.365	debug	Value ELR-29020256.data.53-40-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.365	debug	Value ELR-29020256.data.52-40-Max: 2022-05-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.365	debug	Value ELR-29020256.data.51-39-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.364	debug	Value ELR-29020256.data.50-39-Max: 2022-04-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.364	debug	Value ELR-29020256.data.49-38-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.364	debug	Value ELR-29020256.data.48-38-Max: 2022-03-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.363	debug	Value ELR-29020256.data.47-37-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.363	debug	Value ELR-29020256.data.46-37-Max: 2022-02-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.362	debug	Value ELR-29020256.data.45-36-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.362	debug	Value ELR-29020256.data.44-36-Max: 2022-01-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.362	debug	Value ELR-29020256.data.43-35-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.361	debug	Value ELR-29020256.data.42-35-Max: 2021-12-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.361	debug	Value ELR-29020256.data.41-34-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.360	debug	Value ELR-29020256.data.40-34-Max: 2021-11-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.360	debug	Value ELR-29020256.data.39-33-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.360	debug	Value ELR-29020256.data.38-33-Max: 2021-10-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.359	debug	Value ELR-29020256.data.37-32-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.359	debug	Value ELR-29020256.data.36-32-Max: 2021-09-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.359	debug	Value ELR-29020256.data.35-31-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.358	debug	Value ELR-29020256.data.34-31-Max: 2021-08-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.358	debug	Value ELR-29020256.data.33-30-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.356	debug	Value ELR-29020256.data.32-30-Max: 2021-07-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.356	debug	Value ELR-29020256.data.31-29-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.355	debug	Value ELR-29020256.data.30-29-Max: 2021-06-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.354	debug	Value ELR-29020256.data.29-28-Max: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.353	debug	Value ELR-29020256.data.28-28-Max: 2021-05-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.353	debug	Value ELR-29020256.data.27-More records follow: 1 (unit: ) with factor 0
          mbus.0
          2022-06-13 20:21:52.352	debug	Value ELR-29020256.data.26-20-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.352	debug	Value ELR-29020256.data.25-19-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.351	debug	Value ELR-29020256.data.24-18-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.351	debug	Value ELR-29020256.data.23-17-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.351	debug	Value ELR-29020256.data.22-16-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.350	debug	Value ELR-29020256.data.21-15-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.350	debug	Value ELR-29020256.data.20-14-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.349	debug	Value ELR-29020256.data.19-13-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.349	debug	Value ELR-29020256.data.18-12-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.349	debug	Value ELR-29020256.data.17-11-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.348	debug	Value ELR-29020256.data.16-10-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.347	debug	Value ELR-29020256.data.15-9-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.346	debug	Value ELR-29020256.data.14-8-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.345	debug	Value ELR-29020256.data.13-8-Current: 2021-06-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.345	debug	Value ELR-29020256.data.12-8-Current: 1 (unit: s) with factor 0
          mbus.0
          2022-06-13 20:21:52.344	debug	Value ELR-29020256.data.11-8-Current: 13 (unit: Size of storage block) with factor 0
          mbus.0
          2022-06-13 20:21:52.344	debug	Value ELR-29020256.data.10-6-Current: 2000-00-00T00:00:00 (unit: time & date) with factor 0
          mbus.0
          2022-06-13 20:21:52.344	debug	Value ELR-29020256.data.9-7-Current: 2000-00-00T00:00:00 (unit: time & date) with factor 0
          mbus.0
