    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. [gelöst] Proxmox Zigbee Permisson denied
      MCU @Thomas Braun last edited by
      Jetzt kommen diese Meldungen.
      zigbee.0
      2022-07-03 12:53:54.407	error	Error herdsman start
      zigbee.0
      2022-07-03 12:53:54.406	error	Failed to start Zigbee
      zigbee.0
      2022-07-03 12:53:54.406	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2022-07-03 12:53:44.340	error	Failed to start Zigbee
      zigbee.0
      2022-07-03 12:53:44.340	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      2022-07-03 12:53:44.309	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      2022-07-03 12:53:44.309	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      2022-07-03 12:53:44.309	error	Please update configuration to prevent further issues.
      zigbee.0
      2022-07-03 12:53:44.309	error	- Channel List: configured=11, adapter=11
      zigbee.0
      2022-07-03 12:53:44.309	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0
      2022-07-03 12:53:44.309	error	- Extended PAN ID: configured=77dddddddddddddd, adapter=00124b0024c9b022
      zigbee.0
      2022-07-03 12:53:44.308	error	- PAN ID: configured=6754, adapter=6754
      zigbee.0
      2022-07-03 12:53:44.308	error	Configuration is not consistent with adapter state/backup!
        Thomas Braun Most Active @MCU last edited by
        @mcu sagte in Proxmox Zigbee Permisson denied:
        Musst du übereinander bringen.
          MCU @Thomas Braun last edited by MCU
          @thomas-braun Habs es geändert auf DD...DD
          zigbee.0
          2022-07-03 12:56:03.493	info	Zigbee started
          zigbee.0
          2022-07-03 12:56:03.493	info	Currently no devices.
          zigbee.0
          2022-07-03 12:56:03.482	info	--> transmitPower : normal
          zigbee.0
          2022-07-03 12:56:03.479	info	Unable to disable LED, unsupported function.
          zigbee.0
          2022-07-03 12:56:03.471	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
          Danke für die Unterstützung.
            Man sollte eine individuelle HEX-Zeichenfolge nehmen.
              @thomas-braun Sobald ich es ändere kommt wieder derFehler von oben:
              Wie bring ich die dann übereinander?
                Thomas Braun Most Active @MCU last edited by Thomas Braun
                Trag 00124b0024c9b022 in den Adapter ein.
                Ggf. ändert sich dann aber nochmal die Byte-Folge. Hat mit der Endianess zu tun.
                  @thomas-braun Wo finde ich denn den Adapter?
                    @mcu
                    Da wo du jetzt DDDDDDDDDDDD77 oder sowas drin hast einfach
                    00124b0024c9b022
                    eintragen.
                      @thomas-braun Also mit Adapter ist die PAN ID gemeint. Ok.
                      Vielen Dank.
                        @mcu
                          @thomas-braun Meine Logik dachte, ich müsste es in einem anderen Parameter-Feld eingeben. Hatte nicht an to adapt -> anpassen gedacht.
                            MCU last edited by MCU
                            @thomas-braun Muss leider nochmal nachhaken.
                            Habe jetzt einen priviligierten Container erstellt und versuche Zigbee zu nutzen.
                            Im unpriviligiertem Container läuft es, im priviligiertem nicht?
                            Geprüfte Werte im unpriviligiertem Container
                            prox@iobrokerPROD:~$ ls -l /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
                            crwxrwxrwx 1 nobody nogroup 188, 0 Jul  9 22:04 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
                            Geprüfte Werte im priviligiertem Container
                            prox@iobrokerPRIV:~$ ls -l /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
                            crwxrwxrwx 1 root dialout 188, 0 Jul  9 20:04 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
                            prox@iobrokerPRIV:~$ id iobroker
                            uid=1002(iobroker) gid=1002(iobroker) groups=1002(iobroker),5(tty),20(dialout),29(audio),44(video)
                            Log vom priviligiertem Container
                            zigbee.0
                            2022-07-09 22:19:01.255	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                            zigbee.0
                            2022-07-09 22:17:47.507	error	Error herdsman start
                            zigbee.0
                            2022-07-09 22:17:47.506	error	Failed to start Zigbee
                            zigbee.0
                            2022-07-09 22:17:47.506	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0'"
                            zigbee.0
                            2022-07-09 22:17:47.454	info	Installed Version: iobroker.zigbee@1.7.5
                            zigbee.0
                            2022-07-09 22:17:47.449	info	Starting Zigbee npm ...
                            zigbee.0
                            2022-07-09 22:17:47.448	info	Try to reconnect. 1 attempts left
                            zigbee.0
                            2022-07-09 22:17:37.448	error	Error herdsman start
                            zigbee.0
                            2022-07-09 22:17:37.448	error	Failed to start Zigbee
                            zigbee.0
                            2022-07-09 22:17:37.448	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0'"
                              @mcu
                              Von Containern hab ich nur insofern Ahnung, dass ich weiß:
                              In geraden Wochen wird donnerstags der gelbe geholt, in den ungeraden der graue. Altpapier wird freitags abgeholt.
