    4. js-controller 4.0.x jetzt für alle User im STABLE!
      Tomk81 @Thomas Braun last edited by
      @thomas-braun said in js-controller 4.0.x jetzt für alle User im STABLE!:
      @tomk81
      Und die anderen Befehle?
      ist lang
      pi@raspberrypi:/opt/iobroker $ iobroker stop
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@4.0.23
      > iobroker.js-controller@4.0.23 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > iobroker.js-controller@4.0.23 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      Successfully migrated 3598 objects to Redis Sets
      object system.licenses created
      object _design/system updated
        "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nRkexjZsWlHEw8X1zho8m5E77JpgFVbxgEh5sAqReG4lu+IKj6Pa+\r\n-----END RSA PRIVATE KEY-----\r\n",
        "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\n/2sK2mrfl4BwsF3k3Y9SCgvezSfde89r+2cWzmQCsagBvg0MPc8N6M61\r\n-----END CERTIFICATE-----\r\n"
      Update certificate defaultPrivate
      The object "system.certificates" was updated successfully.
      Update certificate defaultPublic
      States DB type migrated from "file" to "jsonl"
      Objects DB type migrated from "file" to "jsonl"
      ioBroker configuration updated
      Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker/iobroker-data/objects.json: ENOENT: no such file or directory, lstat '/opt/iobroker/iobroker-data/objects.json.new'. Try direct write as fallback
      > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
      > node scripts/postinstall
      > esbuild@0.11.23 postinstall /opt/iobroker/node_modules/esbuild
      > node install.js
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/acme-v2/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/lie/package.json'
      + iobroker.js-controller@4.0.23
      added 79 packages from 27 contributors, removed 14 packages, updated 13 packages and moved 1 package in 78.336s
      111 packages are looking for funding
        run `npm fund` for details
      pi@raspberrypi:/opt/iobroker $ iobroker update
      Used repository: Stable (default)
      Adapter    "admin"        : 5.3.8    , installed 4.2.2  [Updatable]
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.0 [Updatable]
      Adapter    "ical"         : 1.12.1   , installed 1.12.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "iot"          : 1.11.4   , installed 1.8.24 [Updatable]
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Adapter    "mihome-vacuum": 3.3.1    , installed 2.1.1  [Updatable]
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "shelly"       : 5.3.2    , installed 4.0.7  [Updatable]
      Adapter    "simple-api"   : 2.6.4    , installed 2.6.4
      Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
      Adapter    "terminal"     : 0.2.5    , installed 0.2.5
      Adapter    "trashschedule": 1.4.5    , installed 1.2.0  [Updatable]
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.5  [Updatable]
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "web"          : 4.2.3    , installed 3.3.0  [Updatable]
      Adapter    "zigbee"       : 1.6.18   , installed 1.6.6  [Updatable]
      pi@raspberrypi:/opt/iobroker $ iobroker upgrade
      This upgrade of "vis-inventwo" will introduce the following changes:
      -> 3.3.1:
      Bugfix
      -> 3.3.0:
      New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
      -> 3.2.8:
      JSON-Table: Added text align für headrow, Radiobutton-List: Added Multi-Row/-Column schema (for more details go to the changelog on Github)
      -> 3.2.7:
      Fixed issue that popup not closing on datapoint value
      -> 3.2.6:
      JSON-Table: Color background per line depending on a value [#280], JSON-Table: Default sort of a column [#286], Universal- & Multi-Widget ViewInPopUp: View scrolling [#344], Universal- & Multi-Widget HTTP: Link can be opened in same or new tab [#363], FIXED: JSON-Table now also works if there is only a single object in the data point instead of an array with objects [#319], FIXED: JSON-Table: 10-digit timestamp didn't work [#376]
      Would you like to upgrade vis-inventwo from @3.2.5 to @3.3.1 now? [(y)es, (n)o]: y
      Update vis-inventwo from @3.2.5 to @3.3.1
      Installing iobroker.vis-inventwo@3.3.1... (System call)
      + iobroker.vis-inventwo@3.3.1
      added 2 packages from 2 contributors, removed 1 package and updated 13 packages in 32.064s
      57 packages are looking for funding
      Adapter "system.adapter.vis.0" restarted.
      Adapter "system.adapter.web.0" restarted.
