    4. Material Design Widgets: UniFi Netzwerk Status
    • tobasium
      tobasium @cdellasanta last edited by tobasium
      @cdellasanta Danke.
      Habe es soweit mal angepasst. Jetzt läuft alles:
      * Listings for UniFi devices (to use with Material Design Widgets)
      * Requirements:
      *  - UniFi controller permanently running on your network
      *  - UniFi ioBroker adapter >= 0.5.8 (https://www.npmjs.com/package/iobroker.unifi)
      *  - Library "moment" in the "Additional npm modules" of the javascript.0 adapter configuration
      *  - Some programming skills
      * @license http://www.opensource.org/licenses/mit-license.html  MIT License
      * @author  Scrounger <Scrounger@gmx.net>
      * @author  web4wasch @WEB4WASCH
      * @author  cdellasanta <70055566+cdellasanta@users.noreply.github.com>
      * @link    https://forum.iobroker.net/topic/30875/material-design-widgets-unifi-netzwerk-status
      // Script configuration
      const statePrefix = '0_userdata.0.vis.NetzwerkDevicesStatus'; // Might be better to use an english statePrefix (e.g. '0_userdata.0.vis.unifiNetworkState'), but then remember to adapt the Views too
      const defaultLocale = 'de';
      const lastDays = 7;       // Show devices that have been seen in the network within the last X days
      const byteUnits = 'SI'; // SI units use the Metric representation based on 10^3 (1'000) as a order of magnitude
                             // IEC units use 2^10 (1'024) as an order of magnitude
      const defaultSortMode = 'connected'; // Value for default and reset sort
      const sortResetAfter = 120;     // Reset sort value after X seconds (0=disabled)
      const filterResetAfter = 120;   // Reset filter after X seconds (0=disabled)
      const imagesPath = '/vis.0/main/Meine_Icons/Netzwerk/'; // Path for images
      // Optional: Path prefix for UniFi device images (see getUnifiImage function for deeper information on how to extract it for your network)
      // @todo Could take controller host and port from the unifi adapter configuration, but thene there is still the angular subdirectory that needs to be configured ..
      // const unifiImagesUrlPrefix = 'https://<your-controller-ip-or-host>:<controller-port>/manage/angular/g7989b19/images/devices/';
      // const unifiImagesUrlPrefix = null; // Use the 'lan_noImage.png' for all devices
      const unifiImagesUrlPrefix = false; // Use '<device model>.png' from your imagesPath
      // Optional: display links into a separate view, instead of new navigation window (set false to disable this feature)
      const devicesView = false;
      const offlineTextSize = 14;
      const infoIconSize = 20;
      const infoTextSize = 14;
      const performances = {
         none: {
             color: 'grey',
             experience: 'speedometer',
             speedLan: 'network-off',
             speedWifi: 'wifi-off'
         good: {
             color: 'green',
             speedLan: 'network',
             speedWifi: 'signal-cellular-3'
         low: {
             color: '#ff9800',
             experience: 'speedometer-medium',
             speedWifi: 'signal-cellular-2'
         bad: {
             color: 'FireBrick',
             experience: 'speedometer-slow',
             speedWifi: 'signal-cellular-1'
      // Modules: should not need to 'import' them (ref: https://github.com/ioBroker/ioBroker.javascript/blob/c2725dcd9772627402d0e5bc74bf69b5ed6fe375/docs/en/javascript.md#require---load-some-module),
      // but to avoid TypeScript inspection errors, doing it anyway ...
      // import * as moment from "moment"; // Should work, but typescript raises exception ...
      const moment = require('moment');
      // Initialization create/delete states, register listeners
      // Using my global functions (see global script common-states-handling )
      /** For this script to work as standalone, the following 4 functions have been inlined at the end of script,
      *  if you place them in a global script, then you need to uncomment following "declare" statements **/
      // declare function runAfterInitialization(callback: CallableFunction): void;
      // declare function initializeState(stateId: string, defaultValue: any, common: object, listenerChangeType?: string, listenerCallback?: CallableFunction): void;
      // declare function getStateIfExists(stateId: string): any;
      // declare function getStateValue(stateId: string): any;
      const getLocale = () => getStateValue('0_userdata.0.vis.locale') || defaultLocale;
      initializeState(`${statePrefix}.jsonList`, '[]', {name: 'UniFi devices listing: jsonList', type: 'string'});
      // Change on sort mode triggers list generation and reset of sort-timer-reset
      initializeState(`${statePrefix}.sortMode`, defaultSortMode, {name: 'UniFi device listing: sortMode', type: 'string'}, 'any', () => { updateDeviceLists(); resetSortTimer(); });
      // Change on filter mode triggers list generation and reset of filter-timer-reset
      initializeState(`${statePrefix}.filterMode`, '', {name: 'UniFi device listing: filterMode', type: 'string'}, 'any', () => { updateDeviceLists(); resetFilterTimer(); });
      // Sorters, filters and some additional translations are saved in states to permit texts localization
      initializeState(`${statePrefix}.sortersJsonList`, '{}', {name: 'UniFi device listing: sortersJsonList', type: 'string', read: true, write: false});
      initializeState(`${statePrefix}.filtersJsonList`, '{}', {name: 'UniFi device listing: filtersJsonList', type: 'string', read: true, write: false});
      initializeState(`${statePrefix}.translations`, '{}', {name: 'UniFi device listing: viewTranslations', type: 'string', read: true, write: false});
      // On locale change, setup correct listings
      if (existsState('0_userdata.0.vis.locale')) {
         runAfterInitialization(() => on('0_userdata.0.vis.locale', 'ne', setup));
      runAfterInitialization(() => {
         setup();
         // Refresh lists every time the unifi adapter has updated its data
         on('unifi.0.info.connection','any', updateDeviceLists);
      function setup(): void {
         setTimeLocale();
         setSortItems();
         setFilterItems();
         setViewTranslations();
         // Fill lists
      function updateDeviceLists() {
         const getNote = (idDevice, name, mac, ip) => {
             try {
                 return JSON.parse(getStateValue(`${idDevice}.note`) || '{}');
             } catch (ex) {
                 console.error(`${name} (ip: ${ip}, mac: ${mac}): ${ex.message}`);
             return {};
         try {
             // Selector help: https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#---selector
             let devices = $('state[id=unifi\.0\.default\.*\.*\.mac]'); // Query every time function is called (for new devices)
             let deviceList = [];
             for (var i = 0; i <= devices.length - 1; i++) {
                 let [,,, deviceType, mac] = devices[i].split('.');
                 // Only 'clients' and 'devices' are allowed (not 'alerts' ... can't exclude direclty on selector ...)
                 if (!['clients', 'devices'].includes(deviceType)) {
                     continue;
                 let idDevice = devices[i].replace('.mac', '');
                 let unifiDevice = deviceType === 'devices';
                 let isWired = getStateValue(`${idDevice}.is_wired`) || unifiDevice;
                 let lastSeen = new Date(getStateValue(`${idDevice}.last_seen`));
                 // For clients, if lastSeen difference is bigger than lastDays, then skip the device
                 if (!unifiDevice && (new Date().getTime() - lastSeen.getTime()) > lastDays * 86400 * 1000) {
                     continue;
                 // Values for all device types and connection
                 let isConnected = getStateValue(`${idDevice}.is_online`) || unifiDevice;
                 let ip = getStateValue(`${idDevice}.ip`) || '';
                 let name = getStateValue(`${idDevice}.name`) || getStateValue(`${idDevice}.hostname`) || ip || mac;
                 let isGuest = getStateValue(`${idDevice}.is_guest`);
                 let note = getNote(idDevice, name, mac, ip);
                 let received = getStateValue(`${idDevice}.${unifiDevice || !isWired ? '' : 'wired-'}tx_bytes`) || 0;
                 let sent = getStateValue(`${idDevice}.${unifiDevice || !isWired ? '' : 'wired-'}rx_bytes`) || 0;
                 let uptime = getStateValue(`${idDevice}.uptime`);
                 let experience = getStateValue(`${idDevice}.satisfaction`) || (isConnected ? 100 : 0); // For LAN devices I got null as expirience .. file a bug?
