    4. [Synology Docker]Iobroker startet nicht (no database)
    • Glasfaser
      Glasfaser @SimKa last edited by Glasfaser
      @simka sagte in [Synology Docker]Iobroker startet nicht (no database):
      2022-07-04 21:26:04.302 - info: host.iobroker hostname: iobroker, node: v14.19.3
      Ich frage deshalb weil der jetzige Container wieder 14 hat und die oben im Start-Thread 16 hattest
      Laut deinem neusten Log
        SimKa @Glasfaser last edited by
        @glasfaser said in [Synology Docker]Iobroker startet nicht (no database):
        Hab ne neue Instanz gestartet in einem leeren Ordner. Anscheinend ist die 14er standardmäßig installiert. iobroker.2022-07-04 (14).log
          @glasfaser
          Ich hab noch mal über das Webinterface das Backup eingespielt.
          iobroker.2022-07-04 (16).log
            Nach einem Neustart bleibts zumindest bei v14 aber wieder ein Fehler
            2022-07-04 22:16:45.676  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
            2022-07-04 22:16:45.689  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
            2022-07-04 22:16:45.691  - info: host.iobroker hostname: iobroker, node: v14.19.3
            2022-07-04 22:16:45.692  - info: host.iobroker ip addresses: 172.17.0.2
            2022-07-04 22:16:47.534  - info: host.iobroker connected to Objects and States
            2022-07-04 22:16:47.603  - info: host.iobroker Node.js version has changed from unknown to 14.19.3
            2022-07-04 22:16:47.635  - info: host.iobroker added notifications configuration of host
            2022-07-04 22:16:48.203  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
            Failed to set capabilities on file `/usr/bin/node' (Operation not supported)
            The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
            2022-07-04 22:16:48.338  - info: host.iobroker Delete host system.host.iobroker-default
            2022-07-04 22:16:48.452  - info: host.iobroker 28 instances found
            2022-07-04 22:16:48.490  - warn: host.iobroker does not start any instances on this host
            iobroker.2022-07-04 (19).log
            • Glasfaser
              iobroker host this
              Verstehe trozdem nicht , wo das wieder herkommt bei dir
              Du erstellt doch einen neuen Container mit ioBroker , dann spielst du es mit dem Backitup Adapter wieder ein .
              Weil .... deine gezeigten Log´s zeigen nichts davon an !
              • andre
                andre Developer @SimKa last edited by
                Wenn ich das wüsste. Ich habe kein Update von der Synology gemacht, kein Update des Dockers aber ich meine, ich hätte ein update von iobroker über das Webinterface gemacht.
                Welches Tag des Docker Images nutzt du denn? Ausserdem wäre es hilfreich mal das Log aus dem Container zu zeigen. Dann gäbe es hier mal Klarheit was die Versionen angeht...
                MfG,
                Andre
                Glasfaser S 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @andre last edited by
                  @andre sagte in [Synology Docker]Iobroker startet nicht (no database):
                  Das frage ich ja auch schon die ganze Zeit .
                  Mal ist es Nodejs 16 ( ist ja dein neustes Beta ) , mal 14
                    iobroker host this
                    root@iobroker-default:/opt/iobroker# iobroker host this
                    Cannot execute changes on running system. Stop iobroker first.
                    root@iobroker-default:/opt/iobroker# iobroker stop
                    iobroker controller daemon is not running
                    root@iobroker-default:/opt/iobroker# iobroker status
                    Objects type: jsonl
                    States  type: jsonl
                    Kanns dir nicht erklären, warum das Backup nicht in den Logs erscheint. Ich erstelle eine weitere Instanz und versuche es mal mit der console, das Backup einzuspielen.
                      SimKa @andre last edited by
                      @andre said in [Synology Docker]Iobroker startet nicht (no database):
                      MfG,
                      Andre
                      Ich erstelle es von iobroker/iobroker:latest
                      Welche logs meinst du? Kannst du mir sagen, wo diese liegen?
                      • Glasfaser
                        im Container gibt es kein Stop Befehl .
                        der ist dann so:
                        pkill -u iobroker
                        • Glasfaser
                          hier :
                          Beispielbild :
                            Habe eine neue Instanz deployed ohne etwas zu ändern.
                            root@iobroker-default:/opt/iobroker# npm -v
                            6.14.17
                            root@iobroker-default:/opt/iobroker# node -v
                            v14.19.3
                            Habe nun über die console ein Backup versuche
                            root@iobroker-default:/opt/iobroker# pkill -u iobroker
                            root@iobroker-default:/opt/iobroker# iobroker restore backups/iobroker_2022_05_07-02_40_10_backupiobroker.tar.gz
                            host.iobroker-default OK.