      Update "system.adapter.vis-inventwo.0"
      upload [21] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
      upload [20] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
      upload [19] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
      upload [18] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
      upload [17] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
      upload [16] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
      upload [15] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
      upload [14] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
      upload [13] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
      upload [12] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
      upload [11] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
      upload [10] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
      upload [9] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/Set_new.png Set_new.png image/png
      upload [8] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
      upload [7] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i1_150.png i1_150.png image/png
      upload [6] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
      upload [5] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
      upload [4] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
      upload [3] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
      upload [2] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/inventwo.png inventwo.png image/png
      upload [1] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
      upload [0] vis-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
      This upgrade of "hm-rpc" will at least introduce the following changes:
      -> 1.15.12:
      we now adjust min/max correct if a `SPECIAL` value falls out of range (closes #459)
      -> 1.15.11:
      fallback to old adapter port determination logic (closes #509)
      -> 1.15.10:
      we use our own set of forbidden chars again
      -> 1.15.9:
      fixed handling of `replaceDevice` event
      we have fixed some log messages
      added image of HmIP-SMI55-2
      -> 1.15.8:
      we now ensure, that the `uuid` used for connection is really unique
      -> 1.15.7:
      fixed new devices beeing created as `undefined`
      -> 1.15.6:
      implemented workaround for the RSSI_DEVICE 128 bug if devices connect to HMIP-HAP (fixes #346, #469, #402)
      Would you like to upgrade hm-rpc from @1.15.0 to @1.15.12 now? [(y)es, (n)o]: y
      Update hm-rpc from @1.15.0 to @1.15.12
      Installing iobroker.hm-rpc@1.15.12... (System call)
      + iobroker.hm-rpc@1.15.12
      updated 3 packages in 18.654s
      114 packages are looking for funding
      Update "system.adapter.hm-rpc.0"
      Update "system.adapter.hm-rpc.1"
      upload [256] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/homematic.png homematic.png image/png
      upload [250] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [200] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/137_hmip-fal-c6_thumb.png icons/137_hmip-fal-c6_thumb.png image/png
      upload [150] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/183_hmip-mod-tm_thumb.png icons/183_hmip-mod-tm_thumb.png image/png
      upload [100] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/42_hm-cc-tc_thumb.png icons/42_hm-cc-tc_thumb.png image/png
      upload [90] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/51_hm-sec-sd_thumb.png icons/51_hm-sec-sd_thumb.png image/png
      upload [80] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/59_hmw-io-12-fm_thumb.png icons/59_hmw-io-12-fm_thumb.png image/png
      upload [70] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/69_hm-lc-sw2-dr_thumb.png icons/69_hm-lc-sw2-dr_thumb.png image/png
      upload [60] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/7_hm-lc-bl1-fm_thumb.png icons/7_hm-lc-bl1-fm_thumb.png image/png
      upload [50] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/87_hm-sen-rd-o_thumb.png icons/87_hm-sen-rd-o_thumb.png image/png
      upload [40] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/99_hm-mod-em-8_thumb.png icons/99_hm-mod-em-8_thumb.png image/png
      upload [30] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/OM55_DimmerSwitch_thumb.png icons/OM55_DimmerSwitch_thumb.png image/png
      upload [20] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hb-uni-sen-temp-ds18b20_thumb.png icons/hb-uni-sen-temp-ds18b20_thumb.png image/png
      upload [19] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-dim.png icons/hm-coupling-dim.png image/png
      upload [18] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-group.png icons/hm-coupling-group.png image/png
      upload [17] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-onoff.png icons/hm-coupling-onoff.png image/png
      upload [16] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb-dim.png icons/hm-coupling-rgb-dim.png image/png
      upload [15] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgb.png icons/hm-coupling-rgb.png image/png
      upload [14] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw-dim.png icons/hm-coupling-rgbw-dim.png image/png
      upload [13] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-rgbw.png icons/hm-coupling-rgbw.png image/png
      upload [12] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white-dim.png icons/hm-coupling-white-dim.png image/png
      upload [11] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-coupling-white.png icons/hm-coupling-white.png image/png
      upload [10] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-hue_gateway.png icons/hm-hue_gateway.png image/png
      upload [9] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm-lightify_gateway.png icons/hm-lightify_gateway.png image/png