                 let additionalInfoItems = '';
                 const infoItem = (icon, color, text) => `<span style="margin: 0 2px">
                     <span class="mdi mdi-${icon}" style="color: ${color}; font-size: ${infoIconSize}px; "></span>
                     <span style="color: grey; font-family: RobotoCondensed-LightItalic; font-size: ${infoTextSize}px; margin-left: 2px;">${text}</span>
                     </span>`;
                 if (unifiDevice) {
                     let cpu = getStateValue(`${idDevice}.system-stats.cpu`) || 0;
                     let mem = getStateValue(`${idDevice}.system-stats.mem`) || 0;
                     let cpuPerformance = !isConnected ? 'none' : (cpu <= 70 ? 'good' : (cpu <= 90 ? 'low' : 'bad'));
                     let memPerformance = !isConnected ? 'none' : (mem <= 70 ? 'good' : (mem <= 90 ? 'low' : 'bad'));
                     // The icons do not really fit, there is no good option for a "ram memory bank" in https://materialdesignicons.com/
                     additionalInfoItems += infoItem(/*'cpu-64-bit'*/ 'memory', performances[cpuPerformance].color, `${cpu}%`);
                     additionalInfoItems += infoItem(/*'memory' 'expansion-card-variant'*/ 'sd', performances[memPerformance].color, `${mem}%`);
                 } else {
                     let experiencePerformance = !isConnected ? 'none' : (experience >= 70 ? 'good' : (experience >= 40 ? 'low' : 'bad'));
                     let speedText = '';
                     let speedPerformance = 'none';
                     if (isWired) {
                         // If exists prefer uptime on switch port
                         uptime = getStateValue(`${idDevice}.uptime_by_usw`) || uptime;
                         let switchMac = getStateValue(`${idDevice}.sw_mac`) || false;
                         let switchPort = getStateValue(`${idDevice}.sw_port`) || false;
                         if (switchMac && switchPort) {
                             let speed = getStateValue(`unifi.0.default.devices.${switchMac}.port_table.port_${switchPort}.speed`) || 0;
                             speedText = speed === 0 ? '' : (speed < 1000 ? (speed + ' Mbit/s') : (speed/1000 + ' Gbit/s'));
                             speedPerformance = !isConnected ? 'none' : (speed == 1000 ? 'good' : 'low');
                         // Do not consider fiber ports
                         if (switchPort > 24) { // @todo  On some switches the fiber port is already on port 9 .. there are surely better ways to recognise a fiber port
                             // @todo This is legacy code, why are devices connected to fiber ports not of interest?
                             continue; // Skip device
                     } else {
                         let channel = getStateValue(`${idDevice}.channel`);
                         let signal = getStateValue(`${idDevice}.signal`);
                         speedText = channel === null ? '' : (channel > 13 ? '5G' : '2G');
                         speedPerformance = !isConnected ? 'none' : (signal >= -55 ? 'good' : (signal >= -70 ? 'low' : 'bad'));
                     additionalInfoItems += infoItem(performances[speedPerformance][isWired ? 'speedLan' : 'speedWifi'], performances[speedPerformance].color, speedText);
                     additionalInfoItems += infoItem(performances[experiencePerformance].experience, performances[experiencePerformance].color, `${experience}%`);
                 deviceList.push({
                     // Visualization data (tplVis-materialdesign-Icon-List)
                     statusBarColor: isConnected ? 'green' : 'FireBrick',
                     text: isGuest ? `<span class="mdi mdi-account-box" style="color: #ff9800;">${name}</span>` : name,
                     subText: `
                         ${ip}
                         <div style="display: flex; flex-direction: row; padding-left: 8px; padding-right: 8px; align-items: center; justify-content: center;">
                             <span style="color: grey; font-size: ${offlineTextSize}px; line-height: 1.3; font-family: RobotoCondensed-LightItalic;">
                                 ${translate(isConnected ? 'online' : 'offline')} ${(isConnected ? moment().subtract(uptime, 's') : moment(lastSeen)).fromNow()}
                             </span>
                         </div>
                         <div style="display: flex; flex-direction: row; padding-left: 4px; padding-right: 4px; margin-top: 10px; align-items: center;">
                             <div style="display: flex; flex: 1; text-align: left; align-items: center; position: relative;">
                                 ${infoItem('arrow-down', '#44739e', formatBytes(received, byteUnits))}
                                 ${infoItem('arrow-up', '#44739e', formatBytes(sent, byteUnits))}
                             </div>
                             <div style="display: flex; margin-left: 8px; align-items: center;">
                                 ${additionalInfoItems}
                             </div>
                         </div>
                     listType: !note.link ? 'text' : 'buttonLink',
                     buttonLink: !note.link ? '' : (['http', 'https'].includes(note.link) ? `${note.link}://${ip}` : note.link),
                     image: unifiDevice ? getUnifiImage(getStateValue(`${idDevice}.model`)) : (imagesPath + (note.image ? note.image : ((isWired ? 'lan' : 'wlan') + '_noImage')) + '.png'),
                     icon: note.icon || '',
                     // Additional data used for list sorting
                     ip: ip,
                     connected: isConnected,
                     received: received,
                     sent: sent,
                     experience: experience,
                     uptime: uptime,
                     isWired: isWired,
                     isUnifi: unifiDevice
             // Sorting
             let sortMode = getStateValue(`${statePrefix}.sortMode`);
             deviceList.sort((a, b) => {
                 switch (sortMode) {
                     case 'ip':
                         const na = Number(a['ip'].split(".").map(v => `000${v}`.slice(-3)).join(''));
                         const nb = Number(b['ip'].split(".").map(v => `000${v}`.slice(-3)).join(''));
                         return na - nb;
                     case 'connected':
                     case 'received':
                     case 'sent':
                     case 'experience':
                     case 'uptime':
                         return a[sortMode] === b[sortMode] ? 0 : +(a[sortMode] < b[sortMode]) || -1;
                     case 'name':
                     default:
                         return a['name'].localeCompare(b['name'], getLocale(), {sensitivity: 'base'});
             if (devicesView) {
                 // Create links list (before filtering)
                 let linkList = [];
                 deviceList.forEach(obj => {
                     if (obj.listType === 'buttonLink') {
                         linkList.push({
                             // Visualization data (tplVis-materialdesign-Select)
                             text: obj.name,
                             value: obj.buttonLink,
                             icon: obj.icon
                             /** @todo Add some properties (connected, ip, received, sent, experience, ...)? */
                         // Change behaviour from 'buttonLink' to 'buttonState',
                         // a listener on the state change of the objectId will trigger the jump to the devices view
                         obj['listType'] = 'buttonState';
                         obj['objectId'] = `${statePrefix}.selectedUrl`;
                         obj['showValueLabel'] = false;
                         obj['buttonStateValue'] = obj.buttonLink;
                         delete obj['buttonLink'];
                 let linkListString = JSON.stringify(linkList);
                 if (getStateValue(`${statePrefix}.linksJsonList`) !== linkListString) {
                     setState(`${statePrefix}.linksJsonList`, linkListString, true);
             // Filtering
             let filterMode = getStateValue(`${statePrefix}.filterMode`) || '';
             if (filterMode && filterMode !== '') {
                 deviceList = deviceList.filter(item => {
                     switch (filterMode) {
                         case 'connected':
                             return item.connected;
                         case 'disconnected':
                             return !item.connected;
                         case 'lan':
                             return item.isWired;
                         case 'wlan':
                             return !item.isWired;
                         case 'unifi':
                             return item.isUnifi;
                         default:
                             return false; // Unknown filter, return no item
             let result = JSON.stringify(deviceList);
             if (getStateValue(`${statePrefix}.jsonList`) !== result) {
                 setState(`${statePrefix}.jsonList`, result, true);
         } catch (err) {
             console.error(`[updateDeviceLists] error: ${err.message}`);
             console.error(`[updateDeviceLists] stack: ${err.stack}`);
         log(`Updated lists`, 'debug');
      let sortTimeoutID;
      function resetSortTimer() {
         if (sortResetAfter > 0) {
             clearTimeout(sortTimeoutID); // If set then clear previous timer
             sortTimeoutID = setTimeout(() => setState(`${statePrefix}.sortMode`, defaultSortMode), sortResetAfter * 1000);
      let filterTimeoutID;
      function resetFilterTimer() {
         if (filterResetAfter > 0) {
             clearTimeout(filterTimeoutID); // If set then clear previous timer
