    4. admin hat falsche Version
      Thomas Braun Most Active @Rette70 last edited by
      @rette70
      Wie bist du da im Moment unterwegs?
      iobroker update -i
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      mal bekannt geben.
      Rette70 1 Reply Last reply Reply Quote 0
      • Rette70
        Rette70 @Thomas Braun last edited by
        @thomas-braun momentan Admin Version 5.3.8
          @rette70
          Nix nacherzählen, Rückgaben in der Konsole zu obigen Kommandos sind gefragt. In CodeTags eingebettet, nicht als Screenshot.
          • Rette70
            @thomas-braun wie bekomme ich die aus der Konsole rauskopiert
            <aarch64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.15.1
            v16.15.1
            8.11.0
            pi>
            <iobroker update -i
            Used repository: stable
            Adapter "admin" : 5.3.8 , installed 5.3.8
            Adapter "alexa2" : 3.11.2 , installed 3.11.2
            Adapter "backitup" : 2.4.9 , installed 2.4.9
            Adapter "cloud" : 4.1.1 , installed 4.1.1
            Adapter "daswetter" : 3.1.2 , installed 3.1.2
            Adapter "devices" : 1.0.12 , installed 1.0.12
            Adapter "discovery" : 3.0.3 , installed 3.0.3
            Adapter "dwd" : 2.8.3 , installed 2.8.3
            Adapter "fb-checkpresence": 1.1.14, installed 1.1.14
            Adapter "history" : 1.11.1 , installed 1.11.1
            Adapter "hue-extended" : 2.0.0 , installed 2.0.0
            Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
            Adapter "icons-material-png": 0.1.0, installed 0.1.0
            Adapter "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
            Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
            Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
            Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
            Adapter "influxdb" : 2.6.3 , installed 2.6.3
            Adapter "info" : 1.9.19 , installed 1.9.19
            Adapter "iot" : 1.11.4 , installed 1.11.4
            Adapter "iqontrol" : 2.0.0 , installed 2.0.0
            Adapter "javascript" : 5.7.0 , installed 5.7.0
            Controller "js-controller": 4.0.23 , installed 4.0.23
            Adapter "material" : 1.1.2 , installed 1.1.2
            Adapter "mobile" : 1.0.1 , installed 1.0.1
            Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
            Adapter "nina" : 0.0.25 , installed 0.0.25
            Adapter "onvif" : 0.4.4 , installed 0.4.4
            Adapter "openweathermap": 0.2.4 , installed 0.2.4
            Adapter "ping" : 1.5.3 , installed 1.5.3
            Adapter "pushover" : 2.1.0 , installed 2.1.0
            Adapter "rpi2" : 1.3.2 , installed 1.3.2
            Adapter "shelly" : 5.3.2 , installed 5.3.2
            Adapter "siegenia" : 1.1.1 , installed 1.1.1
            Adapter "simple-api" : 2.7.0 , installed 2.7.0
            Adapter "smartgarden" : 2.0.0 , installed 2.0.0
            Adapter "socketio" : 4.2.0 , installed 4.2.0
            Adapter "statistics" : 2.1.1 , installed 2.1.1
            Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
            Adapter "telegram" : 1.13.0 , installed 1.13.0
            Adapter "text2command" : 2.2.1 , installed 2.2.1
            Adapter "tr-064" : 4.2.16 , installed 4.2.16
            Adapter "tuya" : 3.6.15 , installed 3.6.15
            Adapter "upnp" : 1.0.21 , installed 1.0.21
            Adapter "vis" : 1.4.15 , installed 1.4.15
            Adapter "vis-bars" : 0.1.4 , installed 0.1.4
            Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
            Adapter "vis-history" : 1.0.0 , installed 1.0.0
            Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0
            Adapter "vis-icontwo" : 0.87.0 , installed 0.87.0
            Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
            Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
            Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter "vis-metro" : 1.2.0 , installed 1.2.0
            Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
            Adapter "vis-timeandweather": 1.1.7, installed 1.1.7
            Adapter "vis-weather" : 2.5.5 , installed 2.5.5
            Adapter "web" : 4.3.0 , installed 4.3.0
            Adapter "ws" : 1.3.0 , installed 1.3.0>
            crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
              crunchip Forum Testing Most Active @Rette70 last edited by crunchip
              @rette70 sagte in admin hat falsche Version:
              passt doch
              erbunden mit Host fehlt und Lebenszeichen
              logausgabe?
                @rette70
                Schmeiß mal ein
                iobroker upload all
                hinterher. Im Grunde ist das alles korrekt.
