    4. Anfrage Tahoma/Somfy IO Adapter
      Willi-Wunder last edited by
      @Excodibur
      Weiß nicht ob dir das hilft, hänge hier mal etwas ran.
      tahoma.0
      	2022-06-27 02:49:08.680	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-06-27 02:49:08.680	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
      tahoma.0
      	2022-06-27 02:49:08.674	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
      tahoma.0
      	2022-06-27 02:49:08.673	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      • Excodibur
        Excodibur Developer last edited by
        @willi-wunder Du kannst mir gerne nochmal DEBUG-Logs (inkl. Adapter Neustart schicken, dann kann ich mal schauen.
        @Murphys234d Das Release ins Stable-Repo dauert noch etwas. Aktuell gibt es noch einige Probleme mit dem Adapter und der lokalen API (hauptsächlich "Unknown Object", was mit fehlenden API-Funktionen zusammenhängt), die erst behoben werden sollten, aber doch etwas aufwändiger sind.
          puls200 @Murphys234d last edited by puls200
          @murphys234d Hi... was heisst das jetzt? Müsste es theoretisch mit der Connexoon Box auch funktionieren?
          Ich bin nun von der Connexoon-App zur Tahoma-App gewechselt. Soweit geht auch alles über die Tahoma App. Der Adapter hat eine Verbindung zur Connexoon Box aber weiterhin kann ich die Jalousien nicht ansprechen, egal, ob ich die PIN eingebe oder nicht.
          Und noch was anderes: falls die Connexoon Box nun nicht mehr mit dem Adapter funktioniert: sind sowohl die Tahoma Box als auch das Connectivity Kit kompatibel mit dem Adapter (Unterschiede siehe HIER). Und dann gibt es ja noch die Tahoma Switch. Oder wurde die Tahoma Box mit der Switch ersetzt? Mir ist das Update etwas schleierhaft...
            blackeagle998 @puls200 last edited by
            @puls200
            Ich habe auch eine Connexoon und bin letzte Woche von der Connexoon App auf die Tahoma App gewechselt.
            Aktuell habe ich die Adapterversion 0.7.2 im Einsatz und kann weiterhin meine Rollladen über die Connexoon Box und den Adapter steuern.
            Lediglich eine lokale API bietet die Connexoon (noch) nicht, vielleicht kommt da ja noch was, die Hoffnung stirbt zuletzt.
              puls200 @blackeagle998 last edited by
              @blackeagle998 Wie komme ich denn an die Version 0.7.2? Bei mir ist die 0.7.1 installiert, aber ioBroker bietet mir keine aktuellere Version an.
                @puls200
                Schau mal bitte in den ioBroker Einstellungen, Reiter "Repositories", ob da stable oder Beta (latest) angehakt ist?
                  Yes!
                  Jetzt geht wieder Alles dank v0.7.2...
                  Vielen Dank an alle!
                    Willi-Wunder @Excodibur last edited by
                    @excodibur
                    Log sollte gerade per PN raus sein. Hoffe es paßt so......
                    Gruß Willi
                      Willi-Wunder last edited by Willi-Wunder
                      @Excodibur
                      PN hat nicht geklappt, hab keine Adresse gefunden........Hab aber gerade wieder den Fehler im Log, vielleicht reicht das auch schon, ansonsten kann ich dir gerne die anderen Dateien noch schicken.
                      tahoma.0
                      	2022-07-02 01:09:48.188	info	eventRegisterID = 221bef9d-1c57-4d26-8ba3-005b34dxxxxx
                      tahoma.0
                      	2022-07-02 01:09:46.343	info	Using stored bearer token 6263c4b71f21561xxxxx
                      tahoma.0
                      	2022-07-02 01:09:46.340	info	Adapter will connect to Tahoma Box via local API.
                      tahoma.0
                      	2022-07-02 01:09:46.337	info	Configured polling interval: 500000
                      tahoma.0
                      	2022-07-02 01:09:46.336	info	[START] Starting adapter tahoma v0.7.2.3
                      tahoma.0
                      	2022-07-02 01:09:46.300	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
                      host.raspberrypi
                      	2022-07-02 01:09:44.086	info	instance system.adapter.tahoma.0 started with pid 27807
                      host.raspberrypi
                      	2022-07-02 01:09:13.866	info	Restart adapter system.adapter.tahoma.0 because enabled
                      host.raspberrypi
                      	2022-07-02 01:09:13.864	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      tahoma.0
                      	2022-07-02 01:09:13.254	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.254	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:09:13.253	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.252	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:09:13.250	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.249	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:09:13.248	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.247	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:09:13.242	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      tahoma.0
                      	2022-07-02 01:09:13.240	info	terminating
                      tahoma.0
                      	2022-07-02 01:09:13.236	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.236	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:09:13.234	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.233	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:09:13.227	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.226	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:09:13.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:09:13.219	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:00:53.155	info	eventRegisterID = 90020fb6-eea8-4b6d-a51c-c8870f5xxxxxx
                      tahoma.0
                      	2022-07-02 01:00:51.366	info	Using stored bearer token 6263c4b71f21561xxxxx
                      tahoma.0
                      	2022-07-02 01:00:51.363	info	Adapter will connect to Tahoma Box via local API.