      upload [8] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hm_resc-win-pcb-sc_thumb.png icons/hm_resc-win-pcb-sc_thumb.png image/png
      upload [7] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/hmip_brc2.png icons/hmip_brc2.png image/png
      upload [6] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/pc.png icons/pc.png image/png
      upload [5] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/removeBackground.js icons/removeBackground.js application/javascript
      upload [4] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/sonos.png icons/sonos.png image/png
      upload [3] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/icons/unknown_device_thumb.png icons/unknown_device_thumb.png image/png
      upload [2] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index.html index.html text/html
      upload [1] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/index_m.html index_m.html text/html
      upload [0] hm-rpc.admin /opt/iobroker/node_modules/iobroker.hm-rpc/admin/words.js words.js application/javascript
      This upgrade of "admin" will at least introduce the following changes:
      -> 5.3.8:
      Changed the datapoint history list
      Added support of swagger adapter
      -> 5.3.7:
      Changed the charts rendering
      -> 5.3.6:
      Corrected the host selector in "add instance" dialog
      corrected display of "null" values, e.g. by time/date
      -> 5.3.5:
      -> 5.3.4:
      Fix some crash cases reported by Sentry
      Corrected user tab
      -> 5.3.3:
      Implemented the objects coloring depends on other states
      -> 5.3.2:
      added Radio Buttons for value2table
      Corrected many GUI errors
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @4.2.2 to @5.3.8 now? [(y)es, (n)o]: y
      Update admin from @4.2.2 to @5.3.8
      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      Installing iobroker.admin@5.3.8... (System call)
      + iobroker.admin@5.3.8
      added 36 packages from 34 contributors and updated 6 packages in 69.098s
      Update "system.adapter.admin.0"
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      host.raspberrypi Adapter "system.adapter.admin.0" is started
      This upgrade of "zigbee" will at least introduce the following changes:
      -> 1.6.18:
      fix pairing mode
      -> 1.6.16:
      admin dep fix
      -> 1.6.15:
      Battery status was changed
      -> 1.6.14:
      Groups were newly revised 2
      -> 1.6.13:
      zh 0.14.xx
      -> 1.6.12:
      -> 1.6.11:
      Some changes for tuya-devices
      Would you like to upgrade zigbee from @1.6.6 to @1.6.18 now? [(y)es, (n)o]: y
      Update zigbee from @1.6.6 to @1.6.18
      host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
      Installing iobroker.zigbee@1.6.18... (System call)
      > @serialport/bindings@9.2.8 install /opt/iobroker/node_modules/@serialport/bindings
      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/@serialport/bindings/build'
        CXX(target) Release/obj.target/bindings/src/serialport.o
        CXX(target) Release/obj.target/bindings/src/serialport_unix.o
        CXX(target) Release/obj.target/bindings/src/poller.o
        CXX(target) Release/obj.target/bindings/src/serialport_linux.o
        SOLINK_MODULE(target) Release/obj.target/bindings.node
        COPY Release/bindings.node
      make: Leaving directory '/opt/iobroker/node_modules/@serialport/bindings/build'
      + iobroker.zigbee@1.6.18
      added 11 packages from 22 contributors, removed 5 packages, updated 8 packages and moved 1 package in 46.568s
      108 packages are looking for funding
      Update "system.adapter.zigbee.0"
      upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
      upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
      upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion_a.png img/bitron_motion_a.png image/png
      upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1ht.png img/hs1ht.png image/png
      upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_air-sensor.png img/lifecontrol_air-sensor.png image/png
      upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_ensis.png img/philips_ensis.png image/png
      upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_2.png img/philips_hue_argenta_2.png image/png
      upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_fuzo.png img/philips_hue_fuzo.png image/png
      upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwo001.png img/philips_hue_lwo001.png image/png
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/q-flag_led_panel.png img/q-flag_led_panel.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_switch_aq2.png img/sensor_switch_aq2.png image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smoke.png img/smoke.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_RH3052.png img/tuya_RH3052.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
      host.raspberrypi Adapter "system.adapter.zigbee.0" is started
      This upgrade of "web" will at least introduce the following changes:
      -> 4.2.3:
      Updated ws and socketio to have `log` method in sockets
      -> 4.2.2:
      -> 4.2.1:
      Provide state and object changes for simple-api
      -> 4.2.0:
      Updated ws to fix the flot editor
      -> 4.1.6:
      Prevent some potential crash cases on adapter stop
      -> 4.1.5:
      Updated ws and socket-io
      -> 4.1.4:
      Added debug output for white list
      Logout button will be hidden if basic authentication enabled. As logout not possible with basic authentication.
      Would you like to upgrade web from @3.3.0 to @4.2.3 now? [(y)es, (n)o]: y
      Update web from @3.3.0 to @4.2.3
      host.raspberrypi Adapter "system.adapter.web.0" is stopped.