             filterTimeoutID = setTimeout(() => setState(`${statePrefix}.filterMode`, ''), filterResetAfter * 1000);
      function setTimeLocale(): void {
         let locale = getLocale();
         moment.locale(locale);
         moment.updateLocale(locale, {
             relativeTime: {
                 future: translate('in %s'),
                 past: translate('since %s'), // Default for past is '%s ago'
                 s: translate('a few seconds'),
                 ss: translate('%d seconds'),
                 m: translate('a minute'),
                 mm: translate('%d minutes'),
                 h: translate('an hour'),
                 hh: translate('%d hours'),
                 d: translate('a day'),
                 dd: translate('%d days'),
                 w: translate('a week'),
                 ww: translate('%d weeks'),
                 M: translate('a month'),
                 MM: translate('%d months'),
                 y: translate('a year'),
                 yy: translate('%d years')
      function setSortItems(): void {
         setState(
             JSON.stringify([
                     text: translate('Name'),
                     value: 'name',
                     icon: 'sort-alphabetical-variant'
                     text: translate('IP address'),
                     value: 'ip',
                     icon: 'information-variant'
                     text: translate('Connected'),
                     value: 'connected',
                     icon: 'check-network'
                     text: translate('Received data'),
                     value: 'received',
                     icon: 'arrow-down'
                     text: translate('Sent data'),
                     value: 'sent',
                     icon: 'arrow-up'
                     text: translate('Experience'),
                     value: 'experience',
                     icon: 'speedometer'
                     text: translate('Uptime'),
                     value: 'uptime',
                     icon: 'clock-check-outline'
             true
      function setFilterItems(): void {
         setState(
             JSON.stringify([
                     text: translate('connected'),
                     value: 'connected',
                     text: translate('disconnected'),
                     value: 'disconnected',
                     icon: 'network-off'
                     text: translate('LAN connection'),
                     value: 'lan',
                     icon: 'network'
                     text: translate('WLAN connection'),
                     value: 'wlan',
                     icon: 'wifi'
                     text: translate('UniFi network devices'),
                     value: 'unifi',
                     icon: 'router-network'
             true
      function setViewTranslations(): void {
         setState(
             JSON.stringify([
                 'Sort by',
                 'Filter by',
                 'Device'
             ].reduce((o, key) => ({...o, [key]: translate(key)}), {})),
             true
      function translate(enText) {
         const map = { // For translations used https://translator.iobroker.in (that uses Google translator)
             // Sort items
             'Name': {de: 'Name', ru: 'имя', pt: 'Nome', nl: 'Naam', fr: 'Nom', it: 'Nome', es: 'Nombre', pl: 'Nazwa','zh-cn': '名称'},
             'IP address': {de: 'IP Adresse', ru: 'Aйпи адрес', pt: 'Endereço de IP', nl: 'IP adres', fr: 'Adresse IP', it: 'Indirizzo IP', es: 'Dirección IP', pl: 'Adres IP','zh-cn': 'IP地址'},
             'Connected': {de: 'Verbunden', ru: 'Связано', pt: 'Conectado', nl: 'Verbonden', fr: 'Connecté', it: 'Collegato', es: 'Conectado', pl: 'Połączony','zh-cn': '连接的'},
             'Received data': {de: 'Daten empfangen', ru: 'Полученные данные', pt: 'Dados recebidos', nl: 'Ontvangen data', fr: 'Données reçues', it: 'Dati ricevuti', es: 'Datos recibidos', pl: 'Otrzymane dane','zh-cn': '收到资料'},
             'Sent data': {de: 'Daten gesendet', ru: 'Отправленные данные', pt: 'Dados enviados', nl: 'Verzonden gegevens', fr: 'Données envoyées', it: 'Dati inviati', es: 'Datos enviados', pl: 'Wysłane dane','zh-cn': '发送数据'},
             'Experience': {de: 'Erlebnis', ru: 'Опыт', pt: 'Experiência', nl: 'Ervaring', fr: 'Expérience', it: 'Esperienza', es: 'Experiencia', pl: 'Doświadczenie','zh-cn': '经验'},
             'Uptime': {de: 'Betriebszeit', ru: 'Время безотказной работы', pt: 'Tempo de atividade', nl: 'Uptime', fr: 'Disponibilité', it: 'Disponibilità', es: 'Tiempo de actividad', pl: 'Dostępność','zh-cn': '正常运行时间'},
             // Filter Items
             'connected': {de: 'verbunden', ru: 'связано', pt: 'conectado', nl: 'verbonden', fr: 'connecté', it: 'collegato', es: 'conectado', pl: 'połączony','zh-cn': '连接的'},
             'disconnected': {de: 'nicht verbunden', ru: 'отключен', pt: 'desconectado', nl: 'losgekoppeld', fr: 'débranché', it: 'disconnesso', es: 'desconectado', pl: 'niepowiązany','zh-cn': '断开连接'},
             'LAN connection': {de: 'LAN Verbindungen', ru: 'подключение по локальной сети', pt: 'conexão LAN', nl: 'LAN-verbinding', fr: 'connexion LAN', it: 'connessione LAN', es: 'coneccion LAN', pl: 'połączenie LAN','zh-cn': '局域网连接'},
             'WLAN connection': {de: 'WLAN Verbindungen', ru: 'поединение WLAN', pt: 'conexão WLAN', nl: 'WLAN-verbinding', fr: 'connexion WLAN', it: 'connessione WLAN', es: 'conexión WLAN', pl: 'połączenie WLAN','zh-cn': 'WLAN连接'},
             'UniFi network devices': {de: 'UniFi-Netzwerkgeräte', ru: 'Сетевые устройства UniFi', pt: 'Dispositivos de rede UniFi', nl: 'UniFi-netwerkapparaten', fr: 'Périphériques réseau UniFi', it: 'Dispositivi di rete UniFi', es: 'Dispositivos de red UniFi', pl: 'Urządzenia sieciowe UniFi', 'zh-cn': 'UniFi网络设备'},
             // Additional view translations
             'Sort by': {de: 'Sortieren nach', ru: 'Сортировать по', pt: 'Ordenar por', nl: 'Sorteer op', fr: 'Trier par', it: 'Ordina per', es: 'Ordenar por', pl: 'Sortuj według', 'zh-cn': '排序方式'},
             'Filter by': {de: 'Filtern nach', ru: 'Сортировать по', pt: 'Filtrar por', nl: 'Filteren op', fr: 'Filtrer par', it: 'Filtra per', es: 'Filtrado por', pl: 'Filtruj według','zh-cn': '过滤'},
             'Device': {de: 'Gerät', ru: 'Устройство', pt: 'Dispositivo', nl: 'Apparaat', fr: 'Dispositif', it: 'Dispositivo', es: 'Dispositivo', pl: 'Urządzenie','zh-cn': '设备'},
             // On/off times
             'online': {de: 'online', ru: 'онлайн', pt: 'conectados', nl: 'online', fr: 'en ligne', it: 'in linea', es: 'en línea', pl: 'online', 'zh-cn': "线上"},
             'offline': {de: 'offline', ru: 'не в сети', pt: 'desligada', nl: 'offline', fr: 'hors ligne', it: 'disconnesso', es: 'desconectado', pl: 'offline', 'zh-cn': "离线"},
             // Relative times
             'in %s': {de: 'in %s', ru: 'через %s', pt: 'em %s', nl: 'in %s', fr: 'en %s', it: 'in %s', es: 'en %s', pl: 'w %s','zh-cn': '在%s中'},
             'since %s': {de: 'seit %s', ru: 'поскольку %s', pt: 'desde %s', nl: 'sinds %s', fr: 'depuis %s', it: 'da %s', es: 'desde %s', pl: 'od %s','zh-cn': '自%s'},
             'a few seconds': {de: 'ein paar Sekunden', ru: 'несколько секунд', pt: 'alguns segundos', nl: 'een paar seconden', fr: 'quelques secondes', it: 'pochi secondi', es: 'unos pocos segundos', pl: 'kilka sekund','zh-cn': '几秒钟'},
             '%d seconds': {de: '%d Sekunden', ru: '%d секунд', pt: '%d segundos', nl: '%d seconden', fr: '%d secondes', it: '%d secondi', es: '%d segundos', pl: '%d sekund','zh-cn': '%d秒'},
             'a minute': {de: 'eine Minute', ru: 'минута', pt: 'um minuto', nl: 'een minuut', fr: 'une minute', it: 'un minuto', es: 'un minuto', pl: 'minutę','zh-cn': '一分钟'},
             '%d minutes': {de: '%d Minuten', ru: '%d минут', pt: '%d minutos', nl: '%d minuten', fr: '%d minutes', it: '%d minuti', es: '%d minutos', pl: '%d minut','zh-cn': '%d分钟'},
             'an hour': {de: 'eine Stunde', ru: 'час', pt: 'uma hora', nl: 'een uur', fr: 'une heure', it: 'un\'ora', es: 'una hora', pl: 'godzina','zh-cn': '一小时'},
             '%d hours': {de: '%d Stunden', ru: '%d часов', pt: '%d horas', nl: '%d uur', fr: '%d heures', it: '%d ore', es: '%d horas', pl: '%d godzin','zh-cn': '%d小时'},
             'a day': {de: 'ein Tag', ru: 'день', pt: 'um dia', nl: 'een dag', fr: 'un jour', it: 'un giorno', es: 'un día', pl: 'dzień','zh-cn': '一天'},
             '%d days': {de: '%d Tage', ru: '%d дней', pt: '%d dias', nl: '%d dagen', fr: '%d jours', it: '%d giorni', es: '%d días', pl: '%d dni','zh-cn': '%d天'},
             'a week': {de: 'eine Woche', ru: 'неделя', pt: 'uma semana', nl: 'een week', fr: 'une semaine', it: 'una settimana', es: 'una semana', pl: 'tydzień','zh-cn': '一周'},
             '%d weeks': {de: '%d Wochen', ru: '%d недель', pt: '%d semanas', nl: '%d weken', fr: '%d semaines', it: '%d settimane', es: '%d semanas', pl: '%d tygodni','zh-cn': '%d周'},
             'a month': {de: 'ein Monat', ru: 'месяц', pt: 'um mês', nl: 'een maand', fr: 'un mois', it: 'un mese', es: 'un mes', pl: 'miesiąc','zh-cn': '一个月'},
             '%d months': {de: '%d Monate', ru: '%d месяцев', pt: '%d meses', nl: '%d maanden', fr: '%d mois', it: '%d mesi', es: '%d meses', pl: '%d miesięcy','zh-cn': '%d个月'},
             'a year': {de: 'ein Jahr', ru: 'год', pt: 'um ano', nl: 'een jaar', fr: 'une année', it: 'un anno', es: 'un año', pl: 'rok','zh-cn': '一年'},
             '%d years': {de: '%d Jahre', ru: '%d лет', pt: '%d anos', nl: '%d jaar', fr: '%d années', it: '%d anni', es: '%d años', pl: '%d lat','zh-cn': '%d年'}
         return (map[enText] || {})[getLocale()] || enText;
      function formatBytes(bytes, unit?: 'SI' | 'IEC') : string  {
         if (bytes === 0) return 'N/A';
         const orderOfMagnitude = unit === 'SI' ? Math.pow(10, 3) : Math.pow(2, 10);
         const abbreviations = unit === 'SI' ?
