    4. Test Adapter luxtronik2 v0.4.x
      Henning 1 last edited by
      Hier inkl. eingegebenes Kommando:
      pi@iobroker-pi:/opt/iobroker $ npm i iobroker.luxtronik2                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules'
      npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/pi/.npm/_logs/2022-07-03T12_13_16_514Z-debug.log
        Thomas Braun Most Active @Henning 1 last edited by
        @henning-1
        groups
        als pi ausgeführt liefert?
          pi@iobroker-pi:/opt/iobroker $ groups
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
            @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
            Alternativ:
            cd /opt/iobroker
            sudo -H -u iobroker npm i iobroker.luxtronik2
              @henning-1
              Der pi fehlt in der Gruppe 'iobroker'
              sudo usermod -aG iobroker pi
                @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
                Das liefert er:
                pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                + iobroker.luxtronik2@0.4.2
                added 7 packages from 82 contributors in 29.319s
                50 packages are looking for funding
                  run `npm fund` for details
                Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
                  Henning 1 @Thomas Braun last edited by
                  Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
                  pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
                  pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
                  host.iobroker-pi install adapter luxtronik2
                  upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
                  upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
                  upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
                  upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
                  host.iobroker-pi object system.adapter.luxtronik2 created/updated
                  host.iobroker-pi create instance luxtronik2
                  host.iobroker-pi object system.adapter.luxtronik2.0.alive created
                  host.iobroker-pi object system.adapter.luxtronik2.0.connected created
                  host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
                  host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
                  host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
                  host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
                  host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
                  host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
                  host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
                  host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
                  host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
                  host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
                  host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
                  host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
                  host.iobroker-pi object luxtronik2.0.info created
                  host.iobroker-pi object luxtronik2.0.info.connection created
                  host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
                  host.iobroker-pi object system.adapter.luxtronik2.0 created
                  Ich mache mal nen Reboot und schaue dann, was ich sehe.
                    Henning 1 @Henning 1 last edited by
                    Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
                    Schönes WE soweit noch 🙂
                      ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                      2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                      2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                      2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                      2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                      2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                      2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                        @henning-1
                        Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                          Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                          und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                            Das Ganze steht bei Wärmemenge auch nochmal drin
                              Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                              Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                                @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                                  pgBroker last edited by pgBroker
                                  Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                                  Unknown data item parameters.mk1_curve_parallel_offset
                                  Unknown data item parameters.mk1_curve_end_point
                                  Unknown data item parameters.deltaMk1Reduction
                                  Wie kriege ich die weg?
                                    pgBroker @pgBroker last edited by
                                    Hmmm, hat niemand ne idee? 😕
                                    • Bernd 0
                                      Bernd 0 last edited by
                                      kann man über den Adapter herausfinden, welchen Leistungsbezug die Wärmepumpe aus dem Netz bezieht? Also kWh?
                                      Ich habe nur gefunden, dass man die erzeugte Wärmeleistung abfragen kann.
                                      Vielen Dank.
                                      GB
                                      TbsJah 1 Reply Last reply Reply Quote 0
                                      • TbsJah
                                        TbsJah @Bernd 0 last edited by
                                        @bernd-0 aktuell gibt es dafür keinen Parameter.
                                        Du könntest den Wert jedoch annäherungsweise über die Temperatur WQ ermitteln
                                        Bernd 0 1 Reply Last reply Reply Quote 0
                                          hg4711 last edited by
                                          ich hatte den Adapter neu installiert (0.4.2). Er ist auch konfigurierbar mit dem Passwort, den Parametern Websocket 8214 und Port 8889 bekomme ich keine Verbindung. Im Log bekomme ich nach dem Start die Fehlermeldung:
                                          2d9b730f-841d-4915-af6e-ce08dcbd6e27-image.png und weitere als Konsequenz ...
                                          Hat jemand eine Idee was hier fehlt oder schief läuft?
                                          Danke schon mal
                                            Thomas Braun Most Active @hg4711 last edited by Thomas Braun
                                            @hg4711 sagte in Test Adapter luxtronik2 v0.4.x:
                                            Eine aktuelle Version von nodejs.
                                            Der vorgesehene Stand ist nodeJS 16.
                                            Der js-controller ist auch veraltet:
                                            stable: 4.0.23 for 4 months
                                            Bring dein System auf Stand.
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            67915