                      tahoma.0
                      	2022-07-02 01:00:51.360	info	Configured polling interval: 500000
                      tahoma.0
                      	2022-07-02 01:00:51.359	info	[START] Starting adapter tahoma v0.7.2.3
                      tahoma.0
                      	2022-07-02 01:00:51.323	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
                      host.raspberrypi
                      	2022-07-02 01:00:49.003	info	instance system.adapter.tahoma.0 started with pid 27411
                      host.raspberrypi
                      	2022-07-02 01:00:18.879	info	Restart adapter system.adapter.tahoma.0 because enabled
                      host.raspberrypi
                      	2022-07-02 01:00:18.878	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      tahoma.0
                      	2022-07-02 01:00:18.224	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      tahoma.0
                      	2022-07-02 01:00:18.223	info	terminating
                      tahoma.0
                      	2022-07-02 01:00:18.221	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.221	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:00:18.220	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.220	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:00:18.219	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.219	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:00:18.218	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.218	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 01:00:18.216	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.215	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 01:00:18.209	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 01:00:18.209	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 00:35:18.102	info	eventRegisterID = 29eff3c1-fe48-4ff3-81ba-a7927f1xxxxx
                      tahoma.0
                      	2022-07-02 00:35:16.296	info	Using stored bearer token 6263c4b71f21561xxxxx
                      tahoma.0
                      	2022-07-02 00:35:16.293	info	Adapter will connect to Tahoma Box via local API.
                      tahoma.0
                      	2022-07-02 00:35:16.290	info	Configured polling interval: 500000
                      tahoma.0
                      	2022-07-02 00:35:16.289	info	[START] Starting adapter tahoma v0.7.2.3
                      tahoma.0
                      	2022-07-02 00:35:16.253	info	starting. Version 0.7.2 (non-npm: Excodibur/ioBroker.tahoma) in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.12, js-controller: 4.0.23
                      host.raspberrypi
                      	2022-07-02 00:35:14.066	info	instance system.adapter.tahoma.0 started with pid 26211
                      host.raspberrypi
                      	2022-07-02 00:34:43.957	info	Restart adapter system.adapter.tahoma.0 because enabled
                      host.raspberrypi
                      	2022-07-02 00:34:43.956	error	instance system.adapter.tahoma.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      tahoma.0
                      	2022-07-02 00:34:43.306	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      tahoma.0
                      	2022-07-02 00:34:43.305	info	terminating
                      tahoma.0
                      	2022-07-02 00:34:43.303	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.302	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 00:34:43.302	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.301	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 00:34:43.301	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.300	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 00:34:43.300	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.299	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      tahoma.0
                      	2022-07-02 00:34:43.298	error	The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.297	error	Error: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position! at validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5669:23) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5752:21) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:1317:36) at processImmediate (internal/timers.js:463:21)
                      tahoma.0
                      	2022-07-02 00:34:43.294	error	unhandled promise rejection: The state contains the forbidden properties security_level, soft_stop, discreet_mode_speed, nominal_mode_speed, soft_start, smart_protect, unroll_end_limit_state, roll_end_limit_state, open_level, setting_state, current_position!
                      tahoma.0
                      	2022-07-02 00:34:43.294	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      Gruß Willi
                        memme last edited by memme
                        Wenn ich den bei meinem Rolladen den command.down auf True stelle, fährt der Rolladen runter. Er stellt sich dann aber nicht wieder auf false, wenn er runtergefahren ist.
                        Nun kann ich auch keinen anderen Rolladen mehr fahren, sondern muss die adapter instanz neu starten. Dann kann ich wieder einmal fahren.
                        Wenn ich nach dem runterfahren den down wert wieder auf false stelle geht es wieder mit dem hochfahren. Dann muss ich up wieder auf false stellen. Das geht dann ein paar mal, dann gar nicht mehr und ich muss die instanz wieder neustarten.....
                        Gibt es eine Anleitung um die Rolläden als button in Jarvis hinzuzufügen?
                        note: Nutze tahoma switch, adapter auf 0.7.2
                        Excodibur 1 Reply Last reply Reply Quote 0
                        • Excodibur
                          Excodibur Developer @memme last edited by
                          @memme Ja, das ist einer der komplizierteren Bugs mit der lokalen API. Hängt mit https://github.com/Excodibur/ioBroker.tahoma/issues/149 zusammen, nur leider bin ich noch nicht dazu gekommen.
