    4. Test Adapter luxtronik2 v0.4.x
      Thomas Braun Most Active @Henning 1 last edited by
      @henning-1
      Mach es so...
        Das hatte ich schon probiert. Der Adapter ist nicht sichtbar.
          @henning-1
          iobroker update -i
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "fronius"      : 1.1.3    , installed 1.1.3
            Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            Adapter    "openknx"      : 0.2.5    , installed 0.1.22 [Updatable]
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "pvforecast"   : 2.1.4    , installed 2.1.4
            Adapter    "unifi"        : 0.5.10   , installed 0.5.10
            Adapter    "valloxmv"     : 1.1.3    , installed 1.1.3
            Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
              @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
              Ich versuchs jetzt nochmal im opt/iobroker mittels npm. Geht auch nicht
              Was genau hast du da eingegeben?
              Bitte IMMER vollständige Ein- wie Ausgaben zeigen.
                Hier inkl. eingegebenes Kommando:
                pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
                npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
                npm ERR! code EACCES
                npm ERR! syscall access
                npm ERR! path /opt/iobroker/node_modules
                npm ERR! errno -13
                npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
                npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
                npm ERR!   errno: -13,
                npm ERR!   code: 'EACCES',
                npm ERR!   syscall: 'access',
                npm ERR!   path: '/opt/iobroker/node_modules'
                npm ERR! }
                npm ERR!
                npm ERR! The operation was rejected by your operating system.
                npm ERR! It is likely you do not have the permissions to access this file as the current user
                npm ERR!
                npm ERR! If you believe this might be a permissions issue, please double-check the
                npm ERR! permissions of the file and its containing directories, or try running
                npm ERR! the command again as root/Administrator.
                npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
                  @henning-1
                  groups
                  als pi ausgeführt liefert?
                    pi@iobroker-pi:/opt/iobroker $ groups
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                      Alternativ:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm i iobroker.luxtronik2
                        @henning-1
                        Der pi fehlt in der Gruppe 'iobroker'
                        sudo usermod -aG iobroker pi
                          @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                          Das liefert er:
                          pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          + iobroker.luxtronik2@0.4.2
                          added 7 packages from 82 contributors in 29.319s
                          50 packages are looking for funding
                            run `npm fund` for details
                          Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                            Henning 1 @Thomas Braun last edited by
                            Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                            pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                            pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                            host.iobroker-pi install adapter luxtronik2
                            upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                            upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                            upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                            upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                            host.iobroker-pi object system.adapter.luxtronik2 created/updated
                            host.iobroker-pi create instance luxtronik2
                            host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                            host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                            host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                            host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                            host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                            host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                            host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                            host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                            host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                            host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                            host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                            host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                            host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                            host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                            host.iobroker-pi object luxtronik2.0.info created
                            host.iobroker-pi object luxtronik2.0.info.connection created
                            host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                            host.iobroker-pi object system.adapter.luxtronik2.0 created
                            Ich mache mal nen Reboot und schaue dann, was ich sehe.
                              Henning 1 @Henning 1 last edited by
                              Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                              Schönes WE soweit noch 🙂
                                ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                                2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                                2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                                2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                                2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                                2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                                2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                                  @henning-1
                                  Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                                    Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                                    und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                                      Das Ganze steht bei Wärmemenge auch nochmal drin
                                        Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                                        Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                                          @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                                            pgBroker last edited by pgBroker
                                            Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                                            Unknown data item parameters.mk1_curve_parallel_offset
                                            Unknown data item parameters.mk1_curve_end_point
                                            Unknown data item parameters.deltaMk1Reduction
                                            Wie kriege ich die weg?
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            68068