             ['Bytes', 'kB', 'MB', 'GB', 'TB', 'PB', 'EB', 'ZB', 'YB'] :
             ['Bytes', 'KiB', 'MiB', 'GiB', 'TiB', 'PiB', 'EiB', 'ZiB', 'YiB'];
         const i = Math.floor(Math.log(bytes) / Math.log(orderOfMagnitude));
         return parseFloat((bytes / Math.pow(orderOfMagnitude, i)).toFixed(3).substring(0, 4)) + ' ' + abbreviations[i];
      function getUnifiImage(deviceModel: string): string {
         // For unifi devices, there is no 'note' where an image information can be stored, but we have the
         // device 'model' that provides enough information for the choice of the correct image.
         // The images themselves are on your network, hosted by the UniFi controller for its devices grid view.
         // Example for my 3 device models (extract using developer console: see backround-image of element):
         //  * US16P150: https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/usw/US16/grid.png
         //  * U7LT:     https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/uap/default/grid.png
         //  * UGW3:     https://10.10.10.5:8443/manage/angular/g7989b19/images/devices/ugw/UGW3/grid.png
         // From the divice model we need some insight to get to the image URL, this is provided by the app.css
         // of the Unifi Controller (I used mine with version 5.13.29)
         // Following list is obtained with some reverse engeeniring: downloaded minified app.css, reformatted code with Phpstorm, then regex-replace: "\.unifiDeviceIcon--([^.]+)\.is-grid[^{]+\{\s+background-image: url\("\.\./images/devices/([^"]+)grid\.png\"\)" with "deviceModel['$1'] = '$2';", ant then some additional parsing ..
         const unifiControllerimagesPaths = {BZ2: 'uap/BZ2', BZ2LR: 'uap/BZ2', p2N: 'uap/p2N', U2HSR: 'uap/U2HSR', U2IW: 'uap/U2IW', U2L48: 'uap/BZ2', U2Lv2: 'uap/BZ2', U2M: 'uap/default', U2O: 'uap/U2O', U2S48: 'uap/BZ2', U2Sv2: 'uap/BZ2', U5O: 'uap/U2O', U7E: 'uap/U7E', U7EDU: 'uap/U7EDU', U7Ev2: 'uap/U7E', U7HD: 'uap/default', U7IW: 'uap/U7IW', U7IWP: 'uap/U7IW', U7LR: 'uap/default', U7LT: 'uap/default', U7MP: 'uap/U7O', U7MSH: 'uap/U7MSH', U7NHD: 'uap/U7NHD', U7O: 'uap/U7O', UFLHD: 'uap/UFLHD', U7P: 'uap/default', U7PG2: 'uap/default', U7SHD: 'uap/default', UCMSH: 'uap/default', UCXG: 'uap/default', UHDIW: 'uap/U7IW', ULTE: 'uap/ULTE', UXSDM: 'uap/UXSDM', UXBSDM: 'uap/UXBSDM', UDMB: 'uap/UDMB', UP1: 'uap/UP1', UBB: 'ubb/UBB', UGW3: 'ugw/UGW3', UGW4: 'ugw/UGW4', UGWXG: 'ugw/UGWXG', S216150: 'usw/US16', S224250: 'usw/US24', S224500: 'usw/US24', S248500: 'usw/US48', S248750: 'usw/US48', S28150: 'usw/US8P150', UDC48X6: 'usw/UDC48X6', US16P150: 'usw/US16', US24: 'usw/US24', US24P250: 'usw/US24', US24P500: 'usw/US24', US24PL2: 'usw/US24', US24PRO: 'usw/US24PRO', US24PRO2: 'usw/US24PRO2', US48: 'usw/US48', US48P500: 'usw/US48', US48P750: 'usw/US48', US48PL2: 'usw/US48', US48PRO: 'usw/US48PRO', US48PRO2: 'usw/US48PRO2', US6XG150: 'usw/US6XG150', US8: 'usw/US8', US8P150: 'usw/US8P150', US8P60: 'usw/US8P60', USC8: 'usw/US8', USC8P450: 'usw/USC8P450', USF5P: 'usw/USF5P', USXG: 'usw/USXG', USL8LP: 'usw/USL8LP', USL16LP: 'usw/USL16LP', USL16P: 'usw/USL16P', USL24: 'usw/USL24', USL48: 'usw/USL48', USL24P: 'usw/USL24P', USL48P: 'usw/USL48P', USMINI: 'usw/USMINI', USPRPS: 'usw/USPRPS', UAS: 'uas/UAS', UCK: 'uas/UCK', UCKG2: 'uas/UCKG2', UCKP: 'uas/UCKP', UMAD: 'ua/UMAD', UDM: 'udm/UDM', 'UDM-UAP': 'udm/UDM-UAP', 'UDM-USW': 'udm/UDM-USW', 'UDM-UGW': 'udm/UDM-UGW', UDMSE: 'udm/UDMSE', 'UDMSE-UAP': 'udm/UDM-UAP', 'UDMSE-USW': 'udm/UDM-USW', 'UDMSE-UGW': 'udm/UDM-UGW', UDMPRO: 'udm/UDMPRO', 'UDMPRO-USW': 'udm/UDMPRO-USW', 'UDMPRO-UGW': 'udm/UDMPRO-UGW'};
         // If prefix set to null return the 'lan_noImage.png' for all devices, if set to false return '<device model>.png'
         if (!unifiImagesUrlPrefix) {
             return imagesPath + (unifiImagesUrlPrefix === null ? 'lan_noImage' : deviceModel) + '.png';
         return unifiImagesUrlPrefix + unifiControllerimagesPaths[deviceModel] + '/grid.png';
      /** Global functions ********************************************************************************/
      // My global functions for state and listener initialization
      // see doc https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#global-functions
      const resetStatesOnReload = false; // Enable only when actively developing
      let statesInitializing = 0; // Semaphore for runAfterInitialization, handled by initializeState
      // Helper function for states setup
      function runAfterInitialization(callback) {
         log(`States initializing: ${statesInitializing}`, 'silly');
         if (statesInitializing <= 0) {
             callback();
             return;
         // Important: use timout instead of wait!
         setTimeout(() => runAfterInitialization(callback), 100);
      function initializeState(stateId, defaultValue, common, listenerChangeType?: string, listenerCallback?: CallableFunction) {
         const registerListener = () => {
             if (listenerChangeType) {
                 // Register listener only after all states are initialized
                     on(stateId, listenerChangeType, listenerCallback);
                     log(`Registered listener on ${stateId}`, 'debug');
         const myCreateState = () => {
             statesInitializing++;
             log(`myCreateState: increased states initializing: ${statesInitializing}`, 'silly');
             createState(stateId, defaultValue , common, () => {
                 log(`Created state ${stateId}`, 'debug');
                 registerListener();
                 statesInitializing--;
                 log(`myCreateState: reduced states initializing: ${statesInitializing}`, 'silly');
         const resetState = () => {
             log(`resetState: increased states initializing: ${statesInitializing}`, 'silly');
             deleteState(stateId, () => {
                 log(`Deleted state ${stateId}`, 'debug');
                 myCreateState();
                 log(`resetState: reduced states initializing: ${statesInitializing}`, 'silly');
         if (!existsState(stateId)) {
             myCreateState();
         } else if (resetStatesOnReload) {
             resetState();
         } else {
             registerListener();
      function getStateIfExists(stateId) {
         // Avoid warning when state does not exists
             return null;
         return getState(stateId);
      function getStateValue(stateId) {
         return (getStateIfExists(stateId) || {}).val || null;
      • qqolli
        qqolli @Scrounger last edited by
        @scrounger
        habe mir das Skript gerade installier, läuft soweit auch super, bis auf die u. g. Meldungen:
        javascript.0	2021-02-26 07:46:00.130	error	(18767) script.js.Olli.Unifi_Netzwerk: Keller Flur Regal (ip: 192.168.178.34, mac: unifi.0.default.clients.e4:ff:a1:13:a7:de): Unexpected token S in JSON at position 0
        javascript.0	2021-02-26 07:46:00.129	error	(18767) script.js.Olli.Unifi_Netzwerk: Echo Dot 1 (ip: 192.168.178.63, mac: unifi.0.default.clients.f4:02:2b:d1:37:7c): Unexpected end of JSON input
        javascript.0	2021-02-26 07:46:00.127	error	(18767) script.js.Olli.Unifi_Netzwerk: Echo Dot 2 (ip: 192.168.178.32, mac: unifi.0.default.clients.fe:f0:a4:c4:d2:01): Unexpected end of JSON input
        javascript.0	2021-02-26 07:46:00.125	error	(18767) script.js.Olli.Unifi_Netzwerk: Xiaomi 1 (ip: 192.168.178.26, mac: unifi.0.default.clients.ec:de:6f:c5:b2:ed): Unexpected end of JSON input
        javascript.0	2021-02-26 07:46:00.124	error	(18767) script.js.Olli.Unifi_Netzwerk: EG Wohnzimmer Sonos (ip: 192.168.178.68, mac: unifi.0.default.clients.ee:77:03:c2:43:1a): Unexpected token S in JSON at position 0
        javascript.0	2021-02-26 07:46:00.123	error	(18767) script.js.Olli.Unifi_Netzwerk: Sonoff P1_2 (ip: 192.168.178.66, mac: unifi.0.default.clients.e5:9e:01:c4:2a:25): Unexpected token S in JSON at position 0
        javascript.0	2021-02-26 07:46:00.122	error	(18767) script.js.Olli.Unifi_Netzwerk: Sonoff P1_1 (ip: 192.168.178.39, mac: unifi.0.default.clients.f0:98:0e:f4:e3:62): Unexpected token S in JSON at position 0
        javascript.0	2021-02-26 07:46:00.121	error	(18767) script.js.Olli.Unifi_Netzwerk: Echo Dot 3 (ip: 192.168.178.71, mac: unifi.0.default.clients.dc:9b:bf:66:e4:7a): Unexpected end of JSON input
        javascript.0	2021-02-26 07:46:00.118	error	(18767) script.js.Olli.Unifi_Netzwerk: Kühltruhe (ip: 192.168.178.30, mac: unifi.0.default.clients.dd:e1:2b:e5:ec:7c): Unexpected token S in JSON at position 0
        Woran könnte das liegen?