      Installing iobroker.web@4.2.3... (System call)
      + iobroker.web@4.2.3
      added 38 packages from 35 contributors, removed 2 packages and updated 4 packages in 23.443s
      117 packages are looking for funding
      upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
      Update "system.adapter.web.0"
      upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
      upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
      upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.3f8d124d.chunk.js static/js/2.3f8d124d.chunk.js application/javascript
      upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.3f8d124d.chunk.js.LICENSE.txt static/js/2.3f8d124d.chunk.js.LICENSE.txt text/plain
      upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.3f8d124d.chunk.js.map static/js/2.3f8d124d.chunk.js.map application/json
      upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.8f46bdf1.chunk.js static/js/main.8f46bdf1.chunk.js application/javascript
      upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.8f46bdf1.chunk.js.map static/js/main.8f46bdf1.chunk.js.map application/json
      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
      host.raspberrypi Adapter "system.adapter.web.0" is started
      This upgrade of "trashschedule" will at least introduce the following changes:
      -> 1.4.5:
      Allow spaces in next text seperator
      -> 1.4.4:
      Updated dependencies
      -> 1.4.3:
      Updated state roles
      Added hint for Admin 4 configuration
      -> 1.4.2:
      Added check for ical configuration
      -> 1.4.1:
      -> 1.4.0:
      Allow to hide "not found" warnings for single trash types (like christmas tree pickup)
      Added limit option for VIS widget
      Added option for VIS widget to hide the name
      -> 1.3.6:
      Require new version for translated instance objects
      Fixed timeout issues
      Would you like to upgrade trashschedule from @1.2.0 to @1.4.5 now? [(y)es, (n)o]: y
      Update trashschedule from @1.2.0 to @1.4.5
      Installing iobroker.trashschedule@1.4.5... (System call)
      + iobroker.trashschedule@1.4.5
      updated 3 packages in 18.803s
      Update "system.adapter.trashschedule.0"
      upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [11] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [10] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [9] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [8] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [7] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [6] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [4] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [3] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
      upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
      This upgrade of "shelly" will at least introduce the following changes:
      -> 5.3.2:
      Added cover position status for generation 2 devices
      Added cover power, voltage, current and energy for generation 2 devices
      Updated switch roles for material ui (switch.power to switch)
      -> 5.3.1:
      Don't ack new values directly after change
      -> 5.3.0:
      Added Shelly Plus I4
      Added more objects for power metering channels (current, voltage, limits, ...)
      Moved device temperature of generation 2 devices to relays (this is the official way)
      Added Sys channel (eco mode, timezone, ...) for generation 1 devices
      Fixed datatype error of Shelly 1/PM ext switch
      Added option to enable/disable WiFi access point (generation 2 devices)
      Added power limits and position control for covers (generation 2 devices)
      Removed colors for online state indication on device objects
      -> 5.2.0:
      Added Shelly Pro 1
      Added Shelly Pro 1 PM
      Added Shelly Pro 2
      Added Shelly Pro 2 PM
      Added Shelly Plus 2 PM
      Allow to change device and channel names of generation 2 devices
      Added auto on/off timers for generation 2 devices
      Added input mode, events and initial state for generation 2 devices
      Added support of covers / shutters for generation 2 devices
      Replaced node-fetch with axios (also for digest auth)
      -> 5.1.3:
      Changed common.states strings to objects
      Just perform firmware update if an available update was detected
      Extended logging for CoAP
      -> 5.1.2:
      Fixed Shelly UNI ADC voltage
      Fixed dimmer brightness values handling
      Logging improvements for offline devices
      -> 5.1.1:
      Fixed firmware auto update
      Updated timeouts
      Added command source for shelly 2.5
      Added color for device objects as online indicator
      Would you like to upgrade shelly from @4.0.7 to @5.3.2 now? [(y)es, (n)o]: y
      Update shelly from @4.0.7 to @5.3.2
      Installing iobroker.shelly@5.3.2... (System call)
      + iobroker.shelly@5.3.2
      added 21 packages from 65 contributors, removed 23 packages and updated 7 packages in 21.386s
      118 packages are looking for funding
      Update "system.adapter.shelly.0"
      upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      This upgrade of "mihome-vacuum" will at least introduce the following changes:
      -> 3.3.1:
      fix IOBROKER-MIHOME-VACUUM-Z
      fix some errors
      -> 3.3.0:
      fix no rooms for S5
      fix IOBROKER-MIHOME-VACUUM-4 DB closed
      fix connection error
      -> 3.2.2:
      the communication is corrected
      Added roles to be detected by type-detector
      -> 3.2.1:
      Adjust several crash cases (IOBROKER-MIHOME-VACUUM-K, IOBROKER-MIHOME-VACUUM-J, IOBROKER-MIHOME-VACUUM-F, IOBROKER-MIHOME-VACUUM-7, IOBROKER-MIHOME-VACUUM-A, IOBROKER-MIHOME-VACUUM-4, IOBROKER-MIHOME-VACUUM-G, IOBROKER-MIHOME-VACUUM-C, IOBROKER-MIHOME-VACUUM-B, IOBROKER-MIHOME-VACUUM-Q, IOBROKER-MIHOME-VACUUM-M)
      -> 3.2.0:
      fixed error
      -> 3.1.7:
      added Sentry, minimize messages, fix disk I/O
      -> 3.1.5:
      Breaking changes, Map format changed, added wifi state, added multimap support, added mopstate, fixed objects, show zones and points when selectiong in app, minmize disk I/O, minimize Messages clear and extend log,
      Would you like to upgrade mihome-vacuum from @2.1.1 to @3.3.1 now? [(y)es, (n)o]: y
      Update mihome-vacuum from @2.1.1 to @3.3.1
      Installing iobroker.mihome-vacuum@3.3.1... (System call)
      > canvas@2.9.1 install /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/canvas
      > node-pre-gyp install --fallback-to-build
      make: Entering directory '/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/canvas/build'
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/canvas/build'
      + iobroker.mihome-vacuum@3.3.1
      added 21 packages from 25 contributors and updated 1 package in 76.562s
      Update "system.adapter.mihome-vacuum.0"
      upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
      upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
      upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
      upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
      upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
      upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
      upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
      upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
      upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
      upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
      upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
      This upgrade of "iot" will at least introduce the following changes:
      -> 1.11.4:
      Fix crash cases reported by Sentry
      -> 1.11.3:
      Added the generation of URL key for services
      -> 1.11.2:
      Fix crash case reported by Sentry (IOBROKER-IOT-3P)
      -> 1.11.1:
      Optimize logging when many devices are used
      -> 1.11.0:
      Also support "stored" when a rgb state is turned on/off
      Fix control percent value to respect min/max correctly
      Support of response messages longer than 128k (zip)
      -> 1.10.0:
      Respect min/max when calculating the value for byOn with % values
      -> 1.9.7:
      Fix crash case reported by Sentry (IOBROKER-IOT-3C)
      Would you like to upgrade iot from @1.8.24 to @1.11.4 now? [(y)es, (n)o]: y
      Update iot from @1.8.24 to @1.11.4
      host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
      Installing iobroker.iot@1.11.4... (System call)
      > canvas@2.9.1 install /opt/iobroker/node_modules/canvas
      make: Entering directory '/opt/iobroker/node_modules/canvas/build'
      make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
      + iobroker.iot@1.11.4
      added 15 packages from 21 contributors, removed 23 packages and updated 28 packages in 96.522s
      Update "system.adapter.iot.0"
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js static/js/2.1d439ead.chunk.js application/javascript
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.LICENSE.txt static/js/2.1d439ead.chunk.js.LICENSE.txt text/plain
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.1d439ead.chunk.js.map static/js/2.1d439ead.chunk.js.map application/json
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js static/js/main.846bc990.chunk.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.846bc990.chunk.js.map static/js/main.846bc990.chunk.js.map application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js static/js/runtime-main.1a18d9e5.js application/javascript
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.1a18d9e5.js.map static/js/runtime-main.1a18d9e5.js.map application/json
      host.raspberrypi Adapter "system.adapter.iot.0" is started
      pi@raspberrypi:/opt/iobroker $ iobroker start
      pi@raspberrypi:/opt/iobroker $ iobroker status
      Objects type: jsonl
      States  type: jsonl
        Thomas Braun Most Active @Tomk81 last edited by
        @tomk81
        Das schaut doch ganz gut aus nun.
        iobroker update -u
        Und zum Abschluss noch nodejs auf v14 bringen. Siehe in meiner Signatur.
          iobroker update -u
          pi@raspberrypi:/opt/iobroker $ iobroker update -u
            @tomk81
            Gut, alles aktuell.