                                Kochen @MCU last edited by
                                @mcu Kannst du mir sagen, was du in/an der conf umgestellt hast?
                                Ich habe die gleichen Probleme:
                                Container:
                                ls -l /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_xxx-if00-port0
                                ---------- 1 root root 0 Sep 22 13:56 /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_xxx-if00-port0
                                  MCU @Kochen last edited by MCU
                                  @kochen
                                  Wie sieht es denn auf dem Host aus? Und Deine conf? Bei dir scheint es ein Rechte Problem zu geben?
                                    @mcu
                                    Hi, hier die Daten, dabei habe ich mich an diese Anleitung gehalten:
                                    https://www.iobroker.net/#de/documentation/install/proxmox.md
                                    Host
                                    code_textroot@proxmox:~# lsusb
                                    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                    Bus 001 Device 005: ID 8087:07da Intel Corp. Centrino Bluetooth Wireless Transceiver
                                    Bus 001 Device 006: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                    Bus 001 Device 007: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                    root@proxmox:~#
                                    root@proxmox:~# ls -l /dev/bus/usb/001/010
                                    crw-rw-rw- 1 root users 189, 9 Sep 24 20:31 /dev/bus/usb/001/010
                                    root@proxmox:~#
                                    root@proxmox:~# ls /dev/serial/by-id/
                                    usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f266e43a5229ec1184766f7840c9ce8d-if00-port0
                                    root@proxmox:~#
                                    root@proxmox:~# ls -l /dev/ttyACM*
                                    ls: cannot access '/dev/ttyACM*': No such file or directory
                                    root@proxmox:~# ls -l /dev/ttyUSB*
                                    crw-rw-rw- 1 root dialout 188, 0 Sep 24 20:31 /dev/ttyUSB0
                                    root@proxmox:~#
                                     GNU nano 5.4        115.conf *
                                    arch: amd64
                                    cores: 1
                                    features: nesting=1
                                    hostname: ioBroker
                                    memory: 1024
                                    net0: name=eth0,bridge=vmbr0,firewall=1,hwaddr=6E:65:FC:36:43:CB,ip=dhcp,type=veth
                                    ostype: debian
                                    parent: nachIoInstall
                                    rootfs: local-lvm:vm-115-disk-0,size=16G
                                    swap: 1024
                                    unprivileged: 1
                                    lxc.cgroup2.devices.allow: c 189:* rwm
                                    lxc.mount.entry: usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_xxx-if00-port0 dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_xxx-if00-port0 none bind,optional,create=file
                                    lxc.cgroup2.devices.allow: c 188:* rwm
                                    lxc.mount.entry: /dev/ttyUSB0 dev/ttyUSB0 none bind,optional,create=file
                                    [nachIoInstall]
                                    #ioBroker erfolgreich installiert ip 163
                                    arch: amd64
                                    cores: 1
                                    features: nesting=1
                                    hostname: ioBroker
                                    memory: 1024
                                    ostype: debian
                                    parent: vorIOInstall
                                    snaptime: 1664004213
                                    swap: 1024
                                    unprivileged: 1
                                    [vorIOInstall]
                                    #Date, User David updates
                                    arch: amd64
                                    cores: 1
                                    features: nesting=1
                                    hostname: ioBroker
                                    root@proxmox:/etc/pve/lxc# chmod o+rw /dev/ttyUSB*
                                    LXC Container:
                                    david@ioBroker:~$ lsusb
                                    Bus 001 Device 004: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                                    Bus 001 Device 003: ID 046a:0180 Cherry GmbH Strait 3.0
                                    Bus 001 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                    david@ioBroker:~$
                                    david@ioBroker:~$ ls -l /dev
                                    total 0
                                    crw--w---- 1 root   tty     136, 0 Sep 25 13:33 console
                                    lrwxrwxrwx 1 root   root        11 Sep 25 13:33 core -> /proc/kcore
                                    lrwxrwxrwx 1 root   root        13 Sep 25 13:32 fd -> /proc/self/fd
                                    crw-rw-rw- 1 nobody nogroup   1, 7 Sep 25 13:29 full
                                    lrwxrwxrwx 1 root   root        12 Sep 25 13:33 initctl -> /run/initctl
                                    lrwxrwxrwx 1 root   root        28 Sep 25 13:33 log -> /run/systemd/journal/dev-log
                                    drwxrwxrwt 2 nobody nogroup     40 Sep 25 13:32 mqueue
