    4. Test Adapter luxtronik2 v0.4.x
      Thomas Braun Most Active @Henning 1 last edited by
      @henning-1 sagte in Test Adapter luxtronik2 v0.4.x:
      npm i iobroker.luxtronik2
      Alternativ:
      cd /opt/iobroker
      sudo -H -u iobroker npm i iobroker.luxtronik2
        @henning-1
        Der pi fehlt in der Gruppe 'iobroker'
        sudo usermod -aG iobroker pi
          @thomas-braun sagte in Test Adapter luxtronik2 v0.4.x:
          Das liefert er:
          pi@iobroker-pi:/opt/iobroker $ sudo -H -u iobroker npm i iobroker.luxtronik2
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + iobroker.luxtronik2@0.4.2
          added 7 packages from 82 contributors in 29.319s
          50 packages are looking for funding
            run `npm fund` for details
          Den Adapter sehe ich noch nicht. Gruppe mache ich gleich
            Henning 1 @Thomas Braun last edited by
            Sieht besser aus. Habe nach der Gruppenanpassung den add Befehr ausgeführt
            pi@iobroker-pi:/opt/iobroker $ sudo usermod -aG iobroker pi
            pi@iobroker-pi:/opt/iobroker $ iobroker add luxtronik2
            host.iobroker-pi install adapter luxtronik2
            upload [4] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/admin.d.ts admin.d.ts video/mp2t
            upload [3] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/index_m.html index_m.html text/html
            upload [2] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/luxtronik2.png luxtronik2.png image/png
            upload [1] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/style.css style.css text/css
            upload [0] luxtronik2.admin /opt/iobroker/node_modules/iobroker.luxtronik2/admin/words.js words.js application/javascript
            host.iobroker-pi object system.adapter.luxtronik2 created/updated
            host.iobroker-pi create instance luxtronik2
            host.iobroker-pi object system.adapter.luxtronik2.0.alive created
            host.iobroker-pi object system.adapter.luxtronik2.0.connected created
            host.iobroker-pi object system.adapter.luxtronik2.0.compactMode created
            host.iobroker-pi object system.adapter.luxtronik2.0.cpu created
            host.iobroker-pi object system.adapter.luxtronik2.0.cputime created
            host.iobroker-pi object system.adapter.luxtronik2.0.memHeapUsed created
            host.iobroker-pi object system.adapter.luxtronik2.0.memHeapTotal created
            host.iobroker-pi object system.adapter.luxtronik2.0.memRss created
            host.iobroker-pi object system.adapter.luxtronik2.0.uptime created
            host.iobroker-pi object system.adapter.luxtronik2.0.inputCount created
            host.iobroker-pi object system.adapter.luxtronik2.0.outputCount created
            host.iobroker-pi object system.adapter.luxtronik2.0.eventLoopLag created
            host.iobroker-pi object system.adapter.luxtronik2.0.sigKill created
            host.iobroker-pi object system.adapter.luxtronik2.0.logLevel created
            host.iobroker-pi object luxtronik2.0.info created
            host.iobroker-pi object luxtronik2.0.info.connection created
            host.iobroker-pi Set default value of luxtronik2.0.info.connection: false
            host.iobroker-pi object system.adapter.luxtronik2.0 created
            Ich mache mal nen Reboot und schaue dann, was ich sehe.
              Henning 1 @Henning 1 last edited by
              Vielen Dank für Diene Zeit eben!!! Das hat geholfen und der Adapter ist sichtbar und scheint mit Port 8889 und PWD 0000 zu funktionieren. Ich spiele jetzt bzw. heute Abend erstmal und versuche Logiken im Zusammenspiel mit dem Fronius WR zu basteln.
              Schönes WE soweit noch 🙂
                ich habe jede Menge Fehlermeldungen im Protokoll. Liegt das an mir oder an der Adapter Version? Anbei ein Ausschnitt:
                2022-07-05 10:49:51.478 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-1_C
                2022-07-05 10:49:51.553 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-1_C
                2022-07-05 10:49:51.562 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-1°C" has no existing object, this might lead to an error in future versions
                2022-07-05 10:50:02.620 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Ausgänge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Ausgänge.51-0_C-53-2_C
                2022-07-05 10:50:02.685 - warn: luxtronik2.0 (15011) Used invalid characters: luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C changed to luxtronik2.0.Informationen.Wärmemenge.51-0_C-53-2_C
                2022-07-05 10:50:02.697 - warn: luxtronik2.0 (15011) State "luxtronik2.0.Informationen.Wärmemenge.51-0°C-53-2°C" has no existing object, this might lead to an error in future versions
                  @henning-1
                  Die Gradzeichen sind nicht zulässig und werden ersetzt. Wenn der Datenpunkt von dir so angelegt wurde: Ändere es ab.