            Bis auf nodejs.
              @tomk81
              Gut, alles aktuell.
              Bis auf nodejs.
              Vielen Dank.
              vielleicht hab ich noch fragen zu den nodejs aber nicht mehr heute.
              Danke euch beiden!!!!!!!!!!!!!!!!
              • Keksmonster
                Keksmonster last edited by
                Hallo Leute!
                ich brauche hilfe 😞
                Irgendwie will mein js-controller nicht updaten. Hat jemand einen Plan, was das sein kann?
                pi@SmartHome:~ $ iobroker upgrade self
                Update js-controller from @3.1.6 to @4.0.23
                NPM version: 6.14.17
                npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefi                           x "/opt/iobroker" (System call)
                 Objects 127.0.0.1:49952 Error from InMemDB: Error: GET-UNSUPPORTED for namespac                           e cfg.: Data=["meta.objects.features.useSets"]
                 States 127.0.0.1:36718 Error from InMemDB: Error: GET-UNSUPPORTED for namespace                            meta.: Data=["meta.states.protocolVersion"]
                 Objects 127.0.0.1:49952 Error from InMemDB: Error: GET-UNSUPPORTED for namespac                           e cfg.: Data=["meta.objects.protocolVersion"]
                 Objects 127.0.0.1:49952 Error from InMemDB: Error: scan NOT SUPPORTED
                 States 127.0.0.1:36720 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for na                           mespace meta.: Data=["meta.*"]
                /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                        throw e;
                ReplyError: Error scan NOT SUPPORTED
                    at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                    at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                Emitted 'error' event on ScanStream instance at:
                    at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.j                           s:12:23)
                    at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                    at processTicksAndRejections (internal/process/task_queues.js:95:5) {
                  command: {
                    args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
                npm ERR! This is probably not a problem with npm. There is likely additional log                           ging output above.
                npm ERR!     /home/iobroker/.npm/_logs/2022-06-07T22_40_24_484Z-debug.log
                host.SmartHome Cannot install iobroker.js-controller@4.0.23: 1
                pi@SmartHome:~ $
                Im Log steht:
                1 verbose cli [
                1 verbose cli   '/usr/bin/node',
                1 verbose cli   '/usr/bin/npm',
                1 verbose cli   'install',
                1 verbose cli   'iobroker.js-controller@4.0.23',
                1 verbose cli   '--loglevel',
                1 verbose cli   'error',
                1 verbose cli   '--unsafe-perm',
                1 verbose cli   '--prefix',
                1 verbose cli   '/opt/iobroker'
                1 verbose cli ]
                2 info using npm@6.14.17
                3 info using node@v14.19.3
                4 verbose npm-session 4663683b180f216c
                5 silly install loadCurrentTree
                6 silly install readLocalPackageData
                7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 1130ms (from cache)
                8 silly pacote version manifest for iobroker.js-controller@4.0.23 fetched in 1218ms
                9 timing stage:loadCurrentTree Completed in 23244ms
                10 silly install loadIdealTree
                11 silly install cloneCurrentTreeToIdealTree
                12 timing stage:loadIdealTree:cloneCurrentTree Completed in 325ms
                13 silly install loadShrinkwrap
                14 timing stage:loadIdealTree:loadShrinkwrap Completed in 6449ms
                15 silly install loadAllDepsIntoIdealTree
                16 silly resolveWithNewModule iobroker.js-controller@4.0.23 checking installable status
                17 silly removeObsoleteDep removing iobroker.js-controller@3.1.6 from the tree as its been replaced by a newer version or is no longer required
                18 silly removeObsoleteDep removing @iobroker/plugin-sentry@1.1.4 from the tree as its been replaced by a newer version or is no longer required
                19 silly removeObsoleteDep removing @iobroker/plugin-base@1.2.0 from the tree as its been replaced by a newer version or is no longer required
                20 silly removeObsoleteDep removing @sentry/integrations@5.27.2 from the tree as its been replaced by a newer version or is no longer required
                21 silly removeObsoleteDep removing @sentry/types@5.27.2 from the tree as its been replaced by a newer version or is no longer required
                22 silly removeObsoleteDep removing @sentry/utils@5.27.2 from the tree as its been replaced by a newer version or is no longer required
                23 silly removeObsoleteDep removing localforage@1.8.1 from the tree as its been replaced by a newer version or is no longer required
                24 silly removeObsoleteDep removing lie@3.1.1 from the tree as its been replaced by a newer version or is no longer required
                25 silly removeObsoleteDep removing @sentry/node@5.27.2 from the tree as its been replaced by a newer version or is no longer required
                26 silly removeObsoleteDep removing @sentry/core@5.27.2 from the tree as its been replaced by a newer version or is no longer required
                • Keksmonster
                  Jetzt hats mir bei dem obrigen Versuch komplett iobroker zerschossen.
