    4. Test Adapter luxtronik2 v0.4.x
      Henning 1 last edited by
      sorry, meine geistige Umnachtung 🙂 Ist irgendwie zu warm draußen... Ich machs gleich nochmal anders.
        Hmm, ging auch nicht:
        pi@iobroker-pi:~ $ iobroker add luxtronik2
        host.iobroker-pi Unknown packetName luxtronik2. Please install packages from outside the repository using npm!
        pi@iobroker-pi:~ $ iobroker add iobroker.luxtronik2
        Ich versuchs jetzt nochmal im opt/iobroker mittels npm. Geht auch nicht 😞
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /opt/iobroker/node_modules
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
        npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/opt/iobroker/node_modules'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/pi/.npm/_logs/2022-07-03T11_29_51_613Z-debug.log
          Thomas Braun Most Active @Henning 1 last edited by
          @henning-1
          Mach es so...
            Das hatte ich schon probiert. Der Adapter ist nicht sichtbar.
              @henning-1
              iobroker update -i
                Used repository: stable
                Adapter    "admin"        : 5.3.8    , installed 5.3.8
                Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                Adapter    "fronius"      : 1.1.3    , installed 1.1.3
                Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
                Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                Adapter    "openknx"      : 0.2.5    , installed 0.1.22 [Updatable]
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "pvforecast"   : 2.1.4    , installed 2.1.4
                Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                Adapter    "valloxmv"     : 1.1.3    , installed 1.1.3
                Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
                  @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
                  Was genau hast du da eingegeben?
                  Bitte IMMER vollständige Ein- wie Ausgaben zeigen.
                    Hier inkl. eingegebenes Kommando:
                    pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
                    npm ERR! errno -13
                    npm ERR! }
                    npm ERR!
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
                      @henning-1
                      groups
                      als pi ausgeführt liefert?
                        pi@iobroker-pi:/opt/iobroker $ groups
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                          Alternativ:
                          cd /opt/iobroker
                          sudo -H -u iobroker npm i iobroker.luxtronik2
                            @henning-1
                            Der pi fehlt in der Gruppe 'iobroker'
                            sudo usermod -aG iobroker pi
                              @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                              Das liefert er:
                              pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              + iobroker.luxtronik2@0.4.2
                              added 7 packages from 82 contributors in 29.319s
                              50 packages are looking for funding
                                run `npm fund` for details
                              Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                                Henning 1 @Thomas Braun last edited by
                                Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                                pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                                pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                                host.iobroker-pi install adapter luxtronik2
                                upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                                upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                                upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                                upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                                host.iobroker-pi object system.adapter.luxtronik2 created/updated
                                host.iobroker-pi create instance luxtronik2
                                host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                                host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                                host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                                host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                                host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                                host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                                host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                                host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                                host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                                host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                                host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                                host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                                host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                                host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                                host.iobroker-pi object luxtronik2.0.info created
                                host.iobroker-pi object luxtronik2.0.info.connection created
                                host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                                host.iobroker-pi object system.adapter.luxtronik2.0 created
                                Ich mache mal nen Reboot und schaue dann, was ich sehe.
                                  Henning 1 @Henning 1 last edited by
                                  Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                                  Schönes WE soweit noch 🙂
                                    ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                                    2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                                    2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                                    2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                                    2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                                    2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                                    2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                                      @henning-1
                                      Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                                        Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                                        und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                                          Das Ganze steht bei Wärmemenge auch nochmal drin
                                            Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                                            Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            69154
