    4. Test Adapter luxtronik2 v0.4.x
      Henning 1 last edited by
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "gruenbeck"    : 0.0.34   , installed 0.0.34
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "openknx"      : 0.2.5    , installed 0.1.22 [Updatable]
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "pvforecast"   : 2.1.4    , installed 2.1.4
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "valloxmv"     : 1.1.3    , installed 1.1.3
      Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
        Thomas Braun Most Active @Henning 1 last edited by
        @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
        Ich versuchs jetzt nochmal im opt/iobroker mittels npm. Geht auch nicht
        Was genau hast du da eingegeben?
        Bitte IMMER vollständige Ein- wie Ausgaben zeigen.
          Hier inkl. eingegebenes Kommando:
          pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! code EACCES
          npm ERR! syscall access
          npm ERR! path /opt/iobroker/node_modules
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
          npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/opt/iobroker/node_modules'
          npm ERR! }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator.
          npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
            @henning-1
            groups
            als pi ausgeführt liefert?
              pi@iobroker-pi:/opt/iobroker $ groups
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
                Alternativ:
                cd /opt/iobroker
                sudo -H -u iobroker npm i iobroker.luxtronik2
                  @henning-1
                  Der pi fehlt in der Gruppe 'iobroker'
                  sudo usermod -aG iobroker pi
                    @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                    Das liefert er:
                    pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    + iobroker.luxtronik2@0.4.2
                    added 7 packages from 82 contributors in 29.319s
                    50 packages are looking for funding
                      run `npm fund` for details
                    Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                      Henning 1 @Thomas Braun last edited by
                      Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                      pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                      pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                      host.iobroker-pi install adapter luxtronik2
                      upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                      upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                      upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                      upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                      host.iobroker-pi object system.adapter.luxtronik2 created/updated
                      host.iobroker-pi create instance luxtronik2
                      host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                      host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                      host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                      host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                      host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                      host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                      host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                      host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                      host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                      host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                      host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                      host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                      host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                      host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                      host.iobroker-pi object luxtronik2.0.info created
                      host.iobroker-pi object luxtronik2.0.info.connection created
                      host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                      host.iobroker-pi object system.adapter.luxtronik2.0 created
                      Ich mache mal nen Reboot und schaue dann, was ich sehe.
                        Henning 1 @Henning 1 last edited by
                        Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                        Schönes WE soweit noch 🙂
                          ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                          2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                          2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                          2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                          2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                          2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                          2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                            @henning-1
                            Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                              Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                              und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                                Das Ganze steht bei Wärmemenge auch nochmal drin
                                  Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                                  Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                                    @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                                      pgBroker last edited by pgBroker
                                      Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                                      Unknown data item parameters.mk1_curve_parallel_offset
                                      Unknown data item parameters.mk1_curve_end_point
                                      Unknown data item parameters.deltaMk1Reduction
                                      Wie kriege ich die weg?
                                        pgBroker @pgBroker last edited by
                                        Hmmm, hat niemand ne idee? 😕
                                        • Bernd 0
                                          Bernd 0 last edited by
                                          kann man über den Adapter herausfinden, welchen Leistungsbezug die Wärmepumpe aus dem Netz bezieht? Also kWh?
                                          Ich habe nur gefunden, dass man die erzeugte Wärmeleistung abfragen kann.
                                          Vielen Dank.
                                          GB
                                          TbsJah 1 Reply Last reply Reply Quote 0
                                          • TbsJah
                                            TbsJah @Bernd 0 last edited by
                                            @bernd-0 aktuell gibt es dafür keinen Parameter.
                                            Du könntest den Wert jedoch annäherungsweise über die Temperatur WQ ermitteln
                                            Bernd 0 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            68071