                  pi@SmartHome:~ $ iobroker fix
                  library: loaded
                  Library version=2022-06-03
                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                  Habe es mit npm install iobroker.js-controller@3.3 wieder zum laufen bekommen ... Kann jede Hilfe gebrauchen 🙂
                  • Keksmonster
                    Endlich ( bin heute 4h dran gesessen) ...
                    Ich hab jetzt noch mal die Anleitung mit der "manuellen Installation" durchgespielt (dachte eigentlich genau so habe ich es schon versucht) und nun ist es durchgelaufen! Juhu!
                      apollon77 @Keksmonster last edited by
                      @jan-3 Ich denke dein Fix zuerst auf die 3.3. zu gehen hat es zum funktionieren gebracht
                        matzi last edited by Negalein
                        ich versuche mich seit paar Stunden erfolglos an dem JS-Controller update von 3.1.6 nach 4.0.x.
                        Zu Beginn bin ich der Anleitung über den Satz gestolpert "ACHTUNG: Wer von einer kleineren js-controller Version als 3.2 kommt, sollte direkt per npm installieren und NICHT per iob uograde self!!" . Da ich absolut keine Ahnung davon habe, wie per npm installiert wird, habe ich es gemäß der Anleitung mit 'iobroker upgrade self' probiert.
                        Dabei bekomme ich immer folgende Meldungen:
                        matthias@iobroker:~$ iobroker upgrade self
                        NPM version: 8.11.0
                        npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                         Objects 127.0.0.1:33972 Error from InMemDB: Error: client NOT SUPPORTED
                         Objects 127.0.0.1:33972 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                         Objects 127.0.0.1:33972 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                         Objects 127.0.0.1:33972 Error from InMemDB: Error: scan NOT SUPPORTED
                         Objects 127.0.0.1:33978 Error from InMemDB: Error: client NOT SUPPORTED
                         Objects 127.0.0.1:33980 Error from InMemDB: Error: client NOT SUPPORTED
                         States 127.0.0.1:37326 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                         Objects 127.0.0.1:33974 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                         Objects 127.0.0.1:33974 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                         Objects 127.0.0.1:33974 Error from InMemDB: Error: scan NOT SUPPORTED
                         States 127.0.0.1:37332 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                         Objects 127.0.0.1:33978 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace cfg.: Data=["meta.*"]
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                        npm ERR!         throw e;
                        npm ERR!         ^
                        npm ERR!
                        npm ERR! ReplyError: Error scan NOT SUPPORTED
                        npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                        npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                        npm ERR! Emitted 'error' event on ScanStream instance at:
                        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                        npm ERR!     at processTicksAndRejections (node:internal/process/task_queues:96:5) {
                        npm ERR!   command: {
                        npm ERR!     name: 'scan',
                        npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                        npm ERR!   }
                        npm ERR! }
                        npm ERR!     /home/iobroker/.npm/_logs/2022-07-03T10_45_15_147Z-debug-0.log
                        Starting node restart.js
                        Danach habe ich es mit dem Befehl 'sudo -H -u iobroker npm install iobroker.js-controller' versucht und den iobroker gestartet.
                        matthias@iobroker:~$ sudo -H -u iobroker npm install iobroker.js-controller
                        [sudo] password for matthias:
                        up to date, audited 284 packages in 17s
                        4 vulnerabilities (3 moderate, 1 high)
                        To address all issues (including breaking changes), run:
                          npm audit fix --force
                        Run `npm audit` for details.
                        Egal was ich mache, ist es nach dem Start vom iobroker immer noch die js-Controller Version 3.1.6.
                        Betriebssystem: Linux Ubuntu 18.04.6 LTS (aktualisiert)
                        Node-JS: 16.15.1
                        NPM: 8.11.0
                        Was mache ich falsch?
                        Viele Grüße
                        Matthias
                        Mod-Edit: Code in </> Code-Tag gepackt!
                          Thomas Braun Most Active @matzi last edited by
                          @matzi sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                          Richtiger Befehl, aber im falschen Verzeichnis ausgeführt.