                            Removing current installation of iobroker.admin
                            removed 21 packages in 22.107s
                            37 packages are looking for funding
                              run `npm fund` for details
                            Removing current installation of iobroker.backitup
                            removed 98 packages in 18.525s
                            35 packages are looking for funding
                            Removing current installation of iobroker.discovery
                            removed 93 packages in 15.548s
                            16 packages are looking for funding
                            host.iobroker-default Clear all objects and states...
                            clean 135 objects...
                            clean 94 states...
                            host.iobroker-default done.
                            host.iobroker-default Processed 0/2039 objects
                            host.iobroker-default Processed 200/2039 objects
                            host.iobroker-default Processed 400/2039 objects
                            host.iobroker-default Processed 600/2039 objects
                            host.iobroker-default Processed 800/2039 objects
                            host.iobroker-default Processed 1000/2039 objects
                            host.iobroker-default Processed 1200/2039 objects
                            host.iobroker-default Processed 1400/2039 objects
                            host.iobroker-default Processed 1600/2039 objects
                            host.iobroker-default Processed 1800/2039 objects
                            host.iobroker-default Processed 2000/2039 objects
                            2039 objects restored.
                            host.iobroker-default Processed 0/1612 states
                            host.iobroker-default Processed 200/1612 states
                            host.iobroker-default Processed 400/1612 states
                            host.iobroker-default Processed 600/1612 states
                            host.iobroker-default Processed 800/1612 states
                            host.iobroker-default Processed 1000/1612 states
                            host.iobroker-default Processed 1200/1612 states
                            host.iobroker-default Processed 1400/1612 states
                            host.iobroker-default Processed 1600/1612 states
                            1612 states restored.
                            host.iobroker-default Upload user file "vis.0/main/vis-views.json
                            Reinstalling adapter "admin" from "iobroker.admin@5.3.1"
                            + iobroker.admin@5.3.1
                            added 71 packages from 90 contributors in 43.167s
                            20 packages are looking for funding
                            Reinstalling adapter "backitup" from "iobroker.backitup@2.3.3"
                            + iobroker.backitup@2.3.3
                            added 73 packages from 59 contributors in 30.069s
                            24 packages are looking for funding
                            Auch nicht mehr erreichbar über port 8081 und https (auch nicht über http)
                            iobroker.2022-07-05.log
                              hier :
                              Beispielbild :
                              iobroker-default.html
                              • Glasfaser
                                @simka
                                iobroker status
                                iobroker list instances
                                • Glasfaser
                                  v16.15.1
                                  War das schon im Container oder hast du ein Update von 14 auf 16 gemacht !?
                                  Ich hab nur den Container erstellt, den Ordner gemountet und gestartet. Während der Container startete, sind einige Sachen installiert worden. Manuell habe ich nichts installiert.
                                  Das ist irgendwie verwirrend bei dir
                                  , denn der Container den du hast
                                  ist das :
                                  Image : v6.1.0
                                  mit :
                                  npm: 6.14.16
                                  node: v14.19.0
                                  und im ganzen Verlauf .... schreibst du , du hast nichts gemacht ,
                                  bist trotzdem
                                  " Iobroker startet nicht (no database) "
                                  mich hat es leider auch getroffen. Iobroker lässt sich nicht mehr starten.
                                  und hast ganz oben im Start-Thread wie ich schon mehere male erwähnt und auch nachgefragt Node in
                                  v16.15.1
                                  8.11.0
                                  , also das aktuelle.
                                  Von alleine geht das nicht !!
                                  • andre
                                    andre Developer last edited by
                                    Latest ist schon mal nicht so gut. Aktuell scheint bei dir zwar noch v6.1.0 lokal zu liegen, wenn du da Image allerdings neu pullst würdest du die v7.0.0 bekommen. Das könnte dann noch andere Probleme geben. 🙂 Aber das ist eine andere Story.
                                    Dein Log von nem neuen Container sieht sauber aus. Image Version passt zur node version.
                                    Wenn ich es richtig verstehe, dann kommt der iobroker auch "jungfräulich" hoch, richtig?
                                    Dein Restore sieht m.E: auch schonmal gut aus.
                                    Jetzt kannst du über die Kommandozeile die beiden Kommandos die @Glasfaser gepostet hat mal ausführen. Gleichzeitig mal schauen welche Prozesse in deinem Container laufen:
                                    Mag ja sein, dass alles läuft, du aber nur nich drauf kommst? Was sagt das Protokoll vom Container nach dem restore?
                                    MfG,
                                    André
                                      iobroker is not running on this host.