                          NilsReinecke created this issue in Excodibur/ioBroker.tahoma
                          closed Failed getting execution state on local api #149
                          M T 2 Replies Last reply Reply Quote 0
                            Wie macht ihr es denn, wenn ihr einen Repeater braucht? Der IO Somfy Repeater kostet ja mehr als die Switch. Kann man die Connexoon in die Switch einlernen und dann auch mit dem Adapter steuern? Denn die Connexoon als single wird ja nicht vom adapter unterstützt.
                            Und gibt es eine Jarvis Anleitung?
                              mike2712 last edited by
                              ich habe auch noch mal einen neuen Versuch mit der neueren Version vorgenommen, aber irgendwie komme ich nicht weiter, wie schaltet man eigentlich um, auf lokal und umgekehrt?
                              Hier der Log, mir sagt das alles nicht viel:
                              -2989-5271.local, request path: setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:22:50.248	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:22:50.247	debug	Update gateway status for id undefined
                              tahoma.0
                              2022-07-08 09:22:20.245	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:22:10.227	debug	GET request on https://gateway-xxxxx-xxxxx-xxxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:22:10.226	debug	Update gateway status for id undefined
                              tahoma.0
                              2022-07-08 09:21:40.224	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:21:30.304	warn	{"error":{"errno":-3001,"code":"EAI_AGAIN","syscall":"getaddrinfo","hostname":"gateway-xxxxx-xxxxx-xxxxx.local"}}
                              tahoma.0
                              2022-07-08 09:21:30.304	warn	setup failed!
                              tahoma.0
                              2022-07-08 09:21:30.303	warn	error during request: Error: getaddrinfo EAI_AGAIN gateway-xxxxx-xxxxx-xxxxx.local, request path: setup with payload:{}
                              tahoma.0
                              2022-07-08 09:21:30.204	debug	GET request on https://gateway-xxxxx-xxxx-xxxx.local:8443/enduser-mobile-web/1/enduserAPI/setup/gateways with payload:{}
                              tahoma.0
                              2022-07-08 09:21:30.203	debug	Update gateway status for id undefined
                              • Excodibur
                                Excodibur Developer @mike2712 last edited by
                                @mike2712 Wenn du ab Version 0.7.2 die Gateway PIN aus der Konfiguration nimmst, verbindet sich der Adapter statt mit der lokalen API wieder mit Tahomalink (online).
                                Dein Fehler getaddrinfo EAI_AGAIN deutet darauf hin, das bei dir die lokale Namensauflösung nicht funktioniert, d.h. der Adapter findet zu dem Namen kein Gerät im lokalen Netz. Eine Lösung wäre in deinem Router zu schauen, welche IP zu der Domain (gateway-xxxxx-xxxxx-xxxxx.local) gehört und die auf dem System wo dein Adapter läuft direkt mit der IP in die lokale hosts Datei einzutragen und dann den Adapter neu zu starten.
                                  mike2712 @Excodibur last edited by
                                  @excodibur
                                  danke für den Tipp.
                                  Adapter:
                                  Fritz Box:
                                  An welcher Stelle muss ich jetzt die 172.16.20.61 eintragen, das verstehe ich nicht?
                                    wusa @mike2712 last edited by
                                    @mike2712
                                    Wenn ich das richtig sehe, dann ist bei dir Tahoma im selben Netz wie "alles" andere auch?
                                    Hast du schon mal mDNS aktiviert?
                                    Funktioniert es damit?
                                      mike2712 @wusa last edited by
                                      @wusa
                                      ja mDNS das habe ich aktiviert.
                                      Es ist aber nicht alles im selben Netz. Der iOBroker ist 172.16.20.30,. Alles im selben Netz ist unmöglich, dafür sind es zu viele Geräte, das ist in bestimmten Gruppen aufgeteilt, es ist alles im 172.16.xx.xx.
                                      Das es nicht gefunden wird klingt etwas plausibel, aber ich weiß nicht an welcher Stelle ich den "IP in die lokale hosts Datei " eintragen muss.
                                      • Excodibur
                                        @mike2712 mDNS funktioniert bei mir zu Hause im von einer Fritzbox verwalteten Netz z.B. nicht, deswegen habe ich das immer aus.