                          Zuvor
                          cd /opt/iobroker
                          Und künfitg nicht so schludern mit den Updates, dann ist das alles einfacher.
                            Danke - jetzt bin ich einen Schritt weiter. Die JS-Controller Version ist jetzt 3.3.22 .
                            Werde mit dem Stand erst mal die VM sichern, dann alle Adapter aktualisieren und dann das Update des JS-Controllers auf 4.0.x versuchen.
                              MCU last edited by
                              @apollon77 Laut Doku von oben soll es in der iobroker.json für objects und states einen Eintrag für "connectionTimeouts" geben.
                              Editiere /opt/iobroker/iobroker-data/iobroker.json
                              Unter objects und states gibt es jeweils ein ' "connectTimeout": 2000,`
                              Zahl ändern auf 5000
                              Bei mir gibt es den Eintrag nur für objects. Muss man den Eintrag für states ergänzen?
                                apollon77 @MCU last edited by
                                @mcu ja. Einfach ergänzen.
                                  Rocket85 last edited by
                                  Hallo zusammen, kann mir vielleicht jemand beim Update helfen?
                                  Komme von Version 2.2.10 und hier sollte ich wohl nicht direkt per upgrad self starten?
                                    apollon77 @Rocket85 last edited by
                                    @rocket85 hehe .... nnneeeee am besten nicht.
                                    Am Ende zwei Varianten:
                                    1.) Backup/Restore
                                    • Backup machen inkl. von iobroker-data nochmal gesondert um ggf was raussuchen zu können was doch nicht im Backup ist. Dann /opt/iobroker löschen. Dann mit Linux installer neu installieren. Beenden. Dann Backup restore ...
                                    • dann direkt vor dem start (!!) Alle adapter aktualisieren. Major Versionsprünge bei Adaptern aufschreiben das Du sie danach abarbeiten kannst was sich geändert hat. Starten ... Alles nach und nach hinbiegen und ggf fehlende Dateien aus Backup rausholen
                                    2.) "Sollte tun"
                                    • Backup gilt immer wie oben von allem. dann beenden. node_modules Verzeichnis löschen (rest lassen). dann in /opt/iobroker ein npm install iobroker.js-controller@4.0.23 --production ausführen. Dann verifizieren das iob update" bzw iob list instances` tut.
                                    • dann an aich wie oben ggf zuerst adapter aktualisieren und wie oben
                                    Ein schrittweise update vom js-controller (Variante 3) macht in meinen Augen nur Aufwand aber bringt nicht so viele vorteile.
                                      Snapergy last edited by
                                      Ich habe gerade das Update gemacht und habe aber bei meinem KNX-Adapter ein Problem. Es kommen immer folgende Meldungen und der Adapter (V1.31 -> ich weiß, ist nicht die aktuellste, aber für meine Zwecke die, die am besten funktioniert) startet nicht mehr 😞
                                      knx.0
                                      	2022-08-29 11:32:37.213	error	Cannot read property 'getObjectView' of undefined
                                      knx.0
                                      	2022-08-29 11:32:37.212	error	TypeError: Cannot read property 'getObjectView' of undefined at Object._0x2a4410 [as ready] (/opt/iobroker/node_modules/iobroker.knx/knx.js:79:30550) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8225:68
                                      knx.0
                                      	2022-08-29 11:32:37.208	error	unhandled promise rejection: Cannot read property 'getObjectView' of undefined
                                      knx.0
                                      	2022-08-29 11:32:37.208	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      Vielleicht kann mir jemand hier direkt helfen und auf eine Lösung aufmerksam machen. Bin gerade erstmal wieder auf die JS-Controller-Version 3.3.22 zurück
                                        apollon77 @Snapergy last edited by
                                        @snapergy knx Adapter issue machen. Bzw falls knx nicht aktuell ist dann bitte aktualisieren!!
                                          Snapergy @apollon77 last edited by
                                          @apollon77 Einen issua gibt es dazu schon von einem anderen Nutzer, dort gibt es bis heute keinen response. Aktualisieren ist halt nicht so einfach, da der adapter ab V2 kostenpflichtig wird und innerhalb von V1.X keine, für mich funktionierende, version existiert. Also alles ein wenig kompliziert 😞
                                            @snapergy Ja welche version nutzt du denn? Meines wissens nach tut die 1.0.46 problemlos - also mindestens der hier genannte Fehler ist da nicht drin ...
                                            501
                                            124165