        qqolli 1 Reply Last reply Reply Quote 0
          ps1304 @Scrounger last edited by
          @scrounger evtl. hast du nen schnellen Tipp. Skript angelegt als JS, Datenpunkte wurden vom Script angelegt - View "List" importiert, leider ist die Liste der Geräte leer?
          Und was hat es mit der View "Devices" auf sich - da bekomme ich den Fehler "selected URL not found" - was sollte man da angeben?
          Gruß Peter
          • qqolli
            qqolli @qqolli last edited by
            @qqolli @Scrounger
            da es schon eine weile her ist, nochmal die Frage ob Du vlt. eine Idee hast, woran es liegen könnte?
            • N
              nousefor82 last edited by nousefor82
              bei mir klappt es soweit mit der View.
              Das mit den Bildern habe ich nicht verstanden; sind aber aktuell auch nicht wichtig. Wenn man das direkt vom controller übernehmen könnte, wäre das natürlich spitze, denn hier sind die Bilder hinterlegt.
              Ich bekomme jedoch folgenden Fehler ausgespuckt:
              16:29:00.092	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: DLAN Adapter (ip: 192.168.188.27, mac: unifi.0.default.clients.00:1a:22:07:e1:84): Unexpected end of JSON input
              16:29:00.092	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: Yamaha RX-V773 (ip: 192.168.188.11, mac: unifi.0.default.clients.00:a0:de:93:d3:0d): Unexpected end of JSON input
              16:29:00.094	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: Show 5 Studio (ip: 192.168.188.18, mac: unifi.0.default.clients.1c:4d:66:d8:fa:3a): Unexpected end of JSON input
              16:29:00.094	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: Sonos Beam (ip: 192.168.188.72, mac: unifi.0.default.clients.34:7e:5c:82:73:36): Unexpected end of JSON input
              16:29:00.097	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: Shelly Studio Licht (ip: 192.168.188.70, mac: unifi.0.default.clients.84:f3:eb:32:c8:58): Unexpected end of JSON input
              16:29:00.098	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: Tedee (ip: 192.168.188.24, mac: unifi.0.default.clients.90:e2:02:8b:11:46): Unexpected end of JSON input
              16:29:00.100	error	javascript.0 (8648) script.js.common.Netzwerk.Unifi-Clients: IoBroker (ip: 192.168.188.120, mac: unifi.0.default.clients.f8:63:3f:0c:61:ba): Unexpected end of JSON input
              @Scrounger Kannst du mir sagen, was muss ich tun, um das Problem zu lösen?
              Vielen Dank!!
              • qqolli
                qqolli @nousefor82 last edited by
                @nousefor82
                habe die gleichen Fehlermeldungen (s. weiter oben). Aber bisher hat er nicht geantwortet, leider ...
                  ps1304 @qqolli last edited by
                  @qqolli @cdellasanta
                  bei mir waren dieser Fehler wohl aufgrund eines falschen Zeichens bei "Anmerkung" der einzelnen Geräte im Unif Controller!!
                  das funktioniert bei mir:
                  "image": "Switch"
                  das Bild natürlich abändern auf Deine Bezeichnung
                  die Bilder der Unifi Geräte habe ich wie folgt gelöst:
                  im Script: const unifiImagesUrlPrefix = false; //Use '<device model>.png' from your imagesPath
                  das Model habe ich mit dem Unifi Browser ausgelesen; U-AP-Pro z.Bsp: U7PG2 - mein Image lautet dann U7PG2.png im image Pfad, das Model sieht man leider nicht im Unifi Controller :-((
                  Was hat es mit der optionalen View auf sich ? Link funktionert bei mir leider nicht.
                  Also ich habe bei der Fritzbox unter "Anmerkung" hinterlegt:
                  "image": "FB6591",
                  "link": "http"
                  in der View wird mir der Link angeboten - passiert aber nichts.
                  Gruß Peter
                  Frank Zoellner 1 Reply Last reply Reply Quote 0
                    mguenther last edited by mguenther
                    ich blicke irgendwie nichts mehr. Ich habe ein Unifi Netzwerk und wollte mir das in der VIS anzeigen lassen. Dazu muss ich hier aus dem Thread (es gibt inzwischen zig Skripte - alle erzeugen massive Warning/ Fehler Einträge) ein Skript kopieren, anpassen und ausführen. Welches Skript denn nun? und was muss ich da anpassen? Muss ich nur die 3 Datenpunkte unter userdata anlegen?
                    0_userdata.0.VIS.NetzwerkDevicesStatus
                    0_userdata.0.VIS.NetzwerkDevicesStatus.jsonList
                    0_userdata.0.VIS.NetzwerkDevicesStatus.sortMode
                    Ich nutze Unifi Adapter 0.5.10.
                    was muss ich wie einstellen? Ich habe die UDM PRO und welchen Port hat da z.B. der Controler? 8443?
                    Und wo muss ich für die VIEW unter Version UDM Pro 1.11.0, Network 6.5.55 die icon Einstellungen hinterlegen? Ich finde irgendwie diese Felder bei meiner UDM Pro so nicht...
                    Marcus
                    • Ullulaki
                      Ullulaki last edited by
                      @qqolli sagte in Material Design Widgets: UniFi Netzwerk Status:
                      @nousefor82
                      Auch wenn schon ein wenig her: ich hatte heute beim implementieren der Übersicht dieselben Bugs bei einigen Geräten, obwohl ich im Unifi-Controller bei den Geräten noch nichts eingetragen habe.
                      Meine Lösung: einfach in den im Log auftauchenden Devices im Unifi-Controller unter Anmerkungen die Bilder hinterlegen, dann verschwinden die Meldungen.
                      Ich glaube, es ging auch mit folgenden "Dummy"-Werten, aber nicht mehr ganz sicher:
                          "image": "",
                         "link": ""
                      Wollte das just noch einmal testen bei den bei mir betroffenen Geräten, also Code unter "Anmerkungen" im Controller entfernt - die Fehler tauchen aber nicht wieder auf 😠 😂
                      • N
                        nerg last edited by
                        Ich fände es mega, in die Übersicht noch für jedes DEvice einen reconnect Knopf analog zur Unifi-App aufzunehmen.
                        Die Funktion müsste -in etwa!- so aussehen:
                        const unifi = require('node-unifi');
                        const controller = new unifi.Controller({host: '192.168.xx', port: 443, sslverify: false});
                        // LOGIN
                        function reconnectMacID(macID) {
                            controller.login('userMitEntsprechenderBerechtigung', 'password')
                            .then(result => {
                                console.log('login: ' + JSON.stringify(result));
                                console.log('MacID in der Function: ' + macID);
                                return controller.reconnectClient(macID);
                            // Reconnect Infos
                            .then(result => {
                                console.log('Ergebnis: ' + JSON.stringify(result) + result);
                                return controller.logout();
                            // LOGOUT
                            .then(result => {
                                console.log('logout: ' + JSON.stringify(result));
                            .catch(error => {
                                console.log('ERROR: ' + error);
                        Weiß jemand, was zu tun wäre, um das unterzubringen?
                        • Frank Zoellner
                          Frank Zoellner @ps1304 last edited by
                          Hallo Leute,
                          irgendwie Blicke ich das mit den Bildern für die Devices nicht. ich habe diesen Thread durchstöbert aber irgendwie weis ich nicht genau was man nun machen sollte.
                          Script ist das was im Git im ersten Post zur Verfügung steht.
                          Unifi Controller Version 7.2.92
                          Adapter Version 0.6.1
                          Zum einen wird von Anmerkungen im Unifizierter Controller (?) gesprochen, bei mir finde ich da nichts. Ich kann dem Device ein Icon aus einer Liste im Unifizierter Controller zuweisen.
                          ich vermute das es sich hierbei um die Zuordnung Bild zu Device gehen soll...?