                                      Objects type: jsonl
                                      States  type: jsonl
                                      root@iobroker-default:/opt/iobroker# iobroker list instances
                                        system.adapter.admin.0                  : admin                 : iobroker-default                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        system.adapter.backitup.0               : backitup              : iobroker-default                         -  enabled
                                        system.adapter.daswetter.0              : daswetter             : iobroker-default                         - disabled
                                        system.adapter.discovery.0              : discovery             : iobroker-default                         - disabled
                                        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-default                         - disabled, port: 42101
                                        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-default                         - disabled, port: 42102
                                        system.adapter.ical.0                   : ical                  : iobroker-default                         - disabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-default                         - disabled
                                        system.adapter.slideshow.0              : slideshow             : iobroker-default                         - disabled
                                        system.adapter.slideshow.1              : slideshow             : iobroker-default                         - disabled
                                        system.adapter.slideshow.2              : slideshow             : iobroker-default                         - disabled
                                        system.adapter.synology.0               : synology              : iobroker-default                         - disabled, port: 5001
                                        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-default                         - disabled
                                        system.adapter.trashschedule.0          : trashschedule         : iobroker-default                         - disabled
                                        system.adapter.vis-bars.0               : vis-bars              : iobroker-default                         - disabled
                                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-default                         - disabled
                                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-default                         - disabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-default                         - disabled
                                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-default                         - disabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-default                         - disabled
                                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-default                         - disabled
                                        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-default                         - disabled
                                        system.adapter.vis-players.0            : vis-players           : iobroker-default                         - disabled
                                        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-default                         - disabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-default                         - disabled
                                        system.adapter.vis-weather.0            : vis-weather           : iobroker-default                         - disabled
                                        system.adapter.vis.0                    : vis                   : iobroker-default                         - disabled
                                        system.adapter.web.0                    : web                   : iobroker-default                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      iobroker-default (1).html
                                        v16.15.1
                                        ist das :
                                        Image : v6.1.0
                                        mit :
                                        npm: 6.14.16
                                        node: v14.19.0
                                        bist trotzdem
                                        v16.15.1
                                        8.11.0
                                        Da habe ich mich wohl falsch ausgedrückt. Entschuldige für die Verwirrung.
                                        Ich habe bereits nach dem Problem gegoogelt und auch hier im Forum danach gesucht. Ich habe am Anfang den iobroker fix und den curl Befehl mit dem fix ausgeführt, paar mal neu gestartet, dann den js-controller installiert usw. Da alles nichts geholfen hat, habe ich eine neue Instanz erstellt und dort das Backup eingespielt und wieder paar Sachen versucht, z.B. zu updaten usw.
                                        Als ich geschrieben habe, dass ich nichts gemacht habe, meinte ich damit, dass ich eine neue Instanz erstellt habe und nicht an dieser Instanz gemacht habe, z.B. habe ich kein Update des Dockers oder von iobroker durchgeführt.
                                        • Glasfaser
                                          @simka
                                          ist das richtig , verschlüsselt !?
                                          iobroker start
                                          iobroker logs --watch
                                            Was meinst du mit richtig verschlüsselt? Ich habe Https/SSL damals beim Einrichten angehakt
                                            root@iobroker-default:/opt/iobroker# iobroker start
                                            Starting iobroker controller daemon...
                                            iobroker controller daemon started. PID: 16246
                                            root@iobroker-default:/opt/iobroker# iobroker logs --watch
                                            2022-07-05 09:17:00.349  - info: host.iobroker-default iobroker.js-controller version 4.0.21 js-controller starting
                                            2022-07-05 09:17:00.363  - info: host.iobroker-default Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                            2022-07-05 09:17:00.364  - info: host.iobroker-default hostname: iobroker-default, node: v14.19.3
                                            2022-07-05 09:17:00.365  - info: host.iobroker-default ip addresses: 172.17.0.2
                                            2022-07-05 09:17:01.176  - info: host.iobroker-default added notifications configuration of host
                                            2022-07-05 09:17:01.646  - info: host.iobroker-default 3 instances found
                                            2022-07-05 09:17:01.769  - info: host.iobroker-default instance system.adapter.admin.0 started with pid 1866
                                            2022-07-05 09:17:01.669  - info: host.iobroker-default starting 3 instances
                                            2022-07-05 09:17:05.179  - info: admin.0 (1866) received all objects
                                            2022-07-05 09:17:05.230  - info: admin.0 (1866) Request actual repository...