          2022-06-13 20:21:52.343	debug	Value ELR-29020256.data.8-0-Current: 0 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.343	debug	Value ELR-29020256.data.7-0-Max: 1020 (unit: m m^3/h) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.342	debug	Value ELR-29020256.data.6-0-Max: 2022-06-13 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.342	debug	Value ELR-29020256.data.5-0-Current: 1 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.341	debug	Value ELR-29020256.data.4-1-Current: 2023-01-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.341	debug	Value ELR-29020256.data.3-1-Current: 0 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.341	debug	Value ELR-29020256.data.2-1-Current: 2022-01-01 (unit: date) with factor 0
          mbus.0
          2022-06-13 20:21:52.340	debug	Value ELR-29020256.data.1-0-Current: 2022-06-13T20:21:00 (unit: time & date) with factor 0
          mbus.0
          2022-06-13 20:21:52.339	debug	Value ELR-29020256.data.0-0-Current: 82033 (unit: m m^3) with factor 0.001
          mbus.0
          2022-06-13 20:21:52.330	debug	Create State ELR-29020256.data.lastStatus
          mbus.0
          2022-06-13 20:21:52.322	debug	Create State ELR-29020256.data.53-40-Max
          mbus.0
          2022-06-13 20:21:52.314	debug	Create State ELR-29020256.data.52-40-Max
          mbus.0
          2022-06-13 20:21:52.306	debug	Create State ELR-29020256.data.51-39-Max
          mbus.0
          2022-06-13 20:21:52.298	debug	Create State ELR-29020256.data.50-39-Max
          mbus.0
          2022-06-13 20:21:52.286	debug	Create State ELR-29020256.data.49-38-Max
          mbus.0
          2022-06-13 20:21:52.279	debug	Create State ELR-29020256.data.48-38-Max
          mbus.0
          2022-06-13 20:21:52.268	debug	Create State ELR-29020256.data.47-37-Max
          mbus.0
          2022-06-13 20:21:52.258	debug	Create State ELR-29020256.data.46-37-Max
          mbus.0
          2022-06-13 20:21:52.246	debug	Create State ELR-29020256.data.45-36-Max
          mbus.0
          2022-06-13 20:21:52.221	debug	Create State ELR-29020256.data.44-36-Max
          mbus.0
          2022-06-13 20:21:52.213	debug	Create State ELR-29020256.data.43-35-Max
          mbus.0
          2022-06-13 20:21:52.206	debug	Create State ELR-29020256.data.42-35-Max
          mbus.0
          2022-06-13 20:21:52.199	debug	Create State ELR-29020256.data.41-34-Max
          mbus.0
          2022-06-13 20:21:52.189	debug	Create State ELR-29020256.data.40-34-Max
          mbus.0
          2022-06-13 20:21:52.174	debug	Create State ELR-29020256.data.39-33-Max
          mbus.0
          2022-06-13 20:21:52.167	debug	Create State ELR-29020256.data.38-33-Max
          mbus.0
          2022-06-13 20:21:52.160	debug	Create State ELR-29020256.data.37-32-Max
          mbus.0
          2022-06-13 20:21:52.153	debug	Create State ELR-29020256.data.36-32-Max
          mbus.0
          2022-06-13 20:21:52.145	debug	Create State ELR-29020256.data.35-31-Max
          mbus.0
          2022-06-13 20:21:52.137	debug	Create State ELR-29020256.data.34-31-Max
          mbus.0
          2022-06-13 20:21:52.129	debug	Create State ELR-29020256.data.33-30-Max
          mbus.0
          2022-06-13 20:21:52.123	debug	Create State ELR-29020256.data.32-30-Max
          mbus.0
          2022-06-13 20:21:52.112	debug	Create State ELR-29020256.data.31-29-Max
          mbus.0
          2022-06-13 20:21:52.104	debug	Create State ELR-29020256.data.30-29-Max
          mbus.0
          2022-06-13 20:21:52.096	debug	Create State ELR-29020256.data.29-28-Max
          mbus.0
          2022-06-13 20:21:52.087	debug	Create State ELR-29020256.data.28-28-Max
          mbus.0
          2022-06-13 20:21:52.081	debug	Create State ELR-29020256.data.27-More records follow
          mbus.0
          2022-06-13 20:21:52.076	debug	Create State ELR-29020256.data.26-20-Current
          mbus.0
          2022-06-13 20:21:52.070	debug	Create State ELR-29020256.data.25-19-Current
          mbus.0
          2022-06-13 20:21:52.064	debug	Create State ELR-29020256.data.24-18-Current
          mbus.0
          2022-06-13 20:21:52.058	debug	Create State ELR-29020256.data.23-17-Current
          mbus.0
          2022-06-13 20:21:52.049	debug	Create State ELR-29020256.data.22-16-Current
          mbus.0
          2022-06-13 20:21:52.044	debug	Create State ELR-29020256.data.21-15-Current
          mbus.0
          2022-06-13 20:21:52.040	debug	Create State ELR-29020256.data.20-14-Current
          mbus.0
          2022-06-13 20:21:52.035	debug	Create State ELR-29020256.data.19-13-Current
          mbus.0
          2022-06-13 20:21:52.030	debug	Create State ELR-29020256.data.18-12-Current
          mbus.0
          2022-06-13 20:21:52.023	debug	Create State ELR-29020256.data.17-11-Current