                • Rette70
                  Die Meldung kommt immer.
                  host.IoBroker-Master
                  2022-07-04 18:20:51.310 Error startInstance system.adapter.smartgarden.0 Adapterabhängigkeit auf keinem Host erfüllt: erforderlicher Adapter "admin" hat falsche Version. Installiert "5.3.1", erforderlich ">=5.3.2"!
                    @rette70
                    iobroker upload all
                    ausgeführt? Ist das ein Multihost-System da?
                    • Rette70
                      @thomas-braun ja, ist Multihost. Jetzt spielt der Wetteradapter auch noch verrückt.
                      ich führe das dort dann auch noch mal aus..
                      muss ich morgen machen. muss erstmal los. Vielen Dank erstmal.
                      • Rette70
                        Rette70 @Rette70 last edited by
                        @rette70 hatte es nicht hinbekommen. Versuche grad nochmal ein Backup von ner ältere Version. Der Smardgardenadapter wurde erstmal grün. Wenns klappt update ich dann nach und nach.
                        Hab gestern mehrmals versucht das ganze System nochmal neu aufzuspielen. Habs mit den Raspiimager geflasht und auch vorher SSh usw. eingetragen. Ich komme da nicht rauf.
                        Die Desktopvariante ging nach dem update auch nicht. OS hatte ich 64 bit ausgewählt.
                        Meine alte SD konnte ich jetzt bei hochfahren des Raspis an einem Monitor sehen. Fehlermeldung altes System SD.jpeg
                        Wie kann ich die wieder reparieren?
                        Hatte die Vermutung das mein USB Stick auch fehlerhaft ist.
                        Hat dazu jemand eine Idee?
                        Vielen Dank
                          Vermutlich gar nicht.
                          • Rette70
                            @thomas-braun Ich habe noch ein Ubuntu-system, bringt die Funktion Dateisystem reparieren was?
                              @rette70
                              Das scheit die boot-Partition zu sein, die ist oft FAT formatiert.
                              Aber angeschossene Dateisysteme kannst du sinnvoll nur noch backuppen und versuchen da später was draus zu lesen. Dateiträger kannst du entsorgen, dem vertraut man keine Daten mehr an.
                              Da es sich hier um die Boot-Partition handelt sind da aber keine nennenswerten Daten drauf.
                              • Rette70
                                @rette70 said in admin hat falsche Version:
                                Hallo, es kommt immer diese Meldung. Obwohl ich den Admin Adapter in Version 5.3.8 habe.. Hab mit den Smartgarden Adapter schon versucht wieder eine Version unter 2.0 zu nehmen, geht auch nicht. Bin ratlos. Und in Google find ich auch nix. Vielleicht kann mir hier jemand helfen.
                                Es hatte auch schon mal geklappt, aber nach irgendein update ging es nicht mehr.
                                Habs aber nicht gleich mitbekommen. Verbunden mit Host fehlt und Lebenszeichen. Mit Gerät oder Dienst geht es.
                                ********"startInstance system.adapter.smartgarden.0 Adapterabhängigkeit auf keinem Host erfüllt: erforderlicher Adapter "admin" hat falsche Version. Installiert "5.3.1", erforderlich ">=5.3.2"!
                                • Rette70
                                  Das gleiche Problem besteht immer noch.
                                  jemand eine idee
                                  2022-09-18 19:44:39.025 error startInstance system.adapter.shelly.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=5.3.3"!
                                  Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                    @rette70
                                    Frisches Basissystem?
                                    iobroker update
                                    sagt?
                                      Homoran Global Moderator Administrators @Rette70 last edited by
                                      hast du Multihost?
                                        @rette70
                                        Von beiden Systemen, wenn das ein Multihostsetup sein sollte.
                                        • Rette70
                                          @thomas-braun apt policy nodejs
                                          nodejs:
                                          Installed: 16.17.0-deb-1nodesource1
                                          Candidate: 16.17.0-deb-1nodesource1
                                          Version table:
                                          *** 16.17.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                          100 /var/lib/dpkg/status
                                          12.22.12~dfsg-1~deb11u1 500
                                          500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
                                          12.22.5~dfsg-2~11u1 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                          • Rette70
                                            Rette70 @Rette70 last edited by Homoran
                                            @rette70
                                            iobroker update
                                            Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                            Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                                            Adapter    "cloud"        : 4.2.2    , installed 4.1.1  [Updatable]
                                            Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                                            Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
                                            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                            Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
                                            Adapter    "history"      : 2.2.0    , installed 2.1.7  [Updatable]
                                            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                            Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
                                            Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
                                            Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                                            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                            Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
                                            Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                            Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
                                            Adapter    "smartgarden"  : 2.0.0    , installed 1.0.6  [Updatable]
                                            Adapter    "statistics"   : 2.2.0    , installed 2.1.1  [Updatable]
                                            Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                            Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                            Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
                                            admin falsche version smartgarden
                                            1516