                    Das ist es ja. Ich hab da gar nichts angelegt. Nur die Instanz. Alles andere ist so, wie vom Adapter vorgegeben. Und das sieht bei Ausgängen so aus:
                    und geht so weiter bis 57. Danach kommt AV-Abtauventil...
                      Das Ganze steht bei Wärmemenge auch nochmal drin
                        Ich habe mal das Webinterface mit den Adapterwerten verglichen. Neben dieses Vielen Temperaturwerten gibt es noch andere Unterschiede. Bei Eingänge fehlt bsw. Durchfluss 2 etc
                        Bei Temperaturen fehlen auch Parameter. Kann es sein, dass der Adapter da irgendwie durcheinander kommt?
                          @UncleSam Soll ich da ein Ticket aufmachen? Ich habe nämlich zwei Außeneinheiten an einer Steuerung. Daher gibt's bei mir einige Werte doppelt. Mit manchen schien der Adapter klar zu kommen ,mit anderen nicht.
                            pgBroker last edited by pgBroker
                            Musste meinen ioBroker nach einem Crash neu aufsetzen und bekomme jetzt im log im Sekundentakt diese Warnung:
                            Unknown data item parameters.mk1_curve_parallel_offset
                            Unknown data item parameters.mk1_curve_end_point
                            Unknown data item parameters.deltaMk1Reduction
                            Wie kriege ich die weg?
                              pgBroker @pgBroker last edited by
                              Hmmm, hat niemand ne idee? 😕
                              • Bernd 0
                                Bernd 0 last edited by
                                kann man über den Adapter herausfinden, welchen Leistungsbezug die Wärmepumpe aus dem Netz bezieht? Also kWh?
                                Ich habe nur gefunden, dass man die erzeugte Wärmeleistung abfragen kann.
                                Vielen Dank.
                                GB
                                TbsJah 1 Reply Last reply Reply Quote 0
                                • TbsJah
                                  TbsJah @Bernd 0 last edited by
                                  @bernd-0 aktuell gibt es dafür keinen Parameter.
                                  Du könntest den Wert jedoch annäherungsweise über die Temperatur WQ ermitteln
                                  Bernd 0 1 Reply Last reply Reply Quote 0
                                    hg4711 last edited by
                                    ich hatte den Adapter neu installiert (0.4.2). Er ist auch konfigurierbar mit dem Passwort, den Parametern Websocket 8214 und Port 8889 bekomme ich keine Verbindung. Im Log bekomme ich nach dem Start die Fehlermeldung:
                                    2d9b730f-841d-4915-af6e-ce08dcbd6e27-image.png und weitere als Konsequenz ...
                                    Hat jemand eine Idee was hier fehlt oder schief läuft?
                                    Danke schon mal
                                      Thomas Braun Most Active @hg4711 last edited by Thomas Braun
                                      @hg4711 sagte in Test Adapter luxtronik2 v0.4.x:
                                      Eine aktuelle Version von nodejs.
                                      Der vorgesehene Stand ist nodeJS 16.
                                      Der js-controller ist auch veraltet:
                                      stable: 4.0.23 for 4 months
                                      Bring dein System auf Stand.
                                        lessthanmore last edited by
                                        @hg4711 Passwort korrekt?
                                        Gerne auch mal Port 8888 probieren.
                                          hg4711 @lessthanmore last edited by
                                          @lessthanmore
                                          Denke es liegt an einer alten FW Version der Luxtronik2. Was ich gelesen habe: Erst ab V. 3.81 gibt es Websockets. Muss ich mal prüfen ob die drauf ist. Bin aber gerade nicht vor Ort. Wochenende ...
                                          Port 8888 habe ich natürlich getestet und PW stimmt sicher, aber soweit kommt der Adapter gar nicht.
                                          Danke soweit
                                          • Bernd 0
                                            Bernd 0 @TbsJah last edited by Bernd 0
                                            @tbsjah Hi tbsjah,
                                            Danke für deine Antwort. Die Idee ist an sich nicht schlecht. Da die Leistungskurven aber keine einfachen Funktionen sind, könnte man nur für jeden Temperaturwert eine direkte Korrelation zur Leistungsaufnahme herstellen. Das finde ich ziemlich aufwändig und ist vermutlich auch nicht sehr genau. Bei meiner WP sind die Verläufe deutlich unschöner als in deinem Diagramm 🙂
                                            Desweiteren verstehe ich auch nicht, wieso es dann einen min/max Verlauf im Diagramm bzgl. Leistungsaufnahme und Abgabe der Heizleistung gibt und auch nicht, wieso die Leistungsaufnahme bei 65°C kleiner als bei 55°C ist. Da hab ich wohl eine Bildungslücke!
                                            Beste Grüße!
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            67913
