    4. admin hat falsche Version
    • Rette70
      Rette70 @Thomas Braun last edited by
      @thomas-braun wie bekomme ich die aus der Konsole rauskopiert
      <aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.15.1
      v16.15.1
      8.11.0
      pi>
      <iobroker update -i
      Used repository: stable
      Adapter "admin" : 5.3.8 , installed 5.3.8
      Adapter "alexa2" : 3.11.2 , installed 3.11.2
      Adapter "backitup" : 2.4.9 , installed 2.4.9
      Adapter "cloud" : 4.1.1 , installed 4.1.1
      Adapter "daswetter" : 3.1.2 , installed 3.1.2
      Adapter "devices" : 1.0.12 , installed 1.0.12
      Adapter "discovery" : 3.0.3 , installed 3.0.3
      Adapter "dwd" : 2.8.3 , installed 2.8.3
      Adapter "fb-checkpresence": 1.1.14, installed 1.1.14
      Adapter "history" : 1.11.1 , installed 1.11.1
      Adapter "hue-extended" : 2.0.0 , installed 2.0.0
      Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
      Adapter "icons-material-png": 0.1.0, installed 0.1.0
      Adapter "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
      Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
      Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter "influxdb" : 2.6.3 , installed 2.6.3
      Adapter "info" : 1.9.19 , installed 1.9.19
      Adapter "iot" : 1.11.4 , installed 1.11.4
      Adapter "iqontrol" : 2.0.0 , installed 2.0.0
      Adapter "javascript" : 5.7.0 , installed 5.7.0
      Controller "js-controller": 4.0.23 , installed 4.0.23
      Adapter "material" : 1.1.2 , installed 1.1.2
      Adapter "mobile" : 1.0.1 , installed 1.0.1
      Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1
      Adapter "nina" : 0.0.25 , installed 0.0.25
      Adapter "onvif" : 0.4.4 , installed 0.4.4
      Adapter "openweathermap": 0.2.4 , installed 0.2.4
      Adapter "ping" : 1.5.3 , installed 1.5.3
      Adapter "pushover" : 2.1.0 , installed 2.1.0
      Adapter "rpi2" : 1.3.2 , installed 1.3.2
      Adapter "shelly" : 5.3.2 , installed 5.3.2
      Adapter "siegenia" : 1.1.1 , installed 1.1.1
      Adapter "simple-api" : 2.7.0 , installed 2.7.0
      Adapter "smartgarden" : 2.0.0 , installed 2.0.0
      Adapter "socketio" : 4.2.0 , installed 4.2.0
      Adapter "statistics" : 2.1.1 , installed 2.1.1
      Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1
      Adapter "telegram" : 1.13.0 , installed 1.13.0
      Adapter "text2command" : 2.2.1 , installed 2.2.1
      Adapter "tr-064" : 4.2.16 , installed 4.2.16
      Adapter "tuya" : 3.6.15 , installed 3.6.15
      Adapter "upnp" : 1.0.21 , installed 1.0.21
      Adapter "vis" : 1.4.15 , installed 1.4.15
      Adapter "vis-bars" : 0.1.4 , installed 0.1.4
      Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
      Adapter "vis-history" : 1.0.0 , installed 1.0.0
      Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0
      Adapter "vis-icontwo" : 0.87.0 , installed 0.87.0
      Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
      Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
      Adapter "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter "vis-metro" : 1.2.0 , installed 1.2.0
      Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
      Adapter "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter "vis-weather" : 2.5.5 , installed 2.5.5
      Adapter "web" : 4.3.0 , installed 4.3.0
      Adapter "ws" : 1.3.0 , installed 1.3.0>
      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Rette70 last edited by crunchip
        @rette70 sagte in admin hat falsche Version:
        passt doch
        erbunden mit Host fehlt und Lebenszeichen
        logausgabe?
          Thomas Braun Most Active @Rette70 last edited by
          @rette70
          Schmeiß mal ein
          iobroker upload all
          hinterher. Im Grunde ist das alles korrekt.
          Rette70 1 Reply Last reply Reply Quote 0
          • Rette70
            Die Meldung kommt immer.
            host.IoBroker-Master
            2022-07-04 18:20:51.310 Error startInstance system.adapter.smartgarden.0 Adapterabhängigkeit auf keinem Host erfüllt: erforderlicher Adapter "admin" hat falsche Version. Installiert "5.3.1", erforderlich ">=5.3.2"!
              @rette70
              iobroker upload all
              ausgeführt? Ist das ein Multihost-System da?
              • Rette70
                @thomas-braun ja, ist Multihost. Jetzt spielt der Wetteradapter auch noch verrückt.
                ich führe das dort dann auch noch mal aus..
                muss ich morgen machen. muss erstmal los. Vielen Dank erstmal.
                • Rette70
                  Rette70 @Rette70 last edited by
                  @rette70 hatte es nicht hinbekommen. Versuche grad nochmal ein Backup von ner ältere Version. Der Smardgardenadapter wurde erstmal grün. Wenns klappt update ich dann nach und nach.
                  Hab gestern mehrmals versucht das ganze System nochmal neu aufzuspielen. Habs mit den Raspiimager geflasht und auch vorher SSh usw. eingetragen. Ich komme da nicht rauf.