                          Dann gibt es im Script nur einen Pfad auf ein Verzeichnis wo man Bilder hinterlegt, also müsste ich die Icons dann manuell da hinlegen?
                          • Q
                            quorle last edited by
                            Also bei mir funktioniert das mit den Bildern überhaupt nicht. Und die Liste für die Netzwerkdevices (verbundene Geräte) wird gar nicht erstellt.
                              ps1304 @Frank Zoellner last edited by
                              @frank-zoellner Als im Unifi Controller musst das Bild hinterlegen bei jedem Device in Konfiguration - Zahnrad oben rechts
                              Eintrag wie folgt:
                              "image": "FB6690"
                              wobei dann das Bild "FB6690.png" i angegeben Pfad des Scripts liegen muß - in meinem Beispiel als Zeile im Script: const imagesPath = '/vis.0/Images/'
                              Also musste ich meine Bilder alle im VIS Editor mit dem Dateimanager
                              in das Verzeichnis aus dem Script legen.
                                Hausbaer last edited by
                                Ich muss dieses relativ alte Thema aufgreifen.
                                Die View will ich etwas anpassen bzw. ergänzen.
                                Da mein Netzwerk aus mehreren AP's bzw. Switches besteht, möchte ich mir anzeigen lassen, an welchen Switch an welchem Port und in welchem VLAN das jeweilige Geräte angeschlossen ist.
                                Das Skript hierzu habe ich soweit angepasst, bekomme die Änderung aber nicht in die View
                                • Listings for UniFi devices (to use with Material Design Widgets)
                                • Requirements:
                                  • UniFi controller running on your network
                                  • UniFi ioBroker adapter >= 0.5.8 (https://www.npmjs.com/package/iobroker.unifi)
                                  • Libraries on ioBroker
                                  • Some programming skills
                                • @license http://www.opensource.org/licenses/mit-license.html MIT License
                                • @author Scrounger Scrounger@gmx.net
                                • @author web4wasch @WEB4WASCH
                                • @author cdellasanta 70055566+cdellasanta@users.noreply.github.com
                                • @link https://forum.iobroker.net/topic/30875/material-design-widgets-unifi-netzwerk-status
                                // Farben aus DP holen//
                                let tuerkis = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-1").val;
                                let steingrau = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-2").val;
                                let weiss = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-3").val;
                                let gruen = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-4").val;
                                let orange = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-5").val;
                                let dunkelgrau = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-8").val;
                                let rot = getState("0_userdata.0.einstellung_farben_schriftarten.farbe-8").val;
                                let hintergrund1 = getState("0_userdata.0.einstellung_farben_schriftarten.hintergrund-1").val;
                                let hintergrund2 = getState("0_userdata.0.einstellung_farben_schriftarten.hintergrund-2").val;
                                // Schriftart aus DP holen//
                                let schrift1= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-1").val; // RobotoCondensed-BoldItalic
                                let schrift2= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-2").val; // RobotoCondensed-Bold
                                let schrift3= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-3").val; // RobotoCondensed-Italic
                                let schrift4= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-4").val; // Comfortaa-Regular
                                let schrift5= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-5").val; // Comfortaa-Bold
                                let schrift6= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-6").val; // Comfortaa-Light
                                let schrift7= getState("0_userdata.0.einstellung_farben_schriftarten.schriftart-7").val; // Pacifico
                                // Schriftgrüße aus DP holen//
                                let groesse12 = getState("0_userdata.0.einstellung_farben_schriftarten.schriftgrosse-4").val;
                                let groesse16 = getState("0_userdata.0.einstellung_farben_schriftarten.schriftgrosse-3").val;
                                let groesse20 = getState("0_userdata.0.einstellung_farben_schriftarten.schriftgrosse-2").val;
                                let groesse22 = getState("0_userdata.0.einstellung_farben_schriftarten.schriftgrosse-1").val;
                                let groesse26 = getState("0_userdata.0.einstellung_farben_schriftarten.schriftgrosse-7").val;
                                // Datenpunkte anlegen falls nicht vorhanden ********************************
                                if ( !existsState("0_userdata.0.it.adapterstatus.jsonList")){createState("0_userdata.0.it.adapterstatus.jsonList", false, {type: 'string'})};
                                if ( !existsState("0_userdata.0.it.adapterstatus.restartTrigger")){createState("0_userdata.0.it.adapterstatus.restartTrigger", false, {type: 'string'})};
                                if ( !existsState("0_userdata.0.it.adapterstatus.sortMode")){createState("0_userdata.0.it.adapterstatus.sortMode", false, {type: 'string'})};
                                if ( !existsState("0_userdata.0.it.adapterstatus.filterMode")){createState("0_userdata.0.it.adapterstatus.filterMode", false, {type: 'string'})};
                                const prefix = '0_userdata.0.it.unifi.networkstate'; // Might be better to use an english prefix (e.g. '0_userdata.0.vis.unifiNetworkState'), but then remember to adapt the Views too
                                const locale = 'de'; // On change make sure you drop all states (delete prefix directory)
                                const updateInterval = 1; // Lists update interval in minutes (modulo on current minutes, therefore more than 30 means once per hour, more than 60 means never)
                                const imagePath = '/vis-2.0/bilder/geraete/'; // Path for images
                                const defaultSortMode = 'name'; // Value for default and reset sort
                                const devicesView = {currentViewState: '0_userdata.0.vis.currentView', devicesViewKey: 1};
                                const speedIconSize = 20;
                                const speedTextSize = 14;
                                const trafficIconSize = 14;
                                const trafficTextSize = 14;
                                const experienceIconSize = 20;
                                const experienceTextSize = 14;
                                const mathjs = require('mathjs');
                                // States are registered automatically if prefix directory does not exists (delete directory to recreate them)
                                setup();
                                // Create lists on script startup
                                createList();
                                // Refresh lists every updateInterval minutes
                                schedule(*/${updateInterval} * * * *, createList);
                                on({id: ${prefix}.sortMode, change: 'any'}, () => { createList(); resetSortTimer(); });
                                on({id: ${prefix}.filterMode, change: 'any'}, () => { createList(); resetFilterTimer(); });
                                if (devicesView) {
                                // On selected device change, go to "Devices" view
                                on({id: ${prefix}.selectedUrl, change: 'any'}, () => { setState(devicesView.currentViewState, devicesView.devicesViewKey); });
                                function createList() {
                                try {
                                let devices = $('[id=unifi.0.default.clients.*.mac]'); // Query every time function is called (for new devices)
                                        let isWired = getState(`${idDevice}.is_wired`).val;
                                		let switchname = getState(`unifi.0.default.devices.${getState(`${idDevice}.sw_mac`).val}.name`).val;
                                	    let network = getState(`${idDevice}.network`).val;
                                		let port = getState(`${idDevice}.sw_port`).val;
                                        let lastSeen = new Date(getState(`${idDevice}.last_seen`).val);
                                        if (isInRange(lastSeen)) {
                                            // Values for both WLAN and LAN
                                            let isConnected = getState(`${idDevice}.is_online`).val;
                                            let ip = existsState(`${idDevice}.ip`) ? getState(`${idDevice}.ip`).val : '';
                                            let mac = idDevice;
                                            let name = getName(idDevice, ip, mac);
                                            let isGuest = getState(`${idDevice}.is_guest`).val;
                                            let experience = (existsState(`${idDevice}.satisfaction`) && isConnected) ? (getState(`${idDevice}.satisfaction`).val || 100) : 0; // For LAN devices I got null as expirience .. file a bug?
