    4. Adapter für VELUX KLF-200 Interface
    • ChrisNett
      ChrisNett @adarof last edited by
      moin zusammen,
      der adapter ist bei leider immer mal wieder Rot
      host.IoBroker	2022-06-30 07:11:29.867	info	Do not restart adapter system.adapter.klf200.0 because desired by instance
      host.IoBroker	2022-06-30 07:11:29.867	error	instance system.adapter.klf200.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      klf200.0	2022-06-30 07:11:29.810	info	(304269) Remove socket listener...
      klf200.0	2022-06-30 07:11:29.304	info	(304269) Terminated (ADAPTER_REQUESTED_TERMINATION): Login to KLF-200 device at 192.168.178.83 failed.
      klf200.0	2022-06-30 07:11:25.035	info	(304269) Host: 192.168.178.83
      klf200.0	2022-06-30 07:11:25.027	silly	(304269) States system redis pmessage system.adapter.klf200.0.logLevel/system.adapter.klf200.0.logLevel:{"val":"silly","ack":true,"ts":1656565885022,"q":0,"from":"system.adapter.klf200.0","lc":165656
      klf200.0	2022-06-30 07:11:24.996	debug	(304269) Schedule restart: 0 3 * * *
      klf200.0	2022-06-30 07:11:24.983	info	(304269) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.klf200, node: v14.19.1, js-controller: 4.0.21
      klf200.0	2022-06-30 07:11:24.787	silly	(304269) statesDB connected
      klf200.0	2022-06-30 07:11:24.787	debug	(304269) States connected to redis: 127.0.0.1:9000
      klf200.0	2022-06-30 07:11:24.758	debug	(304269) States create User PubSub Client
      klf200.0	2022-06-30 07:11:24.757	debug	(304269) States create System PubSub Client
      klf200.0	2022-06-30 07:11:24.743	debug	(304269) Redis States: Use Redis connection: 127.0.0.1:9000
      klf200.0	2022-06-30 07:11:24.742	silly	(304269) objectDB connected
      klf200.0	2022-06-30 07:11:24.739	silly	(304269) redis psubscribe cfg.o.enum.*
      klf200.0	2022-06-30 07:11:24.723	silly	(304269) redis psubscribe cfg.o.system.user.*
      klf200.0	2022-06-30 07:11:24.722	debug	(304269) Objects connected to redis: 127.0.0.1:9001
      klf200.0	2022-06-30 07:11:24.719	debug	(304269) Objects client initialize lua scripts
      klf200.0	2022-06-30 07:11:24.674	debug	(304269) Objects create User PubSub Client
      klf200.0	2022-06-30 07:11:24.673	debug	(304269) Objects create System PubSub Client
      klf200.0	2022-06-30 07:11:24.672	debug	(304269) Objects client ready ... initialize now
      klf200.0	2022-06-30 07:11:24.637	debug	(304269) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.IoBroker	2022-06-30 07:11:24.184	info	instance system.adapter.klf200.0 started with pid 304269
      host.IoBroker	2022-06-30 07:09:58.548	info	Do not restart adapter system.adapter.klf200.0 because desired by instance
      host.IoBroker	2022-06-30 07:09:58.547	error	instance system.adapter.klf200.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      klf200.0	2022-06-30 07:09:58.490	info	(304180) Remove socket listener...
      klf200.0	2022-06-30 07:09:57.982	info	(304180) Terminated (ADAPTER_REQUESTED_TERMINATION): Login to KLF-200 device at 192.168.178.83 failed.
      klf200.0	2022-06-30 07:09:54.008	silly	(304180) system.adapter.cloud.0: logging true
      klf200.0	2022-06-30 07:09:54.007	silly	(304180) States system redis pmessage *.logging/system.adapter.cloud.0.logging:{"val":true,"ack":true,"ts":1656565794001,"q":0,"from":"system.adapter.cloud.0","lc":1656565794001}
      klf200.0	2022-06-30 07:09:53.716	info	(304180) Host: 192.168.178.83
      klf200.0	2022-06-30 07:09:53.707	silly	(304180) States system redis pmessage system.adapter.klf200.0.logLevel/system.adapter.klf200.0.logLevel:{"val":"silly","ack":true,"ts":1656565793702,"q":0,"from":"system.adapter.klf200.0","lc":165656
      klf200.0	2022-06-30 07:09:53.676	debug	(304180) Schedule restart: 0 3 * * *
      klf200.0	2022-06-30 07:09:53.663	info	(304180) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.klf200, node: v14.19.1, js-controller: 4.0.21
      klf200.0	2022-06-30 07:09:53.463	silly	(304180) statesDB connected
      klf200.0	2022-06-30 07:09:53.463	debug	(304180) States connected to redis: 127.0.0.1:9000
      klf200.0	2022-06-30 07:09:53.438	debug	(304180) States create User PubSub Client
      klf200.0	2022-06-30 07:09:53.438	debug	(304180) States create System PubSub Client
      klf200.0	2022-06-30 07:09:53.424	debug	(304180) Redis States: Use Redis connection: 127.0.0.1:9000
      klf200.0	2022-06-30 07:09:53.423	silly	(304180) objectDB connected
      klf200.0	2022-06-30 07:09:53.420	silly	(304180) redis psubscribe cfg.o.enum.*
      klf200.0	2022-06-30 07:09:53.404	silly	(304180) redis psubscribe cfg.o.system.user.*
      klf200.0	2022-06-30 07:09:53.403	debug	(304180) Objects connected to redis: 127.0.0.1:9001
      klf200.0	2022-06-30 07:09:53.400	debug	(304180) Objects client initialize lua scripts
      klf200.0	2022-06-30 07:09:53.358	debug	(304180) Objects create User PubSub Client
      klf200.0	2022-06-30 07:09:53.357	debug	(304180) Objects create System PubSub Client
      klf200.0	2022-06-30 07:09:53.356	debug	(304180) Objects client ready ... initialize now
      klf200.0	2022-06-30 07:09:53.298	debug	(304180) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.IoBroker	2022-06-30 07:09:52.853	info	instance system.adapter.klf200.0 started with pid 304180
      hier ein log von zwei Start versuchen, kann mir jemand helfen wo das Problem liegt?