                                    crw-rw-rw- 1 nobody nogroup   1, 3 Sep 25 13:29 null
                                    crw-rw-rw- 1 root   root      5, 2 Sep 25 13:34 ptmx
                                    drwxr-xr-x 2 root   root         0 Sep 25 13:32 pts
                                    crw-rw-rw- 1 nobody nogroup   1, 8 Sep 25 13:29 random
                                    drwxr-xr-x 3 root   root        60 Sep 25 13:32 serial
                                    drwxrwxrwt 2 root   root        40 Sep 25 13:33 shm
                                    lrwxrwxrwx 1 root   root        15 Sep 25 13:32 stderr -> /proc/self/fd/2
                                    lrwxrwxrwx 1 root   root        15 Sep 25 13:32 stdin -> /proc/self/fd/0
                                    lrwxrwxrwx 1 root   root        15 Sep 25 13:32 stdout -> /proc/self/fd/1
                                    crw-rw-rw- 1 nobody nogroup   5, 0 Sep 25 13:29 tty
                                    crw------- 1 david  tty     136, 1 Sep 25 13:34 tty1
                                    crw--w---- 1 root   tty     136, 2 Sep 25 13:33 tty2
                                    crw-rw-rw- 1 nobody nogroup 188, 0 Sep 25 13:29 ttyUSB0
                                    crw-rw-rw- 1 nobody nogroup   1, 9 Sep 25 13:29 urandom
                                    crw-rw-rw- 1 nobody nogroup   1, 5 Sep 25 13:29 zero
                                    david@ioBroker:~$
                                    Zigbee Adapter:
                                    zigbee.0
                                    2022-09-25 13:38:33.445	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                                    zigbee.0
                                    2022-09-25 13:37:25.932	error	Error herdsman start
                                    zigbee.0
                                    2022-09-25 13:37:25.931	error	Failed to start Zigbee
                                    zigbee.0
                                    2022-09-25 13:37:25.930	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                    zigbee.0
                                    2022-09-25 13:37:15.741	error	Error herdsman start
                                    zigbee.0
                                    2022-09-25 13:37:15.740	error	Failed to start Zigbee
                                    zigbee.0
                                    2022-09-25 13:37:15.740	error	Starting zigbee-herdsman problem : "No path provided and failed to auto detect path"
                                    zigbee.0
                                    2022-09-25 13:37:14.925	error	Serial port not selected! Go to settings page.
                                    Irgendwelche Ideen?
                                    Ich versuche es nun schon seit einigen Tagen, aber ohne Erfolg 😞
                                    CrunkFX 1 Reply Last reply Reply Quote 0
                                    • CrunkFX
                                      CrunkFX Forum Testing @Kochen last edited by CrunkFX
                                      @kochen Hi, um dem ganzen Ärger der durch diesen Versuch immer wieder entsteht ein wenig den Wind aus den Segeln zu nehmen empfehle ich ganz stark gerade Leuten die nicht übermäßig viel Proxmox Erfahrung haben einen privilegierten Container anzulegen. Das ist zwar für sicherheitskritische Anwendungen absolut nicht zu empfehlen, solange der iobroker Server aber im lokalen Netzwerk steht und über VPN etc. Erreicht wird ist das m.E. die beste und vor allem stressfreieste Methode.
                                      Um einen unprivilegierten Container zu einem privilegierten zu machen, ist es in Proxmox >6 lediglich notwendig ein Backup zu machen und anschließend über die Funktion wiederherstellen als privilegierten Container wiederherstellen.
                                      Damit werden nun alle USB Geräte im Host automatisch im LXC mit vollen Rechten bereitgestellt.
                                      Bei Fragen stehe ich gerne zur Verfügung.
                                      LG und frohes Schaffen
                                      K I 2 Replies Last reply Reply Quote 0
                                        Kochen @CrunkFX last edited by
                                        @crunkfx ok, danke.
                                        Dann werde ich es mal mit einem privilegierten Container ausprobieren.
                                        Also einfach einen erstellen bzw. aus dem Backup heraus und dann?
                                        Muss noch irgendwas in der Config angepasst werden? Oder was muss ich dann beim Zigbee Adapter einstellen? /dev/ttyUSB0 ?
                                        Viele Grüße
                                        • CrunkFX
                                          @kochen Du musst nach dem Anlegen schauen als was das USB Gerät erkannt wird. Dazu kannst du per
                                          ls /dev
                                          In der Konsole die aktuellen Geräte sehen und auch beim ein/ausstecken den Unterschied.
                                          • I
                                            iThiel @CrunkFX last edited by
                                            @crunkfx bei den Sicherheitsbedenken stimme ich dir zu, allerdings gibt es einen in meinen Augen viel größeren Nachteil im Bezug auf unprivilegierten Containern und ioBroker.
                                            Meines Wissens nach ist es nicht möglich Netzwerkshares direkt einzubinden, was die Nutzung von Adaptern wie Backitup obsolet machen. Natürlich kann ich mein Backupshare für ioBroker direkt in Proxmox einbinden und an den unprivilegierten Container durch zu mounten, allerdings bin ich der Meinung, das gerade bei Backups so wenig "player" wie möglich die Finger drin haben sollten.
                                            zigbee proxmox nuc
                                            3014