                                            let note = parseNote(idDevice, name, mac, ip);
                                            let icon = (note && note.icon) || '';
                                            let listType = 'text';
                                            let buttonLink = '';
                                            setLink();
                                            // Variables for values that are fetched differently depending on device wiring
                                            let receivedRaw = getTraffic(isWired, idDevice)
                                            let received = formatTraffic(receivedRaw).replace('.', ',');
                                            let sentRaw = getTraffic(isWired, idDevice, true);
                                            let sent = formatTraffic(sentRaw).replace('.', ',');
                                            let speed = '';
                                            let uptime = 0;
                                            let image = '';
                                            let wlanSignal = '';
                                            if (isWired) {
                                                let switchPort = getState(`${idDevice}.sw_port`).val;
                                                    continue; // Skip add
                                                speed = getState(`unifi.0.default.devices.${getState(`${idDevice}.sw_mac`).val}.port_table.port_${switchPort}.speed`).val;
                                                uptime = getState(`${idDevice}.uptime_by_usw`).val;
                                                image = (note && note.image) ? `${imagePath}${note.image}.png` : `${imagePath}lan_noImage.png`
                                            } else {
                                                speed = existsState(`${idDevice}.channel`) ? (getState(`${idDevice}.channel`).val > 13) ? '5G' : '2G' : '';
                                                uptime = getState(`${idDevice}.uptime`).val;
                                                wlanSignal = getState(`${idDevice}.signal`).val;
                                                image = (note && note.image) ? `${imagePath}${note.image}.png` : `${imagePath}wlan_noImage.png`
                                            addToList();
                                            function setLink() {
                                                if (note && note.link) {
                                                    listType = 'buttonLink';
                                                    if (note.link === 'http') {
                                                        buttonLink = `http://${ip}`;
                                                    } else if (note.link === 'https') {
                                                        buttonLink = `https://${ip}`;
                                                    } else {
                                                        buttonLink = note.link;
                                            function addToList() {
                                                let statusBarColor = isConnected ? 'gruen' : 'rot';
                                                let text = isGuest ? `<span class="mdi mdi-account-box" style="color: orange;"> ${name}</span>` : name;
                                                let speedElement;
                                                if (speed === 1000 || speed === 100) {
                                                    speedElement = `<div style="display: flex; flex: 1; text-align: left; align-items: center; position: relative;">
        ${getLanSpeed(speed, speedIconSize, isConnected)}
        <span style="color: steingrau; font-family: RobotoCondensed-LightItalic; font-size: ${speedTextSize}px; margin-left: 4px;">${speed.toString().replace('1000', '1.000')} MBit/s</span>
        </div>`
                                                } else {
        ${getWifiStrength(wlanSignal, speedIconSize, isConnected)}
        <span style="color: steingrau; font-family: RobotoCondensed-LightItalic; font-size: ${speedTextSize}px; margin-left: 4px;">${speed}</span>
        </div>`;
                                                let receivedElement = `<span class="mdi mdi-arrow-down" style="font-size: ${trafficIconSize}px; color: #44739e;"></span><span style="color: steingrau; font-family: RobotoCondensed-LightItalic; font-size: ${trafficTextSize}px; margin-left: 2px; margin-right: 4px">${received}</span>`
                                                let sentElement = `<span class="mdi mdi-arrow-up" style="font-size: ${trafficIconSize}px; color: #44739e;"></span><span style="color: steingrau; font-family: RobotoCondensed-LightItalic; font-size: ${trafficTextSize}px; margin-left: 2px;">${sent}</span>`
                                                let experienceElement = `<div style="display: flex; margin-left: 8px; align-items: center;">${getExperience(experience, experienceIconSize, isConnected)}<span style="color: steingrau; font-family: RobotoCondensed-LightItalic; font-size: ${experienceTextSize}px; margin-left: 4px;">${experience} %</span></div>`
                                                let subText = `
                                                            ${ip}
        ${getOnOffTime(isConnected, uptime, lastSeen)}
                                                            </div>
                                                            <div style="display: flex; flex-direction: row; padding-left: 8px; padding-right: 8px; margin-top: 10px; align-items: center;">
        ${speedElement}${receivedElement}${sentElement}${experienceElement}
                                                            </div>
                                                deviceList.push({
                                                    text: text,
                                                    subText: subText,
                                                    listType: listType,
                                                    buttonLink: buttonLink,
                                                    image: image,
                                                    icon: icon,
                                                    statusBarColor: statusBarColor,
                                                    ip: ip,
                                                    network: network,
                                                    switchname: switchname,
                                                    port: port,
                                                    received: receivedRaw,
                                                    sent: sentRaw,
                                                    uptime: uptime,
                                                    isWired: isWired
                                    // Sorting
                                    let sortMode = existsState(`${prefix}.sortMode`) ? getState(`${prefix}.sortMode`).val : defaultSortMode;
                                        switch (sortMode) {
                                            case 'ip':
                                                return na - nb;
                                            case 'network':
                                            case 'switchname':
                                            case 'port':
                                            case 'connected':
                                            case 'received':
                                            case 'sent':
                                            case 'experience':
                                            case 'uptime':
                                            case 'name':
                                            default:
                                                return a['name'].localeCompare(b['name'], locale, {sensitivity: 'base'});
                                    if (devicesView) {
                                        let linkList = [];
                                                linkList.push({
                                                    text: obj.name, /** @todo Add some props (connected, ip, received, sent, experience, ...)? */
                                                    icon: obj.icon
                                                // Change behaviour to buttonState, a listener on the state change on objectId will trigger the jump to that view
                                                obj['objectId'] = `${prefix}.selectedUrl`;
                                        if (existsState(`${prefix}.linksJsonList`) && getState(`${prefix}.linksJsonList`).val !== linkListString) {
                                            setState(`${prefix}.linksJsonList`, linkListString, true);
                                    // Filtering
                                    let filterMode = existsState(`${prefix}.filterMode`) ? getState(`${prefix}.filterMode`).val : '';
                                                case 'connected':
                                                case 'lan':
                                                case 'wlan':
                                                default:
                                    if (existsState(`${prefix}.jsonList`) && getState(`${prefix}.jsonList`).val !== result) {
                                        setState(`${prefix}.jsonList`, result, true);
                                } catch (err) {
                                    console.error(`[createList] error: ${err.message}`);
                                    console.error(`[createList] stack: ${err.stack}`);
                                // Functions **************************************************************************************************************************************
                                function getTraffic(isWired, idDevice, isSent = false) {
                                    if (!isSent) {
                                        // Received
                                        if (isWired) {
                                            if (existsState(`${idDevice}.wired-tx_bytes`)) {
                                                return getState(`${idDevice}.wired-tx_bytes`).val;
                                        } else {
                                            if (existsState(`${idDevice}.tx_bytes`)) {
                                                return getState(`${idDevice}.tx_bytes`).val;
                                    } else {
                                        // Sent
                                        if (isWired) {
                                            if (existsState(`${idDevice}.wired-rx_bytes`)) {
                                                return getState(`${idDevice}.wired-rx_bytes`).val;
                                        } else {
                                            if (existsState(`${idDevice}.rx_bytes`)) {
                                                return getState(`${idDevice}.rx_bytes`).val;
                                    return 0;
                                function formatTraffic(traffic) {
                                    if (traffic > 0) {
                                        traffic = parseFloat(traffic) / 1048576;
                                        if (traffic < 100) {
                                            return `${mathjs.round(traffic, 0)} MB`
                                        } else {
                                            return `${mathjs.round(traffic / 1024, 2)} GB`
                                    return 'N/A';
                                function getName(idDevice, ip, mac) {
                                    let deviceName = '';
                                    if (existsState(`${idDevice}.name`)) {
                                        deviceName = getState(`${idDevice}.name`).val;
                                    if (deviceName === null || deviceName === undefined || deviceName === '') {
                                        if (existsState(`${idDevice}.hostname`)) {
                                            deviceName = getState(`${idDevice}.hostname`).val;
                                        if (ip !== null && ip !== undefined && ip !== '') {
                                            deviceName = ip;
                                        } else {
                                            deviceName = mac;
                                    return deviceName;
                                function isInRange(lastSeen) {
                                    let diff = new Date().getTime() - lastSeen.getTime() * 1000;
                                    return (diff < lastDays * 86400 * 1000) ? true : false;
                                function getWifiStrength(signal, size, isConnected) {
                                    if (!isConnected) {
                                        return `<span class="mdi mdi-wifi-off" style="color: steingrau; font-size: ${size}px"></span>`
                                    if (signal < -70) {
                                        return `<span class="mdi mdi-signal-cellular-1" style="color: rot; font-size: ${size}px"></span>`
                                    } else if (signal >= -70 && signal < -55) {
                                        return `<span class="mdi mdi-signal-cellular-2" style="color: orange; font-size: ${size}px"></span>`
                                    } else {
                                        return `<span class="mdi mdi-signal-cellular-3" style="color: gruen; font-size: ${size}px"></span>`
                                function getLanSpeed(speed, size, isConnected) {
                                    if (!isConnected) {
                                        return `<span class="mdi mdi-network-off" style="color: steingrau; font-size: ${size}px;"></span>`
                                    if (speed === 1000) {
                                        return `<span class="mdi mdi-network" style="color: gruen; font-size: ${size}px;"></span>`
                                    } else {
                                        return `<span class="mdi mdi-network" style="color: orange; font-size: ${size}px;"></span>`
                                function getExperience(experience, size, isConnected) {
                                    let color = 'steingrau';
                                    let icon = 'mdi-speedometer';
                                    if (isConnected) {
                                        if (experience >= 70) {
                                            color = 'gruen';
                                        } else if (experience >= 40) {
                                            color = 'orange';
                                            icon += '-medium';
                                        } else {
                                            color = 'rot';
                                            icon += '-slow';
                                    return `<span class="mdi ${icon}" style="color: ${color}; font-size: ${size}px;"></span>`;
                                function parseNote(idDevice, name, mac, ip) {
                                    try {
                                        if (existsState(`${idDevice}.note`)) {
                                            return JSON.parse(getState(`${idDevice}.note`).val);