                                            2022-07-05 09:17:05.259  - info: host.iobroker-default Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                            2022-07-05 09:17:01.002  - info: host.iobroker-default connected to Objects and States
                                            2022-07-05 09:17:01.049  - info: host.iobroker-default Node.js version has changed from unknown to 14.19.3
                                            2022-07-05 09:17:01.157  - warn: host.iobroker-default Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+e
                                            pi /usr/bin/node
                                            2022-07-05 09:17:02.109  - info: host.iobroker-default Created UUID: 36ffb7ca-2961-47dd-a566-a29dbe05f8ea
                                            2022-07-05 09:17:04.901  - info: admin.0 (1866) starting. Version 5.3.1 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.3, js-controller: 4.0.21
                                            2022-07-05 09:17:05.010  - info: admin.0 (1866) requesting all states
                                            2022-07-05 09:17:05.012  - info: admin.0 (1866) requesting all objects
                                            2022-07-05 09:17:05.277  - info: admin.0 (1866) http server listening on port 8081
                                            2022-07-05 09:17:05.279  - info: admin.0 (1866) Use link "http://localhost:8081" to configure.
                                            2022-07-05 09:17:05.541  - warn: admin.0 (1866) Repository cannot be read: Active repo - stable
                                            2022-07-05 09:17:05.543  - warn: admin.0 (1866) Active repository "stable cannot be read
                                            2022-07-05 09:17:05.778  - info: host.iobroker-default instance system.adapter.discovery.0 started with pid 1894
                                            2022-07-05 09:17:09.224  - info: admin.0 (1866) Repository received successfully.
                                            2022-07-05 09:17:09.639  - info: discovery.0 (1894) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.3, js-controller: 4.0.21
                                            2022-07-05 09:17:09.761  - info: host.iobroker-default instance system.adapter.backitup.0 started with pid 1909
                                            2022-07-05 09:17:12.916  - info: backitup.0 (1909) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.3, js-controller: 4.0.21
                                            2022-07-05 09:17:13.036  - info: backitup.0 (1909) [iobroker] backup was activated at 02:40 every 1 day(s)
                                            2022-07-05 09:19:45.668  - info: admin.0 (1866) terminating http server on port 8081
                                            2022-07-05 09:19:45.670  - info: backitup.0 (1909) cleaned everything up...
                                            2022-07-05 09:19:45.663  - info: host.iobroker-default received SIGTERM
                                            2022-07-05 09:19:45.693  - info: host.iobroker-default stopInstance system.adapter.admin.0 (force=false, process=true)
                                            2022-07-05 09:19:45.695  - info: host.iobroker-default stopInstance system.adapter.discovery.0 (force=false, process=true)
                                            2022-07-05 09:19:45.697  - info: host.iobroker-default stopInstance system.adapter.backitup.0 (force=false, process=true)
                                            2022-07-05 09:19:45.740  - info: admin.0 (1866) Got terminate signal TERMINATE_YOURSELF
                                            2022-07-05 09:19:45.744  - info: discovery.0 (1894) Got terminate signal TERMINATE_YOURSELF
                                            2022-07-05 09:19:45.747  - info: backitup.0 (1909) Got terminate signal TERMINATE_YOURSELF
                                            2022-07-05 09:19:45.761  - info: discovery.0 (1894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2022-07-05 09:19:45.762  - info: host.iobroker-default stopInstance system.adapter.admin.0 send kill signal
                                            2022-07-05 09:19:45.767  - info: admin.0 (1866) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2022-07-05 09:19:45.770  - info: host.iobroker-default stopInstance system.adapter.discovery.0 send kill signal
                                            2022-07-05 09:19:45.772  - info: host.iobroker-default stopInstance system.adapter.backitup.0 send kill signal
                                            2022-07-05 09:19:45.803  - info: backitup.0 (1909) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                            2022-07-05 09:19:46.367  - info: host.iobroker-default instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                            2022-07-05 09:19:46.412  - info: host.iobroker-default instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                            2022-07-05 09:19:46.434  - info: host.iobroker-default instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                            2022-07-05 09:19:46.435  - info: host.iobroker-default All instances are stopped.
                                            2022-07-05 09:19:46.560  - info: host.iobroker-default terminated
                                            2022-07-05 14:05:38.950  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
                                            2022-07-05 14:05:38.971  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                            2022-07-05 14:05:38.973  - info: host.iobroker hostname: iobroker, node: v14.19.3
                                            2022-07-05 14:05:38.974  - info: host.iobroker ip addresses: 172.17.0.2
                                            2022-07-05 14:05:40.838  - info: host.iobroker connected to Objects and States
                                            2022-07-05 14:05:40.907  - info: host.iobroker Node.js version has changed from unknown to 14.19.3
                                            2022-07-05 14:05:40.938  - info: host.iobroker added notifications configuration of host
                                            2022-07-05 14:05:41.613  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/
                                            bin/node
                                            2022-07-05 14:05:41.778  - info: host.iobroker Delete host system.host.iobroker-default
                                            2022-07-05 14:05:41.970  - info: host.iobroker 28 instances found
                                            2022-07-05 14:05:41.999  - warn: host.iobroker does not start any instances on this host
                                            130
                                            8785