      Christian
      A G 2 Replies Last reply Reply Quote 0
        adarof @ChrisNett last edited by
        @christian-sandkaulen Sah bei mir so aus, als ich wenige Beiträge drüber noch die alte FW hatte und gerade von Adapter 0.9.5 auf 1.0.1 gegangen bin. Dabei wird die neue benötigt, wie auch das ChangeLog sagt.
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          @adarof sagte in Adapter für VELUX KLF-200 Interface:
          welche versiob hast du den auf dem KLF 200 ?
          ich habe die 0.2.0.0.71.0
          Christian
            gemuesepudding Developer @ChrisNett last edited by
            @christian-sandkaulen Immer mal wieder heißt: "an sich geht es", aber dann ist der irgendwann auf rot? Das habe ich auch. Der KLF scheint zu crashen und da die [ironie]FW ja so tolle ist gibt es auch updates dafür ohne Enden....[/ironie]. Da hat bei mir nur Strom weg geholfen.
            Ich habe mir ein sonoff davor gepackt und der schaltet das Teil kurz stromlos und wieder an
            ChrisNett F 2 Replies Last reply Reply Quote 0
            • ChrisNett
              ChrisNett @gemuesepudding last edited by
              @gemuesepudding
              ja genau so ist es, es geht 3-5 Tage dann will er nicht mehr und mit neustart geht das dann, ich starte ihn später mal neu und wenn das hilft werde ich das auch mit Tasmota lösen.
              eine Reboot mit der API gibt es nicht oder? könnte man dann nachts immer mal durchführen.
              • amg_666
                amg_666 @ChrisNett last edited by
                @christian-sandkaulen @gemuesepudding Ich habe im Adapter bei "cron pattern for reboot" einen cron-job eingetragen, damit das Teil jede Nacht um 3 Uhr rebootet: 0 3 * * *.
                Seitdem ist es ziemlich stabil und für alle Fälle ist da bei mir auch ein schaltbarer Zwischenstecker (gosund sp111) vorgeschaltet.
                  Frank579 @gemuesepudding last edited by Frank579
                  @gemuesepudding sagte in Adapter für VELUX KLF-200 Interface:
                  Man kann im Adapter den täglichen Neustart einstellen, seit dem läuft meins ohne jegliche Probleme.
                  Ist wenn ich das richtig im Kopf habe aus dem Grund rein gekommen, musst Mal hier schauen...
                  • ChrisNett
                    ChrisNett @Frank579 last edited by
                    Ich habe den KLF200 mal für 2min von netz getrennt und wieder eingebunden, dann blinkte er auch nicht mehr und ich konnte mich wieder verbinden mit ihm. Denke ich werde das mal beobachten und dann zur not einen 5V/Wemos/Relay davor schalten.
                    Christian
                    • ChrisNett
                      ChrisNett @ChrisNett last edited by
                      nach einem Neustart läuft der Adapter jetzt auch gut durch.
                      könnt ihr mir sagen welchen DP ihr zum hoch und runter fahren nutzen kann ? ich mache das im Moment immer über den DP targetPosition
                      • amg_666
                        @christian-sandkaulen So mache ich das auch, in der Visualisierung habe ich dazu je Fenster 4 "Knöpfe" die jeweils die target_position setzen:
                          memberx last edited by
                          Bei mir funktioniert komischerweise immer nur die Seitenmarkise, das Faltdach funktioniert ca. 1 von 100 mal. Über die Somfy Fernbedienung funktioniert alles ohne Probleme. Keine Ahnung warum es über das KLF200 nicht will bzw. über ioBroker 😞
                          • ChrisNett
                            ChrisNett @memberx last edited by
                            @memberx sagte in Adapter für VELUX KLF-200 Interface:
                            empfang? mal neu angelernt?