          mbus.0
          2022-06-13 20:21:52.016	debug	Create State ELR-29020256.data.16-10-Current
          mbus.0
          2022-06-13 20:21:52.007	debug	Create State ELR-29020256.data.15-9-Current
          mbus.0
          2022-06-13 20:21:51.998	debug	Create State ELR-29020256.data.14-8-Current
          mbus.0
          2022-06-13 20:21:51.991	debug	Create State ELR-29020256.data.13-8-Current
          mbus.0
          2022-06-13 20:21:51.982	debug	Create State ELR-29020256.data.12-8-Current
          mbus.0
          2022-06-13 20:21:51.972	debug	Create State ELR-29020256.data.11-8-Current
          mbus.0
          2022-06-13 20:21:51.960	debug	Create State ELR-29020256.data.10-6-Current
          mbus.0
          2022-06-13 20:21:51.947	debug	Create State ELR-29020256.data.9-7-Current
          mbus.0
          2022-06-13 20:21:51.937	debug	Create State ELR-29020256.data.8-0-Current
          mbus.0
          2022-06-13 20:21:51.930	debug	Create State ELR-29020256.data.7-0-Max
          mbus.0
          2022-06-13 20:21:51.921	debug	Create State ELR-29020256.data.6-0-Max
          mbus.0
          2022-06-13 20:21:51.896	debug	Create State ELR-29020256.data.5-0-Current
          mbus.0
          2022-06-13 20:21:51.886	debug	Create State ELR-29020256.data.4-1-Current
          mbus.0
          2022-06-13 20:21:51.879	debug	Create State ELR-29020256.data.3-1-Current
          mbus.0
          2022-06-13 20:21:51.869	debug	Create State ELR-29020256.data.2-1-Current
          mbus.0
          2022-06-13 20:21:51.862	debug	Create State ELR-29020256.data.1-0-Current
          mbus.0
          2022-06-13 20:21:51.853	debug	Create State ELR-29020256.data.0-0-Current
          mbus.0
          2022-06-13 20:21:51.845	debug	Create State ELR-29020256.info.address
          mbus.0
          2022-06-13 20:21:51.838	debug	Create State ELR-29020256.info.Signature
          mbus.0
          2022-06-13 20:21:51.830	debug	Create State ELR-29020256.info.Status
          mbus.0
          2022-06-13 20:21:51.821	debug	Create State ELR-29020256.info.AccessNumber
          mbus.0
          2022-06-13 20:21:51.813	debug	Create State ELR-29020256.info.Medium
          mbus.0
          2022-06-13 20:21:51.801	debug	Create State ELR-29020256.info.ProductName
          mbus.0
          2022-06-13 20:21:51.793	debug	Create State ELR-29020256.info.Version
          mbus.0
          2022-06-13 20:21:51.786	debug	Create State ELR-29020256.info.Manufacturer
          mbus.0
          2022-06-13 20:21:51.779	debug	Create State ELR-29020256.info.Id
          mbus.0
          2022-06-13 20:21:51.708	debug	M-Bus ID 1 data: { "SlaveInformation": { "Id": 29020256, "Manufacturer": "ELR", "Version": 255, "ProductName": "", "Medium": "Water", "AccessNumber": 119, "Status": 0, "Signature": 0 }, "DataRecord": [ { "id": 0, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 0, "Unit": "Volume (m m^3)", "Value": 82033, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 1, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 0, "Unit": "Time Point (time & date)", "Value": "2022-06-13T20:21:00", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 2, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 1, "Unit": "Time Point (date)", "Value": "2022-01-01", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 3, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 1, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 4, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 1, "Unit": "Time Point (date)", "Value": "2023-01-01", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 5, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 0, "Unit": "Volume (m m^3)", "Value": 1, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 6, "frame": 0, "Function": "Maximum value", "StorageNumber": 0, "Unit": "Time Point (date)", "Value": "2022-06-13", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 7, "frame": 0, "Function": "Maximum value", "StorageNumber": 0, "Unit": "Volume flow (m m^3/h)", "Value": 1020, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 8, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 9, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 7, "Tariff": 0, "Device": 0, "Unit": "Time Point (time & date)", "Value": "2000-00-00T00:00:00", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 10, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 6, "Tariff": 0, "Device": 0, "Unit": "Time Point (time & date)", "Value": "2000-00-00T00:00:00", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 11, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 8, "Tariff": 0, "Device": 0, "Unit": "Size of storage block", "Value": 13, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 12, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 8, "Tariff": 0, "Device": 0, "Unit": "Storage interval month(s)", "Value": 1, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 13, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 8, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-06-01", "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 14, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 8, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 15, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 9, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 16, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 10, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 17, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 11, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 18, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 12, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 19, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 13, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 20, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 14, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 21, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 15, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 22, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 16, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 23, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 17, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 24, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 18, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 25, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 19, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 26, "frame": 0, "Function": "Instantaneous value", "StorageNumber": 20, "Tariff": 0, "Device": 0, "Unit": "Volume (m m^3)", "Value": 0, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 27, "frame": 0, "Function": "More records follow", "Value": 1, "Timestamp": "2022-06-13T18:21:50Z" }, { "id": 28, "frame": 1, "Function": "Maximum value", "StorageNumber": 28, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-05-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 29, "frame": 1, "Function": "Maximum value", "StorageNumber": 28, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 30, "frame": 1, "Function": "Maximum value", "StorageNumber": 29, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-06-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 31, "frame": 1, "Function": "Maximum value", "StorageNumber": 29, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 32, "frame": 1, "Function": "Maximum value", "StorageNumber": 30, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-07-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 33, "frame": 1, "Function": "Maximum value", "StorageNumber": 30, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 34, "frame": 1, "Function": "Maximum value", "StorageNumber": 31, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-08-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 35, "frame": 1, "Function": "Maximum value", "StorageNumber": 31, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 36, "frame": 1, "Function": "Maximum value", "StorageNumber": 32, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-09-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 37, "frame": 1, "Function": "Maximum value", "StorageNumber": 32, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 38, "frame": 1, "Function": "Maximum value", "StorageNumber": 33, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-10-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 39, "frame": 1, "Function": "Maximum value", "StorageNumber": 33, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 40, "frame": 1, "Function": "Maximum value", "StorageNumber": 34, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-11-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 41, "frame": 1, "Function": "Maximum value", "StorageNumber": 34, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 42, "frame": 1, "Function": "Maximum value", "StorageNumber": 35, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2021-12-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 43, "frame": 1, "Function": "Maximum value", "StorageNumber": 35, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 44, "frame": 1, "Function": "Maximum value", "StorageNumber": 36, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2022-01-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 45, "frame": 1, "Function": "Maximum value", "StorageNumber": 36, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 