    4. Test Adapter Nuki-extended v2.0.x
      Thomas Braun Most Active @Horst Böttcher last edited by
      @horst-böttcher
      Ich schon. Screenshot?
      Horst Böttcher 1 Reply Last reply Reply Quote 0
      • Horst Böttcher
        Horst Böttcher @Thomas Braun last edited by
          @horst-böttcher
          iobroker update -i
          zeigen.
          • Horst Böttcher
            pi@raspberrypi:/opt/iobroker $ iobroker update -i
            Used repository: stable
            Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "alias-manager": 1.2.4    , installed 1.2.4
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "bring"        : 1.8.1    , installed 1.8.1
            Adapter    "chromecast"   : 2.3.1    , installed 3.0.1
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "devices"      : 1.0.12   , installed 1.0.12
            Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "history"      : 1.11.1   , installed 1.11.1
            Adapter    "hmip"         : 1.17.0   , installed 1.17.0
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "ical"         : 1.12.1   , installed 1.12.1
            Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.11.4   , installed 1.11.4
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            Adapter    "logparser"    : 1.1.0    , installed 1.1.0
            Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
            Adapter    "nina"         : 0.0.25   , installed 0.0.25
            Adapter    "node-red"     : 3.3.1    , installed 3.3.0  [Updatable]
            Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
            Adapter    "nut"          : 1.5.1    , installed 1.5.1
            Adapter    "openweathermap": 0.2.4   , installed 0.2.4
            Adapter    "pushover"     : 2.1.0    , installed 2.1.0
            Adapter    "rssfeed"      : 1.0.0    , installed 1.0.0
            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "sql"          : 1.16.2   , installed 1.16.2
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.13.0   , installed 1.13.0
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tuya"         : 3.6.15   , installed 3.6.15
            Adapter    "vis"          : 1.4.15   , installed 1.4.15
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
            Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
            Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
            Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
            Adapter    "windows-control": 0.1.5  , installed 0.1.5
              @horst-böttcher
              Hast du im Admin noch auf 'alte Oberfläche' gestellt?
              • Horst Böttcher
                @thomas-braun ja habe gerade wieder zurück gestellt und ist immer noch so
                  @horst-böttcher
                  Browser Cache gelöscht?
                  Horst Böttcher 1 Reply Last reply Reply Quote 1
                  • Horst Böttcher
                    Horst Böttcher @Thomas Braun last edited by Horst Böttcher
                    @thomas-braun Jo jetzt geht es dank
                    • Boris Holowka
                      Boris Holowka @Boris Holowka last edited by Boris Holowka
                      Moin Leute
                      Schon lange wollte ich Aktionen steuern wenn jmd. via dem Keypad die Wohnung betritt. Nun kann dies in den Logs ausgelesen werden: nuki-extended.0.smartlocks.wohnungstür.logs
                      Problem: Ich würde gerne dort den Wert "name" auslesen und je nachdem was da drin steht via Blockly eine Aktion starten. Ich habe versucht den Text mit einem Blockly auszulesen. Jedoch reagiert er bei jedem neuen Logeintrag, da er natürlich das ganze Log durchcheckt und den Namen dann findet. Kann man das so steuern, dass er nur den letzten Eintrag checkt und nur diesen Wert von "name" auswertet?
                        Matze89 last edited by Matze89
                        im Datenpunkt Logs werden bei mir die zeiten um 2 Stunden falsch angezeigt?
                        laut logs 15:05 Uhr ist aber tatsächlich 17:05Uhr, ist bei allen einträgen um 2 Stunden Falsch.
                        Egal ob V.2.3.1 oder 2.6.5 ist überall das selbe, hat noch jemand das problem?
                        wie kann ich das ändern?
                        "autoUnlock": false,
                        "date": "2022-07-05T15:05:00.000Z"
                        danke schon mal 🙂
                          Thomas Braun Most Active @Matze89 last edited by Thomas Braun
                          @matze89
                          timedatectl
                          sagt dir?
                          Und 15Z sind 17Uhr lokal. Passt also.
                            Matze89 @Thomas Braun last edited by
                            Local time: Mi 2022-07-06 14:59:01 CEST
                            Universal time: Mi 2022-07-06 12:59:01 UTC
                            RTC time: Mi 2022-07-06 12:59:01
                            NTP service: active
                            RTC in local TZ: no
                              @matze89
                              Passt doch. Ich seh auch dein Problem nicht wirklich. Die Zeiten sind korrekt.
                                @thomas-braun das problem ist immernoch diese Uhrzeit-angabe im wert “T15:05:00.000Z“
                                Diese Uhrzeit-Angabe ist einfach völliger quatsch um das ganze ordentlich zu visualisieren, wie soll man bitte da eine 17:05 Uhr daraus machen ohne alles auseinanderzu nehmen?
                                  @matze89
                                  Vermutlich gibt es da eine Möglichkeit, die Z-Zeit in die lokale Zeitzone zu konvertieren. Ich hab aber keine vis laufen, kann dir da also nicht weiterhelfen.
                                    Matze89 @Thomas Braun last edited by Matze89
                                    @thomas-braun hab die json in brauchbare datenpunkte umgewandelt.
                                    Sieht nun bisher so aus:
                                    Horst Böttcher H 2 Replies Last reply Reply Quote 0
                                    • Horst Böttcher
                                      Horst Böttcher @Matze89 last edited by
                                      @matze89 sagte in Test Adapter Nuki-extended v2.0.x:
                                      kannst du das zur Verfügungstellung
                                      • Horst Böttcher
                                        Horst Böttcher @Horst Böttcher last edited by
                                        Ich hab immer wieder Probleme
                                        Adapter wir immer wieder gelb auch nach update auf Installierte Version:
                                        2.6.5
                                        api ist aktiviert
                                        Please activate Nuki Web API to retrieve log entries!
                                          legro @Horst Böttcher last edited by
                                          @horst-böttcher
                                          Ist bei mir seit über einem Jahr auch so. Adapter neu starten, danach funktioniert's wieder eine Weile. Ich hab's aufgegeben, dagegen etwas zu unternehmen, solange es denn funktioniert.😞
                                          • Horst Böttcher
                                            Horst Böttcher @legro last edited by
                                            @legro das ist echt schade
                                            31.7k
                                            79.8k
                                            nuki nuki-extended adapter
                                            65
                                            599
                                            110320