                              Tontaube last edited by
                              Hi, vor 4 Tagen wurde mein Internetanbieter gewechselt, aktuell läuft alles noch über den alten Router, den ich natürlich einmal zurück setzen musst. WLAN Passwort und Name sind noch identisch wie vorher.
                              Das einzige was seither nicht mehr funktioniert ist die Verbindung zwischen dem Adapter und der klf200.
                              Ich habe die Box einmal aus dem Router raus geworfen, den Adapter mehrfach gelöscht, sämtliche Nutzernamen uns Passwörter versucht.
                              Ich komme leider nicht mehr weiter. Die letzten 1,5 Jahre lief der Adapter problemlos.
                              Wo ich mir nicht ganz sicher bin ist was ich tatsächlich als Host bzw. als Passwort eintragen muss.
                              Lt. Anleitung: "Host
                              Hostname Ihrer KLF-200-Schnittstelle. Dies ist die gleiche Adresse, die Sie in der Adressleiste Ihres Webbrowsers zum Verbinden mit Ihrer Box eintragen."
                              Wenn ich das richtig verstehe - wenn ich ich per WLAN mit der klf verbinde geh ich über den Browser per http://klf200.velux. Dann gibt es das Passwort velux123 oder alternativ das WLAN Passwort. Beide funktionieren nicht.
                              Wenn ich den Adapter neu installiere ist als Host schon "velux-klf-" eingetragen. Dies würde der SSID entsprechen also hänge ich noch die 4 Ziffern entsprechend an. Funktioniert mit beiden Passwörtern nicht. Wenn ich die SSID auf meiner klf ablese wird diese mit VELUX_KLF_XXXX angegeben, also groß geschrieben und mit Unterstrich. Auch so bekomme ich keinen zugriff.
                              Die Fehlermeldung wäre jeweils:
                              klf200.0 2022-07-10 17:18:20.130 info Remove socket listener...
                              klf200.0 2022-07-10 17:18:19.595 info Terminated (ADAPTER_REQUESTED_TERMINATION): Login to KLF-200 device at velux-klf-XXXX failed.
                              klf200.0 2022-07-10 17:18:19.568 info Host: velux-klf-XXXX
                              klf200.0 2022-07-10 17:18:19.496 info starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.klf200, node: v14.19.3, js-controller: 4.0.23
                              Der Status des Adapters wird jeweils
                              Verbunden mit Host - kurz grün
                              Lebenszeichen - zusätzlich kurz grün
                              Verbunden mit Gerät oder Dienst - bleibt immer rot
                              nach 2 sec ist wieder alles rot.
                              Ich weiß leider nicht mehr weiter - wer kann mir helfen?
                              F amg_666 2 Replies Last reply Reply Quote 0
                                Frank579 @Tontaube last edited by
                                @tontaube
                                Host ist die IP adresse (ohne http/https) des KLF , passwort das WLAN passwort
                                • amg_666
                                  amg_666 @Tontaube last edited by
                                  @tontaube sagte in Adapter für VELUX KLF-200 Interface:
                                  Was genau funktioniert denn nicht? Der klf baut ein eigenes WLAN auf, mit dem musst du dich verbinden. Klappt das?
                                  dann im Browser die Seite klf200.velux aufrufen, klappt das?
                                  Das Passwort müsste auf dem Aufkleber des klf stehen, versuchs mal damit.
                                    Frank579 @amg_666 last edited by
                                    @amg_666 sagte in Adapter für VELUX KLF-200 Interface:
                                    • amg_666
                                      amg_666 @Frank579 last edited by
                                      @frank579 Also kommst du über das Webinterface auf den klf wenn du dich mit wlan verbunden hast, was der klf aufspannt? Dann kannst du da ja mal checken welche Einstellungen/Passwörter du vergeben hast.
                                      Ich würde auch noch versuchen im klf Adapter anstelle von klf200.velux mal die ip adresse des klf anzugeben. Wenn dein neuer Router nicht richtig auflöst könnte das das Problem sein
                                        Bin nicht der fragende 🙂 hatte ich ihm eben auch schon geschrieben 😉
                                        Bei mir hats mit dem namen auch nie funktioniert, vermute der adapter brauch die IP ....
                                          Über das eigene wlan vom Adapter bekomme ich Zugriff auf das klf. Ip Adresse als Host habe ich auch schon versucht. Ich muss mal am klf die Passwörter checken wenn ich wieder zuhause bin. Aber da wlan Passwort funktioniert ja und velux123 im webinterface auch.
                                            Also ich habe nun dem klf eine neue statische ip adresse zugewiesen und diese als host angetragen - Passwort vom klf WLAN und nun funktioniert es wieder. Die ip Adresse die die klf vorher hatte hat nicht funktioniert.
                                            Danke an alle für die schnelle hilfe! 👍
                                            Grüße Tontaube
                                            79.9k
                                            335
                                            64795