46, "frame": 1, "Function": "Maximum value", "StorageNumber": 37, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2022-02-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 47, "frame": 1, "Function": "Maximum value", "StorageNumber": 37, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 48, "frame": 1, "Function": "Maximum value", "StorageNumber": 38, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2022-03-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 49, "frame": 1, "Function": "Maximum value", "StorageNumber": 38, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 50, "frame": 1, "Function": "Maximum value", "StorageNumber": 39, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2022-04-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 51, "frame": 1, "Function": "Maximum value", "StorageNumber": 39, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 52, "frame": 1, "Function": "Maximum value", "StorageNumber": 40, "Tariff": 0, "Device": 0, "Unit": "Time Point (date)", "Value": "2022-05-01", "Timestamp": "2022-06-13T18:21:51Z" }, { "id": 53, "frame": 1, "Function": "Maximum value", "StorageNumber": 40, "Tariff": 0, "Device": 0, "Unit": "Volume flow (m m^3/h)", "Value": 0, "Timestamp": "2022-06-13T18:21:51Z" } ] }
          mbus.0
          2022-06-13 20:21:48.198	debug	Process: 1
          mbus.0
          2022-06-13 20:21:47.733	debug	connected set to true
          mbus.0
          2022-06-13 20:21:47.732	debug	connected set to true
          mbus.0
          2022-06-13 20:21:47.696	info	Schedule initialization for M-Bus-ID 1 with update interval 300
          mbus.0
          2022-06-13 20:21:47.694	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
          mbus.0
          2022-06-13 20:21:47.693	info	Default Update Interval: 300
          mbus.0
          2022-06-13 20:21:47.663	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mbus, node: v14.19.3, js-controller: 4.0.23
          mbus.0
          2022-06-13 20:21:47.302	debug	Plugin sentry Initialize Plugin (enabled=true)
          Nach fünf Minuten (meinem Interval) kommt dann aber wieder das gleiche Bild, dass er keine Daten liest:
          mbus.0
          2022-06-13 20:26:53.807	debug	M-Bus ID 1 data: { "SlaveInformation": { "Id": 29020256, "Manufacturer": "ELR", "Version": 255, "ProductName": "", "Medium": "Water", "AccessNumber": 121, "Status": 0, "Signature": 0 } }
          mbus.0
          2022-06-13 20:26:52.367	debug	Process: 1
          Stoppe ich den Adapter und will alle Datenpunkte neu anlegen lassen, dann habe ich das selbeErgebnis wie oben "Neustart ohne Datenpunkte"
          mbus.0
          2022-06-13 20:28:19.524	debug	Create State ELR-29020256.data.lastStatus
          mbus.0
          2022-06-13 20:28:19.516	debug	Create State ELR-29020256.info.address
          mbus.0
          2022-06-13 20:28:19.499	debug	Create State ELR-29020256.info.Signature
          mbus.0
          2022-06-13 20:28:19.489	debug	Create State ELR-29020256.info.Status
          mbus.0
          2022-06-13 20:28:19.482	debug	Create State ELR-29020256.info.AccessNumber
          mbus.0
          2022-06-13 20:28:19.473	debug	Create State ELR-29020256.info.Medium
          mbus.0
          2022-06-13 20:28:19.465	debug	Create State ELR-29020256.info.ProductName
          mbus.0
          2022-06-13 20:28:19.458	debug	Create State ELR-29020256.info.Version
          mbus.0
          2022-06-13 20:28:19.451	debug	Create State ELR-29020256.info.Manufacturer
          mbus.0
          2022-06-13 20:28:19.444	debug	Create State ELR-29020256.info.Id
          mbus.0
          2022-06-13 20:28:19.372	debug	M-Bus ID 1 data: { "SlaveInformation": { "Id": 29020256, "Manufacturer": "ELR", "Version": 255, "ProductName": "", "Medium": "Water", "AccessNumber": 122, "Status": 0, "Signature": 0 } }
          mbus.0
          2022-06-13 20:28:17.918	debug	Process: 1
          mbus.0
          2022-06-13 20:28:17.486	debug	connected set to true
          mbus.0
          2022-06-13 20:28:17.485	debug	connected set to true
          mbus.0
          2022-06-13 20:28:17.416	info	Schedule initialization for M-Bus-ID 1 with update interval 300
          mbus.0
          2022-06-13 20:28:17.414	info	Initialize M-Bus Serial to /dev/ttyUSB1 with 2400baud
          mbus.0
          2022-06-13 20:28:17.413	info	Default Update Interval: 300
          mbus.0
          2022-06-13 20:28:17.386	info	starting. Version 2.3.4 in /opt/iobroker/node_modules/iobroker.mbus, node: v14.19.3, js-controller: 4.0.23
          mbus.0
          2022-06-13 20:28:16.980	debug	Plugin sentry Initialize Plugin (enabled=true)
          Verstehe es nicht.