                                        Die IP-Adresse musst du bei dem von mir vorgeschlagenen Workaround in die hosts-Datei deines Betriebssystems (inkl. Hostname) eintragen. Läuft ioBroker auf Linux, normalerweise unter /etc/hosts, bei Windows meistens C:\Windows\System32\drivers\etc\hosts. Dort dann einen Eintrag in folgendem Format hinzufügen:
                                        172.16.20.61  gateway-xxxxx-xxxxx-xxxxx.local gateway-xxxxx-xxxxx-xxxxx
                                        xxxx ist natürlich deine individuelle Gateway-ID
                                        M 2 Replies Last reply Reply Quote 1
                                          mike2712 @Excodibur last edited by mike2712
                                          @excodibur
                                          danke, bei mir läuft es im Docker Container, vielleicht noch jemand hier der sich damit etwas auskennt?
                                          Habe einiges probiert, aber hab es nicht hinbekommen.
                                          TCP 172.16.22.35:9999 Error: connect EHOSTUNREACH 172.16.22.35:9999
                                              at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1159:16) {
                                            errno: -113,
                                            code: 'EHOSTUNREACH',
                                            syscall: 'connect',
                                            address: '172.16.22.35',
                                            port: 9999
                                          172.16.20.61 gateway-2006-2989-5271.loacal gateway-xxxx-xxxx-xxxx
                                            errno: -113,
                                            syscall: 'connect',
                                            port: 9999
                                          # list
                                          /bin/sh: 1: list: not found
                                          # dir
                                          backups  homematic_2022_01_11-01_30_12_2.59.7_backupiobroker.tar.sbk  INSTALLER_INFO.txt  iob  iobroker  iobroker.bak  iobroker-data  log  node_modules  package.json  package-lock.json  @Recently-Snapshot  @Recycle  reinstall.js
                                          # cd iob
                                          /bin/sh: 3: cd: can't cd to iob
                                          # cd iobroker
                                          /bin/sh: 4: cd: can't cd to iobroker
                                          # iobroker
                                          iobroker [command]
                                          Commands:
                                            iobroker setup                                               Setup ioBroker
                                            iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                                            iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                                            iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                                            iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                                            iobroker info                                                Shows the host info
                                            iobroker logs [<adapter>]                                    Monitor log
                                            iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                                            iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                                            iobroker rebuild [<module>]                                  Rebuild all native modules or path
                                            iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                                            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                                            iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                                            iobroker update [<repositoryUrl>]                            Update repository and list adapters
                                            iobroker upgrade                                             Upgrade management
                                            iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                                            iobroker object                                              Object management  [aliases: o]
                                            iobroker state                                               State management  [aliases: s]
                                            iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                                            iobroker list <type> [<filter>]                              List all entries, like objects
                                            iobroker chmod <mode> <file>                                 Change file rights
                                            iobroker chown <user> <group> <file>                         Change file ownership
                                            iobroker touch <file>                                        Touch file
                                            iobroker rm <file>                                           Remove file
                                            iobroker file                                                File management
                                            iobroker user                                                User commands
                                            iobroker group                                               group management
                                            iobroker host <hostname>                                     Set host to given hostname
                                            iobroker set <adapter>.<instance>                            Change settings of adapter config
                                            iobroker license <license.file or license.text>              Update license by given file
                                            iobroker cert                                                Certificate management
                                            iobroker clean <yes>                                         Clears all objects and states
                                            iobroker backup                                              Create backup
                                            iobroker restore <backup name or path>                       Restore a specified backup
                                            iobroker validate <backup name or path>                      Validate a specified backup
                                            iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                                            iobroker repo [<name>]                                       Show repo information
                                            iobroker uuid                                                Show uuid of the installation  [aliases: id]
                                            iobroker unsetup                                             Reset license, installation secret and language
                                            iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                                            iobroker multihost                                           Multihost management
                                            iobroker compact                                             compact group management
                                            iobroker plugin                                              Plugin management
                                            iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                                          Options:
                                            --help  Show help  [boolean]
                                          # 172.16.20.61 gateway-xxxx-xxxx-xxxx.loacal gateway-xxxx-xxxx-xxxx
                                          /bin/sh: 6: 172.16.20.61: not found
                                          • Excodibur
                                            @mike2712 Das hinter deinem Gateway-Namen ".loacal" statt ".local" steht, ist seltsam.
                                            Bei Docker gäbe es zwei Möglichkeiten:
                                            • Du verwendest beim Deployment --add-host (https://docs.docker.com/engine/reference/commandline/run/#add-entries-to-container-hosts-file---add-host) und fügst das IP-Hostname-Mapping hinzu. Bei docker-compose wäre das Der extra_hosts Abschnitt.
                                            • Du zwingst deinen Container via --network=host (https://docs.docker.com/network/host/) das Netzwerk des Host-Systems direkt mit zu nutzen, dann wird sicher auch die hosts-Datei deines Betriebssystems bei der Namensauflösung verwendet. Damit hebst du aber auch einen Teil der Docker Container-Isolierung auf, was nicht so optimal ist. Daher würde ich immer eher zu Option 1 raten.
                                            605
                                            157399