                  Die Desktopvariante ging nach dem update auch nicht. OS hatte ich 64 bit ausgewählt.
                  Meine alte SD konnte ich jetzt bei hochfahren des Raspis an einem Monitor sehen. Fehlermeldung altes System SD.jpeg
                  Wie kann ich die wieder reparieren?
                  Hatte die Vermutung das mein USB Stick auch fehlerhaft ist.
                  Hat dazu jemand eine Idee?
                  Vielen Dank
                    Vermutlich gar nicht.
                    • Rette70
                      @thomas-braun Ich habe noch ein Ubuntu-system, bringt die Funktion Dateisystem reparieren was?
                        @rette70
                        Das scheit die boot-Partition zu sein, die ist oft FAT formatiert.
                        Aber angeschossene Dateisysteme kannst du sinnvoll nur noch backuppen und versuchen da später was draus zu lesen. Dateiträger kannst du entsorgen, dem vertraut man keine Daten mehr an.
                        Da es sich hier um die Boot-Partition handelt sind da aber keine nennenswerten Daten drauf.
                        • Rette70
                          @rette70 said in admin hat falsche Version:
                          Hallo, es kommt immer diese Meldung. Obwohl ich den Admin Adapter in Version 5.3.8 habe.. Hab mit den Smartgarden Adapter schon versucht wieder eine Version unter 2.0 zu nehmen, geht auch nicht. Bin ratlos. Und in Google find ich auch nix. Vielleicht kann mir hier jemand helfen.
                          Es hatte auch schon mal geklappt, aber nach irgendein update ging es nicht mehr.
                          Habs aber nicht gleich mitbekommen. Verbunden mit Host fehlt und Lebenszeichen. Mit Gerät oder Dienst geht es.
                          ********"startInstance system.adapter.smartgarden.0 Adapterabhängigkeit auf keinem Host erfüllt: erforderlicher Adapter "admin" hat falsche Version. Installiert "5.3.1", erforderlich ">=5.3.2"!
                          • Rette70
                            Das gleiche Problem besteht immer noch.
                            jemand eine idee
                            2022-09-18 19:44:39.025 error startInstance system.adapter.shelly.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.1", required ">=5.3.3"!
                            Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                              @rette70
                              Frisches Basissystem?
                              iobroker update
                              sagt?
                                Homoran Global Moderator Administrators @Rette70 last edited by
                                hast du Multihost?
                                  @rette70
                                  Von beiden Systemen, wenn das ein Multihostsetup sein sollte.
                                  • Rette70
                                    @thomas-braun apt policy nodejs
                                    nodejs:
                                    Installed: 16.17.0-deb-1nodesource1
                                    Candidate: 16.17.0-deb-1nodesource1
                                    Version table:
                                    *** 16.17.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                    12.22.12~dfsg-1~deb11u1 500
                                    500 http://security.debian.org/debian-security bullseye-security/main ar m64 Packages
                                    12.22.5~dfsg-2~11u1 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                    • Rette70
                                      Rette70 @Rette70 last edited by Homoran
                                      @rette70
                                      iobroker update
                                      Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                      Adapter    "backitup"     : 2.4.10   , installed 2.4.10
                                      Adapter    "cloud"        : 4.2.2    , installed 4.1.1  [Updatable]
                                      Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
                                      Adapter    "deconz"       : 1.3.21   , installed 1.3.20 [Updatable]
                                      Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                      Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
                                      Adapter    "history"      : 2.2.0    , installed 2.1.7  [Updatable]
                                      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                      Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
                                      Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
                                      Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                                      Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                      Adapter    "pushover"     : 3.0.3    , installed 2.1.0  [Updatable]
                                      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.1
                                      Adapter    "smartgarden"  : 2.0.0    , installed 1.0.6  [Updatable]
                                      Adapter    "statistics"   : 2.2.0    , installed 2.1.1  [Updatable]
                                      Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
                                      Adapter    "text2command" : 2.2.2    , installed 2.2.2
                                      Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
                                      • Rette70
                                        Rette70 @Homoran last edited by
                                        @homoran ja hab multihost
                                        • Rette70
                                          @rette70
                                          pi@IoBroker-Slave:~ $ iobroker update
                                          Adapter    "admin"        : 6.2.22   , installed 5.3.8  [Updatable]
                                          Adapter    "backitup"     : 2.4.10   , installed 2.4.9  [Updatable]
                                          Adapter    "discovery"    : 3.0.5    , installed 2.7.0  [Updatable]
                                          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.33 [Updatable]
                                          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.11 [Updatable]
                                          Adapter    "homekit-controller": 0.5.1, installed 0.3.3 [Updatable]
                                          Adapter    "info"         : 1.9.19   , installed 1.9.8  [Updatable]
                                          Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
                                          Adapter    "parcel"       : 0.0.20   , installed 0.0.12 [Updatable]
                                          Adapter    "wireguard"    : 1.3.1    , installed 1.2.1  [Updatable]
                                          Thomas Braun Rette70 2 Replies Last reply Reply Quote 0
                                            @rette70
                                            Auf dem Slave:
                                            iobroker upgrade all
                                            Danach das gleiche auf dem Master
                                            admin falsche version smartgarden
                                            1516