          @apollon77, hast du eine Idee?
          apollon77 2 Replies Last reply Reply Quote 0
            @hant0r checke Ende der Woche.
              @hant0r Ok, Idee keeine. Die kommunikation tut ja aber das Gerät liefert keine Daten zurück. Da müssten wir jetzt seeeer tief reinschauen ...
              Am Ende wäre es erstmal das einfachste wenn Du "libmbus" per "apt get install libmbus" installierst. das bringt dann binaries mit um auch die Daten auszulesen. libmbus wird im Adapter "Unter der Haube" genutzt ... Das relevante Kommando zum lesen sollte dann "mbus-serial-request-data-multi-reply" sein. Zeig mal was da rauskommt
              • Hant0r
                @apollon77 danke, werde ich mir am Wochenende mal ansehen 🙂
                • Hant0r
                  @apollon77 sagte in Adapter mbus - Fehler im log:
                  Hoffe es ist das, was du meinst:
                  root@ioBroker:/opt/libmbus/bin# ./mbus-serial-request-data-multi-reply -d -b 2400 /dev/ttyUSB1 1
                  init_slaves: debug: sending init frame #1
                  [2022-07-01 21:53:21Z] SEND (005): 10 40 FD 3D 16
                  [2022-07-01 21:53:21Z] RECV (001): E5
                  init_slaves: debug: sending init frame #2
                  [2022-07-01 21:53:21Z] SEND (005): 10 7B 01 7C 16
                  [2022-07-01 21:53:22Z] RECV (021): 68 0F 0F 68 08 01 72 56 02 02 29 92 15 FF 07 D6 00 00 00 81 16
                  mbus_frame_print: Dumping M-Bus frame [type 4, 21 bytes]: 68 0F 0F 68 08 01 72 56 02 02 29 92 15 FF 07 D6 00 00 00 81 16
                  <?xml version="1.0" encoding="ISO-8859-1"?>
                  <MBusData>
                      <SlaveInformation>
                          <Id>29020256</Id>
                          <Manufacturer>ELR</Manufacturer>
                          <Version>255</Version>
                          <ProductName></ProductName>
                          <Medium>Water</Medium>
                          <AccessNumber>214</AccessNumber>
                          <Status>00</Status>
                          <Signature>0000</Signature>
                      </SlaveInformation>
                  </MBusData>
                    @hant0r Jupp ... und hier kommt exakt das gleiche raus ... jetzt schau mal in die software wo du immer alles bekokmst ob du da auch sehen kannst was die senden und empfangen als Hex
                    • Hant0r
                      Hant0r @apollon77 last edited by Hant0r
                      @apollon77
                      da kommt das, wenn ich ihn auslese:
                      TX-Puffer:
                      10 7B FE 79 16
                      RX-Puffer:
                      68 0F 0F 68 08 01 72 56 02 02 29 92 15 FF 07 DC 00 00 00 87 16
                      TX-Puffer:
                      68 04 04 68 53 FE 50 00 A1 16
                      RX-Puffer:
                      E5
                      TX-Puffer:
                      10 7B FE 79 16
                      RX-Puffer:
                      68 D8 D8 68 08 01 72 56 02 02 29 92 15 FF 07 DD 00 00 00 0C 13 82 41 08 00 04 6D 18 00 C2 27 42 6C C1 21 4C 13 00 00 00 00 42 EC 7E E1 21 0C 93 3C 01 00 00 00 12 6C C1 27 14 3B FC 03 00 00 04 3B 00 00 00 00 C4 03 6D 00 00 00 00 84 03 6D 00 00 00 00 89 04 FD 22 13 89 04 FD 28 01 82 04 6C A1 27 8C 04 13 00 00 00 00 CC 04 13 00 00 00 00 8C 05 13 00 00 00 00 CC 05 13 00 00 00 00 8C 06 13 00 00 00 00 CC 06 13 00 00 00 00 8C 07 13 00 00 00 00 CC 07 13 00 00 00 00 8C 08 13 00 00 00 00 CC 08 13 00 00 00 00 8C 09 13 00 00 00 00 CC 09 13 00 00 00 00 8C 0A 13 92 37 08 00 0A 93 2A 01 00 0A FD 9A B6 73 00 01 01 7A 01 07 79 56 02 02 29 92 15 FF 07 01 FD 18 00 1F 01 55 16