                                    } catch (ex) {
                                    return undefined;
                                function getOnOffTime(isConnected, uptime, lastSeen) {
                                    return `<span style="color: steingrau; font-size: ${offlineTextSize}px; line-height: 1.3; font-family: RobotoCondensed-LightItalic;">
                                           </span>`;
                                let sortMode = existsState(${prefix}.sortMode) ? getState(${prefix}.sortMode).val : '';
                                    setTimeout(() => {
                                        if (existsState(`${prefix}.sortMode`) && sortMode === getState(`${prefix}.sortMode`).val) {
                                            setState(`${prefix}.sortMode`, defaultSortMode);
                                    }, sortResetAfter * 1000);
                                let filterMode = existsState(${prefix}.filterMode) ? getState(${prefix}.filterMode).val : '';
                                    setTimeout(() => {
                                        if (existsState(`${prefix}.filterMode`) && filterMode === getState(`${prefix}.filterMode`).val) {
                                            setState(`${prefix}.filterMode`, '');
                                    }, filterResetAfter * 1000);
                                function setup() {
                                relativeTime: {
                                // Create states
                                if (!existsState(prefix)) { // Check on prefix (the directory)
                                    const sortItems = [
                                            value: 'name',
                                            icon: 'sort-alphabetical'
                                            value: 'ip',
                                            text: translate('Network'),
                                            value: 'network'
                                            text: translate('Switch Name'),
                                            value: 'switchname'
                                            text: translate('Port'),
                                            value: 'port'
                                            value: 'connected',
                                            value: 'received',
                                            icon: 'arrow-down'
                                            value: 'sent',
                                            icon: 'arrow-up'
                                            icon: 'speedometer'
                                            value: 'uptime',
                                    const filterItems = [
                                            value: 'connected',
                                            icon: 'network-off'
                                            value: 'lan',
                                            icon: 'network'
                                            value: 'wlan',
                                            icon: 'wifi'
                                    const viewTranslations = {
                                        'Sort by': translate('Sort by'),
                                        'Filter by': translate('Filter by'),
                                        'Device': translate('Device')
                                    createState(`${prefix}.jsonList`, '[]', {name: 'UniFi devices listing: jsonList', type: 'string'});
                                    createState(`${prefix}.sortMode`, defaultSortMode, {name: 'UniFi device listing: sortMode', type: 'string'});
                                    createState(`${prefix}.filterMode`, '', {name: 'UniFi device listing: filterMode', type: 'string'});
                                    createState(`${prefix}.sortersJsonList`, JSON.stringify(sortItems), {name: 'UniFi device listing: sortersJsonList', type: 'string', read: true, write: false});
                                    createState(`${prefix}.filtersJsonList`, JSON.stringify(filterItems), {name: 'UniFi device listing: filtersJsonList', type: 'string', read: true, write: false});
                                    createState(`${prefix}.translations`, JSON.stringify(viewTranslations), {name: 'UniFi device listing: viewTranslations', type: 'string', read: true, write: false});
                                    if (devicesView) {
                                        createState(`${prefix}.linksJsonList`, '[]', {name: 'Device links listing: linksJsonList', type: 'string'});
                                        createState(`${prefix}.selectedUrl`, '', {name: 'Selected device link: selectedUrl', type: 'string'});
                                // Sort items
                                // Filter Items
                                'LAN connection': {de: 'LAN Verbindungen', ru: 'подключение по локальной сети', pt: 'conexão LAN', nl: 'lAN-verbinding', fr: 'connexion LAN', it: 'connessione LAN', es: 'coneccion LAN', pl: 'Połączenie LAN','zh-cn': '局域网连接'},
                                'WLAN connection': {de: 'WLAN Verbindungen', ru: 'Соединение WLAN', pt: 'Conexão WLAN', nl: 'WLAN-verbinding', fr: 'Connexion WLAN', it: 'Connessione WLAN', es: 'Conexión WLAN', pl: 'Połączenie WLAN','zh-cn': 'WLAN连接'},
                                // On/off times
                                // Relative times
                                'an hour': {de: 'eine Stunde', ru: 'час', pt: 'uma hora', nl: 'een uur', fr: 'une heure', it: 'un'ora', es: 'una hora', pl: 'godzina','zh-cn': '一小时'},
                                return (map[enText] || {})[locale] || enText;
                                Angezeigt soll im Bereich der roten Linie folgendes werden:
                                network | switchname | port
                                Wo muss ich das im Skript anpassen?
                                • Nashra
                                  Hallo, muß diesen alten Thread nochmal hochziehen aber seit einiger Zeit habe ich Darstellungsfehler
                                  mit dem Skript. @cdellasanta hat zwar damals schon korrigiert aber mittlerweile und nach etlichen
                                  Update seitens Unifi wird es nicht mehr richtig angezeigt.
                                  Wäre toll wenn jemand von den Profis sich vielleicht mal das alte Skript anschaut und den Fehler beheben kann.
                                  Vielen Dank
                                  * Requirements:
                                  const lastDays = 7;       // 7 Show devices that have been seen in the network within the last X days
                                  const defaultSortMode = 'ip'; // Value for default and reset sort
                                  const imagesPath = '/vis.0/Desktop/Unifi-Alias/'; // Path for images
                                  //const unifiImagesUrlPrefix = 'https://<your-controller-ip-or-host>:<controller-port>/manage/angular/g7989b19/images/devices/';
                                  //const unifiImagesUrlPrefix = 'https://192.168.1.15/app-assets/network/angular/gf2f1a60/images/devices/';
                                  //const unifiImagesUrlPrefix =  'https://192.168.1.15/manage/angular/g7989b19/images/devices/';
                                  //const unifiImagesUrlPrefix = null; // Use the 'lan_noImage.png' for all devices
                                     none: {
                                         color: 'grey',
                                     good: {
                                         color: 'green',
                                     low: {
                                         color: '#ff9800',
                                     bad: {
                                         color: 'FireBrick',
                                  if (devicesView) {
                                     initializeState(`${statePrefix}.linksJsonList`, '[]', {name: 'Device links listing: linksJsonList', type: 'string'});
                                     initializeState(`${statePrefix}.selectedUrl`, '', {name: 'Selected device link: selectedUrl', type: 'string'}, 'any', () => { setState(devicesView.currentViewState, devicesView.devicesViewKey); }); // On selected device change, go to "Devices" view
                                     setup();
                                     setTimeLocale();
                                     setSortItems();
                                     setFilterItems();
                                     // Fill lists
                                         try {
                                         } catch (ex) {
                                         return {};
                                     try {
                                                 continue;
                                                 continue;
                                                 <span style="color: gray; font-family: RobotoCondensed-LightItalic; font-size: ${infoTextSize}px; margin-left: 2px;">${text}</span>
                                                 </span>`;
                                             if (unifiDevice) {
                                             } else {
                                                 let speedText = '';
                                                 if (isWired) {
                                                 } else {
                                             deviceList.push({
                                                 subText: `
                                                     ${ip}
                                                         <span style="color: gray; font-size: ${offlineTextSize}px; line-height: 1.3; font-family: RobotoCondensed-LightItalic;">
                                                         </span>
                                                     </div>
                                                         </div>
                                                         </div>
                                                     </div>
                                                 ip: ip,
                                                 received: received,
                                                 sent: sent,
                                                 uptime: uptime,
                                                 isWired: isWired,
                                         // Sorting
                                             switch (sortMode) {
                                                 case 'ip':
                                                     return na - nb;
                                                 case 'connected':
                                                 case 'received':
                                                 case 'sent':
                                                 case 'experience':
                                                 case 'uptime':
                                                 case 'name':
                                                 default:
                                         if (devicesView) {
                                             let linkList = [];
                                                     linkList.push({
                                                         text: obj.name,
                                                         icon: obj.icon
                                         // Filtering
                                                     case 'connected':
                                                     case 'lan':
                                                     case 'wlan':
                                                     case 'unifi':
                                                     default:
                                     } catch (err) {
                                  let sortTimeoutID;
                                         this.clearTimeout(sortTimeoutID); // If set then clear previous timer
                                         sortTimeoutID = this.setTimeout(() => setState(`${statePrefix}.sortMode`, defaultSortMode), sortResetAfter * 1000);
                                         this.clearTimeout(filterTimeoutID); // If set then clear previous timer
                                         filterTimeoutID = this.setTimeout(() => setState(`${statePrefix}.filterMode`, ''), filterResetAfter * 1000);
                                         relativeTime: {
                                     setState(
                                         JSON.stringify([
                                                 value: 'name',
                                                 value: 'ip',
                                                 value: 'connected',
                                                 value: 'received',
                                                 icon: 'arrow-down'
                                                 value: 'sent',
                                                 icon: 'arrow-up'
                                                 icon: 'speedometer'
                                                 value: 'uptime',
                                         true
                                     setState(
                                         JSON.stringify([
                                                 value: 'connected',
                                                 icon: 'network-off'
                                                 value: 'lan',
                                                 icon: 'network'
                                                 value: 'wlan',
                                                 icon: 'wifi'
                                                 value: 'unifi',
                                         true
                                     setState(
                                         JSON.stringify([
                                             'Sort by',
                                             'Filter by',
                                             'Device'
                                         true
                                         // Sort items
                                         // Filter Items
                                         // On/off times
                                         // Relative times
                                         callback();
                                         return;
                                     this.setTimeout(() => runAfterInitialization(callback), 100);
                                             registerListener();
                                             myCreateState();
                                         myCreateState();
                                         resetState();
                                     } else {
                                         registerListener();
                                         return null;
                                    StefanRS last edited by
                                    ich kann leider auch keine BIlder anlegen. Haben die Unifi Controller Ver.9.0.108. Und bei mir gibt es das Feld "Anmerkung" gar nicht mehr.
                                    Muss ich bei dem Unifi Controller noch eine Funktion unter Einstellungen aktivieren?
                                    iconlist material design widgets statusanzeige unifi vis
                                    31
                                    109
                                    17952