                      TX-Puffer:
                      10 5B FE 59 16
                      RX-Puffer:
                      68 BD BD 68 08 01 72 56 02 02 29 92 15 FF 07 DE 00 00 00 92 0E 6C A1 26 94 0E 3B 00 00 00 00 D2 0E 6C A1 27 D4 0E 3B 00 00 00 00 92 0F 6C A1 28 94 0F 3B 00 00 00 00 D2 0F 6C A1 29 D4 0F 3B 00 00 00 00 92 80 01 6C A1 2A 94 80 01 3B 00 00 00 00 D2 80 01 6C A1 2B D4 80 01 3B 00 00 00 00 92 81 01 6C A1 2C 94 81 01 3B 00 00 00 00 D2 81 01 6C C1 21 D4 81 01 3B 00 00 00 00 92 82 01 6C C1 22 94 82 01 3B 00 00 00 00 D2 82 01 6C C1 23 D4 82 01 3B 00 00 00 00 92 83 01 6C C1 24 94 83 01 3B 00 00 00 00 D2 83 01 6C C1 25 D4 83 01 3B 00 00 00 00 92 84 01 6C CD 26 94 84 01 3B FC 03 00 00 84 16
                      TX-Puffer:
                      10 7B FE 79 16
                      RX-Puffer:
                      68 68 68 68 08 01 72 56 02 02 29 92 15 FF 07 DF 00 00 00 0C 78 56 02 02 29 0D FD 0F 05 30 2E 30 2E 32 84 41 6D 00 00 00 00 82 41 FD 3A 00 00 C4 41 6D 00 00 00 00 C2 41 FD 3A 00 00 84 42 6D 00 00 00 00 82 42 FD 3A 00 00 C4 42 6D 00 00 00 00 C2 42 FD 3A 00 00 84 43 6D 00 00 00 00 82 43 FD 3A 00 00 0A FD 47 68 03 01 FD 1A 02 54 16
                        @hant0r Das muss ich mir mit viel muse und Zeit mal auf protokollebene ansehen. Das Program scheint beim ersten mal die gleiche Antwort zu bekommen und mach dann nochmal eine Anfrage ...
                        Hant0r 2 Replies Last reply Reply Quote 0
                        • Hant0r
                          @apollon77 kann ich was tun oder helfen/testen?
                            @hant0r Nur wenn du auf Protokollebene rausfinden willst was die Unterschiede der Messages sind und warum sich das Gerät so verhält wie es tut 🙂
                            • Hant0r
                              @apollon77 wenn ich wüsste wie das geht gerne 😂
                              Hoffe das du es schnell findest. Wenn du noch was brauchst oder auch live was sehen willst, sag Bescheid
                              • Hant0r
                                @apollon77 gibt es schon erste Erkenntnisse? 👼
                                  @hant0r noch keine Zeit gehabt und gerade andere Baustellen. Sorry
                                  Hant0r 1 Reply Last reply Reply Quote 1
                                  • Hant0r
                                    @apollon77 Moin. Wollte nach drei Monaten nochmal fragen, ob schon Licht am Horizont für die Umsetzung zu sehen ist 🙈
                                      @hant0r Sorry, eher schwierig im Moment.
                                      • Hant0r
                                        Hmm schade 😢
                                        @All:
                                        Kennt jemand eine andere Möglichkeit, die Daten von seinem Wasserzähler zu erfassen ohne den MBUS Adapter?
                                        Geht es evtl. über NodeRed oder so?
                                        Finde es so schade, habe den Wasserzähler seit Monaten im Einsatz und komme nicht an die Daten (außer manuell auszulesen).
                                        Danke schon mal für jeden Tipp 🙂
                                        error mbus
                                        6475
